[Swift-commit] cog r3813
swift at ci.uchicago.edu
Wed Oct 23 11:40:03 CDT 2013
r3813 | jmwozniak | 2013-10-23 11:39:38 -0500 (Wed, 23 Oct 2013) | 2 lines
Drop auto-generated files
Index: modules/provider-coaster-c-client/configure
--- modules/provider-coaster-c-client/configure (revision 3812)
+++ modules/provider-coaster-c-client/configure (working copy)
@@ -1,9 +1,11 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for coaster-c-client 1.0.
+# Generated by GNU Autoconf 2.68 for coaster-c-client 1.0.
-# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
+# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
+# 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010 Free Software
+# Foundation, Inc.
# This configure script is free software; the Free Software Foundation
@@ -132,31 +134,6 @@
# CDPATH.
(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# Use a proper internal environment variable to ensure we don't fall
- # into an infinite loop, continuously re-executing ourselves.
- if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
- _as_can_reexec=no; export _as_can_reexec;
- # We cannot yet assume a decent shell, so we have to provide a
-# neutralization value for shells without unset; and this also
-# works around shells that cannot unset nonexistent variables.
-# Preserve -v and -x to the replacement shell.
-BASH_ENV=/dev/null
-ENV=/dev/null
-(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
-case $- in # ((((
- *v*x* | *x*v* ) as_opts=-vx ;;
- *v* ) as_opts=-v ;;
- *x* ) as_opts=-x ;;
- * ) as_opts= ;;
-esac
-exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
-# Admittedly, this is quite paranoid, since all the known shells bail
-# out after a failed `exec'.
-$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
-as_fn_exit 255
- fi
- # We don't want this to propagate to other subprocesses.
- { _as_can_reexec=; unset _as_can_reexec;}
if test "x$CONFIG_SHELL" = x; then
as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
emulate sh
@@ -190,8 +167,7 @@
else
exitcode=1; echo positional parameters were not saved.
fi
-test x\$exitcode = x0 || exit 1
-test -x / || exit 1"
+test x\$exitcode = x0 || exit 1"
as_suggested=" as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
@@ -244,25 +220,21 @@
if test "x$CONFIG_SHELL" != x; then :
- export CONFIG_SHELL
-BASH_ENV=/dev/null
-ENV=/dev/null
-case $- in # ((((
- * ) as_opts= ;;
-esac
-exit 255
+ # We cannot yet assume a decent shell, so we have to provide a
+ # neutralization value for shells without unset; and this also
+ # works around shells that cannot unset nonexistent variables.
+ # Preserve -v and -x to the replacement shell.
+ BASH_ENV=/dev/null
+ ENV=/dev/null
+ (unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
+ export CONFIG_SHELL
+ case $- in # ((((
+ *v*x* | *x*v* ) as_opts=-vx ;;
+ *v* ) as_opts=-v ;;
+ *x* ) as_opts=-x ;;
+ * ) as_opts= ;;
+ esac
+ exec "$CONFIG_SHELL" $as_opts "$as_myself" ${1+"$@"}
fi
if test x$as_have_required = xno; then :
@@ -364,14 +336,6 @@
} # as_fn_mkdir_p
-# as_fn_executable_p FILE
-# Test if FILE is an executable regular file.
-as_fn_executable_p ()
- test -f "$1" && test -x "$1"
-} # as_fn_executable_p
# as_fn_append VAR VALUE
# Append the text in VALUE to the end of the definition contained in VAR. Take
@@ -493,10 +457,6 @@
chmod +x "$as_me.lineno" ||
{ $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
- # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
- # already done that, so ensure we don't try to do so again and fall
- # in an infinite loop. This has already happened in practice.
# Don't try to exec as it changes $[0], causing all sort of problems
# (the dirname of $[0] is not the place where we might find the
# original and so on. Autoconf is especially sensitive to this).
@@ -531,16 +491,16 @@
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -pR'.
+ # In both cases, we have to default to `cp -p'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
@@ -552,8 +512,28 @@
as_mkdir_p=false
fi
-as_test_x='test -x'
-as_executable_p=as_fn_executable_p
+if test -x / >/dev/null 2>&1; then
+ as_test_x='test -x'
+else
+ if ls -dL / >/dev/null 2>&1; then
+ as_ls_L_option=L
+ else
+ as_ls_L_option=
+ fi
+ as_test_x='
+ eval sh -c '\''
+ if test -d "$1"; then
+ test -d "$1/.";
+ else
+ case $1 in #(
+ -*)set "./$1";;
+ esac;
+ case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in #((
+ ???[sx]*):;;*)false;;esac;fi
+ '\'' sh
+fi
+as_executable_p=$as_test_x
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -633,6 +613,8 @@
am__EXEEXT_TRUE
LTLIBOBJS
AM_CXXFLAGS
+SWIG_FALSE
+SWIG_TRUE
LIBOBJS
CXXCPP
am__fastdepCXX_FALSE
@@ -761,6 +743,9 @@
with_sysroot
enable_libtool_lock
enable_debug
+with_tcl
+with_tcl_version
+enable_swig
ac_precious_vars='build_alias
host_alias
@@ -1230,6 +1215,8 @@
if test "x$host_alias" != x; then
if test "x$build_alias" = x; then
cross_compiling=maybe
+ $as_echo "$as_me: WARNING: if you wanted to set the --build type, don't use --host.
+ If a cross compiler is detected then cross compile mode will be used" >&2
elif test "x$build_alias" != "x$host_alias"; then
cross_compiling=yes
fi
@@ -1398,11 +1385,14 @@
--enable-static[=PKGS] build static libraries [default=yes]
--enable-fast-install[=PKGS]
optimize for fast installation [default=yes]
- --disable-dependency-tracking speeds up one-time build
- --enable-dependency-tracking do not reject slow dependency extractors
+ --enable-dependency-tracking
+ do not reject slow dependency extractors
+ --disable-dependency-tracking
+ speeds up one-time build
--disable-libtool-lock avoid locking (might break parallel builds)
--enable-debug enable debugging symbols and disable compiler
optimizations (def=no)
+ --enable-swig enable use of SWIG and Tcl support
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
@@ -1412,6 +1402,8 @@
--with-gnu-ld assume the C compiler uses GNU ld [default=no]
--with-sysroot=DIR Search for dependent libraries within DIR
(or the compiler's sysroot if not specified).
+ --with-tcl location of Tcl
+ --with-tcl-version Tcl version: 8.5 or 8.6
Some influential environment variables:
CC C compiler command
@@ -1493,9 +1485,9 @@
if $ac_init_version; then
cat <<\_ACEOF
coaster-c-client configure 1.0
-generated by GNU Autoconf 2.69
+generated by GNU Autoconf 2.68
-Copyright (C) 2012 Free Software Foundation, Inc.
+Copyright (C) 2010 Free Software Foundation, Inc.
gives unlimited permission to copy, distribute and modify it.
_ACEOF
@@ -1571,7 +1563,7 @@
test ! -s conftest.err
} && test -s conftest$ac_exeext && {
test "$cross_compiling" = yes ||
- test -x conftest$ac_exeext
+ $as_test_x conftest$ac_exeext
}; then :
ac_retval=0
else
@@ -1869,7 +1861,7 @@
}; then :
ac_retval=0
else
@@ -2033,7 +2025,7 @@
running configure, to aid debugging if configure makes a mistake.
It was created by coaster-c-client $as_me 1.0, which was
-generated by GNU Autoconf 2.69. Invocation command line was
+generated by GNU Autoconf 2.68. Invocation command line was
$ $0 $@
@@ -2413,7 +2405,7 @@
#AC_CONFIG_HEADERS([config.h])
-am__api_version='1.11'
+am__api_version='1.12'
# Find a good install program. We prefer a C program (faster),
# so one script is as good as another. But avoid the broken or
@@ -2452,7 +2444,7 @@
# by default.
for ac_prog in ginstall scoinst install; do
for ac_exec_ext in '' $ac_executable_extensions; do
- if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
+ if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
if test $ac_prog = install &&
grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
# AIX install. It has an incompatible calling convention.
@@ -2510,9 +2502,6 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether build environment is sane" >&5
$as_echo_n "checking whether build environment is sane... " >&6; }
-# Just in case
-sleep 1
-echo timestamp > conftest.file
# Reject unsafe characters in $srcdir or the absolute working directory
# name. Accept space and tab only in the latter.
am_lf='
@@ -2523,32 +2512,40 @@
esac
case $srcdir in
*[\\\"\#\$\&\'\`$am_lf\ \ ]*)
- as_fn_error $? "unsafe srcdir value: \`$srcdir'" "$LINENO" 5;;
+ as_fn_error $? "unsafe srcdir value: '$srcdir'" "$LINENO" 5;;
esac
-# Do `set' in a subshell so we don't clobber the current shell's
+# Do 'set' in a subshell so we don't clobber the current shell's
# arguments. Must try -L first in case configure is actually a
# symlink; some systems play weird games with the mod time of symlinks
# (eg FreeBSD returns the mod time of the symlink's containing
# directory).
if (
- set X `ls -Lt "$srcdir/configure" conftest.file 2> /dev/null`
- if test "$*" = "X"; then
- # -L didn't work.
- set X `ls -t "$srcdir/configure" conftest.file`
- fi
- rm -f conftest.file
- if test "$*" != "X $srcdir/configure conftest.file" \
- && test "$*" != "X conftest.file $srcdir/configure"; then
+ am_has_slept=no
+ for am_try in 1 2; do
+ echo "timestamp, slept: $am_has_slept" > conftest.file
+ set X `ls -Lt "$srcdir/configure" conftest.file 2> /dev/null`
+ if test "$*" = "X"; then
+ # -L didn't work.
+ set X `ls -t "$srcdir/configure" conftest.file`
+ fi
+ if test "$*" != "X $srcdir/configure conftest.file" \
+ && test "$*" != "X conftest.file $srcdir/configure"; then
- # If neither matched, then we have a broken ls. This can happen
- # if, for instance, CONFIG_SHELL is bash and it inherits a
- # broken ls alias from the environment. This has actually
- # happened. Such a system could not be considered "sane".
