[Swift-commit] cog r3815
swift at ci.uchicago.edu
Wed Oct 23 11:45:03 CDT 2013
r3815 | jmwozniak | 2013-10-23 11:42:09 -0500 (Wed, 23 Oct 2013) | 2 lines
Drop autogenerated file
Index: modules/provider-coaster-c-client/Makefile.in
--- modules/provider-coaster-c-client/Makefile.in (revision 3814)
+++ modules/provider-coaster-c-client/Makefile.in (working copy)
@@ -1,756 +0,0 @@
-# Makefile.in generated by automake 1.11.6 from Makefile.am.
-# @configure_input@
-# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
-# 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software
-# Foundation, Inc.
-# This Makefile.in is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
- at SET_MAKE@
-VPATH = @srcdir@
-am__make_dryrun = \
- am__dry=no; \
- case $$MAKEFLAGS in \
- echo 'am--echo: ; @echo "AM" OK' | $(MAKE) -f - 2>/dev/null \
- | grep '^AM OK$$' >/dev/null || am__dry=yes;; \
- for am__flg in $$MAKEFLAGS; do \
- case $$am__flg in \
- *n*) am__dry=yes; break;; \
- esac; \
- done;; \
- esac; \
- test $$am__dry = yes; \
-pkgdatadir = $(datadir)/@PACKAGE@
-pkgincludedir = $(includedir)/@PACKAGE@
-pkglibdir = $(libdir)/@PACKAGE@
-pkglibexecdir = $(libexecdir)/@PACKAGE@
-am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
-install_sh_DATA = $(install_sh) -c -m 644
-install_sh_PROGRAM = $(install_sh) -c
-install_sh_SCRIPT = $(install_sh) -c
-INSTALL_HEADER = $(INSTALL_DATA)
-transform = $(program_transform_name)
-NORMAL_INSTALL = :
-PRE_INSTALL = :
-POST_INSTALL = :
-NORMAL_UNINSTALL = :
-PRE_UNINSTALL = :
-POST_UNINSTALL = :
-build_triplet = @build@
-host_triplet = @host@
-subdir = .
-DIST_COMMON = README $(am__configure_deps) $(srcdir)/Makefile.am \
- $(srcdir)/Makefile.in $(top_srcdir)/configure AUTHORS COPYING \
- ChangeLog INSTALL NEWS config/config.guess config/config.sub \
- config/depcomp config/install-sh config/ltmain.sh \
- config/missing
-ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
-am__aclocal_m4_deps = $(top_srcdir)/configure.ac
-am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
- $(ACLOCAL_M4)
-am__CONFIG_DISTCLEAN_FILES = config.status config.cache config.log \
- configure.lineno config.status.lineno
-mkinstalldirs = $(install_sh) -d
-CONFIG_CLEAN_FILES =
-CONFIG_CLEAN_VPATH_FILES =
-SOURCES =
-DIST_SOURCES =
-RECURSIVE_TARGETS = all-recursive check-recursive dvi-recursive \
- html-recursive info-recursive install-data-recursive \
- install-dvi-recursive install-exec-recursive \
- install-html-recursive install-info-recursive \
- install-pdf-recursive install-ps-recursive install-recursive \
- installcheck-recursive installdirs-recursive pdf-recursive \
- ps-recursive uninstall-recursive
-am__can_run_installinfo = \
- case $$AM_UPDATE_INFO_DIR in \
- n|no|NO) false;; \
- *) (install-info --version) >/dev/null 2>&1;; \
- esac
-RECURSIVE_CLEAN_TARGETS = mostlyclean-recursive clean-recursive \
- distclean-recursive maintainer-clean-recursive
