[Swift-commit] cog r3818
    swift at ci.uchicago.edu
    Fri Oct 25 16:05:03 CDT 2013
r3818 | yadunand | 2013-10-25 16:01:00 -0500 (Fri, 25 Oct 2013) | 1 line
Adding CoasterSWIGClientSettings. Broken due to destructor causing loop to stop
Index: modules/provider-coaster-c-client/configure
--- modules/provider-coaster-c-client/configure	(revision 3817)
+++ modules/provider-coaster-c-client/configure	(working copy)
@@ -1385,10 +1385,8 @@
   --enable-static[=PKGS]  build static libraries [default=yes]
   --enable-fast-install[=PKGS]
                           optimize for fast installation [default=yes]
-  --enable-dependency-tracking
-                          do not reject slow dependency extractors
-  --disable-dependency-tracking
-                          speeds up one-time build
+  --disable-dependency-tracking  speeds up one-time build
+  --enable-dependency-tracking   do not reject slow dependency extractors
   --disable-libtool-lock  avoid locking (might break parallel builds)
   --enable-debug          enable debugging symbols and disable compiler
                           optimizations (def=no)
@@ -2405,7 +2403,7 @@
 #AC_CONFIG_HEADERS([config.h])
-am__api_version='1.12'
+am__api_version='1.11'
 # Find a good install program.  We prefer a C program (faster),
 # so one script is as good as another.  But avoid the broken or
@@ -2502,6 +2500,9 @@
 { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether build environment is sane" >&5
 $as_echo_n "checking whether build environment is sane... " >&6; }
+# Just in case
+sleep 1
+echo timestamp > conftest.file
 # Reject unsafe characters in $srcdir or the absolute working directory
 # name.  Accept space and tab only in the latter.
 am_lf='
@@ -2512,40 +2513,32 @@
 esac
 case $srcdir in
   *[\\\"\#\$\&\'\`$am_lf\ \	]*)
-    as_fn_error $? "unsafe srcdir value: '$srcdir'" "$LINENO" 5;;
+    as_fn_error $? "unsafe srcdir value: \`$srcdir'" "$LINENO" 5;;
 esac
-# Do 'set' in a subshell so we don't clobber the current shell's
+# Do `set' in a subshell so we don't clobber the current shell's
 # arguments.  Must try -L first in case configure is actually a
 # symlink; some systems play weird games with the mod time of symlinks
 # (eg FreeBSD returns the mod time of the symlink's containing
 # directory).
 if (
-   am_has_slept=no
-   for am_try in 1 2; do
-     echo "timestamp, slept: $am_has_slept" > conftest.file
-     set X `ls -Lt "$srcdir/configure" conftest.file 2> /dev/null`
-     if test "$*" = "X"; then
-	# -L didn't work.
-	set X `ls -t "$srcdir/configure" conftest.file`
-     fi
-     if test "$*" != "X $srcdir/configure conftest.file" \
-	&& test "$*" != "X conftest.file $srcdir/configure"; then
+   set X `ls -Lt "$srcdir/configure" conftest.file 2> /dev/null`
+   if test "$*" = "X"; then
+      # -L didn't work.
+      set X `ls -t "$srcdir/configure" conftest.file`
+   fi
+   rm -f conftest.file
+   if test "$*" != "X $srcdir/configure conftest.file" \
+      && test "$*" != "X conftest.file $srcdir/configure"; then
-	# If neither matched, then we have a broken ls.  This can happen
-	# if, for instance, CONFIG_SHELL is bash and it inherits a
-	# broken ls alias from the environment.  This has actually
-	# happened.  Such a system could not be considered "sane".
-	as_fn_error $? "ls -t appears to fail.  Make sure there is not a broken
-  alias in your environment" "$LINENO" 5
-     fi
-     if test "$2" = conftest.file || test $am_try -eq 2; then
-       break
-     fi
-     # Just in case.
-     sleep 1
-     am_has_slept=yes
-   done
+      # If neither matched, then we have a broken ls.  This can happen
+      # if, for instance, CONFIG_SHELL is bash and it inherits a
+      # broken ls alias from the environment.  This has actually
+      # happened.  Such a system could not be considered "sane".
+      as_fn_error $? "ls -t appears to fail.  Make sure there is not a broken
+alias in your environment" "$LINENO" 5
+   fi
 then
@@ -2557,16 +2550,6 @@
 fi
 { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
 $as_echo "yes" >&6; }
-# If we didn't sleep, we still need to ensure time stamps of config.status and
-# generated files are strictly newer.
-am_sleep_pid=
-if grep 'slept: no' conftest.file >/dev/null 2>&1; then
-  ( sleep 1 ) &
-  am_sleep_pid=$!
-fi
-rm -f conftest.file
 test "$program_prefix" != NONE &&
   program_transform_name="s&^&$program_prefix&;$program_transform_name"
 # Use a double $ so make ignores it.
@@ -2593,8 +2576,8 @@
   am_missing_run="$MISSING --run "
 else
   am_missing_run=
-  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: 'missing' script is too old or missing" >&5
-$as_echo "$as_me: WARNING: 'missing' script is too old or missing" >&2;}
+  { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: \`missing' script is too old or missing" >&5
+$as_echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
 fi
 if test x"${install_sh}" != xset; then
@@ -2606,10 +2589,10 @@
   esac
 fi
-# Installed binaries are usually stripped using 'strip' when the user
-# run "make install-strip".  However 'strip' might not be the right
+# Installed binaries are usually stripped using `strip' when the user
+# run `make install-strip'.  However `strip' might not be the right
 # tool to use in cross-compilation environments, therefore Automake
-# will honor the 'STRIP' environment variable to overrule this program.
+# will honor the `STRIP' environment variable to overrule this program.
 if test "$cross_compiling" != no; then
   if test -n "$ac_tool_prefix"; then
   # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
@@ -2748,6 +2731,12 @@
 { $as_echo "$as_me:${as_lineno-$LINENO}: result: $MKDIR_P" >&5
 $as_echo "$MKDIR_P" >&6; }
+mkdir_p="$MKDIR_P"
+case $mkdir_p in
+  */*) mkdir_p="\$(top_builddir)/$mkdir_p" ;;
+esac
 for ac_prog in gawk mawk nawk awk
 do
   # Extract the first word of "$ac_prog", so it can be a program name with args.
@@ -2880,12 +2869,6 @@
 MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
-# For better backward compatibility.  To be removed once Automake 1.9.x
-# dies out for good.  For more background, see:
-# <http://lists.gnu.org/archive/html/automake/2012-07/msg00001.html>
-# <http://lists.gnu.org/archive/html/automake/2012-07/msg00014.html>
-mkdir_p='$(MKDIR_P)'
 # We need awk for the "check" target.  The system "awk" is bad on
 # some platforms.
 # Always define AMTAR for backward compatibility.  Yes, it's still used
@@ -3083,7 +3066,7 @@
 _am_result=none
 # First try GNU make style include.
 echo "include confinc" > confmf
-# Ignore all kinds of additional output from 'make'.
+# Ignore all kinds of additional output from `make'.
 case `$am_make -s -f confmf 2> /dev/null` in #(
 *the\ am__doit\ target*)
   am__include=include
@@ -3928,8 +3911,8 @@
   # We make a subdir and do the tests there.  Otherwise we can end up
   # making bogus files that we don't know about and never remove.  For
   # instance it was reported that on HP-UX the gcc test will end up
-  # making a dummy file named 'D' -- because '-MD' means "put the output
-  # in D".
+  # making a dummy file named `D' -- because `-MD' means `put the output
+  # in D'.
   rm -rf conftest.dir
   mkdir conftest.dir
   # Copy depcomp to subdir because otherwise we won't find it if we're
@@ -3964,16 +3947,16 @@
     : > sub/conftest.c
     for i in 1 2 3 4 5 6; do
       echo '#include "conftst'$i'.h"' >> sub/conftest.c
-      # Using ": > sub/conftst$i.h" creates only sub/conftst1.h with
-      # Solaris 10 /bin/sh.
-      echo '/* dummy */' > sub/conftst$i.h
+      # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
+      # Solaris 8's {/usr,}/bin/sh.