- as_fn_error $? "ls -t appears to fail. Make sure there is not a broken
-alias in your environment" "$LINENO" 5
- fi
+ # If neither matched, then we have a broken ls. This can happen
+ # if, for instance, CONFIG_SHELL is bash and it inherits a
+ # broken ls alias from the environment. This has actually
+ # happened. Such a system could not be considered "sane".
+ as_fn_error $? "ls -t appears to fail. Make sure there is not a broken
+ alias in your environment" "$LINENO" 5
+ fi
+ if test "$2" = conftest.file || test $am_try -eq 2; then
+ break
+ fi
+ # Just in case.
+ sleep 1
+ am_has_slept=yes
+ done
then
@@ -2560,6 +2557,16 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
$as_echo "yes" >&6; }
+# If we didn't sleep, we still need to ensure time stamps of config.status and
+# generated files are strictly newer.
+am_sleep_pid=
+if grep 'slept: no' conftest.file >/dev/null 2>&1; then
+ ( sleep 1 ) &
+ am_sleep_pid=$!
+fi
+rm -f conftest.file
test "$program_prefix" != NONE &&
program_transform_name="s&^&$program_prefix&;$program_transform_name"
# Use a double $ so make ignores it.
@@ -2586,8 +2593,8 @@
am_missing_run="$MISSING --run "
else
am_missing_run=
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`missing' script is too old or missing" >&5
-$as_echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
+ { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: 'missing' script is too old or missing" >&5
+$as_echo "$as_me: WARNING: 'missing' script is too old or missing" >&2;}
fi
if test x"${install_sh}" != xset; then
@@ -2599,10 +2606,10 @@
esac
fi
-# Installed binaries are usually stripped using `strip' when the user
-# run `make install-strip'. However `strip' might not be the right
+# Installed binaries are usually stripped using 'strip' when the user
+# run "make install-strip". However 'strip' might not be the right
# tool to use in cross-compilation environments, therefore Automake
-# will honor the `STRIP' environment variable to overrule this program.
+# will honor the 'STRIP' environment variable to overrule this program.
if test "$cross_compiling" != no; then
if test -n "$ac_tool_prefix"; then
# Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
@@ -2621,7 +2628,7 @@
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+ if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
ac_cv_prog_STRIP="${ac_tool_prefix}strip"
$as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
@@ -2661,7 +2668,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_STRIP="strip"
break 2
@@ -2712,7 +2719,7 @@
for ac_prog in mkdir gmkdir; do
- as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext" || continue
+ { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; } || continue
case `"$as_dir/$ac_prog$ac_exec_ext" --version 2>&1` in #(
'mkdir (GNU coreutils) '* | \
'mkdir (coreutils) '* | \
@@ -2741,12 +2748,6 @@
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $MKDIR_P" >&5
$as_echo "$MKDIR_P" >&6; }
-mkdir_p="$MKDIR_P"
-case $mkdir_p in
- */*) mkdir_p="\$(top_builddir)/$mkdir_p" ;;
-esac
for ac_prog in gawk mawk nawk awk
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
@@ -2765,7 +2766,7 @@
IFS=$as_save_IFS
ac_cv_prog_AWK="$ac_prog"
break 2
@@ -2879,6 +2880,12 @@
MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
+# For better backward compatibility. To be removed once Automake 1.9.x
+# dies out for good. For more background, see:
+# <http://lists.gnu.org/archive/html/automake/2012-07/msg00001.html>
+# <http://lists.gnu.org/archive/html/automake/2012-07/msg00014.html>
+mkdir_p='$(MKDIR_P)'
# We need awk for the "check" target. The system "awk" is bad on
# some platforms.
# Always define AMTAR for backward compatibility. Yes, it's still used
@@ -3076,7 +3083,7 @@
_am_result=none
# First try GNU make style include.
echo "include confinc" > confmf
-# Ignore all kinds of additional output from `make'.
+# Ignore all kinds of additional output from 'make'.
case `$am_make -s -f confmf 2> /dev/null` in #(
*the\ am__doit\ target*)
am__include=include
@@ -3142,7 +3149,7 @@
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}gcc"
break 2
@@ -3182,7 +3189,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="gcc"
break 2
@@ -3235,7 +3242,7 @@
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}cc"
break 2
@@ -3276,7 +3283,7 @@
IFS=$as_save_IFS
if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
ac_prog_rejected=yes
continue
@@ -3334,7 +3341,7 @@
IFS=$as_save_IFS
ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
break 2
@@ -3378,7 +3385,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="$ac_prog"
break 2
@@ -3824,7 +3831,8 @@
/* end confdefs.h. */
#include <stdarg.h>
#include <stdio.h>
-struct stat;
+#include <sys/types.h>
+#include <sys/stat.h>
/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
struct buf { int x; };
FILE * (*rcsopen) (struct buf *, struct stat *, int);
@@ -3920,8 +3928,8 @@
# We make a subdir and do the tests there. Otherwise we can end up
# making bogus files that we don't know about and never remove. For
# instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
+ # making a dummy file named 'D' -- because '-MD' means "put the output
+ # in D".
rm -rf conftest.dir
mkdir conftest.dir
# Copy depcomp to subdir because otherwise we won't find it if we're
@@ -3956,16 +3964,16 @@
: > sub/conftest.c
for i in 1 2 3 4 5 6; do
echo '#include "conftst'$i'.h"' >> sub/conftest.c
- # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
- # Solaris 8's {/usr,}/bin/sh.
- touch sub/conftst$i.h
+ # Using ": > sub/conftst$i.h" creates only sub/conftst1.h with
+ # Solaris 10 /bin/sh.
+ echo '/* dummy */' > sub/conftst$i.h
done
echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
+ # We check with '-c' and '-o' for the sake of the "dashmstdout"
# mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this. Also, some Intel
- # versions had trouble with output in subdirs
+ # handle '-M -o', and we need to detect this. Also, some Intel
+ # versions had trouble with output in subdirs.
am__obj=sub/conftest.${OBJEXT-o}
am__minus_obj="-o $am__obj"
case $depmode in
@@ -3974,8 +3982,8 @@
test "$am__universal" = false || continue
nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
+ # After this tag, mechanisms are not by side-effect, so they'll
+ # only be used when explicitly requested.
if test "x$enable_dependency_tracking" = xyes; then
continue
else
@@ -3983,7 +3991,7 @@
fi
msvc7 | msvc7msys | msvisualcpp | msvcmsys)
- # This compiler won't grok `-c -o', but also, the minuso test has
+ # This compiler won't grok '-c -o', but also, the minuso test has
# not run yet. These depmodes are late enough in the game, and
# so weak that their functioning should not be impacted.
am__obj=conftest.${OBJEXT-o}
@@ -4059,7 +4067,7 @@
for ac_prog in sed gsed; do
ac_path_SED="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_SED" || continue
+ { test -f "$ac_path_SED" && $as_test_x "$ac_path_SED"; } || continue
# Check for GNU ac_path_SED and select it if it is found.
# Check for GNU $ac_path_SED
case `"$ac_path_SED" --version 2>&1` in
@@ -4135,7 +4143,7 @@
for ac_prog in grep ggrep; do
ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_GREP" || continue
+ { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
# Check for GNU ac_path_GREP and select it if it is found.
# Check for GNU $ac_path_GREP
case `"$ac_path_GREP" --version 2>&1` in
@@ -4201,7 +4209,7 @@
for ac_prog in egrep; do
ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_EGREP" || continue
+ { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
# Check for GNU ac_path_EGREP and select it if it is found.
# Check for GNU $ac_path_EGREP
case `"$ac_path_EGREP" --version 2>&1` in
@@ -4268,7 +4276,7 @@
for ac_prog in fgrep; do
ac_path_FGREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_FGREP" || continue
+ { test -f "$ac_path_FGREP" && $as_test_x "$ac_path_FGREP"; } || continue
# Check for GNU ac_path_FGREP and select it if it is found.
# Check for GNU $ac_path_FGREP
case `"$ac_path_FGREP" --version 2>&1` in
@@ -4524,7 +4532,7 @@
IFS=$as_save_IFS
ac_cv_prog_DUMPBIN="$ac_tool_prefix$ac_prog"
break 2
@@ -4568,7 +4576,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_DUMPBIN="$ac_prog"
break 2
@@ -4992,7 +5000,7 @@
IFS=$as_save_IFS
ac_cv_prog_OBJDUMP="${ac_tool_prefix}objdump"
break 2
@@ -5032,7 +5040,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_OBJDUMP="objdump"
break 2
@@ -5204,7 +5212,7 @@
lt_cv_deplibs_check_method=pass_all
-netbsd* | netbsdelf*-gnu)
+netbsd*)
if echo __ELF__ | $CC -E - | $GREP __ELF__ > /dev/null; then
lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
else
@@ -5338,7 +5346,7 @@
IFS=$as_save_IFS
ac_cv_prog_DLLTOOL="${ac_tool_prefix}dlltool"
break 2
@@ -5378,7 +5386,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_DLLTOOL="dlltool"
break 2
@@ -5482,7 +5490,7 @@
IFS=$as_save_IFS
ac_cv_prog_AR="$ac_tool_prefix$ac_prog"
break 2
@@ -5526,7 +5534,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_AR="$ac_prog"
break 2
@@ -5651,7 +5659,7 @@
IFS=$as_save_IFS
break 2
@@ -5691,7 +5699,7 @@
IFS=$as_save_IFS
break 2
@@ -5750,7 +5758,7 @@
IFS=$as_save_IFS
ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
break 2
@@ -5790,7 +5798,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_RANLIB="ranlib"
break 2
@@ -6439,7 +6447,7 @@
IFS=$as_save_IFS
ac_cv_prog_MANIFEST_TOOL="${ac_tool_prefix}mt"
break 2
@@ -6479,7 +6487,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_MANIFEST_TOOL="mt"
break 2
@@ -6559,7 +6567,7 @@
IFS=$as_save_IFS
ac_cv_prog_DSYMUTIL="${ac_tool_prefix}dsymutil"
break 2
@@ -6599,7 +6607,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_DSYMUTIL="dsymutil"
break 2
@@ -6651,7 +6659,7 @@
IFS=$as_save_IFS
ac_cv_prog_NMEDIT="${ac_tool_prefix}nmedit"
break 2
@@ -6691,7 +6699,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_NMEDIT="nmedit"
break 2
@@ -6743,7 +6751,7 @@
IFS=$as_save_IFS
ac_cv_prog_LIPO="${ac_tool_prefix}lipo"
break 2
@@ -6783,7 +6791,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_LIPO="lipo"
break 2
@@ -6835,7 +6843,7 @@
IFS=$as_save_IFS
ac_cv_prog_OTOOL="${ac_tool_prefix}otool"
break 2
@@ -6875,7 +6883,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_OTOOL="otool"
break 2
@@ -6927,7 +6935,7 @@
IFS=$as_save_IFS
ac_cv_prog_OTOOL64="${ac_tool_prefix}otool64"
break 2
@@ -6967,7 +6975,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_OTOOL64="otool64"
break 2
@@ -8601,9 +8609,6 @@
openbsd*)
with_gnu_ld=no
- linux* | k*bsd*-gnu | gnu*)
- link_all_deplibs=no
esac
ld_shlibs=yes
@@ -8825,7 +8830,7 @@
fi
- netbsd* | netbsdelf*-gnu)
+ netbsd*)
if echo __ELF__ | $CC -E - | $GREP __ELF__ >/dev/null; then
archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
wlarc=
@@ -9002,7 +9007,6 @@
if test "$aix_use_runtimelinking" = yes; then
shared_flag="$shared_flag "'${wl}-G'
fi
else
# not using gcc
if test "$host_cpu" = ia64; then
@@ -9456,7 +9460,7 @@
link_all_deplibs=yes
+ netbsd*)
archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
else
@@ -10484,18 +10488,6 @@
dynamic_linker='GNU/Linux ld.so'
-netbsdelf*-gnu)
- version_type=linux
- need_lib_prefix=no
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- soname_spec='${libname}${release}${shared_ext}$major'
- shlibpath_var=LD_LIBRARY_PATH
- shlibpath_overrides_runpath=no
- hardcode_into_libs=yes
- dynamic_linker='NetBSD ld.elf_so'
netbsd*)
version_type=sunos
need_lib_prefix=no
@@ -11494,7 +11486,7 @@
IFS=$as_save_IFS
ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
break 2
@@ -11538,7 +11530,7 @@
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CXX="$ac_prog"
break 2
@@ -11734,8 +11726,8 @@
- # in D'.
