[Swift-commit] cog r3819
swift at ci.uchicago.edu
Fri Oct 25 16:30:03 CDT 2013
r3819 | yadunand | 2013-10-25 16:25:05 -0500 (Fri, 25 Oct 2013) | 11 lines
Issue with destructor invoked at end of block fixed.
CoasterSWIGClientSettings, works with no crashes.
Added :
CoasterLoop* CoasterSWIGLoopCreate(void);
int CoasterSWIGLoopDestroy(CoasterLoop* loop);
int CoasterSWIGClientDestroy(CoasterClient *client);
Tests for above changes.
Index: modules/provider-coaster-c-client/src/CoasterSWIG.h
--- modules/provider-coaster-c-client/src/CoasterSWIG.h (revision 3818)
+++ modules/provider-coaster-c-client/src/CoasterSWIG.h (working copy)
@@ -1,14 +1,24 @@
#include "CoasterClient.h"
+//#include "CoasterLoop.h"
#ifdef SWIG
%module coaster
#include "CoasterSWIG.h"
+ #include "CoasterLoop.h"
#endif
-CoasterClient* CoasterSWIGClientCreate(char* serviceURL);
+CoasterLoop* CoasterSWIGLoopCreate(void);
+int CoasterSWIGLoopDestroy(CoasterLoop* loop);
+CoasterClient* CoasterSWIGClientCreate(CoasterLoop &loop, char* serviceURL);
+int CoasterSWIGClientDestroy(CoasterClient *client);
int CoasterSWIGClientSettings(CoasterClient *client, char *settings);
Index: modules/provider-coaster-c-client/src/CoasterSWIG.cpp
--- modules/provider-coaster-c-client/src/CoasterSWIG.cpp (revision 3818)
+++ modules/provider-coaster-c-client/src/CoasterSWIG.cpp (working copy)
@@ -5,9 +5,15 @@
#include <vector>
#include <CoasterSWIG.h>
+#include "CoasterLoop.h"
+#include "CoasterClient.h"
+#include "Settings.h"
+#include "Job.h"
using namespace std;
+/** CoasterSWIGLoopCreate : create, starts and returns
+ * a pointer to a CoasterLoop object.
cout << "CoasterSWIGLoopCreate()..." << endl;
@@ -16,14 +22,25 @@
return loop;
- cout << "CoasterSWIGClientCreate(" << serviceURL << ")..." << endl;
- CoasterLoop loop;
- loop.start();
- CoasterClient* result = new CoasterClient(serviceURL, loop);
+ delete(loop);
+ return 0;
+ cout << "CoasterSWIGClientCreate(" << serviceURL << ")..." << endl;
+ CoasterClient* client = new CoasterClient(serviceURL, loop);
+ return client;
+ delete(client);
+ return 0;
Settings s;
@@ -50,6 +67,6 @@
//TODO: SegFaulting here. Why ?
cout << "client->getURL() : " << client->getURL() << endl ;
- //client->setOptions(s);
+ client->setOptions(s);
return 0;
Index: modules/provider-coaster-c-client/tests/tcl/coaster-loop-start-stop.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-loop-start-stop.tcl (revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-loop-start-stop.tcl (revision 3819)
@@ -0,0 +1,11 @@
+load ../../src/.libs/libcoasterclient.so
+set loop_ptr [CoasterSWIGLoopCreate]
+set client_ptr [CoasterSWIGClientCreate $loop_ptr 140.221.8.81:40568]
+set rcode [CoasterSWIGClientDestroy $client_ptr]
+set rcode [CoasterSWIGLoopDestroy $loop_ptr]
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-3.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-3.tcl (revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-3.tcl (revision 3819)
@@ -0,0 +1,7 @@
+set x [CoasterSWIGClientSettings $client_ptr "SLOTS=1,MAX_NODES=1"]
More information about the Swift-commit
