[Swift-commit] r7132 - SwiftApps/Swift-MapRed/mapred_chirp
yadunandb at ci.uchicago.edu yadunandb at ci.uchicago.edu
Fri Oct 4 11:33:52 CDT 2013
Author: yadunandb
Date: 2013-10-04 11:33:52 -0500 (Fri, 04 Oct 2013)
New Revision: 7132
Modified:
   SwiftApps/Swift-MapRed/mapred_chirp/beagle.xml
   SwiftApps/Swift-MapRed/mapred_chirp/combiner.sh
   SwiftApps/Swift-MapRed/mapred_chirp/parcombiner.sh
   SwiftApps/Swift-MapRed/mapred_chirp/run.sh
   SwiftApps/Swift-MapRed/mapred_chirp/teragen.kml
   SwiftApps/Swift-MapRed/mapred_chirp/teragen.swift
   SwiftApps/Swift-MapRed/mapred_chirp/teragen_wrap.sh
   SwiftApps/Swift-MapRed/mapred_chirp/test
Log:
Minor updates
Modified: SwiftApps/Swift-MapRed/mapred_chirp/beagle.xml
--- SwiftApps/Swift-MapRed/mapred_chirp/beagle.xml	2013-10-04 16:32:50 UTC (rev 7131)
+++ SwiftApps/Swift-MapRed/mapred_chirp/beagle.xml	2013-10-04 16:33:52 UTC (rev 7132)
@@ -1,18 +1,23 @@
 <config>
   <pool handle="beagle">
-    <execution provider="coaster" jobmanager="ssh-cl:pbs" url="login4.beagle.ci.uchicago.edu"/>
+    <execution provider="coaster" jobmanager="local:pbs"/>
     <profile namespace="globus" key="jobsPerNode">24</profile>
     <profile namespace="globus" key="lowOverAllocation">100</profile>
     <profile namespace="globus" key="highOverAllocation">100</profile>
     <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
+    <!-- to use a beage reservation, eg:
+         <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24;pbs.resource_list=advres=wilde.1768</profile>
     <profile namespace="globus" key="maxtime">3600</profile>
-    <profile namespace="globus" key="maxWalltime">00:10:00</profile>
+    <profile namespace="globus" key="maxWalltime">00:15:00</profile>
     <profile namespace="globus" key="userHomeOverride">/lustre/beagle/yadunandb/swiftwork</profile>
-    <profile namespace="globus" key="slots">20</profile>
+    <profile namespace="globus" key="slots">4</profile>
     <profile namespace="globus" key="maxnodes">1</profile>
     <profile namespace="globus" key="nodeGranularity">1</profile>
-    <profile namespace="karajan" key="jobThrottle">1</profile>
+    <profile namespace="karajan" key="jobThrottle">4.80</profile>
     <profile namespace="karajan" key="initialScore">10000</profile>
+    <!-- <filesystem provider="local"/> -->
+    <!-- <workdirectory>/lustre/beagle/yadunandb/swiftwork</workdirectory> -->
     <workdirectory>/tmp/yadunandb/swiftwork</workdirectory>
   </pool>
-</config>
\ No newline at end of file
+</config>
Modified: SwiftApps/Swift-MapRed/mapred_chirp/combiner.sh
--- SwiftApps/Swift-MapRed/mapred_chirp/combiner.sh	2013-10-04 16:32:50 UTC (rev 7131)
+++ SwiftApps/Swift-MapRed/mapred_chirp/combiner.sh	2013-10-04 16:33:52 UTC (rev 7132)
@@ -13,10 +13,10 @@
     chirp_get $HOST $TARGET $TARGET.imd
     RES=($(awk '{ sum += $1 } END { print sum,NR }' $TARGET.imd))
     echo "$TARGET.imd"
     SUM=$(($SUM+${RES[0]}))
     COUNT=$(($COUNT+${RES[1]}))
 done
 echo "SUM  : $SUM"
 echo "COUNT: $COUNT"
+hostname -f
 exit 0
Modified: SwiftApps/Swift-MapRed/mapred_chirp/parcombiner.sh
--- SwiftApps/Swift-MapRed/mapred_chirp/parcombiner.sh	2013-10-04 16:32:50 UTC (rev 7131)
+++ SwiftApps/Swift-MapRed/mapred_chirp/parcombiner.sh	2013-10-04 16:33:52 UTC (rev 7132)
