[Swift-commit] r7214 - in SwiftTutorials/swift-cray-tutorial: app doc part02
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Tue Oct 22 15:29:02 CDT 2013
Author: davidk
Date: 2013-10-22 15:29:02 -0500 (Tue, 22 Oct 2013)
New Revision: 7214
Added:
   SwiftTutorials/swift-cray-tutorial/app/simulate.py
   SwiftTutorials/swift-cray-tutorial/app/stats.py
Modified:
   SwiftTutorials/swift-cray-tutorial/doc/README
   SwiftTutorials/swift-cray-tutorial/doc/build_docs.sh
   SwiftTutorials/swift-cray-tutorial/part02/apps
Log:
Add python examples to cray docs
Added: SwiftTutorials/swift-cray-tutorial/app/simulate.py
--- SwiftTutorials/swift-cray-tutorial/app/simulate.py	                        (rev 0)
+++ SwiftTutorials/swift-cray-tutorial/app/simulate.py	2013-10-22 20:29:02 UTC (rev 7214)
@@ -0,0 +1,125 @@
+#!/usr/bin/env python
+import sys
+import os
+import socket
+import time
+import math
+import random
+import getpass
+def parse():
+    from optparse import OptionParser
+    parser=OptionParser()
+    parser.add_option("-b", "--bias", type="int", dest="bias", default=0,
+                      help="offset bias: add this integer to all results");
+    parser.add_option("-B", "--biasfile", type="string", dest="biasfile",
+                      default="none", help="file of integer biases to add to results" );
+    parser.add_option("-l", "--log", type="string", dest="log", default="yes",
+                      help="generate a log in stderr if not nul");
+    parser.add_option("-n", "--nvalues", type="int", dest="nvalues",default=1,
+                      help="print this many values per simulation" );
+    parser.add_option("-s", "--seed", type="int", dest="initseed", default=0,
+                      help="use this integer [0..32767] as a seed");
+    parser.add_option("-S", "--seedfile", type="string", dest="seedfile",
+                      default="none", help="use this file (containing integer seeds [0..32767]) one per line" );
+    parser.add_option("-t", "--timesteps", type="int", dest="timesteps",
+                      default=0, help='number of simulated "timesteps" in seconds (determines runtime)' );
+    parser.add_option("-r", "--range", type="int", dest="range", default=100,
+                      help="range (limit) of generated results" );
+    parser.add_option("-w", "--width", type="int", dest="width", default=8,
+                      help="Width ?" );
+    parser.add_option("-x", "--scale", type="int", dest="scale", default=1,
+                      help="scale the results by this integer" );
+    # Not implemented yet
+    parser.add_option("-p", "--paramfile", type="string", dest="paramfile", default="none",
+                      help="Not implemented yet" );
+    return (parser.parse_args());
+def log():
+    import datetime
+    print >> sys.stderr, "Called as: ", str(sys.argv)
+    print >> sys.stderr, "Start time: ", datetime.datetime.now()
+    print >> sys.stderr, "Running on node: ", socket.gethostname()
+    print >> sys.stderr, "Running as user: ", getpass.getuser()
+    print >> sys.stderr, "\nEnvironment:\n\n"
+    print >> sys.stderr, os.environ
+def printparams(options):
+    print 'bias =',options.bias
+    print 'biasfile = ',options.biasfile
+    print 'log = ', options.log
+    print 'nvalues = ',options.nvalues
+    print 'seed = ', options.initseed
+    print 'seedfile = ', options.seedfile
+    print 'timesteps = ', options.timesteps
+    print 'range = ', options.range
+    print 'width = ', options.width
+    print 'scale = ', options.scale
+    print 'paramfile = ', options.paramfile
+def simulate(options):
+    time.sleep(options.timesteps)
+    bias=[];
+    if (options.biasfile != "none"):
+        try:
+            with open(options.biasfile) as biasfile:
+                lines = biasfile.read().splitlines()