+      touch sub/conftst$i.h
     done
     echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
-    # We check with '-c' and '-o' for the sake of the "dashmstdout"
+    # We check with `-c' and `-o' for the sake of the "dashmstdout"
     # mode.  It turns out that the SunPro C++ compiler does not properly
-    # handle '-M -o', and we need to detect this.  Also, some Intel
-    # versions had trouble with output in subdirs.
+    # handle `-M -o', and we need to detect this.  Also, some Intel
+    # versions had trouble with output in subdirs
     am__obj=sub/conftest.${OBJEXT-o}
     am__minus_obj="-o $am__obj"
     case $depmode in
@@ -3982,8 +3965,8 @@
       test "$am__universal" = false || continue
     nosideeffect)
-      # After this tag, mechanisms are not by side-effect, so they'll
-      # only be used when explicitly requested.
+      # after this tag, mechanisms are not by side-effect, so they'll
+      # only be used when explicitly requested
       if test "x$enable_dependency_tracking" = xyes; then
 	continue
       else
@@ -3991,7 +3974,7 @@
       fi
     msvc7 | msvc7msys | msvisualcpp | msvcmsys)
-      # This compiler won't grok '-c -o', but also, the minuso test has
+      # This compiler won't grok `-c -o', but also, the minuso test has
       # not run yet.  These depmodes are late enough in the game, and
       # so weak that their functioning should not be impacted.
       am__obj=conftest.${OBJEXT-o}
@@ -5212,7 +5195,7 @@
   lt_cv_deplibs_check_method=pass_all
-netbsd*)
+netbsd* | netbsdelf*-gnu)
   if echo __ELF__ | $CC -E - | $GREP __ELF__ > /dev/null; then
     lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
   else
@@ -8609,6 +8592,9 @@
   openbsd*)
     with_gnu_ld=no
+  linux* | k*bsd*-gnu | gnu*)
+    link_all_deplibs=no
   esac
   ld_shlibs=yes
@@ -8830,7 +8816,7 @@
       fi
-    netbsd*)
+    netbsd* | netbsdelf*-gnu)
       if echo __ELF__ | $CC -E - | $GREP __ELF__ >/dev/null; then
 	archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
 	wlarc=
@@ -9007,6 +8993,7 @@
 	if test "$aix_use_runtimelinking" = yes; then
 	  shared_flag="$shared_flag "'${wl}-G'
 	fi
       else
 	# not using gcc
 	if test "$host_cpu" = ia64; then
@@ -9460,7 +9447,7 @@
       link_all_deplibs=yes
-    netbsd*)
 	archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
       else
@@ -10488,6 +10475,18 @@
   dynamic_linker='GNU/Linux ld.so'
+netbsdelf*-gnu)
+  version_type=linux
+  need_lib_prefix=no
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  soname_spec='${libname}${release}${shared_ext}$major'
+  shlibpath_var=LD_LIBRARY_PATH
+  shlibpath_overrides_runpath=no
+  hardcode_into_libs=yes
+  dynamic_linker='NetBSD ld.elf_so'
 netbsd*)
   version_type=sunos
   need_lib_prefix=no
@@ -11726,8 +11725,8 @@
-  # in D".
+  # in D'.
   rm -rf conftest.dir
   mkdir conftest.dir
@@ -11762,16 +11761,16 @@
     : > sub/conftest.c
     done
     case $depmode in
@@ -11780,8 +11779,8 @@
     nosideeffect)
 	continue
       else
@@ -11789,7 +11788,7 @@
       fi
@@ -13741,7 +13740,7 @@
 	esac
-      netbsd*)
       *qnx* | *nto*)
         # QNX uses GNU C++, but need to define -shared option too, otherwise
@@ -14112,6 +14111,9 @@
     esac
+    link_all_deplibs_CXX=no
     export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
@@ -14737,6 +14739,18 @@
+netbsdelf*-gnu)
+  need_version=no
 netbsd*)
   version_type=sunos
   need_lib_prefix=no
@@ -15314,8 +15328,8 @@
-  # in D".
+  # in D'.
   rm -rf conftest.dir
   mkdir conftest.dir
@@ -15350,16 +15364,16 @@
     : > sub/conftest.c
     done
     case $depmode in
@@ -15368,8 +15382,8 @@
     nosideeffect)
 	continue
       else
@@ -15377,7 +15391,7 @@
       fi
@@ -15982,8 +15996,8 @@
-  # in D".
+  # in D'.
   rm -rf conftest.dir
   mkdir conftest.dir
@@ -16018,16 +16032,16 @@
     : > sub/conftest.c
     done
     case $depmode in
@@ -16036,8 +16050,8 @@
     nosideeffect)
 	continue
       else
@@ -16045,7 +16059,7 @@
       fi
@@ -16914,14 +16928,6 @@
 LTLIBOBJS=$ac_ltlibobjs
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking that generated files are newer than configure" >&5
-$as_echo_n "checking that generated files are newer than configure... " >&6; }
-   if test -n "$am_sleep_pid"; then
-     # Hide warnings about reused PIDs.
-     wait $am_sleep_pid 2>/dev/null
-   fi
-   { $as_echo "$as_me:${as_lineno-$LINENO}: result: done" >&5
-$as_echo "done" >&6; }
  if test -n "$EXEEXT"; then
   am__EXEEXT_TRUE=
   am__EXEEXT_FALSE='#'
@@ -18360,7 +18366,7 @@
     # Strip MF so we end up with the name of the file.
     mf=`echo "$mf" | sed -e 's/:.*$//'`
     # Check whether this is an Automake generated Makefile or not.
-    # We used to match only the files named 'Makefile.in', but
+    # We used to match only the files named `Makefile.in', but
     # some people rename them; so instead we look at the file content.
     # Grep'ing the first line is not enough: some people post-process
     # each Makefile.in and add a new line on top of each file to say so.
@@ -18394,19 +18400,21 @@
       continue
     fi
     # Extract the definition of DEPDIR, am__include, and am__quote
-    # from the Makefile without running 'make'.
+    # from the Makefile without running `make'.
     DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
     test -z "$DEPDIR" && continue
     am__include=`sed -n 's/^am__include = //p' < "$mf"`
     test -z "am__include" && continue
     am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
+    # When using ansi2knr, U may be empty or an underscore; expand it
+    U=`sed -n 's/^U = //p' < "$mf"`
     # Find all dependency output files, they are included files with
     # $(DEPDIR) in their names.  We invoke sed twice because it is the
     # simplest approach to changing $(DEPDIR) to its actual value in the
     # expansion.
     for file in `sed -n "
       s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
-	 sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g'`; do
+	 sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
       # Make sure the directory exists.
       test -f "$dirpart/$file" && continue
       fdir=`$as_dirname -- "$file" ||
Index: modules/provider-coaster-c-client/src/CoasterSWIG.h
--- modules/provider-coaster-c-client/src/CoasterSWIG.h	(revision 3817)
+++ modules/provider-coaster-c-client/src/CoasterSWIG.h	(working copy)
@@ -7,6 +7,8 @@
   #include "CoasterClient.h"
   #include "CoasterSWIG.h"
-#endif
+#endif
 CoasterClient* CoasterSWIGClientCreate(char* serviceURL);
+int CoasterSWIGClientSettings(CoasterClient *client, char *settings);
Index: modules/provider-coaster-c-client/src/CoasterSWIG.cpp
--- modules/provider-coaster-c-client/src/CoasterSWIG.cpp	(revision 3817)
+++ modules/provider-coaster-c-client/src/CoasterSWIG.cpp	(working copy)
@@ -1,10 +1,21 @@
 #include <iostream>
+#include <stdlib.h>
+#include <string>
+#include <sstream>
+#include <vector>
 #include <CoasterSWIG.h>
 using namespace std;
+CoasterLoop* CoasterSWIGLoopCreate(void)
+    cout << "CoasterSWIGLoopCreate()..." << endl;
+    CoasterLoop *loop = new CoasterLoop();
+    loop->start();
+    return loop;
   cout << "CoasterSWIGClientCreate(" << serviceURL << ")..." << endl;
@@ -13,3 +24,32 @@
   CoasterClient* result = new CoasterClient(serviceURL, loop);
+    Settings s;
+    cout << "CoasterSWIGClientSettings(" << settings << ")" <<endl;
+    cout << "Client : [" << (void *) client << "]"<<endl;
+    // Parsing logic
+    // K1=V1, K2=V2 is the format of the settings string
+    std::vector<std::string> elems;
+    std::stringstream ss(settings);
+    std::string item, key, value;
+    while (std::getline(ss, item, ',')) {
+        elems.push_back(item);
+        std::stringstream kv(item);
+        std::string kv_item;
+        std::getline(kv, kv_item, '=');
+        key = kv_item;
+        std::getline(kv, kv_item);
+        value = kv_item;
+        s.set(key, value);
+        cout << "Key,Value : " << key <<", "<<value << endl;
+    //TODO: SegFaulting here. Why ?
