[Swift-commit] r6156 - trunk/bin
davidk at ci.uchicago.edu
Thu Jan 17 16:11:11 CST 2013
Author: davidk
Date: 2013-01-17 16:11:11 -0600 (Thu, 17 Jan 2013)
New Revision: 6156
Modified:
trunk/bin/start-coaster-service
Log:
Some changes to work with the updated gensites
Slurm
Modified: trunk/bin/start-coaster-service
--- trunk/bin/start-coaster-service 2013-01-15 22:27:07 UTC (rev 6155)
+++ trunk/bin/start-coaster-service 2013-01-17 22:11:11 UTC (rev 6156)
@@ -13,7 +13,7 @@
# Setup environment
PORT=$1
- EXECUTION_URL=http://localhost:$PORT
+ EXECUTIONURL=http://localhost:$PORT
export EC2_ACCESS_KEY=$FUTUREGRID_IAAS_ACCESS_KEY
export EC2_SECRET_KEY=$FUTUREGRID_IAAS_SECRET_KEY
@@ -73,7 +73,7 @@
echo $! >> $PID_FILE
else
echo "Starting worker on $MACHINE"
- ssh $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR" &
+ ssh $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $LOG_DIR" &
fi
@@ -84,7 +84,7 @@
start-workers-gp()
PORT=$1
if [ ! -d "$SWIFTVMBOOT_DIR" ] || [ ! -x "$SWIFTVMBOOT_DIR/bin/gp-instance-create" ]; then
crash "SWIFTVMBOOT_DIR incorrectly defined in coaster-service.conf"
@@ -129,7 +129,7 @@
# Copy and start worker script
scp -q -o StrictHostKeyChecking=no $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
- ssh -q -o StrictHostKeyChecking=no $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR" &
+ ssh -q -o StrictHostKeyChecking=no $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $LOG_DIR" &
done
@@ -138,7 +138,7 @@
start-workers-ec2()
PORT=$1
if [ ! -d "$SWIFTVMBOOT_DIR" ] || [ ! -x "$SWIFTVMBOOT_DIR/ec2/bin/ec2-run-instances" ]; then
fi
@@ -193,7 +193,7 @@
else
- ssh $SSH_OPTS $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR" > /dev/null 2>&1 &
+ ssh $SSH_OPTS $WORKER_USERNAME@$MACHINE "$WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $LOG_DIR" > /dev/null 2>&1 &
fi
@@ -207,7 +207,7 @@
start-workers-ssh()
PORT=$1
- EXECUTION_URL=http://$IPADDR:$PORT
+ EXECUTIONURL=http://$IPADDR:$PORT
if [ -z "$PORT" ]; then
crash "start-workers-ssh: Port number not specified, giving up"
fi
@@ -229,14 +229,14 @@
ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST ssh $MACHINE mkdir -p $WORKER_LOCATION > /dev/null 2>&1
ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST "scp /tmp/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION" > /dev/null 2>&1
echo Starting worker on $MACHINE
- ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $WORKER_LOG_DIR" &
+ ssh -A $WORKER_USERNAME@$WORKER_RELAY_HOST ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $WORKER_LOG_DIR" &
# Connect directly
else
ssh $WORKER_USERNAME@$MACHINE mkdir -p $WORKER_LOCATION > /dev/null 2>&1
scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION > /dev/null 2>&1
- ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTION_URL $MACHINE $WORKER_LOG_DIR" &
+ ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/$WORKER $EXECUTIONURL $MACHINE $WORKER_LOG_DIR" &
fi
done
@@ -247,12 +247,12 @@
start-workers-local()
PORT=$1
crash "start-workers-local: Port number not specified, giving up"
fi
echo Starting worker on local machine
- $WORKER $EXECUTION_URL LOCAL $LOG_DIR &
+ $WORKER $EXECUTIONURL LOCAL $LOG_DIR &
return 0
@@ -261,7 +261,7 @@
start-workers-condor()
PORT=$1
fi
@@ -279,7 +279,7 @@
output = workers.stdout
error = workers.stderr
executable = $WORKER_LOCATION/$WORKER
-arguments = $EXECUTION_URL node .