@@ -12,6 +12,7 @@
     TARGET=$(basename $FILE)
+    echo "For $HOST:$FILE$ {RES[*]}"
     echo "${RES[0]} ${RES[1]}" > "$2.$RANDOM.imd2"
@@ -28,28 +29,3 @@
 echo "SUM  : $SUM"
 exit 0
-exit 0
-for file_token in $*
-do
-    TOKEN=($(cat $file_token))
-    HOST=${TOKEN[0]}
-    FILE=${TOKEN[1]}
-    TARGET=$(basename $FILE)
-    chirp_get $HOST $TARGET $TARGET.imd
-    RES=($(awk '{ sum += $1 } END { print sum,NR }' $TARGET.imd))
-    echo "$TARGET.imd"
-    SUM=$(($SUM+${RES[0]}))
-    COUNT=$(($COUNT+${RES[1]}))
-done
-echo "SUM  : $SUM"
-echo "COUNT: $COUNT"
-exit 0
Modified: SwiftApps/Swift-MapRed/mapred_chirp/run.sh
--- SwiftApps/Swift-MapRed/mapred_chirp/run.sh	2013-10-04 16:32:50 UTC (rev 7131)
+++ SwiftApps/Swift-MapRed/mapred_chirp/run.sh	2013-10-04 16:33:52 UTC (rev 7132)
@@ -5,12 +5,14 @@
 #echo "Running run_catsn.swift"
 #swift -tc.file tc.data -sites.file sites.xml run_catsn.swift
+APPS=$1; shift;
+SIZE=$1; shift;
 if [ "$1" != "" ]
 then
     SITE="$1"
 else
-    SITE="anl"
+    SITE="beagle"
 fi
 #Call as check_error $? <ERR_CODE> <Error message>
@@ -31,20 +33,20 @@
     RECSIZE=$2
     ACTUAL_RESULT=($(tail -n 1 final_result))
     EXPECTED_RESULT=$(($LOOPS * $RECSIZE * 10000 ))
-    if [ "$EXPECTED_RESULT" ==  "${ACTUAL_RESULT[1]}" ]
+    if [ "$EXPECTED_RESULT" ==  "${ACTUAL_RESULT[1]}" ]
     then
-	echo "---------------------------------------------"
-	echo "COUNT matches expected records"
-	echo "ACTUAL COUNT  : ${ACTUAL_RESULT[1]}"
-	echo "EXPECTED COUNT: $EXPECTED_RESULT"
+        echo "---------------------------------------------"
+        echo "COUNT matches expected records"
+        echo "ACTUAL COUNT  : ${ACTUAL_RESULT[1]}"
+        echo "EXPECTED COUNT: $EXPECTED_RESULT"
     else
-	echo "COUNT does *NOT* match expected records"
-	cat err_file
+        echo "COUNT does *NOT* match expected records"
+        cat err_file
     fi
@@ -74,91 +76,5 @@
     echo "================================================================"
-#run_swift_chirp 20 20;
-run_swift_chirp 10 100;
+run_swift_chirp 1000 10;
 exit 0
-####################SWIFT + CHIRP VERSION############################
-LOOPS=10
-RECSIZE=100
-for LOOPS in `seq 10 10 50`
-do
-    for RECSIZE in `seq 0 25 200`
-    do
-	[ $RECSIZE -eq 0 ] && RECSIZE=1
-	run_swift_chirp $LOOPS $RECSIZE
-	sleep 300;
-    done
-done;
-exit 0
-####################PROVIDER STAGING VERSION######################
-TOTALSIZE=1000000000 # Totalsize/chunksize is the
-CHUNKSIZE=100000000  # 10^8 records in each chunk
-NUMCHUNKS=$(($TOTALSIZE / $CHUNKSIZE))
-LOOP=1
-TIMEOUT=600
-time {
-    echo "RUNTYPE :PROVIDER STAGING VERSION, SITE: $SITE, CHUNKS: $NUMCHUNKS"
-    echo "timeout $TIMEOUT swift -tc.file tc.data -config cf -sites.file $SITE.xml teragen.swift -loops=$NUMCHUNKS"
-    timeout $TIMEOUT swift -tc.file tc.data -config cf -sites.file $SITE.xml teragen.swift -loops=$NUMCHUNKS
-    check_error $? 124 "Run terminated by timeout of $((TIMEOUT/60)) minute(s)"
-} | tee -a LAB_RECORDS
-exit 0
-#######################CDM VERSION##############################
-CHUNKSIZE=100000000  # 10^8 records in each chunk: THIS IS A DEFAULT
-LOOP=1
-TIMEOUT=600
-time {
-    echo "RUNTYPE :CDM VERSION, SITE: $SITE, CHUNKS: $NUMCHUNKS"