+    cout << "client->getURL() : " << client->getURL() << endl ;
+    //client->setOptions(s);
+    return 0;
Index: modules/provider-coaster-c-client/tests/c++/a.out
Cannot display: file marked as a binary type.
svn:mime-type = application/octet-stream
Property changes on: modules/provider-coaster-c-client/tests/c++/a.out
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
   + application/octet-stream
Index: modules/provider-coaster-c-client/tests/c++/parse.cpp
--- modules/provider-coaster-c-client/tests/c++/parse.cpp	(revision 0)
+++ modules/provider-coaster-c-client/tests/c++/parse.cpp	(revision 3818)
@@ -0,0 +1,60 @@
+#include <iostream>
+#include <string>
+#include <sstream>
+#include <vector>
+#include <typeinfo>
+//#include <list>
+//#include <iostream>
+//#include <algorithm>
+//#include <iterator>
+using namespace std;
+std::vector<std::string> split(const std::string &s, char delim) {
+    std::stringstream ss(s);
+    std::string item;
+    while (std::getline(ss, item, delim)) {
+        cout << "Key : " << kv_item << endl;
+        cout << "Value : " << kv_item << endl;
+    return elems;
+int main (void)
+    std::vector<std::string> settings = split("SLOTS=1,JOBS_PER_NODE=2", ',');
+    return 0;
+Instead of copying the extracted tokens to an output stream, one could insert them into a container, using the same generic copy algorithm.
+ vector<string> tokens;
+copy(istream_iterator<string>(iss),
+     istream_iterator<string>(),
+     back_inserter<vector<string> >(tokens));
+/*The settings string will be of the format
+ * key1=v1,key2=v2
+    std::vector<std::string> pair;
+    for(std::vector<std::string>::iterator it = elems.begin(); it != elems.end(); ++it) {
+        pair << *it;
+        cout << *it <<" Type : " << typeid(pair).name() << endl;
+    return elems;
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-2.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-2.tcl	(revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-2.tcl	(revision 3818)
@@ -0,0 +1,7 @@
+load ../../src/.libs/libcoasterclient.so
+set client_ptr [CoasterSWIGClientCreate 140.221.8.81:40568]
+set x [CoasterSWIGClientSettings $client_ptr "SLOTS=1,MAX_NODES=1"]
+puts $x
+#CoasterSWIGTest "SLOTS=1,MAX_NODES=1"
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-1.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-1.tcl	(revision 3817)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-1.tcl	(working copy)
@@ -1,4 +1,3 @@
-load src/.libs/libcoasterclient.so
 CoasterSWIGClientCreate http://localhost
Index: modules/provider-coaster-c-client/libtool
--- modules/provider-coaster-c-client/libtool	(revision 3817)
+++ modules/provider-coaster-c-client/libtool	(working copy)
@@ -1,8 +1,8 @@
-#! /bin/bash
+#! /bin/sh
 # libtool - Provide generalized library-building support services.
 # Generated automatically by config.status (coaster-c-client) 1.0
-# Libtool was configured on host wozniak-laptop-u:
+# Libtool was configured on host thrash:
 # NOTE: Changes made to this file will be lost: look at ltmain.sh.
 #   Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003, 2004, 2005,
@@ -56,7 +56,7 @@
 fast_install=yes
 # Shell to use when invoking shell scripts.
-SHELL="/bin/bash"
+SHELL="/bin/sh"
 # An echo program that protects backslashes.
 ECHO="printf %s\\n"
@@ -96,7 +96,7 @@
 LN_S="ln -s"
 # What is the maximum length of a command?
-max_cmd_len=1572864
+max_cmd_len=3458764513820540925
 # Object file suffix (normally "o").
 objext=o
@@ -272,10 +272,10 @@
 # Compile-time system search path for libraries.
-sys_lib_search_path_spec="/usr/lib/gcc/x86_64-linux-gnu/4.7 /usr/lib/x86_64-linux-gnu /usr/lib /lib/x86_64-linux-gnu /lib "
+sys_lib_search_path_spec="/usr/lib/gcc/x86_64-linux-gnu/4.6 /usr/lib/x86_64-linux-gnu /usr/lib /lib/x86_64-linux-gnu /lib "
 # Run-time system search path for libraries.
-sys_lib_dlsearch_path_spec="/lib /usr/lib /lib/i386-linux-gnu /usr/lib/i386-linux-gnu /lib/i686-linux-gnu /usr/lib/i686-linux-gnu /usr/local/lib /usr/lib/nvidia-settings-310 /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/mesa-egl /usr/lib/nvidia-310 /usr/lib32/nvidia-310 "
+sys_lib_dlsearch_path_spec="/lib /usr/lib /usr/local/lib /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/mesa /lib32 /usr/lib32 "
 # Whether dlopen is supported.
 dlopen_support=unknown
@@ -399,7 +399,7 @@
 inherit_rpath=no
 # Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=unknown
+link_all_deplibs=no
 # Set to "yes" if exported symbols are required.
 always_export_symbols=no
@@ -513,7 +513,7 @@
 #         compiler:		$LTCC
 #         compiler flags:		$LTCFLAGS
 #         linker:		$LD (gnu? $with_gnu_ld)
-#         $progname:	(GNU libtool) 2.4.2
+#         $progname:	(GNU libtool) 2.4.2 Debian-2.4.2-1ubuntu1
 #         automake:	$automake_version
 #         autoconf:	$autoconf_version
@@ -523,7 +523,7 @@
 PROGRAM=libtool
 PACKAGE=libtool
-VERSION=2.4.2
+VERSION="2.4.2 Debian-2.4.2-1ubuntu1"
 TIMESTAMP=""
 package_revision=1.3337
@@ -6560,7 +6560,10 @@
 	case $pass in
 	dlopen) libs="$dlfiles" ;;
 	dlpreopen) libs="$dlprefiles" ;;
-	link) libs="$deplibs %DEPLIBS% $dependency_libs" ;;
+	link)
+	  libs="$deplibs %DEPLIBS%"
+	  test "X$link_all_deplibs" != Xno && libs="$libs $dependency_libs"
 	esac
       fi
       if test "$linkmode,$pass" = "lib,dlpreopen"; then
@@ -6880,19 +6883,19 @@
 	    # It is a libtool convenience library, so add in its objects.
 	    convenience+=" $ladir/$objdir/$old_library"
 	    old_convenience+=" $ladir/$objdir/$old_library"
+	    tmp_libs=
+	    for deplib in $dependency_libs; do
+	      deplibs="$deplib $deplibs"
+	      if $opt_preserve_dup_deps ; then
+		case "$tmp_libs " in
+		*" $deplib "*) specialdeplibs+=" $deplib" ;;
+		esac
+	      fi
+	      tmp_libs+=" $deplib"
+	    done
 	  elif test "$linkmode" != prog && test "$linkmode" != lib; then
 	    func_fatal_error "\`$lib' is not a convenience library"
 	  fi
-	  tmp_libs=
-	  for deplib in $dependency_libs; do
-	    deplibs="$deplib $deplibs"
-	    if $opt_preserve_dup_deps ; then
-	      case "$tmp_libs " in
-	      *" $deplib "*) specialdeplibs+=" $deplib" ;;
-	      esac
-	    fi
-	    tmp_libs+=" $deplib"
-	  done
 	  continue
 	fi # $pass = conv
@@ -7785,6 +7788,9 @@
 	    revision="$number_minor"
 	    lt_irix_increment=no
+	    func_fatal_configuration "$modename: unknown library version type \`$version_type'"
 	  esac
 	no)
@@ -10197,7 +10203,7 @@
 inherit_rpath=no
@@ -10224,17 +10230,17 @@
 hardcode_action=immediate
 # The directories searched by this compiler when creating a shared library.
-compiler_lib_search_dirs="/usr/lib/gcc/x86_64-linux-gnu/4.7 /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../../lib /lib/x86_64-linux-gnu /lib/../lib /usr/lib/x86_64-linux-gnu /usr/lib/../lib /usr/lib/gcc/x86_64-linux-gnu/4.7/../../.."
