[Swift-commit] cog r3555
swift at ci.uchicago.edu
Wed Jan 16 01:35:09 CST 2013
r3555 | hategan | 2013-01-16 01:31:00 -0600 (Wed, 16 Jan 2013) | 1 line
removed command timeouts
Index: modules/provider-coaster/resources/worker.pl
--- modules/provider-coaster/resources/worker.pl (revision 3554)
+++ modules/provider-coaster/resources/worker.pl (working copy)
@@ -120,7 +120,8 @@
my $TAG = int(rand(10000));
use constant RETRIES => 3;
-use constant REPLYTIMEOUT => 180;
+use constant CHANNEL_TIMEOUT => 180;
+use constant HEARTBEAT_INTERVAL => 60;
use constant MAXFRAGS => 16;
# TODO: Make this configurable (#537)
use constant MAX_RECONNECT_ATTEMPTS => 3;
@@ -136,11 +137,6 @@
use constant IOBUFSZ => 32768;
use constant IOBLOCKSZ => 8;
-# 60 seconds by default. Note that since there is no configuration handshake
-# this would have to match the default interval in the service in order to avoid
-# "lost heartbeats".
-use constant HEARTBEAT_INTERVAL => 30;
# If true, enable a profile result that is written to the log
my $PROFILE = 0;
# Contains tuples (EVENT, PID, TIMESTAMP) (flattened)
@@ -196,6 +192,8 @@
my %SUSPENDED_TRANSFERS = ();
+my $LAST_RECEIVE_TIME = 0;
# partial message being sent when
# writing to the socket would have blocked
my %partialSend;
@@ -244,7 +242,6 @@
-# time: last communication time (used to determine timeouts)
my $LOG = logfilename($LOGDIR, $BLOCKID);
@@ -867,38 +864,11 @@
return 1;
-sub checkTimeouts2 {
- my ($hash) = @_;
- my $now = time();
- my @del = ();
- my $k;
- my $v;
- while (($k, $v) = each(%$hash)) {
- if ($now - $$v[1] > REPLYTIMEOUT) {
- push(@del, $k);
- my $cont = $$v[0];
- $$cont{"dataIn"}($cont, $k, 1, 0, 0, "Reply timeout");
- foreach $k (@del) {
- delete $$hash{$k};
-my $LASTTIMEOUTCHECK = 0;
sub checkTimeouts {
my $time = time();
- if ($time - $LASTTIMEOUTCHECK < 1) {
- return;
+ if ($time - $LAST_RECEIVE_TIME > CHANNEL_TIMEOUT) {
+ crash("Channel timed out. Last receive time: $LAST_RECEIVE_TIME, now: $time");
- $LASTTIMEOUTCHECK = $time;
- checkTimeouts2(\%REQUESTS);
- checkTimeouts2(\%REPLIES);
my $DATA = "";
@@ -909,6 +879,7 @@
my $buf;
$SOCK->recv($buf, 20 - length($DATA));
if (length($buf) > 0) {
+ $LAST_RECEIVE_TIME = time();
$DATA = $DATA . $buf;
if (length($DATA) == 20) {
# wlog DEBUG, "Received " . unpackData($DATA) . "\n";
More information about the Swift-commit
