[Swift-commit] r7215 - in SwiftTutorials/OSG-Swift: app doc part02
davidk at ci.uchicago.edu
Tue Oct 22 15:46:30 CDT 2013
Author: davidk
Date: 2013-10-22 15:46:30 -0500 (Tue, 22 Oct 2013)
New Revision: 7215
Added:
SwiftTutorials/OSG-Swift/app/simulate.py
SwiftTutorials/OSG-Swift/app/stats.py
Modified:
SwiftTutorials/OSG-Swift/doc/README
SwiftTutorials/OSG-Swift/doc/build_docs.sh
SwiftTutorials/OSG-Swift/part02/apps
Log:
Python scripts for osgconnect tutorial
Updated build_docs
Updated README
Added: SwiftTutorials/OSG-Swift/app/simulate.py
--- SwiftTutorials/OSG-Swift/app/simulate.py (rev 0)
+++ SwiftTutorials/OSG-Swift/app/simulate.py 2013-10-22 20:46:30 UTC (rev 7215)
@@ -0,0 +1,125 @@
+#!/usr/bin/env python
+import sys
+import os
+import socket
+import time
+import math
+import random
+import getpass
+def parse():
+ from optparse import OptionParser
+ parser=OptionParser()
+ parser.add_option("-b", "--bias", type="int", dest="bias", default=0,
+ help="offset bias: add this integer to all results");
+ parser.add_option("-B", "--biasfile", type="string", dest="biasfile",
+ default="none", help="file of integer biases to add to results" );
+ parser.add_option("-l", "--log", type="string", dest="log", default="yes",
+ help="generate a log in stderr if not nul");
+ parser.add_option("-n", "--nvalues", type="int", dest="nvalues",default=1,
+ help="print this many values per simulation" );
+ parser.add_option("-s", "--seed", type="int", dest="initseed", default=0,
+ help="use this integer [0..32767] as a seed");
+ parser.add_option("-S", "--seedfile", type="string", dest="seedfile",
+ default="none", help="use this file (containing integer seeds [0..32767]) one per line" );
+ parser.add_option("-t", "--timesteps", type="int", dest="timesteps",
+ default=0, help='number of simulated "timesteps" in seconds (determines runtime)' );
+ parser.add_option("-r", "--range", type="int", dest="range", default=100,
+ help="range (limit) of generated results" );
+ parser.add_option("-w", "--width", type="int", dest="width", default=8,
+ help="Width ?" );
+ parser.add_option("-x", "--scale", type="int", dest="scale", default=1,
+ help="scale the results by this integer" );
+ # Not implemented yet
+ parser.add_option("-p", "--paramfile", type="string", dest="paramfile", default="none",
+ help="Not implemented yet" );
+ return (parser.parse_args());
+def log():
+ import datetime
+ print >> sys.stderr, "Called as: ", str(sys.argv)
+ print >> sys.stderr, "Start time: ", datetime.datetime.now()
+ print >> sys.stderr, "Running on node: ", socket.gethostname()
+ print >> sys.stderr, "Running as user: ", getpass.getuser()
+ print >> sys.stderr, "\nEnvironment:\n\n"
+ print >> sys.stderr, os.environ
+def printparams(options):
+ print 'bias =',options.bias
+ print 'biasfile = ',options.biasfile
+ print 'log = ', options.log
+ print 'nvalues = ',options.nvalues
+ print 'seed = ', options.initseed
+ print 'seedfile = ', options.seedfile
+ print 'timesteps = ', options.timesteps
+ print 'range = ', options.range
+ print 'width = ', options.width
+ print 'scale = ', options.scale
+ print 'paramfile = ', options.paramfile
+def simulate(options):
+ time.sleep(options.timesteps)
+ bias=[];
+ if (options.biasfile != "none"):
+ try:
+ with open(options.biasfile) as biasfile:
+ lines = biasfile.read().splitlines()
+ for line in lines:
+ bias.append(int(line))
+ except IOError:
+ print "Error accessing content from file: ", options.biasfile
