[Swift-commit] r7258 - trunk/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Thu Oct 31 16:48:45 CDT 2013
Author: davidk
Date: 2013-10-31 16:48:45 -0500 (Thu, 31 Oct 2013)
New Revision: 7258
Modified:
   trunk/bin/gensites
Log:
Add ability to update a pool name (-n)
Modified: trunk/bin/gensites
--- trunk/bin/gensites	2013-10-31 18:59:55 UTC (rev 7257)
+++ trunk/bin/gensites	2013-10-31 21:48:45 UTC (rev 7258)
@@ -75,6 +75,7 @@
       -L) TEMPLATE_DIRECTORY=$2; verify_not_null template_directory $TEMPLATE_DIRECTORY; shift ;;
       -l) LIST_SPECIFIC_TEMPLATE=1 ;;
       -T) LIST_TEMPLATES=1 ;;
+      -n) NEW_TEMPLATE_NAME=$2; verify_not_null new_template_name $NEW_TEMPLATE_NAME; shift ;;
       -h|-help|-?) usage ;;
        *) TEMPLATE=$1 ;;
    esac
@@ -151,14 +152,7 @@
 fi
 # Setup for creating a TC file
-if [ -f "$PROPERTIES_FILE" ]; then
-   if [ -n "`grep -e app $PROPERTIES_FILE`" ]; then
-      #if [ -f "tc.data" ]; then
-      #   mv tc.data tc.data.old
-      #fi
-      HOSTS=`grep -i "pool handle" $TEMPLATE_PATH|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
-   fi
-fi
+HOSTS=`grep -i "pool handle" $TEMPLATE_PATH|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
 # Parse values into variables for later sed processing
@@ -214,10 +208,10 @@
    fi
    SED_COMMAND+="-e s@"\_$value\_"@${!value}@g "
 done
+SED_COMMAND+=" -e s@\"$HOSTS\"@\"$NEW_TEMPLATE_NAME\"@g "
 len=$( echo $SED_COMMAND |wc -w )
 if [ $len -gt 1 ]; then
    $SED_COMMAND $TEMPLATE_PATH
 else
    cat $TEMPLATE_PATH
 fi