+ # in D".
rm -rf conftest.dir
mkdir conftest.dir
@@ -11770,16 +11762,16 @@
: > sub/conftest.c
done
case $depmode in
@@ -11788,8 +11780,8 @@
nosideeffect)
continue
else
@@ -11797,7 +11789,7 @@
fi
@@ -13749,7 +13741,7 @@
esac
+ netbsd*)
*qnx* | *nto*)
# QNX uses GNU C++, but need to define -shared option too, otherwise
@@ -14120,9 +14112,6 @@
esac
- link_all_deplibs_CXX=no
export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
@@ -14748,18 +14737,6 @@
-netbsdelf*-gnu)
- need_version=no
netbsd*)
version_type=sunos
need_lib_prefix=no
@@ -15097,7 +15074,7 @@
IFS=$as_save_IFS
break 2
@@ -15141,7 +15118,7 @@
IFS=$as_save_IFS
break 2
@@ -15337,8 +15314,8 @@
- # in D'.
+ # in D".
rm -rf conftest.dir
mkdir conftest.dir
@@ -15373,16 +15350,16 @@
: > sub/conftest.c
done
case $depmode in
@@ -15391,8 +15368,8 @@
nosideeffect)
continue
else
@@ -15400,7 +15377,7 @@
fi
@@ -15476,7 +15453,7 @@
IFS=$as_save_IFS
break 2
@@ -15516,7 +15493,7 @@
IFS=$as_save_IFS
break 2
@@ -15569,7 +15546,7 @@
IFS=$as_save_IFS
break 2
@@ -15610,7 +15587,7 @@
IFS=$as_save_IFS
continue
@@ -15668,7 +15645,7 @@
IFS=$as_save_IFS
break 2
@@ -15712,7 +15689,7 @@
IFS=$as_save_IFS
break 2
@@ -15908,7 +15885,8 @@
#include <stdarg.h>
#include <stdio.h>
-struct stat;
@@ -16004,8 +15982,8 @@
- # in D'.
+ # in D".
rm -rf conftest.dir
mkdir conftest.dir
@@ -16040,16 +16018,16 @@
: > sub/conftest.c
done
case $depmode in
@@ -16058,8 +16036,8 @@
nosideeffect)
continue
else
@@ -16067,7 +16045,7 @@
fi
@@ -16318,7 +16296,7 @@
IFS=$as_save_IFS
break 2
@@ -16358,7 +16336,7 @@
IFS=$as_save_IFS
break 2
@@ -16467,60 +16445,60 @@
cat confdefs.h - <<_ACEOF >conftest.$ac_ext
- #include <stdbool.h>
- #ifndef bool
- "error: bool is not defined"
- #endif
- #ifndef false
- "error: false is not defined"
- #endif
- #if false
- "error: false is not 0"
- #endif
- #ifndef true
- "error: true is not defined"
- #endif
- #if true != 1
- "error: true is not 1"
- #endif
- #ifndef __bool_true_false_are_defined
- "error: __bool_true_false_are_defined is not defined"
- #endif
+#include <stdbool.h>
+#ifndef bool
+ "error: bool is not defined"
+#endif
+#ifndef false
+ "error: false is not defined"
+#endif
+#if false
+ "error: false is not 0"
+#endif
+#ifndef true
+ "error: true is not defined"
+#endif
+#if true != 1
+ "error: true is not 1"
+#endif
+#ifndef __bool_true_false_are_defined
+ "error: __bool_true_false_are_defined is not defined"
+#endif
- struct s { _Bool s: 1; _Bool t; } s;
+ struct s { _Bool s: 1; _Bool t; } s;
- char a[true == 1 ? 1 : -1];
- char b[false == 0 ? 1 : -1];
- char c[__bool_true_false_are_defined == 1 ? 1 : -1];
- char d[(bool) 0.5 == true ? 1 : -1];
- /* See body of main program for 'e'. */
- char f[(_Bool) 0.0 == false ? 1 : -1];
- char g[true];
- char h[sizeof (_Bool)];
- char i[sizeof s.t];
- enum { j = false, k = true, l = false * true, m = true * 256 };
- /* The following fails for
- HP aC++/ANSI C B3910B A.05.55 [Dec 04 2003]. */
- _Bool n[m];
- char o[sizeof n == m * sizeof n[0] ? 1 : -1];
- char p[-1 - (_Bool) 0 < 0 && -1 - (bool) 0 < 0 ? 1 : -1];
- /* Catch a bug in an HP-UX C compiler. See
- http://gcc.gnu.org/ml/gcc-patches/2003-12/msg02303.html
- http://lists.gnu.org/archive/html/bug-coreutils/2005-11/msg00161.html
- _Bool q = true;
- _Bool *pq = &q;
+ char a[true == 1 ? 1 : -1];
+ char b[false == 0 ? 1 : -1];
+ char c[__bool_true_false_are_defined == 1 ? 1 : -1];
+ char d[(bool) 0.5 == true ? 1 : -1];
+ /* See body of main program for 'e'. */
+ char f[(_Bool) 0.0 == false ? 1 : -1];
+ char g[true];
+ char h[sizeof (_Bool)];
+ char i[sizeof s.t];
+ enum { j = false, k = true, l = false * true, m = true * 256 };
+ /* The following fails for
+ HP aC++/ANSI C B3910B A.05.55 [Dec 04 2003]. */
+ _Bool n[m];
+ char o[sizeof n == m * sizeof n[0] ? 1 : -1];
+ char p[-1 - (_Bool) 0 < 0 && -1 - (bool) 0 < 0 ? 1 : -1];
+ /* Catch a bug in an HP-UX C compiler. See
+ http://gcc.gnu.org/ml/gcc-patches/2003-12/msg02303.html
+ http://lists.gnu.org/archive/html/bug-coreutils/2005-11/msg00161.html
+ _Bool q = true;
+ _Bool *pq = &q;
int
main ()
- bool e = &s;
- *pq |= q;
- *pq |= ! q;
- /* Refer to every declared value, to avoid compiler optimizations. */
- return (!a + !b + !c + !d + !e + !f + !g + !h + !i + !!j + !k + !!l
- + !m + !n + !o + !p + !q + !pq);
+ bool e = &s;
+ *pq |= q;
+ *pq |= ! q;
+ /* Refer to every declared value, to avoid compiler optimizations. */
+ return (!a + !b + !c + !d + !e + !f + !g + !h + !i + !!j + !k + !!l
+ + !m + !n + !o + !p + !q + !pq);
return 0;
@@ -16535,7 +16513,7 @@
fi
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdbool_h" >&5
$as_echo "$ac_cv_header_stdbool_h" >&6; }
- ac_fn_c_check_type "$LINENO" "_Bool" "ac_cv_type__Bool" "$ac_includes_default"
+ac_fn_c_check_type "$LINENO" "_Bool" "ac_cv_type__Bool" "$ac_includes_default"
if test "x$ac_cv_type__Bool" = xyes; then :
cat >>confdefs.h <<_ACEOF
@@ -16545,7 +16523,6 @@
fi
if test $ac_cv_header_stdbool_h = yes; then
$as_echo "#define HAVE_STDBOOL_H 1" >>confdefs.h
@@ -16671,8 +16648,122 @@
AM_CXXFLAGS="-O2"
fi
+USE_TCL=0
+# Check whether --with-tcl was given.
+if test "${with_tcl+set}" = set; then :
+ withval=$with_tcl;
+ USE_TCL=$withval
+ CPPFLAGS="${CPPFLAGS} -I ${USE_TCL}/include"
+ AM_CXXFLAGS="${AM_CXXFLAGS} -I ${USE_TCL}/include"
+ for ac_header in tcl.h
+do :
+ ac_fn_c_check_header_mongrel "$LINENO" "tcl.h" "ac_cv_header_tcl_h" "$ac_includes_default"
+if test "x$ac_cv_header_tcl_h" = xyes; then :
+ cat >>confdefs.h <<_ACEOF
+#define HAVE_TCL_H 1
+_ACEOF
+fi
+done
+fi
+USE_TCL_VERSION=0
+# Check whether --with-tcl-version was given.