-    echo "timeout $TIMEOUT swift -cdm.file $SITE.cdm -tc.file tc.data -config cf -sites.file $SITE.xml teragen.swift -loops=$NUMCHUNKS"
-    timeout $TIMEOUT swift -cdm.file $SITE.cdm -tc.file tc.data -config cf -sites.file $SITE.xml teragen.swift -loops=$NUMCHUNKS
-exit 0
Modified: SwiftApps/Swift-MapRed/mapred_chirp/teragen.kml
--- SwiftApps/Swift-MapRed/mapred_chirp/teragen.kml	2013-10-04 16:32:50 UTC (rev 7131)
+++ SwiftApps/Swift-MapRed/mapred_chirp/teragen.kml	2013-10-04 16:33:52 UTC (rev 7132)
@@ -1,4 +1,4 @@
-<project><!-- CACHE ID 9d52f32c-4127-4505-8c1f-1383cafe01de-no-provenance -->
+<project><!-- CACHE ID 776e318b-73ca-4b57-9190-8b70016a4560-no-provenance -->
   <import file="sys.xml"/>
   <import file="scheduler.xml"/>
   <import file="rlog.xml"/>
Modified: SwiftApps/Swift-MapRed/mapred_chirp/teragen.swift
--- SwiftApps/Swift-MapRed/mapred_chirp/teragen.swift	2013-10-04 16:32:50 UTC (rev 7131)
+++ SwiftApps/Swift-MapRed/mapred_chirp/teragen.swift	2013-10-04 16:33:52 UTC (rev 7132)
@@ -25,10 +25,10 @@
-#script combine <"combiner2.sh">;
-#script combine <"combiner.sh">;
+//script combine <"combiner2.sh">;
+//script combine <"combiner.sh">;
 script combine <"parcombiner.sh">;
 file final <"final_result">;
 file errs <"err_file">;
-(final, errs) = comb_data(combine, tgen_out);
+(final, errs) = comb_data(combine, tgen_out);
Modified: SwiftApps/Swift-MapRed/mapred_chirp/teragen_wrap.sh
--- SwiftApps/Swift-MapRed/mapred_chirp/teragen_wrap.sh	2013-10-04 16:32:50 UTC (rev 7131)
+++ SwiftApps/Swift-MapRed/mapred_chirp/teragen_wrap.sh	2013-10-04 16:33:52 UTC (rev 7132)
@@ -1,6 +1,5 @@
 #!/bin/bash
 # By default with ARG1:100 and SLICESIZE=10000, this script will generate
 # 10^6 records.
 ARG1=1
@@ -8,13 +7,14 @@
 FILE="input_$RANDOM.txt"
 LOWERLIMIT=0
-UPPERLIMIT=1000000000 # 10^9
+UPPERLIMIT=10000000 # 10^8
 SLICESIZE=10000     # 10^4 records padded to 100B would result in 1MB file
 #SLICESIZE=1000     # 10^3  If padded to 100B would result
-FOLDER="/sandbox/$USER"
-TIMEOUT=600
+#FOLDER="/lustre/beagle/yadunand"
+FOLDER="/tmp/yadunandb"
+TIMEOUT=100
 # clean_folder SLEEP_TIME FOLDER_NAME
 clean_folder()
@@ -32,7 +32,8 @@
 	killall -u $USER chirp_server;
 	echo "unix:$USER rwlds" >  $FOLDER/acl.conf
 	echo "hostname:* rwl"   >> $FOLDER/acl.conf
-	timeout $TIMEOUT chirp_server -A $FOLDER/acl.conf -r $FOLDER &
+#	timeout $TIMEOUT chirp_server -A $FOLDER/acl.conf -r $FOLDER
+	timeout $TIMEOUT chirp_server -d -o $FOLDER/$FILE -A $FOLDER/acl.conf -r $FOLDER &
     fi
     FILE=$FOLDER/$FILE;
@@ -41,5 +42,7 @@
 fi
 shuf -i $LOWERLIMIT-$UPPERLIMIT -n $(($SLICESIZE*$ARG1)) | awk '{printf "%-99s\n", $0}' > $FILE
-echo "$HOSTNAME $FILE"
+HOST=$(hostname -f)
+echo "$HOST $FILE"
 exit 0
Modified: SwiftApps/Swift-MapRed/mapred_chirp/test
--- SwiftApps/Swift-MapRed/mapred_chirp/test	2013-10-04 16:32:50 UTC (rev 7131)
+++ SwiftApps/Swift-MapRed/mapred_chirp/test	2013-10-04 16:33:52 UTC (rev 7132)
@@ -1,5 +1 @@
-stomp /sandbox/yadunand/input_32754.txt
-thwomp /sandbox/yadunand/input_15959.txt
-stomp /sandbox/yadunand/input_21602.txt
-vanquish /sandbox/yadunand/input_18357.txt
-thrash /sandbox/yadunand/input_27031.txt
+login5.beagle.ci.uchicago.edu /home/yadunandb/Swift-MapRed/mapred_chirp/input_28579.txt
