[Swift-commit] r6503 - in branches/release-0.94/docs: . releasenotes
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon May 6 13:51:28 CDT 2013
Author: davidk
Date: 2013-05-06 13:51:27 -0500 (Mon, 06 May 2013)
New Revision: 6503
Added:
   branches/release-0.94/docs/releasenotes/
   branches/release-0.94/docs/releasenotes/releasenotes.txt
Log:
Most of the 0.94 release notes in asciidoc
Added: branches/release-0.94/docs/releasenotes/releasenotes.txt
--- branches/release-0.94/docs/releasenotes/releasenotes.txt	                        (rev 0)
+++ branches/release-0.94/docs/releasenotes/releasenotes.txt	2013-05-06 18:51:27 UTC (rev 6503)
@@ -0,0 +1,252 @@
+Swift 0.94 Release Notes
+Iterate changes
+To behavior of iterate has changed from 0.93 to 0.94. The until() clause of
+the iterate statement now causes the loop to stop as soon as the until clause
+returns "true", instead of doing one additional iteration when the clause
+turns true.
+For example, iterate code in 0.93 might say:
+iterate i {
+} until (i == 9);
+To achieve the same 10 executions in 0.94, you must say:
+iterate i {
+} until (i==10);
+More information about iterate can be found in the
+http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html#_iterate[iterate section of the Swift User Guide].
+Coaster walltimes
+Walltimes are now strictly enforced by coasters.
+There are two coaster properties that affect how walltimes are handled. They
+are maxtime and maxwalltime.
+Maxtime is the maximum amount of time, in seconds, that a coaster block can run.
+This is defined in sites.xml.
+.Setting a maxTime of 30 minutes
+<profile namespace="globus" key="maxTime">1800</profile>
+The maxwalltime property defines the maximum amount of time that any given
+application may run (in hh:mm:ss format)
+.Setting a maxWallTime of 5 minutes
+<profile namespace="globus" key="maxWallTime">00:05:00</profile>
+An application may run up to the the limit defined in maxwalltime, and are
+packed into coasters slots that run for maxtime seconds.
+In versions of Swift prior to 0.94, if an application exceeded its specified
+maxwalltime, execution would continue. However, if the application exceeded
+its maxwalltime, the queuing system could kill the worker. The resulting error
+message was not always very clear.
+In Swift 0.94, coaster workers enforce the user-specified
+maxwalltime. If an application exceeds its maxwalltime, the coaster worker
+will not allow it to continue, but terminate it and report the error.
+The error message will look something like this:
+Execution failed:
+	Exception in hostsnsleep:
+    Arguments: [30]
+    Host: midway
+    Directory: hostsnsleep-20130502-2009-t8m0l3hb/jobs/n/hostsnsleep-n55v8x8l
+    stderr.txt:
+    stdout.txt: midway009
+Caused by:
+	Walltime exceeded
+org.globus.cog.abstraction.impl.common.execution.JobException: Walltime exceeded (exit code: 513)
+	at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:38)
+	at org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
+	at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:518)
+	at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.stepNIO(AbstractStreamKarajanChannel.java:238)
+	at org.globus.cog.karajan.workflow.service.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
+	at org.globus.cog.karajan.workflow.service.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
+ (exit code: 513)
+	hostsnsleep, hostsnsleep.swift, line 13
+TIP: Maxwalltime may also be define on a per application level in your tc file
+(http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html#_globus_namespace[Globus Namespace section, Swift User Guide]).
+Camel Case Functions
+To make things more consistent, many swift functions are being renamed
+to use camel case naming. For example, @toint is now @toInt. The previous
+naming conventions will still work in 0.94, but may not in future releases.
+If you try to use a function which has been renamed, you will see deprecated
+warnings like this:
+Warning: Function toint is deprecated, at 2
+Below is a list of functions with updated names.
+[options="header", width="25%"]
+| Old Name    | New Name
+| @extractint | @extractInt
+| @toint      | @toInt
+| @tofloat    | @toFloat
+| @tostring   | @toString
+Associative Arrays
+Associative arrays have been added. By default, array keys are integers, but in
+0.94 other primitive types are also allowed as array keys. More details and
+examples can be found in the
+http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html#_associative_arrays[associate array section of the Swift userguide].
+Dynamic profiles
+Many settings formerly only definable in sites.xml can now
+be set on a per-app basis. This can make things easier when running
+multiple apps that have different requirements for settings like processors
+per node and walltime.