+if test "${with_tcl_version+set}" = set; then :
+ withval=$with_tcl_version;
+ [ ${USE_TCL} == 0 ] && \
+ as_fn_error $? "Use of Tcl requires --with-tcl" "$LINENO" 5
+ USE_TCL_VERSION=$withval
+ LDFLAGS="$LDFLAGS -L$USE_TCL/lib"
+ AM_LDFLAGS="${AM_LDFLAGS} -L$USE_TCL/lib -Wl,-rpath $USE_TCL/lib"
+ # -l tcl$USE_TCL_VERSION
+ as_ac_Lib=`$as_echo "ac_cv_lib_tcl$USE_TCL_VERSION''_Tcl_PkgProvide" | $as_tr_sh`
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for Tcl_PkgProvide in -ltcl$USE_TCL_VERSION" >&5
+$as_echo_n "checking for Tcl_PkgProvide in -ltcl$USE_TCL_VERSION... " >&6; }
+if eval \${$as_ac_Lib+:} false; then :
+ $as_echo_n "(cached) " >&6
+else
+ ac_check_lib_save_LIBS=$LIBS
+LIBS="-ltcl$USE_TCL_VERSION $LIBS"
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h. */
+/* Override any GCC internal prototype to avoid an error.
+ Use char because int might match the return type of a GCC
+ builtin and then its argument prototype would still apply. */
+#ifdef __cplusplus
+extern "C"
+#endif
+char Tcl_PkgProvide ();
+int
+main ()
+return Tcl_PkgProvide ();
+ return 0;
+_ACEOF
+if ac_fn_c_try_link "$LINENO"; then :
+ eval "$as_ac_Lib=yes"
+else
+ eval "$as_ac_Lib=no"
+fi
+rm -f core conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+eval ac_res=\$$as_ac_Lib
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
+$as_echo "$ac_res" >&6; }
+if eval test \"x\$"$as_ac_Lib"\" = x"yes"; then :
+#define `$as_echo "HAVE_LIBtcl$USE_TCL_VERSION" | $as_tr_cpp` 1
+_ACEOF
+ LIBS="-ltcl$USE_TCL_VERSION $LIBS"
+fi
+ ac_fn_c_check_func "$LINENO" "Tcl_PkgProvide" "ac_cv_func_Tcl_PkgProvide"
+if test "x$ac_cv_func_Tcl_PkgProvide" = xyes; then :
+else
+ as_fn_error $? "Could not link to Tcl!" "$LINENO" 5
+fi
+fi
+USE_SWIG=0
+# Check whether --enable-swig was given.
+if test "${enable_swig+set}" = set; then :
+ enableval=$enable_swig;
+ [ $USE_TCL_VERSION == 0 ] && \
+ as_fn_error $? "Use of SWIG requires --with-tcl-version" "$LINENO" 5
+ USE_SWIG=1
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: SWIG enabled." >&5
+$as_echo "SWIG enabled." >&6; }
+fi
+ if test $USE_SWIG = 1; then
+ SWIG_TRUE=
+ SWIG_FALSE='#'
+else
+ SWIG_TRUE='#'
+ SWIG_FALSE=
+fi
ac_config_files="$ac_config_files Makefile"
ac_config_files="$ac_config_files src/Makefile"
@@ -16823,6 +16914,14 @@
LTLIBOBJS=$ac_ltlibobjs
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking that generated files are newer than configure" >&5
+$as_echo_n "checking that generated files are newer than configure... " >&6; }
+ if test -n "$am_sleep_pid"; then
+ # Hide warnings about reused PIDs.
+ wait $am_sleep_pid 2>/dev/null
+ fi
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: done" >&5
+$as_echo "done" >&6; }
if test -n "$EXEEXT"; then
am__EXEEXT_TRUE=
am__EXEEXT_FALSE='#'
@@ -16851,6 +16950,10 @@
as_fn_error $? "conditional \"am__fastdepCC\" was never defined.
Usually this means the macro was only invoked conditionally." "$LINENO" 5
fi
+if test -z "${SWIG_TRUE}" && test -z "${SWIG_FALSE}"; then
+ as_fn_error $? "conditional \"SWIG\" was never defined.
+Usually this means the macro was only invoked conditionally." "$LINENO" 5
+fi
: "${CONFIG_STATUS=./config.status}"
ac_write_fail=0
@@ -17149,16 +17252,16 @@
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
as_ln_s=ln
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
@@ -17218,17 +17321,29 @@
as_mkdir_p=false
fi
+else
+ as_ls_L_option=L
+ else
+ as_ls_L_option=
+ fi
+ as_test_x='
+ eval sh -c '\''
+ test -d "$1/.";
+ else
+ case $1 in #(
+ -*)set "./$1";;
+ esac;
+ '\'' sh
+fi
@@ -17249,7 +17364,7 @@
# values after options handling.
ac_log="
This file was extended by coaster-c-client $as_me 1.0, which was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
@@ -17306,10 +17421,10 @@
ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
coaster-c-client config.status 1.0
-configured by $0, generated by GNU Autoconf 2.69,
+configured by $0, generated by GNU Autoconf 2.68,
with options \\"\$ac_cs_config\\"
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
@@ -17389,7 +17504,7 @@
_ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
if \$ac_cs_recheck; then
- set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+ set X '$SHELL' '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
shift
\$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
CONFIG_SHELL='$SHELL'
@@ -18245,7 +18360,7 @@
# Strip MF so we end up with the name of the file.
mf=`echo "$mf" | sed -e 's/:.*$//'`
# Check whether this is an Automake generated Makefile or not.
- # We used to match only the files named `Makefile.in', but
+ # We used to match only the files named 'Makefile.in', but
# some people rename them; so instead we look at the file content.
# Grep'ing the first line is not enough: some people post-process
# each Makefile.in and add a new line on top of each file to say so.
@@ -18279,21 +18394,19 @@
continue
fi
# Extract the definition of DEPDIR, am__include, and am__quote
- # from the Makefile without running `make'.
+ # from the Makefile without running 'make'.
DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
test -z "$DEPDIR" && continue
am__include=`sed -n 's/^am__include = //p' < "$mf"`
test -z "am__include" && continue
am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
- # When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n 's/^U = //p' < "$mf"`
# Find all dependency output files, they are included files with
# $(DEPDIR) in their names. We invoke sed twice because it is the
# simplest approach to changing $(DEPDIR) to its actual value in the
# expansion.
for file in `sed -n "
s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
- sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
+ sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g'`; do
# Make sure the directory exists.
test -f "$dirpart/$file" && continue
fdir=`$as_dirname -- "$file" ||
Index: modules/provider-coaster-c-client/libtool
--- modules/provider-coaster-c-client/libtool (revision 3812)
+++ modules/provider-coaster-c-client/libtool (working copy)
@@ -2,7 +2,7 @@
# libtool - Provide generalized library-building support services.
# Generated automatically by config.status (coaster-c-client) 1.0
-# Libtool was configured on host blabla:
+# Libtool was configured on host wozniak-laptop-u:
# NOTE: Changes made to this file will be lost: look at ltmain.sh.
# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005,
@@ -66,12 +66,12 @@
# The host system.
host_alias=
-host=i686-pc-linux-gnu
+host=x86_64-unknown-linux-gnu
host_os=linux-gnu
# The build system.
build_alias=
-build=i686-pc-linux-gnu
+build=x86_64-unknown-linux-gnu
build_os=linux-gnu
# A sed program that does not truncate output.
@@ -96,7 +96,7 @@
LN_S="ln -s"
# What is the maximum length of a command?
-max_cmd_len=805306365
+max_cmd_len=1572864
# Object file suffix (normally "o").
objext=o
@@ -272,10 +272,10 @@
# Compile-time system search path for libraries.
-sys_lib_search_path_spec="/usr/lib/gcc/i686-linux-gnu/4.6 /usr/lib/i386-linux-gnu /usr/lib /lib/i386-linux-gnu /lib /opt/intel/composerxe-2011.1.107/compiler/lib/ia32 /opt/intel/composerxe-2011.1.107/mkl/lib/ia32 "
+sys_lib_search_path_spec="/usr/lib/gcc/x86_64-linux-gnu/4.7 /usr/lib/x86_64-linux-gnu /usr/lib /lib/x86_64-linux-gnu /lib "
# Run-time system search path for libraries.
-sys_lib_dlsearch_path_spec="/lib /usr/lib /usr/lib/nvidia-current /lib/i386-linux-gnu /usr/lib/i386-linux-gnu /lib/i686-linux-gnu /usr/lib/i686-linux-gnu /usr/local/lib /usr/lib/nvidia-settings "
+sys_lib_dlsearch_path_spec="/lib /usr/lib /lib/i386-linux-gnu /usr/lib/i386-linux-gnu /lib/i686-linux-gnu /usr/lib/i686-linux-gnu /usr/local/lib /usr/lib/nvidia-settings-310 /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/mesa-egl /usr/lib/nvidia-310 /usr/lib32/nvidia-310 "