-AM_RECURSIVE_TARGETS = $(RECURSIVE_TARGETS:-recursive=) \
- $(RECURSIVE_CLEAN_TARGETS:-recursive=) tags TAGS ctags CTAGS \
- distdir dist dist-all distcheck
-ETAGS = etags
-CTAGS = ctags
-DIST_SUBDIRS = $(SUBDIRS)
-DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
-distdir = $(PACKAGE)-$(VERSION)
-top_distdir = $(distdir)
-am__remove_distdir = \
- if test -d "$(distdir)"; then \
- find "$(distdir)" -type d ! -perm -200 -exec chmod u+w {} ';' \
- && rm -rf "$(distdir)" \
- || { sleep 5 && rm -rf "$(distdir)"; }; \
- else :; fi
-am__relativize = \
- dir0=`pwd`; \
- sed_first='s,^\([^/]*\)/.*$$,\1,'; \
- sed_rest='s,^[^/]*/*,,'; \
- sed_last='s,^.*/\([^/]*\)$$,\1,'; \
- sed_butlast='s,/*[^/]*$$,,'; \
- while test -n "$$dir1"; do \
- first=`echo "$$dir1" | sed -e "$$sed_first"`; \
- if test "$$first" != "."; then \
- if test "$$first" = ".."; then \
- dir2=`echo "$$dir0" | sed -e "$$sed_last"`/"$$dir2"; \
- dir0=`echo "$$dir0" | sed -e "$$sed_butlast"`; \
- else \
- first2=`echo "$$dir2" | sed -e "$$sed_first"`; \
- if test "$$first2" = "$$first"; then \
- dir2=`echo "$$dir2" | sed -e "$$sed_rest"`; \
- else \
- dir2="../$$dir2"; \
- fi; \
- dir0="$$dir0"/"$$first"; \
- fi; \
- fi; \
- dir1=`echo "$$dir1" | sed -e "$$sed_rest"`; \
- done; \
- reldir="$$dir2"
-DIST_ARCHIVES = $(distdir).tar.gz
-GZIP_ENV = --best
-distuninstallcheck_listfiles = find . -type f -print
-am__distuninstallcheck_listfiles = $(distuninstallcheck_listfiles) \
- | sed 's|^\./|$(prefix)/|' | grep -v '$(infodir)/dir$$'
-distcleancheck_listfiles = find . -type f -print
-ACLOCAL = @ACLOCAL@
-AMTAR = @AMTAR@
-AM_CXXFLAGS = -pthread
-AR = @AR@
-AUTOCONF = @AUTOCONF@
-AUTOHEADER = @AUTOHEADER@
-AUTOMAKE = @AUTOMAKE@
-AWK = @AWK@
-CC = @CC@
-CCDEPMODE = @CCDEPMODE@
-CFLAGS = @CFLAGS@
-CPP = @CPP@
-CPPFLAGS = @CPPFLAGS@
-CXX = @CXX@
-CXXCPP = @CXXCPP@
-CXXDEPMODE = @CXXDEPMODE@
-CXXFLAGS = @CXXFLAGS@
-CYGPATH_W = @CYGPATH_W@
-DEFS = @DEFS@
-DEPDIR = @DEPDIR@
-DLLTOOL = @DLLTOOL@
-DSYMUTIL = @DSYMUTIL@
-DUMPBIN = @DUMPBIN@
-ECHO_C = @ECHO_C@
-ECHO_N = @ECHO_N@
-ECHO_T = @ECHO_T@
-EGREP = @EGREP@
-EXEEXT = @EXEEXT@
-FGREP = @FGREP@
-GREP = @GREP@
-INSTALL = @INSTALL@
-INSTALL_DATA = @INSTALL_DATA@
-INSTALL_PROGRAM = @INSTALL_PROGRAM@
-INSTALL_SCRIPT = @INSTALL_SCRIPT@
-INSTALL_STRIP_PROGRAM = @INSTALL_STRIP_PROGRAM@
-LD = @LD@
-LDFLAGS = @LDFLAGS@
-LIBOBJS = @LIBOBJS@
-LIBS = -pthread $LIBS
-LIBTOOL = @LIBTOOL@
-LIPO = @LIPO@
-LN_S = @LN_S@
-LTLIBOBJS = @LTLIBOBJS@
-MAKEINFO = @MAKEINFO@
-MANIFEST_TOOL = @MANIFEST_TOOL@
-MKDIR_P = @MKDIR_P@
-NM = @NM@
-NMEDIT = @NMEDIT@
-OBJDUMP = @OBJDUMP@
-OBJEXT = @OBJEXT@
-OTOOL = @OTOOL@
-OTOOL64 = @OTOOL64@
-PACKAGE = @PACKAGE@
-PACKAGE_BUGREPORT = @PACKAGE_BUGREPORT@
-PACKAGE_NAME = @PACKAGE_NAME@
-PACKAGE_STRING = @PACKAGE_STRING@
-PACKAGE_TARNAME = @PACKAGE_TARNAME@
-PACKAGE_URL = @PACKAGE_URL@
-PACKAGE_VERSION = @PACKAGE_VERSION@
-PATH_SEPARATOR = @PATH_SEPARATOR@
