[Swift-commit] r6502 - branches/release-0.94/docs/siteguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon May 6 13:08:26 CDT 2013
Author: davidk
Date: 2013-05-06 13:08:26 -0500 (Mon, 06 May 2013)
New Revision: 6502
Modified:
   branches/release-0.94/docs/siteguide/midway
Log:
Document how Slurm pass-thru settings work
Modified: branches/release-0.94/docs/siteguide/midway
--- branches/release-0.94/docs/siteguide/midway	2013-05-06 15:44:29 UTC (rev 6501)
+++ branches/release-0.94/docs/siteguide/midway	2013-05-06 18:08:26 UTC (rev 6502)
@@ -84,6 +84,30 @@
 </config>
+Defining non-standard Slurm options
+A Slurm submit script has many settings and options. Swift knows about many of
+the basic Slurm settings, like how to define a project or a queue, but it does
+not know about every setting. Swift provides a simple way to pass-thru your own
+settings into the Slurm submit script.
+The general way to do this is:
+<profile namespace="globus" key="slurm.setting">value</profile>
+Here is one specific example. Slurm has the ability to notify users via email
+when a job is done. To make this happen, the Slurm submit script that Swift
+generates needs a line that contains "--mail-type=END". The following line
+will make it happen.
+<profile namespace="globus" key="slurm.mail-type">END</profile>
+Any valid Slurm setting can be set in a similar way (see the sbatch man page
+for a list of all settings).
 Various tips for running MPI jobs
 * You'll need to load an MPI module. Run "module load openmpi" to add to your path.
