[Swift-commit] r5935 - in SwiftApps/CMTS/scaling: . conf input_files
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Thu Sep 20 10:45:33 CDT 2012
Author: davidk
Date: 2012-09-20 10:45:29 -0500 (Thu, 20 Sep 2012)
New Revision: 5935
Added:
   SwiftApps/CMTS/scaling/conf/fusion.cf
   SwiftApps/CMTS/scaling/conf/fusion.xml
   SwiftApps/CMTS/scaling/input_files/par_all22_prot.inp
   SwiftApps/CMTS/scaling/plot.sh
Modified:
   SwiftApps/CMTS/scaling/conf/local.cf
   SwiftApps/CMTS/scaling/input_files/h0_eq.conf
   SwiftApps/CMTS/scaling/namd_wrapper.sh
   SwiftApps/CMTS/scaling/runscaling.sh
   SwiftApps/CMTS/scaling/scaling.swift
Log:
Various updates to scaling scripts
Added: SwiftApps/CMTS/scaling/conf/fusion.cf
--- SwiftApps/CMTS/scaling/conf/fusion.cf	                        (rev 0)
+++ SwiftApps/CMTS/scaling/conf/fusion.cf	2012-09-20 15:45:29 UTC (rev 5935)
@@ -0,0 +1,11 @@
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=0
+lazy.errors=true
+status.mode=provider
+use.provider.staging=false
+provider.staging.pin.swiftfiles=false
+use.wrapper.staging=false
+#app namd_wrapper=$PWD/../namd_wrapper.sh
+#app plot=$PWD/../plot.sh
Added: SwiftApps/CMTS/scaling/conf/fusion.xml
--- SwiftApps/CMTS/scaling/conf/fusion.xml	                        (rev 0)
+++ SwiftApps/CMTS/scaling/conf/fusion.xml	2012-09-20 15:45:29 UTC (rev 5935)
@@ -0,0 +1,18 @@
+<config>
+<pool handle="grotthuss">
+  <execution jobmanager="local:pbs" provider="pbs" url="none"/>
+  <filesystem provider="local" url="none" />
+  <profile namespace="globus" key="maxWallTime">01:00:00</profile>
+  <profile namespace="globus" key="maxTime">3600</profile>
+  <profile key="jobsPerNode" namespace="globus">8</profile>
+  <profile key="slots" namespace="globus">1</profile>
+  <profile key="maxNodes" namespace="globus">1</profile>
+  <profile key="jobThrottle" namespace="karajan">5.99</profile>
+  <profile key="initialScore" namespace="karajan">10000</profile>
+  <profile key="count" namespace="globus">1</profile>
+  <profile key="jobType" namespace="globus">single</profile>
+  <profile key="ppn" namespace="globus">8</profile>
+  <workdirectory>_WORK_</workdirectory>
+</pool>
+</config>
Modified: SwiftApps/CMTS/scaling/conf/local.cf
--- SwiftApps/CMTS/scaling/conf/local.cf	2012-09-19 04:24:57 UTC (rev 5934)
+++ SwiftApps/CMTS/scaling/conf/local.cf	2012-09-20 15:45:29 UTC (rev 5935)
@@ -7,4 +7,5 @@
-#app rmsd=$PWD/../rmsd.sh
Modified: SwiftApps/CMTS/scaling/input_files/h0_eq.conf
--- SwiftApps/CMTS/scaling/input_files/h0_eq.conf	2012-09-19 04:24:57 UTC (rev 5934)
+++ SwiftApps/CMTS/scaling/input_files/h0_eq.conf	2012-09-20 15:45:29 UTC (rev 5935)
@@ -5,32 +5,30 @@
 # Minimization and equilibration of waters with
 # protein held fixed to reduce artifacts
-set WORK	   _WORK_
 ## ADJUSTABLE PARAMETERS                                   ##
-structure          $WORK/h0_solvion.psf
-coordinates        $WORK/h0_solvion.pdb
+structure          h0_solvion.psf
+coordinates        h0_solvion.pdb
 # Output Names                                             ##
-set basename       h0_eq.JOB
-outputName         $WORK/OUT/$basename
-DCDfile            $WORK/OUT/$basename.dcd