-RANLIB = @RANLIB@
-SED = @SED@
-SET_MAKE = @SET_MAKE@
-SHELL = @SHELL@
-STRIP = @STRIP@
-VERSION = @VERSION@
-abs_builddir = @abs_builddir@
-abs_srcdir = @abs_srcdir@
-abs_top_builddir = @abs_top_builddir@
-abs_top_srcdir = @abs_top_srcdir@
-ac_ct_AR = @ac_ct_AR@
-ac_ct_CC = @ac_ct_CC@
-ac_ct_CXX = @ac_ct_CXX@
-ac_ct_DUMPBIN = @ac_ct_DUMPBIN@
-am__include = @am__include@
-am__leading_dot = @am__leading_dot@
-am__quote = @am__quote@
-am__tar = @am__tar@
-am__untar = @am__untar@
-bindir = @bindir@
-build = @build@
-build_alias = @build_alias@
-build_cpu = @build_cpu@
-build_os = @build_os@
-build_vendor = @build_vendor@
-builddir = @builddir@
-datadir = @datadir@
-datarootdir = @datarootdir@
-docdir = @docdir@
-dvidir = @dvidir@
-exec_prefix = @exec_prefix@
-host = @host@
-host_alias = @host_alias@
-host_cpu = @host_cpu@
-host_os = @host_os@
-host_vendor = @host_vendor@
-htmldir = @htmldir@
-includedir = @includedir@
-infodir = @infodir@
-install_sh = @install_sh@
-libdir = @libdir@
-libexecdir = @libexecdir@
-localedir = @localedir@
-localstatedir = @localstatedir@
-mandir = @mandir@
-mkdir_p = @mkdir_p@
-oldincludedir = @oldincludedir@
-pdfdir = @pdfdir@
-prefix = @prefix@
-program_transform_name = @program_transform_name@
-psdir = @psdir@
-sbindir = @sbindir@
-sharedstatedir = @sharedstatedir@
-srcdir = @srcdir@
-sysconfdir = @sysconfdir@
-target_alias = @target_alias@
-top_build_prefix = @top_build_prefix@
-top_builddir = @top_builddir@
-top_srcdir = @top_srcdir@
-ACLOCAL_AMFLAGS = -I m4
-SUBDIRS = src
-EXTRA_DIST = autogen.sh
-all: all-recursive
-.SUFFIXES:
-am--refresh: Makefile
-$(srcdir)/Makefile.in: $(srcdir)/Makefile.am $(am__configure_deps)
- @for dep in $?; do \
- case '$(am__configure_deps)' in \
- *$$dep*) \
- echo ' cd $(srcdir) && $(AUTOMAKE) --gnu'; \
- $(am__cd) $(srcdir) && $(AUTOMAKE) --gnu \
- && exit 0; \
- exit 1;; \
- esac; \
- done; \
- echo ' cd $(top_srcdir) && $(AUTOMAKE) --gnu Makefile'; \
- $(am__cd) $(top_srcdir) && \
- $(AUTOMAKE) --gnu Makefile
-.PRECIOUS: Makefile
-Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
- @case '$?' in \
- *config.status*) \
- echo ' $(SHELL) ./config.status'; \
- $(SHELL) ./config.status;; \
- echo ' cd $(top_builddir) && $(SHELL) ./config.status $@ $(am__depfiles_maybe)'; \
- cd $(top_builddir) && $(SHELL) ./config.status $@ $(am__depfiles_maybe);; \
- esac;
-$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
- $(SHELL) ./config.status --recheck
-$(top_srcdir)/configure: $(am__configure_deps)
- $(am__cd) $(srcdir) && $(AUTOCONF)
-$(ACLOCAL_M4): $(am__aclocal_m4_deps)
- $(am__cd) $(srcdir) && $(ACLOCAL) $(ACLOCAL_AMFLAGS)
-$(am__aclocal_m4_deps):
-mostlyclean-libtool:
- -rm -f *.lo
-clean-libtool:
- -rm -rf .libs _libs
-distclean-libtool:
- -rm -f libtool config.lt
-# This directory's subdirectories are mostly independent; you can cd
-# into them and run `make' without going through this Makefile.