+ bias_count = len(bias)
+ for i in range(options.nvalues):
+ value = (random.random() +
+ random.random()*math.pow(2,16) +
+ random.random()*math.pow(2,32) +
+ random.random()*math.pow(2,48))
+ value=( (int(value)%options.range) * options.scale + options.bias)
+ if ( i < bias_count ):
+ value = value + bias[i]
+ elif ( bias_count > 0 ):
+ value = value + bias[bias_count-1]
+ print '{num:{fill}{width}}'.format(num=value, fill=' ', width=options.width)
+def seed(options):
+ if (options.initseed != 0 ):
+ random.seed(options.initseed)
+ if (options.seedfile != "none"):
+ try:
+ with open(options.seedfile) as seedfile:
+ lines=seedfile.read().splitlines()
+ seed = 0
+ seed = seed + int(line)
+ random.seed(seed)
+ except IOError:
+ print "Could not open file: ", options.seedfile
+if __name__ == "__main__":
+ (options, args) = parse()
+ printparams(options)
+ seed(options)
+ simulate(options)
+ log()
Property changes on: SwiftTutorials/OSG-Swift/app/simulate.py
___________________________________________________________________
Added: svn:executable
Added: SwiftTutorials/OSG-Swift/app/stats.py
--- SwiftTutorials/OSG-Swift/app/stats.py (rev 0)
+++ SwiftTutorials/OSG-Swift/app/stats.py 2013-10-22 20:46:30 UTC (rev 7215)
@@ -0,0 +1,31 @@
+import socket
+import sys
+import os
+def log():
+ import datetime
+ print >> sys.stderr, "Running as user: ",os.getlogin()
+def stat():
+ total = 0
+ count = 0
+ for f in sys.argv[1:]:
+ try:
+ with open(f) as ifile:
+ lines = ifile.read().splitlines()
+ total += int(line)
+ count += 1
+ except IOError:
+ print total/count
+ log()
+ stat()
Property changes on: SwiftTutorials/OSG-Swift/app/stats.py
Modified: SwiftTutorials/OSG-Swift/doc/README
--- SwiftTutorials/OSG-Swift/doc/README 2013-10-22 20:29:02 UTC (rev 7214)
+++ SwiftTutorials/OSG-Swift/doc/README 2013-10-22 20:46:30 UTC (rev 7215)
@@ -324,6 +324,16 @@
image::part02.png[align="center"]
+In part 2, we also update the apps file. Instead of using shell script (simulate.sh), we use
+the equivalent python version (simulate.py). The new apps file now looks like this:
+sys::[cat ../part02/apps]
+Swift does not need to know anything about the language an application is written in. The application
+can be written in Perl, Python, Java, Fortran, or any other language.
.p2.swift
sys::[cat -n ../part02/p2.swift]
Modified: SwiftTutorials/OSG-Swift/doc/build_docs.sh
--- SwiftTutorials/OSG-Swift/doc/build_docs.sh 2013-10-22 20:29:02 UTC (rev 7214)
+++ SwiftTutorials/OSG-Swift/doc/build_docs.sh 2013-10-22 20:46:30 UTC (rev 7215)
@@ -1,13 +1,4 @@
#!/bin/bash -e
-if false; then
- echo skipping
-pushd part11-swift-py-r/code >& /dev/null
-# Strip comments, blank lines; prepend shell prompt ($)
-grep -A 20 stc run-dets.sh | \
- grep -v -e "^$\|#" | \
- sed 's/^/$ /' > run-dets.sh.txt
-popd >& /dev/null
-fi
+asciidoc -a icons -a toc -a toplevels=2 -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o tutorial.html README
-asciidoc -a icons -a "src_tab=3 --line-number=' '" -a toc -a toplevels=2 -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o cic-tutorial.html README
Modified: SwiftTutorials/OSG-Swift/part02/apps
--- SwiftTutorials/OSG-Swift/part02/apps 2013-10-22 20:29:02 UTC (rev 7214)
+++ SwiftTutorials/OSG-Swift/part02/apps 2013-10-22 20:46:30 UTC (rev 7215)
@@ -1 +1 @@
-localhost simulate simulate.sh
+localhost simulate simulate.py
More information about the Swift-commit