# Whether dlopen is supported.
dlopen_support=unknown
@@ -292,7 +292,7 @@
# The linker used to build libraries.
-LD="/usr/bin/ld"
+LD="/usr/bin/ld -m elf_x86_64"
# How to create reloadable object files.
reload_flag=" -r"
@@ -399,7 +399,7 @@
inherit_rpath=no
# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=no
+link_all_deplibs=unknown
# Set to "yes" if exported symbols are required.
always_export_symbols=no
@@ -513,7 +513,7 @@
# compiler: $LTCC
# compiler flags: $LTCFLAGS
# linker: $LD (gnu? $with_gnu_ld)
-# $progname: (GNU libtool) 2.4.2 Debian-2.4.2-1ubuntu1
+# $progname: (GNU libtool) 2.4.2
# automake: $automake_version
# autoconf: $autoconf_version
@@ -523,7 +523,7 @@
PROGRAM=libtool
PACKAGE=libtool
-VERSION="2.4.2 Debian-2.4.2-1ubuntu1"
+VERSION=2.4.2
TIMESTAMP=""
package_revision=1.3337
@@ -6560,10 +6560,7 @@
case $pass in
dlopen) libs="$dlfiles" ;;
dlpreopen) libs="$dlprefiles" ;;
- link)
- libs="$deplibs %DEPLIBS%"
- test "X$link_all_deplibs" != Xno && libs="$libs $dependency_libs"
+ link) libs="$deplibs %DEPLIBS% $dependency_libs" ;;
esac
fi
if test "$linkmode,$pass" = "lib,dlpreopen"; then
@@ -6883,19 +6880,19 @@
# It is a libtool convenience library, so add in its objects.
convenience+=" $ladir/$objdir/$old_library"
old_convenience+=" $ladir/$objdir/$old_library"
- tmp_libs=
- for deplib in $dependency_libs; do
- deplibs="$deplib $deplibs"
- if $opt_preserve_dup_deps ; then
- case "$tmp_libs " in
- *" $deplib "*) specialdeplibs+=" $deplib" ;;
- esac
- fi
- tmp_libs+=" $deplib"
- done
elif test "$linkmode" != prog && test "$linkmode" != lib; then
func_fatal_error "\`$lib' is not a convenience library"
fi
+ tmp_libs=
+ for deplib in $dependency_libs; do
+ deplibs="$deplib $deplibs"
+ if $opt_preserve_dup_deps ; then
+ case "$tmp_libs " in
+ *" $deplib "*) specialdeplibs+=" $deplib" ;;
+ esac
+ fi
+ tmp_libs+=" $deplib"
+ done
continue
fi # $pass = conv
@@ -7788,9 +7785,6 @@
revision="$number_minor"
lt_irix_increment=no
- func_fatal_configuration "$modename: unknown library version type \`$version_type'"
esac
no)
@@ -10099,7 +10093,7 @@
# ### BEGIN LIBTOOL TAG CONFIG: CXX
-LD="/usr/bin/ld"
reload_flag=" -r"
@@ -10203,7 +10197,7 @@
inherit_rpath=no
@@ -10230,17 +10224,17 @@
hardcode_action=immediate
# The directories searched by this compiler when creating a shared library.
-compiler_lib_search_dirs="/usr/lib/gcc/i686-linux-gnu/4.6 /usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu /usr/lib/gcc/i686-linux-gnu/4.6/../../../../lib /lib/i386-linux-gnu /lib/../lib /usr/lib/i386-linux-gnu /usr/lib/../lib /opt/intel/composerxe-2011.1.107/compiler/lib/ia32 /opt/intel/composerxe-2011.1.107/compiler/lib/ia32 /opt/intel/composerxe-2011.1.107/mkl/lib/ia32 /opt/intel/composerxe-2011.1.107/compiler/lib/ia32 /opt/intel/composerxe-2011.1.107/compiler/lib/ia32 /opt/intel/composerxe-2011.1.107/mkl/lib/ia32 /usr/lib/gcc/i686-linux-gnu/4.6/../../.."
+compiler_lib_search_dirs="/usr/lib/gcc/x86_64-linux-gnu/4.7 /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../../lib /lib/x86_64-linux-gnu /lib/../lib /usr/lib/x86_64-linux-gnu /usr/lib/../lib /usr/lib/gcc/x86_64-linux-gnu/4.7/../../.."
# Dependencies to place before and after the objects being linked to
# create a shared library.
-predep_objects="/usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu/crti.o /usr/lib/gcc/i686-linux-gnu/4.6/crtbeginS.o"
-postdep_objects="/usr/lib/gcc/i686-linux-gnu/4.6/crtendS.o /usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu/crtn.o"
+predep_objects="/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.7/crtbeginS.o"
+postdep_objects="/usr/lib/gcc/x86_64-linux-gnu/4.7/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crtn.o"
predeps=""
postdeps="-lstdc++ -lm -lgcc_s -lc -lgcc_s"
# The library search path used internally by the compiler when linking
# a shared library.
-compiler_lib_search_path="-L/usr/lib/gcc/i686-linux-gnu/4.6 -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../../lib -L/lib/i386-linux-gnu -L/lib/../lib -L/usr/lib/i386-linux-gnu -L/usr/lib/../lib -L/opt/intel/composerxe-2011.1.107/compiler/lib/ia32 -L/opt/intel/composerxe-2011.1.107/compiler/lib/ia32 -L/opt/intel/composerxe-2011.1.107/mkl/lib/ia32 -L/opt/intel/composerxe-2011.1.107/compiler/lib/ia32 -L/opt/intel/composerxe-2011.1.107/compiler/lib/ia32 -L/opt/intel/composerxe-2011.1.107/mkl/lib/ia32 -L/usr/lib/gcc/i686-linux-gnu/4.6/../../.."
+compiler_lib_search_path="-L/usr/lib/gcc/x86_64-linux-gnu/4.7 -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../.."
# ### END LIBTOOL TAG CONFIG: CXX
Index: modules/provider-coaster-c-client/config/depcomp
--- modules/provider-coaster-c-client/config/depcomp (revision 3812)
+++ modules/provider-coaster-c-client/config/depcomp (working copy)
@@ -1 +1 @@
-link /usr/share/automake-1.11/depcomp
\ No newline at end of file
+link /home/wozniak/sfw/automake-1.12.5/share/automake-1.12/depcomp
Index: modules/provider-coaster-c-client/config/missing
--- modules/provider-coaster-c-client/config/missing (revision 3812)
+++ modules/provider-coaster-c-client/config/missing (working copy)
@@ -1 +1 @@
-link /usr/share/automake-1.11/missing
+link /home/wozniak/sfw/automake-1.12.5/share/automake-1.12/missing
Index: modules/provider-coaster-c-client/config/config.guess
--- modules/provider-coaster-c-client/config/config.guess (revision 3812)
+++ modules/provider-coaster-c-client/config/config.guess (working copy)
@@ -2,9 +2,9 @@
# Attempt to guess a canonical system name.
# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
# 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
-# 2011, 2012 Free Software Foundation, Inc.
+# 2011 Free Software Foundation, Inc.
-timestamp='2012-02-10'
+timestamp='2011-10-01'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -17,7 +17,9 @@
# General Public License for more details.
# You should have received a copy of the GNU General Public License
-# along with this program; if not, see <http://www.gnu.org/licenses/>.
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 51 Franklin Street - Fifth Floor, Boston, MA
+# 02110-1301, USA.
# As a special exception to the GNU General Public License, if you
# distribute this file as part of a program that contains a
@@ -55,8 +57,8 @@
Originally written by Per Bothner.
Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000,
-2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
-Free Software Foundation, Inc.
+2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free
+Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -143,7 +145,7 @@
case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
*:NetBSD:*:*)
# NetBSD (nbsd) targets should (where applicable) match one or
- # more of the tuples: *-*-netbsdelf*, *-*-netbsdaout*,
+ # more of the tupples: *-*-netbsdelf*, *-*-netbsdaout*,
# *-*-netbsdecoff* and *-*-netbsd*. For targets that recently
# switched to ELF, *-*-netbsd* would select the old
# object file format. This provides both forward
@@ -804,9 +806,6 @@
*:MINGW*:*)
echo ${UNAME_MACHINE}-pc-mingw32
exit ;;
- i*:MSYS*:*)
- echo ${UNAME_MACHINE}-pc-msys
- exit ;;
i*:windows32*:*)
# uname -m includes "-pc" on this system.
echo ${UNAME_MACHINE}-mingw32
@@ -861,13 +860,6 @@
i*86:Minix:*:*)
echo ${UNAME_MACHINE}-pc-minix
exit ;;
- aarch64:Linux:*:*)
- echo ${UNAME_MACHINE}-unknown-linux-gnu
- exit ;;
- aarch64_be:Linux:*:*)
- UNAME_MACHINE=aarch64_be
- exit ;;
alpha:Linux:*:*)
case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
EV5) UNAME_MACHINE=alphaev5 ;;
@@ -902,16 +894,16 @@
exit ;;
cris:Linux:*:*)
- echo ${UNAME_MACHINE}-axis-linux-gnu
+ echo cris-axis-linux-gnu
exit ;;
crisv32:Linux:*:*)
+ echo crisv32-axis-linux-gnu
exit ;;
frv:Linux:*:*)
+ echo frv-unknown-linux-gnu
exit ;;
hexagon:Linux:*:*)
+ echo hexagon-unknown-linux-gnu
exit ;;
i*86:Linux:*:*)
LIBC=gnu
@@ -953,7 +945,7 @@
test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
or32:Linux:*:*)
+ echo or32-unknown-linux-gnu
exit ;;
padre:Linux:*:*)
echo sparc-unknown-linux-gnu
@@ -994,7 +986,7 @@
echo ${UNAME_MACHINE}-dec-linux-gnu
exit ;;
x86_64:Linux:*:*)
+ echo x86_64-unknown-linux-gnu
exit ;;
xtensa*:Linux:*:*)
@@ -1325,9 +1317,6 @@
i*86:AROS:*:*)
echo ${UNAME_MACHINE}-pc-aros
exit ;;
- x86_64:VMkernel:*:*)
- echo ${UNAME_MACHINE}-unknown-esx
- exit ;;
esac
#echo '(No uname command or uname output not recognized.)' 1>&2
Index: modules/provider-coaster-c-client/config/config.sub
--- modules/provider-coaster-c-client/config/config.sub (revision 3812)
+++ modules/provider-coaster-c-client/config/config.sub (working copy)
@@ -2,9 +2,9 @@
# Configuration validation subroutine script.
-timestamp='2012-04-18'
+timestamp='2011-10-08'
# This file is (in principle) common to ALL GNU software.
# The presence of a machine in this file suggests that SOME GNU software
@@ -21,7 +21,9 @@
# GNU General Public License for more details.
+# 02110-1301, USA.