-# To change the values of `make' variables: instead of editing Makefiles,
-# (1) if the variable is set in `config.status', edit `config.status'
-# (which will cause the Makefiles to be regenerated when you run `make');
-# (2) otherwise, pass the desired values on the `make' command line.
-$(RECURSIVE_TARGETS):
- @fail= failcom='exit 1'; \
- for f in x $$MAKEFLAGS; do \
- case $$f in \
- *=* | --[!k]*);; \
- *k*) failcom='fail=yes';; \
- esac; \
- done; \
- dot_seen=no; \
- target=`echo $@ | sed s/-recursive//`; \
- list='$(SUBDIRS)'; for subdir in $$list; do \
- echo "Making $$target in $$subdir"; \
- if test "$$subdir" = "."; then \
- dot_seen=yes; \
- local_target="$$target-am"; \
- else \
- local_target="$$target"; \
- fi; \
- ($(am__cd) $$subdir && $(MAKE) $(AM_MAKEFLAGS) $$local_target) \
- || eval $$failcom; \
- done; \
- if test "$$dot_seen" = "no"; then \
- $(MAKE) $(AM_MAKEFLAGS) "$$target-am" || exit 1; \
- fi; test -z "$$fail"
-$(RECURSIVE_CLEAN_TARGETS):
- case $$f in \
- esac; \
- done; \
- dot_seen=no; \
- case "$@" in \
- distclean-* | maintainer-clean-*) list='$(DIST_SUBDIRS)' ;; \
- *) list='$(SUBDIRS)' ;; \
- esac; \
- rev=''; for subdir in $$list; do \
- if test "$$subdir" = "."; then :; else \
- rev="$$subdir $$rev"; \
- fi; \
- done; \
- rev="$$rev ."; \
- for subdir in $$rev; do \
- else \
- fi; \
- done && test -z "$$fail"
-tags-recursive:
- test "$$subdir" = . || ($(am__cd) $$subdir && $(MAKE) $(AM_MAKEFLAGS) tags); \
- done
-ctags-recursive:
- test "$$subdir" = . || ($(am__cd) $$subdir && $(MAKE) $(AM_MAKEFLAGS) ctags); \
- done
-ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
- list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
- unique=`for i in $$list; do \
- if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
- done | \
- $(AWK) '{ files[$$0] = 1; nonempty = 1; } \
- END { if (nonempty) { for (i in files) print i; }; }'`; \
- mkid -fID $$unique
-tags: TAGS
-TAGS: tags-recursive $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \
- $(TAGS_FILES) $(LISP)
- set x; \
- here=`pwd`; \
- if ($(ETAGS) --etags-include --version) >/dev/null 2>&1; then \
- include_option=--etags-include; \
- empty_fix=.; \
- else \
- include_option=--include; \
- empty_fix=; \
- fi; \
- if test "$$subdir" = .; then :; else \
- test ! -f $$subdir/TAGS || \
- set "$$@" "$$include_option=$$here/$$subdir/TAGS"; \
- fi; \
- done; \
- done | \
- shift; \
- if test -z "$(ETAGS_ARGS)$$*$$unique"; then :; else \
- test -n "$$unique" || unique=$$empty_fix; \
- if test $$# -gt 0; then \
- $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
- "$$@" $$unique; \
- else \
- $$unique; \
- fi; \
- fi
-ctags: CTAGS
-CTAGS: ctags-recursive $(HEADERS) $(SOURCES) $(TAGS_DEPENDENCIES) \
- done | \
- test -z "$(CTAGS_ARGS)$$unique" \
- || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
- $$unique
-GTAGS:
- here=`$(am__cd) $(top_builddir) && pwd` \
- && $(am__cd) $(top_srcdir) \
- && gtags -i $(GTAGS_ARGS) "$$here"
-distclean-tags:
- -rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
-distdir: $(DISTFILES)
- $(am__remove_distdir)