+compiler_lib_search_dirs="/usr/lib/gcc/x86_64-linux-gnu/4.6 /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib /lib/x86_64-linux-gnu /lib/../lib /usr/lib/x86_64-linux-gnu /usr/lib/../lib /usr/lib/gcc/x86_64-linux-gnu/4.6/../../.."
 # Dependencies to place before and after the objects being linked to
 # create a shared library.
-predep_objects="/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.7/crtbeginS.o"
-postdep_objects="/usr/lib/gcc/x86_64-linux-gnu/4.7/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crtn.o"
+predep_objects="/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.6/crtbeginS.o"
+postdep_objects="/usr/lib/gcc/x86_64-linux-gnu/4.6/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crtn.o"
 predeps=""
 postdeps="-lstdc++ -lm -lgcc_s -lc -lgcc_s"
 # The library search path used internally by the compiler when linking
 # a shared library.
-compiler_lib_search_path="-L/usr/lib/gcc/x86_64-linux-gnu/4.7 -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../.."
+compiler_lib_search_path="-L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.."
 # ### END LIBTOOL TAG CONFIG: CXX
Index: modules/provider-coaster-c-client/config/depcomp
--- modules/provider-coaster-c-client/config/depcomp	(revision 3817)
+++ modules/provider-coaster-c-client/config/depcomp	(working copy)
@@ -1 +1 @@
-link /home/wozniak/sfw/automake-1.12.5/share/automake-1.12/depcomp
\ No newline at end of file
+link /usr/share/automake-1.11/depcomp
Index: modules/provider-coaster-c-client/config/missing
--- modules/provider-coaster-c-client/config/missing	(revision 3817)
+++ modules/provider-coaster-c-client/config/missing	(working copy)
@@ -1 +1 @@
-link /home/wozniak/sfw/automake-1.12.5/share/automake-1.12/missing
+link /usr/share/automake-1.11/missing
Index: modules/provider-coaster-c-client/config/config.guess
--- modules/provider-coaster-c-client/config/config.guess	(revision 3817)
+++ modules/provider-coaster-c-client/config/config.guess	(working copy)
@@ -2,9 +2,9 @@
 # Attempt to guess a canonical system name.
 #   Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
 #   2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010,
-#   2011 Free Software Foundation, Inc.
+#   2011, 2012 Free Software Foundation, Inc.
-timestamp='2011-10-01'
+timestamp='2012-02-10'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -17,9 +17,7 @@
 # General Public License for more details.
 # You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 51 Franklin Street - Fifth Floor, Boston, MA
-# 02110-1301, USA.
+# along with this program; if not, see <http://www.gnu.org/licenses/>.
 # As a special exception to the GNU General Public License, if you
 # distribute this file as part of a program that contains a
@@ -57,8 +55,8 @@
 Originally written by Per Bothner.
 Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000,
-2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free
-Software Foundation, Inc.
+2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012
+Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -145,7 +143,7 @@
 case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
     *:NetBSD:*:*)
 	# NetBSD (nbsd) targets should (where applicable) match one or
-	# more of the tupples: *-*-netbsdelf*, *-*-netbsdaout*,
+	# more of the tuples: *-*-netbsdelf*, *-*-netbsdaout*,
 	# *-*-netbsdecoff* and *-*-netbsd*.  For targets that recently
 	# switched to ELF, *-*-netbsd* would select the old
 	# object file format.  This provides both forward
@@ -806,6 +804,9 @@
     *:MINGW*:*)
 	echo ${UNAME_MACHINE}-pc-mingw32
 	exit ;;
+    i*:MSYS*:*)
+	echo ${UNAME_MACHINE}-pc-msys
+	exit ;;
     i*:windows32*:*)
 	# uname -m includes "-pc" on this system.
 	echo ${UNAME_MACHINE}-mingw32
@@ -860,6 +861,13 @@
     i*86:Minix:*:*)
 	echo ${UNAME_MACHINE}-pc-minix
 	exit ;;
+    aarch64:Linux:*:*)
+	echo ${UNAME_MACHINE}-unknown-linux-gnu
+	exit ;;
+    aarch64_be:Linux:*:*)
+	UNAME_MACHINE=aarch64_be
+	exit ;;
     alpha:Linux:*:*)
 	case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
 	  EV5)   UNAME_MACHINE=alphaev5 ;;
@@ -894,16 +902,16 @@
 	exit ;;
     cris:Linux:*:*)
-	echo cris-axis-linux-gnu
+	echo ${UNAME_MACHINE}-axis-linux-gnu
 	exit ;;
     crisv32:Linux:*:*)
-	echo crisv32-axis-linux-gnu
 	exit ;;
     frv:Linux:*:*)
-	echo frv-unknown-linux-gnu
 	exit ;;
     hexagon:Linux:*:*)
-	echo hexagon-unknown-linux-gnu
 	exit ;;
     i*86:Linux:*:*)
 	LIBC=gnu
@@ -945,7 +953,7 @@
 	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
     or32:Linux:*:*)
-	echo or32-unknown-linux-gnu
 	exit ;;
     padre:Linux:*:*)
 	echo sparc-unknown-linux-gnu
@@ -986,7 +994,7 @@
 	echo ${UNAME_MACHINE}-dec-linux-gnu
 	exit ;;
     x86_64:Linux:*:*)
-	echo x86_64-unknown-linux-gnu
 	exit ;;
     xtensa*:Linux:*:*)
@@ -1317,6 +1325,9 @@
     i*86:AROS:*:*)
 	echo ${UNAME_MACHINE}-pc-aros
 	exit ;;
+    x86_64:VMkernel:*:*)
+	echo ${UNAME_MACHINE}-unknown-esx
+	exit ;;
 esac
 #echo '(No uname command or uname output not recognized.)' 1>&2
Index: modules/provider-coaster-c-client/config/config.sub
--- modules/provider-coaster-c-client/config/config.sub	(revision 3817)
+++ modules/provider-coaster-c-client/config/config.sub	(working copy)
@@ -2,9 +2,9 @@
 # Configuration validation subroutine script.
-timestamp='2011-10-08'
 # This file is (in principle) common to ALL GNU software.
 # The presence of a machine in this file suggests that SOME GNU software
@@ -21,9 +21,7 @@
 # GNU General Public License for more details.
-# 02110-1301, USA.
@@ -76,8 +74,8 @@
 GNU config.sub ($timestamp)
@@ -132,6 +130,10 @@
     os=-$maybe_os
     basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
+  android-linux)
+    os=-linux-android
+    basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`-unknown
     basic_machine=`echo $1 | sed 's/-[^-]*$//'`
     if [ $basic_machine != $1 ]
@@ -247,6 +249,7 @@
 	# Some are omitted here because they have special meanings below.
 	1750a | 580 \
 	| a29k \
+	| aarch64 | aarch64_be \
 	| alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
 	| alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
 	| am33_2.0 \
@@ -295,7 +298,7 @@
 	| pdp10 | pdp11 | pj | pjl \
 	| powerpc | powerpc64 | powerpc64le | powerpcle \
 	| pyramid \
-	| rx \
+	| rl78 | rx \
 	| score \
 	| sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
 	| sh64 | sh64le \
@@ -319,8 +322,7 @@
 	c6x)
 		basic_machine=tic6x-unknown
-	m6811 | m68hc11 | m6812 | m68hc12 | picochip)
-		# Motorola 68HC11/12.
