[Swift-commit] r7259 - trunk/bin
davidk at ci.uchicago.edu
Thu Oct 31 17:17:52 CDT 2013
Author: davidk
Date: 2013-10-31 17:17:52 -0500 (Thu, 31 Oct 2013)
New Revision: 7259
Modified:
trunk/bin/swift-service
Log:
Generate pool entries, create sites.xml for one or more pools
Modified: trunk/bin/swift-service
--- trunk/bin/swift-service 2013-10-31 21:48:45 UTC (rev 7258)
+++ trunk/bin/swift-service 2013-10-31 22:17:52 UTC (rev 7259)
@@ -1,6 +1,5 @@
#!/bin/bash
-# set -x
# Determine the location of needed files
export SWIFT_BIN="$( cd "$( dirname "$0" )" && pwd )"
export WORKER="$SWIFT_BIN/worker.pl"
@@ -85,17 +84,27 @@
rm -rf $SERVICE_DIR/$SERVICENAME
+get_services()
+ ls -d $SERVICE_DIR/*/ 2>/dev/null
# Stop the coaster service
stop_service()
if [ -n "$NAME" ]; then
stop_single_service $NAME
else
- for service in $( ls -d $SERVICE_DIR/*/ 2>/dev/null )
+ count=0
+ for service in $( get_services )
do
service=$( basename $service )
stop_single_service $service
+ count=$((count+1))
done
+ if [ "$count" == 0 ]; then
+ crash "No services found to stop"
+ fi
fi
@@ -196,20 +205,14 @@
echo Name: $NAME
echo Service port: $SERVICE_PORT
echo Local port: $LOCAL_PORT
echo $SERVICE_PORT >> $COASTER_DIR/service.port
echo $LOCAL_PORT >> $COASTER_DIR/local.port
# Generate sites.xml
export EXECUTIONURL="http://$IPADDR:$SERVICE_PORT"
export WORKERURL="http://$IPADDR:$LOCAL_PORT"
-# Create a pool entry for use in sites.xml
-create_pool_entry()
- echo Creating pool entry
GENSITES_ARGS=""
if [ -f "$CONFIG_FILE" ]; then
GENSITES_ARGS=" -p $CONFIG_FILE "
@@ -221,22 +224,80 @@
GENSITES_ARGS=" persistent-coasters "
fi
- gensites $GENSITES_ARGS > sites.xml
+ # Give defaults to gensites variables if needed
+ if [ -z "$JOBSPERNODE" ]; then
+ export JOBSPERNODE=1
+ fi
+ if [ -z "$JOBTHROTTLE" ]; then
+ export JOBTHROTTLE=0
+ fi
+ if [ -z "$WORK" ]; then
+ export WORK=/tmp
+ fi
+ gensites -n $NAME $GENSITES_ARGS > $COASTER_DIR/sites.xml
+# Display status of services
display_status()
+ count=0
+ services=""
+ if [ -n "$NAME" ]; then
+ services=$SERVICE_DIR/$NAME
+ else
+ services=$( get_services )
+ fi
+ for service in $services
do
echo -e "\nName: $(basename $service )"
- echo "PID: $( cat $service/pid )"
+ PID=$( cat $service/pid )
+ echo "PID: $PID"
+ ps -p $PID > /dev/null 2>&1
+ if [ "$?" -eq 0 ]; then
+ echo Status: Running
+ else
+ echo Status: Failed
+ fi
echo "Service port: $( cat $service/service.port )"
echo "Local port: $( cat $service/local.port )"
done
- echo
+ if [ "$count" -gt 0 ]; then
+ echo
+ else
+ echo "No services found"
+ fi
+# Generate XML
+generate_xml()
+ count=0
+ echo "<?xml version=\"1.0\" encoding=\"UTF-8\"?>"
+ echo -e "<config xmlns=\"http://www.ci.uchicago.edu/swift/SwiftSites\">\n"
+ services=""
+ else
+ fi
+ do
+ cat $service/sites.xml | grep -v "<?xml" | grep -v "<config" | grep -v "</config>"
+ echo
+ done
+ echo "</config>"
# Parse command line arguments
+START=0; STOP=0; STATUS=0; XML=0
while [ $# -gt 0 ]; do
case $1 in
-conf) CMDLN_CONF=$2; shift 2;;
@@ -244,14 +305,18 @@
-stop) STOP=1; shift;;
-status) STATUS=1; shift;;
-name) NAME=$2; shift 2;;
+ -xml) XML=1; shift;;
*) echo "Do not recognize command line option: $1" 1>&2; exit 1;;
esac
done
+if [ $(($START+$STOP+$STATUS+$XML)) != 1 ]; then
+ crash "Usage fail"
+fi
# Wait until finished processing command line arguments before starting or stopping the service
if [ "$START" == 1 ]; then
start_service
- create_pool_entry
exit 0
fi
@@ -265,3 +330,9 @@
exit 0
fi
+if [ "$XML" == 1 ]; then
+ generate_xml
+ exit 0
+fi
More information about the Swift-commit