- test -d "$(distdir)" || mkdir "$(distdir)"
- @srcdirstrip=`echo "$(srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
- topsrcdirstrip=`echo "$(top_srcdir)" | sed 's/[].[^$$\\*]/\\\\&/g'`; \
- list='$(DISTFILES)'; \
- dist_files=`for file in $$list; do echo $$file; done | \
- sed -e "s|^$$srcdirstrip/||;t" \
- -e "s|^$$topsrcdirstrip/|$(top_builddir)/|;t"`; \
- case $$dist_files in \
- */*) $(MKDIR_P) `echo "$$dist_files" | \
- sed '/\//!d;s|^|$(distdir)/|;s,/[^/]*$$,,' | \
- sort -u` ;; \
- esac; \
- for file in $$dist_files; do \
- if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
- if test -d $$d/$$file; then \
- dir=`echo "/$$file" | sed -e 's,/[^/]*$$,,'`; \
- if test -d "$(distdir)/$$file"; then \
- find "$(distdir)/$$file" -type d ! -perm -700 -exec chmod u+rwx {} \;; \
- fi; \
- if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
- cp -fpR $(srcdir)/$$file "$(distdir)$$dir" || exit 1; \
- fi; \
- cp -fpR $$d/$$file "$(distdir)$$dir" || exit 1; \
- else \
- test -f "$(distdir)/$$file" \
- || cp -p $$d/$$file "$(distdir)/$$file" \
- || exit 1; \
- fi; \
- done
- @list='$(DIST_SUBDIRS)'; for subdir in $$list; do \
- $(am__make_dryrun) \
- || test -d "$(distdir)/$$subdir" \
- || $(MKDIR_P) "$(distdir)/$$subdir" \
- || exit 1; \
- dir1=$$subdir; dir2="$(distdir)/$$subdir"; \
- $(am__relativize); \
- new_distdir=$$reldir; \
- dir1=$$subdir; dir2="$(top_distdir)"; \
- new_top_distdir=$$reldir; \
- echo " (cd $$subdir && $(MAKE) $(AM_MAKEFLAGS) top_distdir="$$new_top_distdir" distdir="$$new_distdir" \\"; \
- echo " am__remove_distdir=: am__skip_length_check=: am__skip_mode_fix=: distdir)"; \
- ($(am__cd) $$subdir && \
- $(MAKE) $(AM_MAKEFLAGS) \
- top_distdir="$$new_top_distdir" \
- distdir="$$new_distdir" \
- am__remove_distdir=: \
- am__skip_length_check=: \
- am__skip_mode_fix=: \
- distdir) \
- || exit 1; \
- fi; \
- done
- -test -n "$(am__skip_mode_fix)" \
- || find "$(distdir)" -type d ! -perm -755 \
- -exec chmod u+rwx,go+rx {} \; -o \
- ! -type d ! -perm -444 -links 1 -exec chmod a+r {} \; -o \
- ! -type d ! -perm -400 -exec chmod a+r {} \; -o \
- ! -type d ! -perm -444 -exec $(install_sh) -c -m a+r {} {} \; \
- || chmod -R a+r "$(distdir)"
-dist-gzip: distdir
- tardir=$(distdir) && $(am__tar) | GZIP=$(GZIP_ENV) gzip -c >$(distdir).tar.gz
-dist-bzip2: distdir
- tardir=$(distdir) && $(am__tar) | BZIP2=$${BZIP2--9} bzip2 -c >$(distdir).tar.bz2
-dist-lzip: distdir
- tardir=$(distdir) && $(am__tar) | lzip -c $${LZIP_OPT--9} >$(distdir).tar.lz
-dist-lzma: distdir
- tardir=$(distdir) && $(am__tar) | lzma -9 -c >$(distdir).tar.lzma
-dist-xz: distdir
- tardir=$(distdir) && $(am__tar) | XZ_OPT=$${XZ_OPT--e} xz -c >$(distdir).tar.xz
-dist-tarZ: distdir
- tardir=$(distdir) && $(am__tar) | compress -c >$(distdir).tar.Z
-dist-shar: distdir
- shar $(distdir) | GZIP=$(GZIP_ENV) gzip -c >$(distdir).shar.gz
-dist-zip: distdir
- -rm -f $(distdir).zip
- zip -rq $(distdir).zip $(distdir)
-dist dist-all: distdir
-# This target untars the dist file and tries a VPATH configuration. Then
-# it guarantees that the distribution is self-contained by making another
-# tarfile.