+	m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | picochip)
 		basic_machine=$basic_machine-unknown
 		os=-none
@@ -333,7 +335,10 @@
 	strongarm | thumb | xscale)
 		basic_machine=arm-unknown
+	xgate)
+		basic_machine=$basic_machine-unknown
+		os=-none
 	xscaleeb)
 		basic_machine=armeb-unknown
@@ -356,6 +361,7 @@
 	# Recognize the basic CPU types with company name.
 	580-* \
 	| a29k-* \
+	| aarch64-* | aarch64_be-* \
 	| alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
 	| alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
 	| alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
@@ -407,7 +413,7 @@
 	| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
 	| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* \
 	| pyramid-* \
-	| romp-* | rs6000-* | rx-* \
+	| rl78-* | romp-* | rs6000-* | rx-* \
 	| sh-* | sh[1234]-* | sh[24]a-* | sh[24]aeb-* | sh[23]e-* | sh[34]eb-* | sheb-* | shbe-* \
 	| shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
 	| sparc-* | sparc64-* | sparc64b-* | sparc64v-* | sparc86x-* | sparclet-* \
@@ -719,7 +725,6 @@
 	i370-ibm* | ibm*)
 		basic_machine=i370-ibm
-# I'm not sure what "Sysv32" means.  Should this be sysv3.2?
 	i*86v32)
 		basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
 		os=-sysv32
@@ -816,6 +821,10 @@
 	ms1-*)
 		basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
+	msys)
+		basic_machine=i386-pc
+		os=-msys
 	mvs)
 		os=-mvs
@@ -1343,7 +1352,7 @@
 	      | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
 	      | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
 	      | -chorusos* | -chorusrdb* | -cegcc* \
-	      | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
+	      | -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
 	      | -mingw32* | -linux-gnu* | -linux-android* \
 	      | -linux-newlib* | -linux-uclibc* \
 	      | -uxpv* | -beos* | -mpeix* | -udk* \
@@ -1555,9 +1564,6 @@
 	m68000-sun)
 		os=-sunos3
-		# This also exists in the configure program, but was not the
-		# default.
-		# os=-sunos4
 	m68*-cisco)
 		os=-aout
Index: modules/provider-coaster-c-client/config/ltmain.sh
--- modules/provider-coaster-c-client/config/ltmain.sh	(revision 3817)
+++ modules/provider-coaster-c-client/config/ltmain.sh	(working copy)
@@ -70,7 +70,7 @@
 #         compiler:		$LTCC
@@ -80,7 +80,7 @@
 PROGRAM=libtool
 PACKAGE=libtool
-VERSION=2.4.2
 TIMESTAMP=""
@@ -6124,7 +6124,10 @@
 	case $pass in
+	link)
 	esac
       fi
@@ -6444,19 +6447,19 @@
 	    func_append convenience " $ladir/$objdir/$old_library"
 	    func_append old_convenience " $ladir/$objdir/$old_library"
+	    tmp_libs=
+		*" $deplib "*) func_append specialdeplibs " $deplib" ;;
+		esac
+	      fi
+	      func_append tmp_libs " $deplib"
+	    done
 	  fi
-	  tmp_libs=
-	      *" $deplib "*) func_append specialdeplibs " $deplib" ;;
-	      esac
-	    fi
-	    func_append tmp_libs " $deplib"
-	  done
 	  continue
 	fi # $pass = conv
@@ -7349,6 +7352,9 @@
 	  esac
 	no)
Index: modules/provider-coaster-c-client/config/install-sh
--- modules/provider-coaster-c-client/config/install-sh	(revision 3817)
+++ modules/provider-coaster-c-client/config/install-sh	(working copy)
@@ -1,7 +1,7 @@
 #!/bin/sh
 # install - install a program, script, or datafile
-scriptversion=2011-01-19.21; # UTC
+scriptversion=2009-04-28.21; # UTC
 # This originates from X11R5 (mit/util/scripts/install.sh), which was
 # later released in X11R6 (xc/config/util/install.sh) with the
@@ -156,10 +156,6 @@
     -s) stripcmd=$stripprog;;
     -t) dst_arg=$2
-	# Protect names problematic for `test' and other utilities.
-	case $dst_arg in
-	  -* | [=\(\)!]) dst_arg=./$dst_arg;;
-	esac
 	shift;;
     -T) no_target_directory=true;;
@@ -190,10 +186,6 @@
     fi
     shift # arg
     dst_arg=$arg
-    case $dst_arg in
-    esac
   done
 fi
@@ -208,11 +200,7 @@
 fi
 if test -z "$dir_arg"; then
-  do_exit='(exit $ret); exit $ret'
-  trap "ret=129; $do_exit" 1
-  trap "ret=130; $do_exit" 2
-  trap "ret=141; $do_exit" 13
-  trap "ret=143; $do_exit" 15
+  trap '(exit $?); exit' 1 2 13 15
   # Set umask so as not to create temps with too-generous modes.
   # However, 'strip' requires both read and write access to temps.
@@ -240,9 +228,9 @@
 for src
 do
+  # Protect names starting with `-'.
   case $src in
-    -* | [=\(\)!]) src=./$src;;
+    -*) src=./$src;;
   esac
   if test -n "$dir_arg"; then
@@ -264,7 +252,12 @@
       echo "$0: no destination specified." >&2
       exit 1
     fi
     dst=$dst_arg
+    case $dst in
+      -*) dst=./$dst;;
+    esac
     # If destination is a directory, append the input filename; won't work
     # if double slashes aren't ignored.
@@ -392,7 +385,7 @@
       case $dstdir in
 	/*) prefix='/';;
-	[-=\(\)!]*) prefix='./';;
+	-*) prefix='./';;
 	*)  prefix='';;
       esac
@@ -410,7 +403,7 @@
       for d
       do
-	test X"$d" = X && continue
+	test -z "$d" && continue
 	prefix=$prefix$d
 	if test -d "$prefix"; then
Index: modules/provider-coaster-c-client/aclocal.m4
--- modules/provider-coaster-c-client/aclocal.m4	(revision 3817)
+++ modules/provider-coaster-c-client/aclocal.m4	(working copy)
@@ -1,7 +1,8 @@
-# generated automatically by aclocal 1.12.5 -*- Autoconf -*-
+# generated automatically by aclocal 1.11.3 -*- Autoconf -*-
-# Copyright (C) 1996-2012 Free Software Foundation, Inc.
+# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004,
+# 2005, 2006, 2007, 2008, 2009, 2010, 2011 Free Software Foundation,
+# Inc.
 # This file is free software; the Free Software Foundation
 # gives unlimited permission to copy and/or distribute it,
 # with or without modifications, as long as this notice is preserved.
@@ -17,7 +18,7 @@
 [m4_warning([this file was generated for autoconf 2.68.
 You have another version of autoconf.  It may work, but is not guaranteed to.
 If you have problems, you may need to regenerate the build system entirely.
-To do so, use the procedure documented by the package, typically 'autoreconf'.])])
+To do so, use the procedure documented by the package, typically `autoreconf'.])])
 # libtool.m4 - Configure libtool for the host system. -*-Autoconf-*-
@@ -2697,6 +2698,18 @@
+netbsdelf*-gnu)
+  need_version=no
 netbsd*)
   version_type=sunos
   need_lib_prefix=no
@@ -3302,7 +3315,7 @@
-netbsd*)
     lt_cv_deplibs_check_method='match_pattern /lib[[^/]]+(\.so\.[[0-9]]+\.[[0-9]]+|_pic\.a)$'
   else
@@ -4114,7 +4127,7 @@
 	esac
-      netbsd*)
       *qnx* | *nto*)
@@ -4591,6 +4604,9 @@
     esac
+    _LT_TAGVAR(link_all_deplibs, $1)=no
     _LT_TAGVAR(export_symbols_cmds, $1)='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
@@ -4653,6 +4669,9 @@
   openbsd*)
     with_gnu_ld=no
   esac
   _LT_TAGVAR(ld_shlibs, $1)=yes
@@ -4874,7 +4893,7 @@
       fi
-    netbsd*)
 	_LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
 	wlarc=
@@ -5051,6 +5070,7 @@
 	fi
       else
 	# not using gcc
@@ -5355,7 +5375,7 @@
       _LT_TAGVAR(link_all_deplibs, $1)=yes
-    netbsd*)
 	_LT_TAGVAR(archive_cmds, $1)='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
       else
@@ -8606,22 +8626,25 @@
 m4_ifndef([_LT_PROG_FC],		[AC_DEFUN([_LT_PROG_FC])])
 m4_ifndef([_LT_PROG_CXX],		[AC_DEFUN([_LT_PROG_CXX])])
-# Copyright (C) 2002-2012 Free Software Foundation, Inc.
+# Copyright (C) 2002, 2003, 2005, 2006, 2007, 2008, 2011 Free Software
+# Foundation, Inc.