@@ -74,8 +76,8 @@
GNU config.sub ($timestamp)
@@ -130,10 +132,6 @@
os=-$maybe_os
basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
- android-linux)
- os=-linux-android
- basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`-unknown
basic_machine=`echo $1 | sed 's/-[^-]*$//'`
if [ $basic_machine != $1 ]
@@ -225,12 +223,6 @@
-isc*)
basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
- -lynx*178)
- os=-lynxos178
- -lynx*5)
- os=-lynxos5
-lynx*)
os=-lynxos
@@ -255,7 +247,6 @@
# Some are omitted here because they have special meanings below.
1750a | 580 \
| a29k \
- | aarch64 | aarch64_be \
| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
| am33_2.0 \
@@ -304,7 +295,7 @@
| pdp10 | pdp11 | pj | pjl \
| powerpc | powerpc64 | powerpc64le | powerpcle \
| pyramid \
- | rl78 | rx \
+ | rx \
| score \
| sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
| sh64 | sh64le \
@@ -328,7 +319,8 @@
c6x)
basic_machine=tic6x-unknown
- m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | picochip)
+ m6811 | m68hc11 | m6812 | m68hc12 | picochip)
+ # Motorola 68HC11/12.
basic_machine=$basic_machine-unknown
os=-none
@@ -341,10 +333,7 @@
strongarm | thumb | xscale)
basic_machine=arm-unknown
- xgate)
- basic_machine=$basic_machine-unknown
- os=-none
xscaleeb)
basic_machine=armeb-unknown
@@ -367,7 +356,6 @@
# Recognize the basic CPU types with company name.
580-* \
| a29k-* \
- | aarch64-* | aarch64_be-* \
| alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
@@ -419,7 +407,7 @@
| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* \
| pyramid-* \
- | rl78-* | romp-* | rs6000-* | rx-* \
+ | romp-* | rs6000-* | rx-* \
| sh-* | sh[1234]-* | sh[24]a-* | sh[24]aeb-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
| shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
| sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
@@ -731,6 +719,7 @@
i370-ibm* | ibm*)
basic_machine=i370-ibm
+# I'm not sure what "Sysv32" means. Should this be sysv3.2?
i*86v32)
basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
os=-sysv32
@@ -827,10 +816,6 @@
ms1-*)
basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
- msys)
- basic_machine=i386-pc
- os=-msys
mvs)
os=-mvs
@@ -1358,7 +1343,7 @@
| -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
| -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
| -chorusos* | -chorusrdb* | -cegcc* \
- | -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
+ | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
| -mingw32* | -linux-gnu* | -linux-android* \
| -linux-newlib* | -linux-uclibc* \
| -uxpv* | -beos* | -mpeix* | -udk* \
@@ -1543,9 +1528,6 @@
c4x-* | tic4x-*)
os=-coff
- hexagon-*)
- os=-elf
tic54x-*)
os=-coff
@@ -1573,6 +1555,9 @@
m68000-sun)
os=-sunos3
+ # This also exists in the configure program, but was not the
+ # default.
+ # os=-sunos4
m68*-cisco)
os=-aout
Index: modules/provider-coaster-c-client/config/ltmain.sh
--- modules/provider-coaster-c-client/config/ltmain.sh (revision 3812)
+++ modules/provider-coaster-c-client/config/ltmain.sh (working copy)
@@ -70,7 +70,7 @@
# compiler: $LTCC
-# $progname: (GNU libtool) 2.4.2 Debian-2.4.2-1ubuntu2
@@ -80,7 +80,7 @@
PROGRAM=libtool
PACKAGE=libtool
-VERSION="2.4.2 Debian-2.4.2-1ubuntu2"
+VERSION=2.4.2
TIMESTAMP=""
@@ -6124,10 +6124,7 @@
case $pass in
- link)
esac
fi
@@ -6447,19 +6444,19 @@
func_append convenience " $ladir/$objdir/$old_library"
func_append old_convenience " $ladir/$objdir/$old_library"
- tmp_libs=
- *" $deplib "*) func_append specialdeplibs " $deplib" ;;
- esac
- fi
- func_append tmp_libs " $deplib"
- done
fi
+ tmp_libs=
+ *" $deplib "*) func_append specialdeplibs " $deplib" ;;
+ esac
+ fi
+ func_append tmp_libs " $deplib"
+ done
continue
fi # $pass = conv
@@ -7352,9 +7349,6 @@
esac
no)
Index: modules/provider-coaster-c-client/aclocal.m4
--- modules/provider-coaster-c-client/aclocal.m4 (revision 3812)
+++ modules/provider-coaster-c-client/aclocal.m4 (working copy)
@@ -1,8 +1,7 @@
-# generated automatically by aclocal 1.11.6 -*- Autoconf -*-
+# generated automatically by aclocal 1.12.5 -*- Autoconf -*-
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004,
-# 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software Foundation,
-# Inc.
+# Copyright (C) 1996-2012 Free Software Foundation, Inc.
# This file is free software; the Free Software Foundation
# gives unlimited permission to copy and/or distribute it,
# with or without modifications, as long as this notice is preserved.
@@ -14,11 +13,11 @@
m4_ifndef([AC_AUTOCONF_VERSION],
[m4_copy([m4_PACKAGE_VERSION], [AC_AUTOCONF_VERSION])])dnl
-m4_if(m4_defn([AC_AUTOCONF_VERSION]), [2.69],,
-[m4_warning([this file was generated for autoconf 2.69.
+m4_if(m4_defn([AC_AUTOCONF_VERSION]), [2.68],,
+[m4_warning([this file was generated for autoconf 2.68.
You have another version of autoconf. It may work, but is not guaranteed to.
If you have problems, you may need to regenerate the build system entirely.
-To do so, use the procedure documented by the package, typically `autoreconf'.])])
+To do so, use the procedure documented by the package, typically 'autoreconf'.])])
# libtool.m4 - Configure libtool for the host system. -*-Autoconf-*-
@@ -2698,18 +2697,6 @@
-netbsdelf*-gnu)
- need_version=no
netbsd*)
version_type=sunos
need_lib_prefix=no
@@ -3315,7 +3302,7 @@
+netbsd*)
lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so\.[[0-9]]+\.[[0-9]]+|_pic\.a)$'
else
@@ -4127,7 +4114,7 @@
esac
+ netbsd*)
*qnx* | *nto*)
@@ -4604,9 +4591,6 @@
esac
- _LT_TAGVAR(link_all_deplibs, $1)=no
_LT_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
@@ -4669,9 +4653,6 @@
openbsd*)
with_gnu_ld=no
esac
_LT_TAGVAR(ld_shlibs, $1)=yes
@@ -4893,7 +4874,7 @@
fi
+ netbsd*)
_LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
wlarc=
@@ -5070,7 +5051,6 @@
fi
else
# not using gcc
@@ -5375,7 +5355,7 @@
_LT_TAGVAR(link_all_deplibs, $1)=yes
+ netbsd*)
_LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
else
@@ -8626,25 +8606,22 @@
m4_ifndef([_LT_PROG_FC], [AC_DEFUN([_LT_PROG_FC])])
m4_ifndef([_LT_PROG_CXX], [AC_DEFUN([_LT_PROG_CXX])])
-# Copyright (C) 2002, 2003, 2005, 2006, 2007, 2008, 2011 Free Software
-# Foundation, Inc.
+# Copyright (C) 2002-2012 Free Software Foundation, Inc.
-# serial 1
# AM_AUTOMAKE_VERSION(VERSION)
# Automake X.Y traces this macro to ensure aclocal.m4 has been
# generated from the m4 files accompanying Automake X.Y.
# (This private macro should not be called outside this file.)
AC_DEFUN([AM_AUTOMAKE_VERSION],
-[am__api_version='1.11'
+[am__api_version='1.12'
dnl Some users find AM_AUTOMAKE_VERSION and mistake it for a way to
dnl require some minimum version. Point them to the right macro.
-m4_if([$1], [1.11.6], [],
+m4_if([$1], [1.12.5], [],
[AC_FATAL([Do not call $0, use AM_INIT_AUTOMAKE([$1]).])])dnl
@@ -8660,24 +8637,22 @@
# Call AM_AUTOMAKE_VERSION and AM_AUTOMAKE_VERSION so they can be traced.
# This function is AC_REQUIREd by AM_INIT_AUTOMAKE.
AC_DEFUN([AM_SET_CURRENT_AUTOMAKE_VERSION],
-[AM_AUTOMAKE_VERSION([1.11.6])dnl
+[AM_AUTOMAKE_VERSION([1.12.5])dnl
_AM_AUTOCONF_VERSION(m4_defn([AC_AUTOCONF_VERSION]))])
# AM_AUX_DIR_EXPAND -*- Autoconf -*-
-# Copyright (C) 2001, 2003, 2005, 2011 Free Software Foundation, Inc.
+# Copyright (C) 2001-2012 Free Software Foundation, Inc.
-# serial 1
# For projects using AC_CONFIG_AUX_DIR([foo]), Autoconf sets
-# $ac_aux_dir to `$srcdir/foo'. In other projects, it is set to
-# `$srcdir', `$srcdir/..', or `$srcdir/../..'.
+# $ac_aux_dir to '$srcdir/foo'. In other projects, it is set to
+# '$srcdir', '$srcdir/..', or '$srcdir/../..'.
# Of course, Automake must honor this variable whenever it calls a
# tool from the auxiliary directory. The problem is that $srcdir (and
@@ -8696,7 +8671,7 @@
# The reason of the latter failure is that $top_srcdir and $ac_aux_dir
# are both prefixed by $srcdir. In an in-source build this is usually
-# harmless because $srcdir is `.', but things will broke when you
+# harmless because $srcdir is '.', but things will broke when you
# start a VPATH build or use an absolute $srcdir.
# So we could use something similar to $top_srcdir/$ac_aux_dir/missing,
@@ -8722,22 +8697,19 @@
# AM_CONDITIONAL -*- Autoconf -*-
-# Copyright (C) 1997, 2000, 2001, 2003, 2004, 2005, 2006, 2008
-# Free Software Foundation, Inc.
+# Copyright (C) 1997-2012 Free Software Foundation, Inc.
-# serial 9
# AM_CONDITIONAL(NAME, SHELL-CONDITION)
# Define a conditional.
AC_DEFUN([AM_CONDITIONAL],
-[AC_PREREQ(2.52)dnl
- ifelse([$1], [TRUE], [AC_FATAL([$0: invalid condition: $1])],
- [$1], [FALSE], [AC_FATAL([$0: invalid condition: $1])])dnl
+[AC_PREREQ([2.52])dnl
+ m4_if([$1], [TRUE], [AC_FATAL([$0: invalid condition: $1])],
+ [$1], [FALSE], [AC_FATAL([$0: invalid condition: $1])])dnl
AC_SUBST([$1_TRUE])dnl
AC_SUBST([$1_FALSE])dnl
_AM_SUBST_NOTMAKE([$1_TRUE])dnl
@@ -8756,16 +8728,14 @@
Usually this means the macro was only invoked conditionally.]])
fi])])
-# Copyright (C) 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2009,
-# 2010, 2011 Free Software Foundation, Inc.