-distcheck: dist
- case '$(DIST_ARCHIVES)' in \
- *.tar.gz*) \
- GZIP=$(GZIP_ENV) gzip -dc $(distdir).tar.gz | $(am__untar) ;;\
- *.tar.bz2*) \
- bzip2 -dc $(distdir).tar.bz2 | $(am__untar) ;;\
- *.tar.lzma*) \
- lzma -dc $(distdir).tar.lzma | $(am__untar) ;;\
- *.tar.lz*) \
- lzip -dc $(distdir).tar.lz | $(am__untar) ;;\
- *.tar.xz*) \
- xz -dc $(distdir).tar.xz | $(am__untar) ;;\
- *.tar.Z*) \
- uncompress -c $(distdir).tar.Z | $(am__untar) ;;\
- *.shar.gz*) \
- GZIP=$(GZIP_ENV) gzip -dc $(distdir).shar.gz | unshar ;;\
- *.zip*) \
- unzip $(distdir).zip ;;\
- esac
- chmod -R a-w $(distdir); chmod u+w $(distdir)
- mkdir $(distdir)/_build
- mkdir $(distdir)/_inst
- chmod a-w $(distdir)
- test -d $(distdir)/_build || exit 0; \
- dc_install_base=`$(am__cd) $(distdir)/_inst && pwd | sed -e 's,^[^:\\/]:[\\/],/,'` \
- && dc_destdir="$${TMPDIR-/tmp}/am-dc-$$$$/" \
- && am__cwd=`pwd` \
- && $(am__cd) $(distdir)/_build \
- && ../configure --srcdir=.. --prefix="$$dc_install_base" \
- $(AM_DISTCHECK_CONFIGURE_FLAGS) \
- $(DISTCHECK_CONFIGURE_FLAGS) \
- && $(MAKE) $(AM_MAKEFLAGS) \
- && $(MAKE) $(AM_MAKEFLAGS) dvi \
- && $(MAKE) $(AM_MAKEFLAGS) check \
- && $(MAKE) $(AM_MAKEFLAGS) install \
- && $(MAKE) $(AM_MAKEFLAGS) installcheck \
- && $(MAKE) $(AM_MAKEFLAGS) uninstall \
- && $(MAKE) $(AM_MAKEFLAGS) distuninstallcheck_dir="$$dc_install_base" \
- distuninstallcheck \
- && chmod -R a-w "$$dc_install_base" \
- (cd ../.. && umask 077 && mkdir "$$dc_destdir") \
- && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" install \
- && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" uninstall \
- && $(MAKE) $(AM_MAKEFLAGS) DESTDIR="$$dc_destdir" \
- distuninstallcheck_dir="$$dc_destdir" distuninstallcheck; \
- } || { rm -rf "$$dc_destdir"; exit 1; }) \
- && rm -rf "$$dc_destdir" \
- && $(MAKE) $(AM_MAKEFLAGS) dist \
- && rm -rf $(DIST_ARCHIVES) \
- && $(MAKE) $(AM_MAKEFLAGS) distcleancheck \
- && cd "$$am__cwd" \
- || exit 1
- @(echo "$(distdir) archives ready for distribution: "; \
- list='$(DIST_ARCHIVES)'; for i in $$list; do echo $$i; done) | \
- sed -e 1h -e 1s/./=/g -e 1p -e 1x -e '$$p' -e '$$x'
-distuninstallcheck:
- @test -n '$(distuninstallcheck_dir)' || { \
- echo 'ERROR: trying to run $@ with an empty' \
- '$$(distuninstallcheck_dir)' >&2; \
- exit 1; \
- $(am__cd) '$(distuninstallcheck_dir)' || { \
- echo 'ERROR: cannot chdir into $(distuninstallcheck_dir)' >&2; \
- exit 1; \
- test `$(am__distuninstallcheck_listfiles) | wc -l` -eq 0 \
- || { echo "ERROR: files left after uninstall:" ; \
- if test -n "$(DESTDIR)"; then \
- echo " (check DESTDIR support)"; \
- fi ; \
- $(distuninstallcheck_listfiles) ; \
- exit 1; } >&2
-distcleancheck: distclean
- @if test '$(srcdir)' = . ; then \
- echo "ERROR: distcleancheck can only run from a VPATH build" ; \
- exit 1 ; \
- fi
- @test `$(distcleancheck_listfiles) | wc -l` -eq 0 \
- || { echo "ERROR: files left in build directory after distclean:" ; \
- $(distcleancheck_listfiles) ; \
- exit 1; } >&2
-check-am: all-am
-check: check-recursive
-all-am: Makefile
-installdirs: installdirs-recursive
-installdirs-am:
-install: install-recursive
-install-exec: install-exec-recursive
-install-data: install-data-recursive
-uninstall: uninstall-recursive
-install-am: all-am
- @$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
-installcheck: installcheck-recursive
-install-strip:
- if test -z '$(STRIP)'; then \
- $(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
- install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
- install; \
- else \
- "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'" install; \
- fi
-mostlyclean-generic:
-clean-generic:
-distclean-generic:
- -test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES)
- -test . = "$(srcdir)" || test -z "$(CONFIG_CLEAN_VPATH_FILES)" || rm -f $(CONFIG_CLEAN_VPATH_FILES)
-maintainer-clean-generic:
- @echo "This command is intended for maintainers to use"
- @echo "it deletes files that may require special tools to rebuild."