+More information and examples can be found in the
+http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html#_dynamic_profiles[dynamic profiles section of the Swift userguide]
+SSH command line provider
+Added a new ssh command line provider. Previously ssh support was done by
+creating a file called ~/.ssh/auth.defaults. The ssh command line provider
+is more flexible and doesn't require this step. ssh-cl allows you to use
+your existing SSH agents. You can use ssh-cl to run remotely by adding
+something like this to your sites.xml:
+  <execution provider="coaster" url="my.host.uchicago.edu" jobmanager="ssh-cl:pbs"/>
+Coaster provider staging improvements
+Coasters provides a mechanism for transferring files between hosts, called
+coaster provider staging. Coaster provider staging is explained in more
+detail in http://www.ci.uchicago.edu/swift/papers/UCC-coasters.pdf[this
+research paper].
+In 0.94 there have been many fixes and improvements to make coaster
+provider staging more reliable.
+Added support for the Slurm scheduler
+Swift 0.94 includes support for Slurm - an open source job scheduler used on
+many supercomputers and computer clusters.
+The http://www.ci.uchicago.edu/swift/guides/trunk/siteguide/siteguide.html#_midway_x86_cluster[Swift siteguide entry for Midway]
+has an entry containing information about how to run Swift on a specific Slurm
+cluster at the University of Chicago called Midway. By changing queue names
+and project names, this information could be used to run on any Slurm cluster.
+Added support for the LSF scheduler
+Swift 0.94 includes support for the LSF (Load Sharing Facility) scheduler. An
+example sites.xml can be found in the
+http://www.ci.uchicago.edu/swift/guides/release-0.94/siteguide/siteguide.html#_geyser_and_caldera_x86_clusters[Swift siteguide entry for Geyser].
+Condor Improvements
+Some improvements have been made to the condor provider. For condor systems
+without a shared filesystem, Swift can now use Condor's built-in file transfer
+mechanisms to transfer the scripts it needs to starts jobs. To do this, you can
+define the jobtype to "non-shared" in sites.xml.
+<profile namespace="globus"  key="jobType">nonshared</profile>
+An example setup that uses this style of configuration can be found in the
+http://www.ci.uchicago.edu/swift/guides/release-0.94/siteguide/siteguide.html#_uc3_x86_cluster[Swift siteguide entry for the UC3 cluster].
+Textual User Interface
+Fixes for the textual user interface (TUI). Adding the -tui option to the swift
+command line allows you to monitor progress in a curses based menu. For example:
+swift -sites.file sites.xml -tc.file tc.data -tui myscript.swift
+A brief example of this can be found at http://www.ci.uchicago.edu/~davidk/modis.ogv.
+ at java
+Added the ability to call Java methods within swift using @java. For example:
+float f = @java("java.lang.Math", "sin", 0.5);
+More information can be found in the
+http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html#_java[Swift userguide entry on @java].
+Hang Checker
+Added a hang checker that provides the user with more information about
+potential hangs. Here is one example of a situation that may cause Swift
+to hang:
+int a;
+int b;
+a = b;
+b = a;
+When this script is run, you will now see a more detailed message explaining
+what's happening.
+Dependency loop found:
+	b (declared on line 2) is needed by:
+		a = b, test.swift, line 5
+	which produces a (declared on line 1)
+	a (declared on line 1) is needed by:
+		b = a, test.swift, line 6
+	which produces b (declared on line 2)
+ at strjoin
+A function called @strjoin function for joining strings. More information and examples are
+in the
+http://www.ci.uchicago.edu/swift/guides/release-0.94/userguide/userguide.html#_strjoin[Swift userguide section on @strjoin].
+Worker Init Command
+If you have a requirement that a command get run on the worker node before
+processing any work, worker.pl will now execute commands stored in the
+environment variable $WORKER_INIT_CMD.
+export WORKER_INIT_CMD=/path/to/script.to.run
+Swift Userhome
+Swift creates some files it needs by default in your home directory. If
+your home filesystem is not available on the worker nodes of a cluster you are
+trying to use, this can cause tasks to fail. Setting the environment variable
+SWIFT_USERHOME to the location of a shared filesystem will get around this
+restriction.
+MPI Improvements
+Various improvements to the way that Swift runs MPI jobs.