+# Copyright (C) 1999-2012 Free Software Foundation, Inc.
-# serial 12
-# There are a few dirty hacks below to avoid letting `AC_PROG_CC' be
+# There are a few dirty hacks below to avoid letting 'AC_PROG_CC' be
# written in clear, in which case automake, when reading aclocal.m4,
# will think it sees a *use*, and therefore will trigger all it's
# C support machinery. Also note that it means that autoscan, seeing
@@ -8775,7 +8745,7 @@
# _AM_DEPENDENCIES(NAME)
# See how the compiler implements dependency checking.
-# NAME is "CC", "CXX", "GCJ", or "OBJC".
+# NAME is "CC", "CXX", "OBJC", "OBJCXX", "UPC", or "GJC".
# We try a few techniques and use that to set a single cache variable.
# We don't AC_REQUIRE the corresponding AC_PROG_CC since the latter was
@@ -8788,12 +8758,13 @@
AC_REQUIRE([AM_MAKE_INCLUDE])dnl
AC_REQUIRE([AM_DEP_TRACK])dnl
-ifelse([$1], CC, [depcc="$CC" am_compiler_list=],
- [$1], CXX, [depcc="$CXX" am_compiler_list=],
- [$1], OBJC, [depcc="$OBJC" am_compiler_list='gcc3 gcc'],
- [$1], UPC, [depcc="$UPC" am_compiler_list=],
- [$1], GCJ, [depcc="$GCJ" am_compiler_list='gcc3 gcc'],
- [depcc="$$1" am_compiler_list=])
+m4_if([$1], [CC], [depcc="$CC" am_compiler_list=],
+ [$1], [CXX], [depcc="$CXX" am_compiler_list=],
+ [$1], [OBJC], [depcc="$OBJC" am_compiler_list='gcc3 gcc'],
+ [$1], [OBJCXX], [depcc="$OBJCXX" am_compiler_list='gcc3 gcc'],
+ [$1], [UPC], [depcc="$UPC" am_compiler_list=],
+ [$1], [GCJ], [depcc="$GCJ" am_compiler_list='gcc3 gcc'],
+ [depcc="$$1" am_compiler_list=])
AC_CACHE_CHECK([dependency style of $depcc],
[am_cv_$1_dependencies_compiler_type],
@@ -8801,8 +8772,8 @@
- # in D'.
+ # in D".
rm -rf conftest.dir
mkdir conftest.dir
@@ -8842,16 +8813,16 @@
: > sub/conftest.c
done
case $depmode in
@@ -8860,8 +8831,8 @@
nosideeffect)
continue
else
@@ -8869,7 +8840,7 @@
fi
@@ -8917,7 +8888,7 @@
# AM_SET_DEPDIR
# Choose a directory name for dependency files.
-# This macro is AC_REQUIREd in _AM_DEPENDENCIES
+# This macro is AC_REQUIREd in _AM_DEPENDENCIES.
AC_DEFUN([AM_SET_DEPDIR],
[AC_REQUIRE([AM_SET_LEADING_DOT])dnl
AC_SUBST([DEPDIR], ["${am__leading_dot}deps"])dnl
@@ -8927,9 +8898,13 @@
# AM_DEP_TRACK
AC_DEFUN([AM_DEP_TRACK],
-[AC_ARG_ENABLE(dependency-tracking,
-[ --disable-dependency-tracking speeds up one-time build
- --enable-dependency-tracking do not reject slow dependency extractors])
+[AC_ARG_ENABLE([dependency-tracking], [dnl
+AS_HELP_STRING(
+ [--enable-dependency-tracking],
+ [do not reject slow dependency extractors])
+AS_HELP_STRING(
+ [--disable-dependency-tracking],
+ [speeds up one-time build])])
if test "x$enable_dependency_tracking" != xno; then
am_depcomp="$ac_aux_dir/depcomp"
AMDEPBACKSLASH='\'
@@ -8944,14 +8919,12 @@
# Generate code to set up dependency tracking. -*- Autoconf -*-
-# Copyright (C) 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2008
-#serial 5
# _AM_OUTPUT_DEPENDENCY_COMMANDS
@@ -8970,7 +8943,7 @@
@@ -8982,21 +8955,19 @@
continue
fi
# expansion.
fdir=`AS_DIRNAME(["$file"])`
@@ -9014,7 +8985,7 @@
# This macro should only be invoked once -- use via AC_REQUIRE.
# This code is only required when automatic dependency tracking
-# is enabled. FIXME. This creates each `.P' file that we will
+# is enabled. FIXME. This creates each '.P' file that we will
# need in order to bootstrap the dependency handling code.
AC_DEFUN([AM_OUTPUT_DEPENDENCY_COMMANDS],
[AC_CONFIG_COMMANDS([depfiles],
@@ -9024,15 +8995,12 @@
# Do all the work for Automake. -*- Autoconf -*-
-# 2005, 2006, 2008, 2009 Free Software Foundation, Inc.
-# serial 16
# This macro actually does too much. Some checks are only needed if
# your package does certain things. But this isn't really a big deal.
@@ -9077,31 +9045,41 @@
# Define the identity of the package.
dnl Distinguish between old-style and new-style calls.
m4_ifval([$2],
-[m4_ifval([$3], [_AM_SET_OPTION([no-define])])dnl
+[AC_DIAGNOSE([obsolete],
+[$0: two- and three-arguments forms are deprecated. For more info, see:
+http://www.gnu.org/software/automake/manual/automake.html#Modernize-AM_INIT_AUTOMAKE-invocation])
+m4_ifval([$3], [_AM_SET_OPTION([no-define])])dnl
AC_SUBST([PACKAGE], [$1])dnl
AC_SUBST([VERSION], [$2])],
[_AM_SET_OPTIONS([$1])dnl
dnl Diagnose old-style AC_INIT with new-style AM_AUTOMAKE_INIT.
-m4_if(m4_ifdef([AC_PACKAGE_NAME], 1)m4_ifdef([AC_PACKAGE_VERSION], 1), 11,,
+m4_if(
+ m4_ifdef([AC_PACKAGE_NAME], [ok]):m4_ifdef([AC_PACKAGE_VERSION], [ok]),
+ [ok:ok],,
[m4_fatal([AC_INIT should be called with package and version arguments])])dnl
AC_SUBST([PACKAGE], ['AC_PACKAGE_TARNAME'])dnl
AC_SUBST([VERSION], ['AC_PACKAGE_VERSION'])])dnl
_AM_IF_OPTION([no-define],,
-[AC_DEFINE_UNQUOTED(PACKAGE, "$PACKAGE", [Name of package])
- AC_DEFINE_UNQUOTED(VERSION, "$VERSION", [Version number of package])])dnl
+[AC_DEFINE_UNQUOTED([PACKAGE], ["$PACKAGE"], [Name of package])
+ AC_DEFINE_UNQUOTED([VERSION], ["$VERSION"], [Version number of package])])dnl
# Some tools Automake needs.
AC_REQUIRE([AM_SANITY_CHECK])dnl
AC_REQUIRE([AC_ARG_PROGRAM])dnl
-AM_MISSING_PROG(ACLOCAL, aclocal-${am__api_version})
-AM_MISSING_PROG(AUTOCONF, autoconf)
-AM_MISSING_PROG(AUTOMAKE, automake-${am__api_version})
-AM_MISSING_PROG(AUTOHEADER, autoheader)
-AM_MISSING_PROG(MAKEINFO, makeinfo)
+AM_MISSING_PROG([ACLOCAL], [aclocal-${am__api_version}])
+AM_MISSING_PROG([AUTOCONF], [autoconf])
+AM_MISSING_PROG([AUTOMAKE], [automake-${am__api_version}])
+AM_MISSING_PROG([AUTOHEADER], [autoheader])
+AM_MISSING_PROG([MAKEINFO], [makeinfo])
AC_REQUIRE([AM_PROG_INSTALL_SH])dnl
AC_REQUIRE([AM_PROG_INSTALL_STRIP])dnl
-AC_REQUIRE([AM_PROG_MKDIR_P])dnl
+AC_REQUIRE([AC_PROG_MKDIR_P])dnl
+AC_SUBST([mkdir_p], ['$(MKDIR_P)'])
# some platforms.
AC_REQUIRE([AC_PROG_AWK])dnl
@@ -9112,28 +9090,35 @@
[_AM_PROG_TAR([v7])])])
_AM_IF_OPTION([no-dependencies],,
[AC_PROVIDE_IFELSE([AC_PROG_CC],
- [_AM_DEPENDENCIES(CC)],
- [define([AC_PROG_CC],
- defn([AC_PROG_CC])[_AM_DEPENDENCIES(CC)])])dnl
+ [_AM_DEPENDENCIES([CC])],
+ [m4_define([AC_PROG_CC],
+ m4_defn([AC_PROG_CC])[_AM_DEPENDENCIES([CC])])])dnl
AC_PROVIDE_IFELSE([AC_PROG_CXX],
- [_AM_DEPENDENCIES(CXX)],
- [define([AC_PROG_CXX],
- defn([AC_PROG_CXX])[_AM_DEPENDENCIES(CXX)])])dnl
+ [_AM_DEPENDENCIES([CXX])],
+ [m4_define([AC_PROG_CXX],
+ m4_defn([AC_PROG_CXX])[_AM_DEPENDENCIES([CXX])])])dnl
AC_PROVIDE_IFELSE([AC_PROG_OBJC],
- [_AM_DEPENDENCIES(OBJC)],
- [define([AC_PROG_OBJC],
- defn([AC_PROG_OBJC])[_AM_DEPENDENCIES(OBJC)])])dnl
+ [_AM_DEPENDENCIES([OBJC])],
+ [m4_define([AC_PROG_OBJC],
+ m4_defn([AC_PROG_OBJC])[_AM_DEPENDENCIES([OBJC])])])dnl
+dnl Support for Objective C++ was only introduced in Autoconf 2.65,
+dnl but we still cater to Autoconf 2.62.