+# serial 1
 # AM_AUTOMAKE_VERSION(VERSION)
 # Automake X.Y traces this macro to ensure aclocal.m4 has been
 # generated from the m4 files accompanying Automake X.Y.
 # (This private macro should not be called outside this file.)
 AC_DEFUN([AM_AUTOMAKE_VERSION],
-[am__api_version='1.12'
+[am__api_version='1.11'
 dnl Some users find AM_AUTOMAKE_VERSION and mistake it for a way to
 dnl require some minimum version.  Point them to the right macro.
-m4_if([$1], [1.12.5], [],
+m4_if([$1], [1.11.3], [],
       [AC_FATAL([Do not call $0, use AM_INIT_AUTOMAKE([$1]).])])dnl
@@ -8637,22 +8660,24 @@
 # Call AM_AUTOMAKE_VERSION and AM_AUTOMAKE_VERSION so they can be traced.
 # This function is AC_REQUIREd by AM_INIT_AUTOMAKE.
 AC_DEFUN([AM_SET_CURRENT_AUTOMAKE_VERSION],
-[AM_AUTOMAKE_VERSION([1.12.5])dnl
+[AM_AUTOMAKE_VERSION([1.11.3])dnl
 m4_ifndef([AC_AUTOCONF_VERSION],
   [m4_copy([m4_PACKAGE_VERSION], [AC_AUTOCONF_VERSION])])dnl
 _AM_AUTOCONF_VERSION(m4_defn([AC_AUTOCONF_VERSION]))])
 # AM_AUX_DIR_EXPAND                                         -*- Autoconf -*-
-# Copyright (C) 2001-2012 Free Software Foundation, Inc.
+# Copyright (C) 2001, 2003, 2005, 2011 Free Software Foundation, Inc.
+# serial 1
 # For projects using AC_CONFIG_AUX_DIR([foo]), Autoconf sets
-# $ac_aux_dir to '$srcdir/foo'.  In other projects, it is set to
-# '$srcdir', '$srcdir/..', or '$srcdir/../..'.
+# $ac_aux_dir to `$srcdir/foo'.  In other projects, it is set to
+# `$srcdir', `$srcdir/..', or `$srcdir/../..'.
 # Of course, Automake must honor this variable whenever it calls a
 # tool from the auxiliary directory.  The problem is that $srcdir (and
@@ -8671,7 +8696,7 @@
 # The reason of the latter failure is that $top_srcdir and $ac_aux_dir
 # are both prefixed by $srcdir.  In an in-source build this is usually
-# harmless because $srcdir is '.', but things will broke when you
+# harmless because $srcdir is `.', but things will broke when you
 # start a VPATH build or use an absolute $srcdir.
 # So we could use something similar to $top_srcdir/$ac_aux_dir/missing,
@@ -8697,19 +8722,22 @@
 # AM_CONDITIONAL                                            -*- Autoconf -*-
-# Copyright (C) 1997-2012 Free Software Foundation, Inc.
+# Copyright (C) 1997, 2000, 2001, 2003, 2004, 2005, 2006, 2008
+# Free Software Foundation, Inc.
+# serial 9
 # AM_CONDITIONAL(NAME, SHELL-CONDITION)
 # Define a conditional.
 AC_DEFUN([AM_CONDITIONAL],
-[AC_PREREQ([2.52])dnl
- m4_if([$1], [TRUE],  [AC_FATAL([$0: invalid condition: $1])],
-       [$1], [FALSE], [AC_FATAL([$0: invalid condition: $1])])dnl
+[AC_PREREQ(2.52)dnl
+ ifelse([$1], [TRUE],  [AC_FATAL([$0: invalid condition: $1])],
+	[$1], [FALSE], [AC_FATAL([$0: invalid condition: $1])])dnl
 AC_SUBST([$1_TRUE])dnl
 AC_SUBST([$1_FALSE])dnl
 _AM_SUBST_NOTMAKE([$1_TRUE])dnl
@@ -8728,14 +8756,16 @@
 Usually this means the macro was only invoked conditionally.]])
 fi])])
-# Copyright (C) 1999-2012 Free Software Foundation, Inc.
+# Copyright (C) 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2009,
+# 2010, 2011 Free Software Foundation, Inc.
+# serial 12
-# There are a few dirty hacks below to avoid letting 'AC_PROG_CC' be
+# There are a few dirty hacks below to avoid letting `AC_PROG_CC' be
 # written in clear, in which case automake, when reading aclocal.m4,
 # will think it sees a *use*, and therefore will trigger all it's
 # C support machinery.  Also note that it means that autoscan, seeing
@@ -8745,7 +8775,7 @@
 # _AM_DEPENDENCIES(NAME)
 # See how the compiler implements dependency checking.
-# NAME is "CC", "CXX", "OBJC", "OBJCXX", "UPC", or "GJC".
+# NAME is "CC", "CXX", "GCJ", or "OBJC".
 # We try a few techniques and use that to set a single cache variable.
 # We don't AC_REQUIRE the corresponding AC_PROG_CC since the latter was
@@ -8758,13 +8788,12 @@
 AC_REQUIRE([AM_MAKE_INCLUDE])dnl
 AC_REQUIRE([AM_DEP_TRACK])dnl
-m4_if([$1], [CC],   [depcc="$CC"   am_compiler_list=],
-      [$1], [CXX],  [depcc="$CXX"  am_compiler_list=],
-      [$1], [OBJC], [depcc="$OBJC" am_compiler_list='gcc3 gcc'],
-      [$1], [OBJCXX], [depcc="$OBJCXX" am_compiler_list='gcc3 gcc'],
-      [$1], [UPC],  [depcc="$UPC"  am_compiler_list=],
-      [$1], [GCJ],  [depcc="$GCJ"  am_compiler_list='gcc3 gcc'],
-                    [depcc="$$1"   am_compiler_list=])
+ifelse([$1], CC,   [depcc="$CC"   am_compiler_list=],
+       [$1], CXX,  [depcc="$CXX"  am_compiler_list=],
+       [$1], OBJC, [depcc="$OBJC" am_compiler_list='gcc3 gcc'],
+       [$1], UPC,  [depcc="$UPC"  am_compiler_list=],
+       [$1], GCJ,  [depcc="$GCJ"  am_compiler_list='gcc3 gcc'],
+                   [depcc="$$1"   am_compiler_list=])
 AC_CACHE_CHECK([dependency style of $depcc],
                [am_cv_$1_dependencies_compiler_type],
@@ -8772,8 +8801,8 @@
-  # in D".
+  # in D'.
   rm -rf conftest.dir
   mkdir conftest.dir
@@ -8813,16 +8842,16 @@
     : > sub/conftest.c
     done
     case $depmode in
@@ -8831,8 +8860,8 @@
     nosideeffect)
 	continue
       else
@@ -8840,7 +8869,7 @@
       fi
@@ -8888,7 +8917,7 @@
 # AM_SET_DEPDIR
 # Choose a directory name for dependency files.
-# This macro is AC_REQUIREd in _AM_DEPENDENCIES.
+# This macro is AC_REQUIREd in _AM_DEPENDENCIES
 AC_DEFUN([AM_SET_DEPDIR],
 [AC_REQUIRE([AM_SET_LEADING_DOT])dnl
 AC_SUBST([DEPDIR], ["${am__leading_dot}deps"])dnl
@@ -8898,13 +8927,9 @@
 # AM_DEP_TRACK
 AC_DEFUN([AM_DEP_TRACK],
-[AC_ARG_ENABLE([dependency-tracking], [dnl
-AS_HELP_STRING(
-  [--enable-dependency-tracking],
-  [do not reject slow dependency extractors])
-AS_HELP_STRING(
-  [--disable-dependency-tracking],
-  [speeds up one-time build])])
+[AC_ARG_ENABLE(dependency-tracking,
+[  --disable-dependency-tracking  speeds up one-time build
+  --enable-dependency-tracking   do not reject slow dependency extractors])
 if test "x$enable_dependency_tracking" != xno; then
   am_depcomp="$ac_aux_dir/depcomp"
   AMDEPBACKSLASH='\'
@@ -8919,12 +8944,14 @@
 # Generate code to set up dependency tracking.              -*- Autoconf -*-
+# Copyright (C) 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2008
+#serial 5
 # _AM_OUTPUT_DEPENDENCY_COMMANDS
@@ -8943,7 +8970,7 @@
@@ -8955,19 +8982,21 @@
       continue
     fi
     # expansion.
       fdir=`AS_DIRNAME(["$file"])`
@@ -8985,7 +9014,7 @@
 # This macro should only be invoked once -- use via AC_REQUIRE.
 # This code is only required when automatic dependency tracking
-# is enabled.  FIXME.  This creates each '.P' file that we will
+# is enabled.  FIXME.  This creates each `.P' file that we will
 # need in order to bootstrap the dependency handling code.
 AC_DEFUN([AM_OUTPUT_DEPENDENCY_COMMANDS],
 [AC_CONFIG_COMMANDS([depfiles],
@@ -8995,12 +9024,15 @@
 # Do all the work for Automake.                             -*- Autoconf -*-
+# 2005, 2006, 2008, 2009 Free Software Foundation, Inc.