+                for line in lines:
+                    bias.append(int(line))
+        except IOError:
+            print "Error accessing content from file: ", options.biasfile
+    bias_count = len(bias)
+    for i in range(options.nvalues):
+        value = (random.random() +
+        random.random()*math.pow(2,16) +
+        random.random()*math.pow(2,32) +
+        random.random()*math.pow(2,48))
+        value=( (int(value)%options.range) * options.scale + options.bias)
+        if ( i < bias_count ):
+            value = value + bias[i]
+        elif ( bias_count > 0 ):
+            value = value + bias[bias_count-1]
+        print '{num:{fill}{width}}'.format(num=value, fill=' ', width=options.width)
+def seed(options):
+    if (options.initseed != 0 ):
+        random.seed(options.initseed)
+    if (options.seedfile != "none"):
+        try:
+            with open(options.seedfile) as seedfile:
+                lines=seedfile.read().splitlines()
+                seed = 0
+                    seed = seed + int(line)
+            random.seed(seed)
+        except IOError:
+            print "Could not open file: ", options.seedfile
+if __name__ == "__main__":
+    (options, args) = parse()
+    printparams(options)
+    seed(options)
+    simulate(options)
+    log()
Property changes on: SwiftTutorials/swift-cray-tutorial/app/simulate.py
___________________________________________________________________
Added: svn:executable
Added: SwiftTutorials/swift-cray-tutorial/app/stats.py
--- SwiftTutorials/swift-cray-tutorial/app/stats.py	                        (rev 0)
+++ SwiftTutorials/swift-cray-tutorial/app/stats.py	2013-10-22 20:29:02 UTC (rev 7214)
@@ -0,0 +1,31 @@
+import socket
+import sys
+import os
+def log():
+    import datetime
+    print >> sys.stderr, "Running as user: ",os.getlogin()
+def stat():
+    total = 0
+    count = 0
+    for f in sys.argv[1:]:
+        try:
+            with open(f) as ifile:
+                lines = ifile.read().splitlines()
+                    total += int(line)
+                    count += 1
+        except IOError:
+        print total/count
+    log()
+    stat()
Property changes on: SwiftTutorials/swift-cray-tutorial/app/stats.py
Modified: SwiftTutorials/swift-cray-tutorial/doc/README
--- SwiftTutorials/swift-cray-tutorial/doc/README	2013-10-22 20:06:48 UTC (rev 7213)
+++ SwiftTutorials/swift-cray-tutorial/doc/README	2013-10-22 20:29:02 UTC (rev 7214)
@@ -344,6 +344,16 @@
 sys::[cat ../part02/p2.swift]
+In part 2, we also update the apps file. Instead of using shell script (simulate.sh), we use
+the equivalent python version (simulate.py). The new apps file now looks like this:
+sys::[cat ../part02/apps]
+Swift does not need to know anything about the language an application is written in. The application
+can be written in Perl, Python, Java, Fortran, or any other language.
 The script also shows an
 example of naming the output files of an ensemble run. In this case, the output files will be named
 `output/sim_N.out`.
Modified: SwiftTutorials/swift-cray-tutorial/doc/build_docs.sh
--- SwiftTutorials/swift-cray-tutorial/doc/build_docs.sh	2013-10-22 20:06:48 UTC (rev 7213)
+++ SwiftTutorials/swift-cray-tutorial/doc/build_docs.sh	2013-10-22 20:29:02 UTC (rev 7214)
@@ -1,4 +1,4 @@
 #!/bin/bash -e
-asciidoc -a icons -a toc -a toplevels=2 -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o swift-cray-tutorial.html README
+asciidoc -a icons -a toc -a toplevels=2 -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o tutorial.html README
Modified: SwiftTutorials/swift-cray-tutorial/part02/apps
--- SwiftTutorials/swift-cray-tutorial/part02/apps	2013-10-22 20:06:48 UTC (rev 7213)
+++ SwiftTutorials/swift-cray-tutorial/part02/apps	2013-10-22 20:29:02 UTC (rev 7214)
@@ -1 +1 @@
-localhost simulate simulate.sh
+localhost simulate simulate.py