+m4_ifdef([AC_PROG_OBJCXX],
+[AC_PROVIDE_IFELSE([AC_PROG_OBJCXX],
+ [_AM_DEPENDENCIES([OBJCXX])],
+ [m4_define([AC_PROG_OBJCXX],
+ m4_defn([AC_PROG_OBJCXX])[_AM_DEPENDENCIES([OBJCXX])])])])dnl
_AM_IF_OPTION([silent-rules], [AC_REQUIRE([AM_SILENT_RULES])])dnl
-dnl The `parallel-tests' driver may need to know about EXEEXT, so add the
-dnl `am__EXEEXT' conditional if _AM_COMPILER_EXEEXT was seen. This macro
+dnl The 'parallel-tests' driver may need to know about EXEEXT, so add the
+dnl 'am__EXEEXT' conditional if _AM_COMPILER_EXEEXT was seen. This macro
dnl is hooked onto _AC_COMPILER_EXEEXT early, see below.
AC_CONFIG_COMMANDS_PRE(dnl
[m4_provide_if([_AM_COMPILER_EXEEXT],
[AM_CONDITIONAL([am__EXEEXT], [test -n "$EXEEXT"])])])dnl
-dnl Hook into `_AC_COMPILER_EXEEXT' early to learn its expansion. Do not
+dnl Hook into '_AC_COMPILER_EXEEXT' early to learn its expansion. Do not
dnl add the conditional right here, as _AC_COMPILER_EXEEXT may be further
dnl mangled by Autoconf and run in a shell conditional statement.
m4_define([_AC_COMPILER_EXEEXT],
@@ -9161,15 +9146,12 @@
done
echo "timestamp for $_am_arg" >`AS_DIRNAME(["$_am_arg"])`/stamp-h[]$_am_stamp_count])
-# Copyright (C) 2001, 2003, 2005, 2008, 2011 Free Software Foundation,
-# Inc.
-# serial 1
# AM_PROG_INSTALL_SH
# Define $install_sh.
@@ -9183,16 +9165,14 @@
install_sh="\${SHELL} $am_aux_dir/install-sh"
esac
fi
-AC_SUBST(install_sh)])
+AC_SUBST([install_sh])])
-# Copyright (C) 2003, 2005 Free Software Foundation, Inc.
+# Copyright (C) 2003-2012 Free Software Foundation, Inc.
-# serial 2
# Check whether the underlying file-system supports filenames
# with a leading dot. For instance MS-DOS doesn't.
AC_DEFUN([AM_SET_LEADING_DOT],
@@ -9208,14 +9188,12 @@
# Check to see how 'make' treats includes. -*- Autoconf -*-
-# Copyright (C) 2001, 2002, 2003, 2005, 2009 Free Software Foundation, Inc.
-# serial 4
# AM_MAKE_INCLUDE()
# Check to see how make treats includes.
@@ -9233,7 +9211,7 @@
_am_result=none
am__include=include
@@ -9260,15 +9238,12 @@
# Fake the existence of programs that GNU maintainers use. -*- Autoconf -*-
-# Copyright (C) 1997, 1999, 2000, 2001, 2003, 2004, 2005, 2008
-# serial 6
# AM_MISSING_PROG(NAME, PROGRAM)
AC_DEFUN([AM_MISSING_PROG],
@@ -9276,7 +9251,6 @@
$1=${$1-"${am_missing_run}$2"}
AC_SUBST($1)])
# AM_MISSING_HAS_RUN
# Define MISSING if not defined so far and test if it supports --run.
@@ -9297,50 +9271,18 @@
else
am_missing_run=
- AC_MSG_WARN([`missing' script is too old or missing])
+ AC_MSG_WARN(['missing' script is too old or missing])
fi
-# Copyright (C) 2003, 2004, 2005, 2006, 2011 Free Software Foundation,
-# Inc.
-# This file is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# serial 1
-# AM_PROG_MKDIR_P
-# Check for `mkdir -p'.
-AC_DEFUN([AM_PROG_MKDIR_P],
-[AC_PREREQ([2.60])dnl
-AC_REQUIRE([AC_PROG_MKDIR_P])dnl
-dnl Automake 1.8 to 1.9.6 used to define mkdir_p. We now use MKDIR_P,
-dnl while keeping a definition of mkdir_p for backward compatibility.
-dnl @MKDIR_P@ is magic: AC_OUTPUT adjusts its value for each Makefile.
-dnl However we cannot define mkdir_p as $(MKDIR_P) for the sake of
-dnl Makefile.ins that do not define MKDIR_P, so we do our own
-dnl adjustment using top_builddir (which is defined more often than
-dnl MKDIR_P).
-AC_SUBST([mkdir_p], ["$MKDIR_P"])dnl
-case $mkdir_p in
-esac
# Helper functions for option handling. -*- Autoconf -*-
-# Copyright (C) 2001, 2002, 2003, 2005, 2008, 2010 Free Software
-# Foundation, Inc.
-# serial 5
# _AM_MANGLE_OPTION(NAME)
AC_DEFUN([_AM_MANGLE_OPTION],
@@ -9350,7 +9292,7 @@
# Set option NAME. Presently that only means defining a flag for this option.
AC_DEFUN([_AM_SET_OPTION],
-[m4_define(_AM_MANGLE_OPTION([$1]), 1)])
+[m4_define(_AM_MANGLE_OPTION([$1]), [1])])
# _AM_SET_OPTIONS(OPTIONS)
@@ -9366,22 +9308,16 @@
# Check to make sure that the build environment is sane. -*- Autoconf -*-
-# Copyright (C) 1996, 1997, 2000, 2001, 2003, 2005, 2008
-# serial 5
# AM_SANITY_CHECK
AC_DEFUN([AM_SANITY_CHECK],
[AC_MSG_CHECKING([whether build environment is sane])
-# Just in case
-sleep 1
am_lf='
@@ -9392,32 +9328,40 @@
esac
case $srcdir in
*[[\\\"\#\$\&\'\`$am_lf\ \ ]]*)
- AC_MSG_ERROR([unsafe srcdir value: `$srcdir']);;
+ AC_MSG_ERROR([unsafe srcdir value: '$srcdir']);;
esac
# directory).
if (
- if test "$[*]" = "X"; then
- # -L didn't work.
- fi
- if test "$[*]" != "X $srcdir/configure conftest.file" \
- && test "$[*]" != "X conftest.file $srcdir/configure"; then
+ am_has_slept=no
+ if test "$[*]" = "X"; then
+ # -L didn't work.
+ fi
+ if test "$[*]" != "X $srcdir/configure conftest.file" \
+ && test "$[*]" != "X conftest.file $srcdir/configure"; then
- AC_MSG_ERROR([ls -t appears to fail. Make sure there is not a broken
-alias in your environment])
- fi
+ AC_MSG_ERROR([ls -t appears to fail. Make sure there is not a broken
+ alias in your environment])
+ fi
+ if test "$[2]" = conftest.file || test $am_try -eq 2; then
+ break
+ fi
+ # Just in case.
+ sleep 1
+ am_has_slept=yes
+ done
then
@@ -9427,46 +9371,58 @@
AC_MSG_ERROR([newly created file is older than distributed files!
Check your system clock])
fi
-AC_MSG_RESULT(yes)])
+AC_MSG_RESULT([yes])
+am_sleep_pid=
+ ( sleep 1 ) &
+ am_sleep_pid=$!
+fi
+AC_CONFIG_COMMANDS_PRE(
+ [AC_MSG_CHECKING([that generated files are newer than configure])
+ fi
+ AC_MSG_RESULT([done])])
-# serial 1
# AM_PROG_INSTALL_STRIP
-# One issue with vendor `install' (even GNU) is that you can't
+# One issue with vendor 'install' (even GNU) is that you can't
# specify the program used to strip binaries. This is especially
# annoying in cross-compiling environments, where the build's strip
# is unlikely to handle the host's binaries.
# Fortunately install-sh will honor a STRIPPROG variable, so we
-# always use install-sh in `make install-strip', and initialize
+# always use install-sh in "make install-strip", and initialize
# STRIPPROG with the value of the STRIP variable (set by the user).
AC_DEFUN([AM_PROG_INSTALL_STRIP],
[AC_REQUIRE([AM_PROG_INSTALL_SH])dnl
-dnl Don't test for $cross_compiling = yes, because it might be `maybe'.
+dnl Don't test for $cross_compiling = yes, because it might be 'maybe'.
AC_CHECK_TOOL([STRIP], [strip], :)
fi
INSTALL_STRIP_PROGRAM="\$(install_sh) -c -s"
AC_SUBST([INSTALL_STRIP_PROGRAM])])
-# Copyright (C) 2006, 2008, 2010 Free Software Foundation, Inc.
+# Copyright (C) 2006-2012 Free Software Foundation, Inc.
-# serial 3
# _AM_SUBST_NOTMAKE(VARIABLE)
# Prevent Automake from outputting VARIABLE = @VARIABLE@ in Makefile.in.
@@ -9480,18 +9436,16 @@
# Check how to create a tarball. -*- Autoconf -*-
-# Copyright (C) 2004, 2005, 2012 Free Software Foundation, Inc.
+# Copyright (C) 2004-2012 Free Software Foundation, Inc.
-# serial 2
# _AM_PROG_TAR(FORMAT)
# Check how to create a tarball in format FORMAT.
-# FORMAT should be one of `v7', `ustar', or `pax'.
+# FORMAT should be one of 'v7', 'ustar', or 'pax'.
# Substitute a variable $(am__tar) that is a command
# writing to stdout a FORMAT-tarball containing the directory
@@ -9514,7 +9468,7 @@
_am_tools='gnutar m4_if([$1], [ustar], [plaintar]) pax cpio none'
_am_tools=${am_cv_prog_tar_$1-$_am_tools}
# Do not fold the above two line into one, because Tru64 sh and
-# Solaris sh will not grok spaces in the rhs of `-'.
+# Solaris sh will not grok spaces in the rhs of '-'.
for _am_tool in $_am_tools
do
case $_am_tool in
More information about the Swift-commit