+# serial 16
 # This macro actually does too much.  Some checks are only needed if
 # your package does certain things.  But this isn't really a big deal.
@@ -9045,41 +9077,31 @@
 # Define the identity of the package.
 dnl Distinguish between old-style and new-style calls.
 m4_ifval([$2],
-[AC_DIAGNOSE([obsolete],
-[$0: two- and three-arguments forms are deprecated.  For more info, see:
-http://www.gnu.org/software/automake/manual/automake.html#Modernize-AM_INIT_AUTOMAKE-invocation])
-m4_ifval([$3], [_AM_SET_OPTION([no-define])])dnl
+[m4_ifval([$3], [_AM_SET_OPTION([no-define])])dnl
  AC_SUBST([PACKAGE], [$1])dnl
  AC_SUBST([VERSION], [$2])],
 [_AM_SET_OPTIONS([$1])dnl
 dnl Diagnose old-style AC_INIT with new-style AM_AUTOMAKE_INIT.
-m4_if(
-  m4_ifdef([AC_PACKAGE_NAME], [ok]):m4_ifdef([AC_PACKAGE_VERSION], [ok]),
-  [ok:ok],,
+m4_if(m4_ifdef([AC_PACKAGE_NAME], 1)m4_ifdef([AC_PACKAGE_VERSION], 1), 11,,
   [m4_fatal([AC_INIT should be called with package and version arguments])])dnl
  AC_SUBST([PACKAGE], ['AC_PACKAGE_TARNAME'])dnl
  AC_SUBST([VERSION], ['AC_PACKAGE_VERSION'])])dnl
 _AM_IF_OPTION([no-define],,
-[AC_DEFINE_UNQUOTED([PACKAGE], ["$PACKAGE"], [Name of package])
- AC_DEFINE_UNQUOTED([VERSION], ["$VERSION"], [Version number of package])])dnl
+[AC_DEFINE_UNQUOTED(PACKAGE, "$PACKAGE", [Name of package])
+ AC_DEFINE_UNQUOTED(VERSION, "$VERSION", [Version number of package])])dnl
 # Some tools Automake needs.
 AC_REQUIRE([AM_SANITY_CHECK])dnl
 AC_REQUIRE([AC_ARG_PROGRAM])dnl
-AM_MISSING_PROG([ACLOCAL], [aclocal-${am__api_version}])
-AM_MISSING_PROG([AUTOCONF], [autoconf])
-AM_MISSING_PROG([AUTOMAKE], [automake-${am__api_version}])
-AM_MISSING_PROG([AUTOHEADER], [autoheader])
-AM_MISSING_PROG([MAKEINFO], [makeinfo])
+AM_MISSING_PROG(ACLOCAL, aclocal-${am__api_version})
+AM_MISSING_PROG(AUTOCONF, autoconf)
+AM_MISSING_PROG(AUTOMAKE, automake-${am__api_version})
+AM_MISSING_PROG(AUTOHEADER, autoheader)
+AM_MISSING_PROG(MAKEINFO, makeinfo)
 AC_REQUIRE([AM_PROG_INSTALL_SH])dnl
 AC_REQUIRE([AM_PROG_INSTALL_STRIP])dnl
-AC_REQUIRE([AC_PROG_MKDIR_P])dnl
-AC_SUBST([mkdir_p], ['$(MKDIR_P)'])
+AC_REQUIRE([AM_PROG_MKDIR_P])dnl
 # some platforms.
 AC_REQUIRE([AC_PROG_AWK])dnl
@@ -9090,35 +9112,28 @@
 			     [_AM_PROG_TAR([v7])])])
 _AM_IF_OPTION([no-dependencies],,
 [AC_PROVIDE_IFELSE([AC_PROG_CC],
-		  [_AM_DEPENDENCIES([CC])],
-		  [m4_define([AC_PROG_CC],
-			     m4_defn([AC_PROG_CC])[_AM_DEPENDENCIES([CC])])])dnl
+		  [_AM_DEPENDENCIES(CC)],
+		  [define([AC_PROG_CC],
+			  defn([AC_PROG_CC])[_AM_DEPENDENCIES(CC)])])dnl
 AC_PROVIDE_IFELSE([AC_PROG_CXX],
-		  [_AM_DEPENDENCIES([CXX])],
-		  [m4_define([AC_PROG_CXX],
-			     m4_defn([AC_PROG_CXX])[_AM_DEPENDENCIES([CXX])])])dnl
+		  [_AM_DEPENDENCIES(CXX)],
+		  [define([AC_PROG_CXX],
+			  defn([AC_PROG_CXX])[_AM_DEPENDENCIES(CXX)])])dnl
 AC_PROVIDE_IFELSE([AC_PROG_OBJC],
-		  [_AM_DEPENDENCIES([OBJC])],
-		  [m4_define([AC_PROG_OBJC],
-			     m4_defn([AC_PROG_OBJC])[_AM_DEPENDENCIES([OBJC])])])dnl
-dnl Support for Objective C++ was only introduced in Autoconf 2.65,
-dnl but we still cater to Autoconf 2.62.
-m4_ifdef([AC_PROG_OBJCXX],
-[AC_PROVIDE_IFELSE([AC_PROG_OBJCXX],
-		  [_AM_DEPENDENCIES([OBJCXX])],
-		  [m4_define([AC_PROG_OBJCXX],
-			     m4_defn([AC_PROG_OBJCXX])[_AM_DEPENDENCIES([OBJCXX])])])])dnl
+		  [_AM_DEPENDENCIES(OBJC)],
+		  [define([AC_PROG_OBJC],
+			  defn([AC_PROG_OBJC])[_AM_DEPENDENCIES(OBJC)])])dnl
 _AM_IF_OPTION([silent-rules], [AC_REQUIRE([AM_SILENT_RULES])])dnl
-dnl The 'parallel-tests' driver may need to know about EXEEXT, so add the
-dnl 'am__EXEEXT' conditional if _AM_COMPILER_EXEEXT was seen.  This macro
+dnl The `parallel-tests' driver may need to know about EXEEXT, so add the
+dnl `am__EXEEXT' conditional if _AM_COMPILER_EXEEXT was seen.  This macro
 dnl is hooked onto _AC_COMPILER_EXEEXT early, see below.
 AC_CONFIG_COMMANDS_PRE(dnl
 [m4_provide_if([_AM_COMPILER_EXEEXT],
   [AM_CONDITIONAL([am__EXEEXT], [test -n "$EXEEXT"])])])dnl
-dnl Hook into '_AC_COMPILER_EXEEXT' early to learn its expansion.  Do not
+dnl Hook into `_AC_COMPILER_EXEEXT' early to learn its expansion.  Do not
 dnl add the conditional right here, as _AC_COMPILER_EXEEXT may be further
 dnl mangled by Autoconf and run in a shell conditional statement.
 m4_define([_AC_COMPILER_EXEEXT],
@@ -9146,12 +9161,15 @@
 done
 echo "timestamp for $_am_arg" >`AS_DIRNAME(["$_am_arg"])`/stamp-h[]$_am_stamp_count])
+# Copyright (C) 2001, 2003, 2005, 2008, 2011 Free Software Foundation,
+# Inc.
+# serial 1
 # AM_PROG_INSTALL_SH
 # Define $install_sh.
@@ -9165,14 +9183,16 @@
     install_sh="\${SHELL} $am_aux_dir/install-sh"
   esac
 fi
-AC_SUBST([install_sh])])
+AC_SUBST(install_sh)])
-# Copyright (C) 2003-2012 Free Software Foundation, Inc.