+arguments = $EXECUTIONURL node .
notification = Never
leave_in_queue = FALSE
machine_count = $CONDOR_MACHINE_COUNT
@@ -296,11 +296,51 @@
fi
+# Start condor workers
+start-workers-slurm()
+ PORT=$1
+ if [ -z "$PORT" ]; then
+ crash "start-workers-local: Port number not specified, giving up"
+ fi
+ echo Starting workers
+ if [ -z "$MACHINE_COUNT" ]; then
+ export MACHINE_COUNT=1
+ fi
+cat <<EOF > start_workers.submit
+#!/bin/bash
+#SBATCH --output=start_workers.stdout
+#SBATCH --error=start_workers.stderr
+#SBATCH --nodes=$MACHINE_COUNT
+#SBATCH --exclusive
+#SBATCH --ntasks-per-node=1
+#SBATCH --cpus-per-task=12
+#SBATCH --partition=normal
+#SBATCH --time=11:59:00
+#SBATCH -A TG-ASC090068
+export WORKER_LOGGING_LEVEL=NONE
+ibrun $WORKER_LOCATION/$WORKER $EXECUTIONURL node .
+EOF
+ if [ -n "$WORKER_RELAY_HOST" ]; then
+ scp start_workers.submit $WORKER_USERNAME@$WORKER_RELAY_HOST:
+ scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$WORKER_RELAY_HOST:$WORKER_LOCATION > /dev/null 2>&1
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "sbatch start_workers.submit"
+ else
+ sbatch start_workers.submit
+ fi
# Start GWMS workers
start-workers-gwms()
PORT=$1
@@ -318,10 +358,10 @@
ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "mkdir -p condor"
ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "grid-proxy-init"
- ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "WORKER_INIT_CMD='$WORKER_INIT_CMD' WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL run-gwms-workers $EXECUTION_URL $CONDOR_WORKERS"
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "WORKER_INIT_CMD='$WORKER_INIT_CMD' WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL run-gwms-workers $EXECUTIONURL $CONDOR_WORKERS"
else
mkdir -p condor
- run-gwms-workers $EXECUTION_URL $CONDOR_WORKERS
+ run-gwms-workers $EXECUTIONURL $CONDOR_WORKERS
fi
@@ -332,7 +372,7 @@
crash "start-workers-cobalt: Port number not specified, giving up"
fi
TIMESTAMP=$(date "+%Y.%m%d.%H%M%S")
R=${RANDOM}
ID="${TIMESTAMP}.${R}"
@@ -346,7 +386,7 @@
-E cobalt.${$}.stderr \
-o cobalt.${$}.stdout \
-e "WORKER_LOGGING_LEVEL=DEBUG:ZOID_ENABLE_NAT=true" \
- $SWIFT_BIN/$WORKER $EXECUTION_URL $ID $PWD/$LOG_DIR
+ $SWIFT_BIN/$WORKER $EXECUTIONURL $ID $PWD/$LOG_DIR
return 0
@@ -477,7 +517,7 @@
echo Local port: $LOCAL_PORT
# Generate sites.xml
-export EXECUTION_URL="http://$IPADDR:$SERVICE_PORT"
+export EXECUTIONURL="http://$IPADDR:$SERVICE_PORT"
echo Generating sites.xml
if [ -f "gensites.template" ]; then
gensites `cat gensites.template` -p $CONFIG_FILE > $RUN_DIR/sites.xml
@@ -518,6 +558,9 @@
gwms)
start-workers-gwms $LOCAL_PORT
+ slurm)
+ start-workers-slurm $LOCAL_PORT
crash "Unknown WORKER_MODE. Please modify coaster-service.conf"
More information about the Swift-commit