-clean: clean-recursive
-clean-am: clean-generic clean-libtool mostlyclean-am
-distclean: distclean-recursive
- -rm -f $(am__CONFIG_DISTCLEAN_FILES)
- -rm -f Makefile
-distclean-am: clean-am distclean-generic distclean-libtool \
- distclean-tags
-dvi: dvi-recursive
-dvi-am:
-html: html-recursive
-html-am:
-info: info-recursive
-info-am:
-install-data-am:
-install-dvi: install-dvi-recursive
-install-dvi-am:
-install-exec-am:
-install-html: install-html-recursive
-install-html-am:
-install-info: install-info-recursive
-install-info-am:
-install-man:
-install-pdf: install-pdf-recursive
-install-pdf-am:
-install-ps: install-ps-recursive
-install-ps-am:
-installcheck-am:
-maintainer-clean: maintainer-clean-recursive
- -rm -rf $(top_srcdir)/autom4te.cache
- -rm -f Makefile
-maintainer-clean-am: distclean-am maintainer-clean-generic
-mostlyclean: mostlyclean-recursive
-mostlyclean-am: mostlyclean-generic mostlyclean-libtool
-pdf: pdf-recursive
-pdf-am:
-ps: ps-recursive
-ps-am:
-uninstall-am:
-.MAKE: $(RECURSIVE_CLEAN_TARGETS) $(RECURSIVE_TARGETS) ctags-recursive \
- install-am install-strip tags-recursive
-.PHONY: $(RECURSIVE_CLEAN_TARGETS) $(RECURSIVE_TARGETS) CTAGS GTAGS \
- all all-am am--refresh check check-am clean clean-generic \
- clean-libtool ctags ctags-recursive dist dist-all dist-bzip2 \
- dist-gzip dist-lzip dist-lzma dist-shar dist-tarZ dist-xz \
- dist-zip distcheck distclean distclean-generic \
- distclean-libtool distclean-tags distcleancheck distdir \
- distuninstallcheck dvi dvi-am html html-am info info-am \
- install install-am install-data install-data-am install-dvi \
- install-dvi-am install-exec install-exec-am install-html \
- install-html-am install-info install-info-am install-man \
- install-pdf install-pdf-am install-ps install-ps-am \
- install-strip installcheck installcheck-am installdirs \
- installdirs-am maintainer-clean maintainer-clean-generic \
- mostlyclean mostlyclean-generic mostlyclean-libtool pdf pdf-am \
- ps ps-am tags tags-recursive uninstall uninstall-am
-binaries: all
- mkdir -p dist/bin
- mkdir -p dist/lib
- cp src/.libs/libcoasterclient.a dist/lib
- cp -d src/.libs/libcoasterclient.so* dist/lib
- cp src/.libs/coaster-client-test dist/bin
- cp src/.libs/run-coaster-job dist/bin
-# Tell versions [3.59,3.63) of GNU make to not export all variables.
-# Otherwise a system limit (for SysV at least) may be exceeded.
-.NOEXPORT:
More information about the Swift-commit