+# Copyright (C) 2003, 2005  Free Software Foundation, Inc.
+# serial 2
 # Check whether the underlying file-system supports filenames
 # with a leading dot.  For instance MS-DOS doesn't.
 AC_DEFUN([AM_SET_LEADING_DOT],
@@ -9188,12 +9208,14 @@
 # Check to see how 'make' treats includes.	            -*- Autoconf -*-
+# Copyright (C) 2001, 2002, 2003, 2005, 2009  Free Software Foundation, Inc.
+# serial 4
 # AM_MAKE_INCLUDE()
 # Check to see how make treats includes.
@@ -9211,7 +9233,7 @@
 _am_result=none
   am__include=include
@@ -9238,12 +9260,15 @@
 # Fake the existence of programs that GNU maintainers use.  -*- Autoconf -*-
+# Copyright (C) 1997, 1999, 2000, 2001, 2003, 2004, 2005, 2008
+# serial 6
 # AM_MISSING_PROG(NAME, PROGRAM)
 AC_DEFUN([AM_MISSING_PROG],
@@ -9251,6 +9276,7 @@
 $1=${$1-"${am_missing_run}$2"}
 AC_SUBST($1)])
 # AM_MISSING_HAS_RUN
 # Define MISSING if not defined so far and test if it supports --run.
@@ -9271,18 +9297,50 @@
 else
   am_missing_run=
-  AC_MSG_WARN(['missing' script is too old or missing])
+  AC_MSG_WARN([`missing' script is too old or missing])
 fi
+# Copyright (C) 2003, 2004, 2005, 2006, 2011 Free Software Foundation,
+# Inc.
+# This file is free software; the Free Software Foundation
+# gives unlimited permission to copy and/or distribute it,
+# with or without modifications, as long as this notice is preserved.
+# serial 1
+# AM_PROG_MKDIR_P
+# Check for `mkdir -p'.
+AC_DEFUN([AM_PROG_MKDIR_P],
+[AC_PREREQ([2.60])dnl
+AC_REQUIRE([AC_PROG_MKDIR_P])dnl
+dnl Automake 1.8 to 1.9.6 used to define mkdir_p.  We now use MKDIR_P,
+dnl while keeping a definition of mkdir_p for backward compatibility.
+dnl @MKDIR_P@ is magic: AC_OUTPUT adjusts its value for each Makefile.
+dnl However we cannot define mkdir_p as $(MKDIR_P) for the sake of
+dnl Makefile.ins that do not define MKDIR_P, so we do our own
+dnl adjustment using top_builddir (which is defined more often than
+dnl MKDIR_P).
+AC_SUBST([mkdir_p], ["$MKDIR_P"])dnl
+case $mkdir_p in
+esac
 # Helper functions for option handling.                     -*- Autoconf -*-
+# Copyright (C) 2001, 2002, 2003, 2005, 2008, 2010 Free Software
+# Foundation, Inc.
+# serial 5
 # _AM_MANGLE_OPTION(NAME)
 AC_DEFUN([_AM_MANGLE_OPTION],
@@ -9292,7 +9350,7 @@
 # Set option NAME.  Presently that only means defining a flag for this option.
 AC_DEFUN([_AM_SET_OPTION],
-[m4_define(_AM_MANGLE_OPTION([$1]), [1])])
+[m4_define(_AM_MANGLE_OPTION([$1]), 1)])
 # _AM_SET_OPTIONS(OPTIONS)
@@ -9308,16 +9366,22 @@
 # Check to make sure that the build environment is sane.    -*- Autoconf -*-
+# Copyright (C) 1996, 1997, 2000, 2001, 2003, 2005, 2008
+# serial 5
 # AM_SANITY_CHECK
 AC_DEFUN([AM_SANITY_CHECK],
 [AC_MSG_CHECKING([whether build environment is sane])
+# Just in case
+sleep 1
 am_lf='
@@ -9328,40 +9392,32 @@
 esac
 case $srcdir in
   *[[\\\"\#\$\&\'\`$am_lf\ \	]]*)
-    AC_MSG_ERROR([unsafe srcdir value: '$srcdir']);;
+    AC_MSG_ERROR([unsafe srcdir value: `$srcdir']);;
 esac
 # directory).
 if (
-   am_has_slept=no
-     if test "$[*]" = "X"; then
-	# -L didn't work.
-     fi
-     if test "$[*]" != "X $srcdir/configure conftest.file" \
-	&& test "$[*]" != "X conftest.file $srcdir/configure"; then
+   if test "$[*]" = "X"; then
+      # -L didn't work.
+   fi
+   if test "$[*]" != "X $srcdir/configure conftest.file" \
+      && test "$[*]" != "X conftest.file $srcdir/configure"; then
-	AC_MSG_ERROR([ls -t appears to fail.  Make sure there is not a broken
-  alias in your environment])
-     fi
-     if test "$[2]" = conftest.file || test $am_try -eq 2; then
-       break
-     fi
-     # Just in case.
-     sleep 1
-     am_has_slept=yes
-   done
+      AC_MSG_ERROR([ls -t appears to fail.  Make sure there is not a broken
+alias in your environment])
+   fi
 then
@@ -9371,58 +9427,46 @@
    AC_MSG_ERROR([newly created file is older than distributed files!
 Check your system clock])
 fi
-AC_MSG_RESULT([yes])
-am_sleep_pid=
-  ( sleep 1 ) &
-  am_sleep_pid=$!
-fi
-AC_CONFIG_COMMANDS_PRE(
-  [AC_MSG_CHECKING([that generated files are newer than configure])
-   fi
-   AC_MSG_RESULT([done])])
+AC_MSG_RESULT(yes)])
+# serial 1
 # AM_PROG_INSTALL_STRIP
-# One issue with vendor 'install' (even GNU) is that you can't
+# One issue with vendor `install' (even GNU) is that you can't
 # specify the program used to strip binaries.  This is especially
 # annoying in cross-compiling environments, where the build's strip
 # is unlikely to handle the host's binaries.
 # Fortunately install-sh will honor a STRIPPROG variable, so we
-# always use install-sh in "make install-strip", and initialize
+# always use install-sh in `make install-strip', and initialize
 # STRIPPROG with the value of the STRIP variable (set by the user).
 AC_DEFUN([AM_PROG_INSTALL_STRIP],
 [AC_REQUIRE([AM_PROG_INSTALL_SH])dnl
-dnl Don't test for $cross_compiling = yes, because it might be 'maybe'.
+dnl Don't test for $cross_compiling = yes, because it might be `maybe'.
   AC_CHECK_TOOL([STRIP], [strip], :)
 fi
 INSTALL_STRIP_PROGRAM="\$(install_sh) -c -s"
 AC_SUBST([INSTALL_STRIP_PROGRAM])])
-# Copyright (C) 2006-2012 Free Software Foundation, Inc.
+# Copyright (C) 2006, 2008, 2010 Free Software Foundation, Inc.
+# serial 3
 # _AM_SUBST_NOTMAKE(VARIABLE)
 # Prevent Automake from outputting VARIABLE = @VARIABLE@ in Makefile.in.
@@ -9436,16 +9480,18 @@
 # Check how to create a tarball.                            -*- Autoconf -*-
-# Copyright (C) 2004-2012 Free Software Foundation, Inc.
+# Copyright (C) 2004, 2005, 2012 Free Software Foundation, Inc.
+# serial 2
 # _AM_PROG_TAR(FORMAT)
 # Check how to create a tarball in format FORMAT.
-# FORMAT should be one of 'v7', 'ustar', or 'pax'.
+# FORMAT should be one of `v7', `ustar', or `pax'.
 # Substitute a variable $(am__tar) that is a command
 # writing to stdout a FORMAT-tarball containing the directory
@@ -9468,7 +9514,7 @@
 _am_tools='gnutar m4_if([$1], [ustar], [plaintar]) pax cpio none'
 _am_tools=${am_cv_prog_tar_$1-$_am_tools}
 # Do not fold the above two line into one, because Tru64 sh and
-# Solaris sh will not grok spaces in the rhs of '-'.
+# Solaris sh will not grok spaces in the rhs of `-'.
 for _am_tool in $_am_tools
 do
   case $_am_tool in
More information about the Swift-commit