-restartname        $WORK/RESTART/$basename.restart
+set basename       h0_eq._JOB_
+outputName         $basename
+DCDfile            $basename.dcd
+restartname        $basename.restart
 # Initial temperature
 set temperature    310
 # Continuing a job from the restart files
 if {1} {
-set inputname      h0_eq.0
-binCoordinates     $WORK/RESTART/$inputname.restart.coor
-binVelocities      $WORK/RESTART/$inputname.restart.vel
-extendedSystem     $WORK/RESTART/$inputname.restart.xsc
+set inputname      h0_eq.0
+binCoordinates     $inputname.restart.coor
+binVelocities      $inputname.restart.vel
+extendedSystem     $inputname.restart.xsc
 firsttimestep 	  0
@@ -41,7 +39,7 @@
 # Input
 paraTypeCharmm      on
-parameters          $WORK/par_all22_prot.inp
+parameters          par_all22_prot.inp
 # Periodic Boundary Conditions from extended system cell (.xsc)
 wrapWater           on
@@ -106,4 +104,4 @@
 ## EXECUTION SCRIPT                                        ##
-run 5000
+run 500
Added: SwiftApps/CMTS/scaling/input_files/par_all22_prot.inp
--- SwiftApps/CMTS/scaling/input_files/par_all22_prot.inp	                        (rev 0)
+++ SwiftApps/CMTS/scaling/input_files/par_all22_prot.inp	2012-09-20 15:45:29 UTC (rev 5935)
@@ -0,0 +1,3330 @@
+*>>>>> CHARMM22 All-Hydrogen Parameter File for Proteins <<<<<<<<
+*>>>>> Includes phi, psi cross term map (CMAP) correction <<<<<<<
+*>>>>>>>>>>>>>>>>>>>>>> December, 2003 <<<<<<<<<<<<<<<<<<<<<<<<<<
+* All comments to ADM jr. via the CHARMM web site: www.charmm.org
+*               parameter set discussion forum
+! references
+!PROTEINS
+!MacKerell, A.D., Jr,. Feig, M., Brooks, C.L., III, Extending the
+!treatment of backbone energetics in protein force fields: limitations
+!of gas-phase quantum mechanics in reproducing protein conformational
+!distributions in molecular dynamics simulations, Journal of
+!Computational Chemistry, 25: 1400-1415, 2004.
+!MacKerell, Jr., A. D.; Bashford, D.; Bellott, M.; Dunbrack Jr., R.L.;
+!Evanseck, J.D.; Field, M.J.; Fischer, S.; Gao, J.; Guo, H.; Ha, S.;
+!Joseph-McCarthy, D.; Kuchnir, L.; Kuczera, K.; Lau, F.T.K.; Mattos,
+!C.; Michnick, S.; Ngo, T.; Nguyen, D.T.; Prodhom, B.; Reiher, III,
+!W.E.; Roux, B.; Schlenkrich, M.; Smith, J.C.; Stote, R.; Straub, J.;
+!Watanabe, M.; Wiorkiewicz-Kuczera, J.; Yin, D.; Karplus, M.  All-atom
+!empirical potential for molecular modeling and dynamics Studies of
+!proteins.  Journal of Physical Chemistry B, 1998, 102, 3586-3616.
+!IONS (see lipid and nucleic acid topology and parameter files for
+!additional ions
+!ZINC
+!Roland H. Stote and Martin Karplus, Zinc Binding in Proteins and
+!Solution: A Simple but Accurate Nonbonded Representation, PROTEINS:
+!Structure, Function, and Genetics 23:12-31 (1995)
+BONDS
+!V(bond) = Kb(b - b0)**2
+!Kb: kcal/mole/A**2
+!b0: A
+!atom type Kb          b0
+NH2   CT1   240.00      1.455  ! From LSN NH2-CT2
+!Carbon Dioxide
+CST  OST   937.96      1.1600 ! JES
+!Heme to Sulfate (PSUL) link
+SS   FE    250.0       2.3200 !force constant a guess
+           !equilbrium bond length optimized to reproduce
+           !CSD survey values of
+           !2.341pm0.01 (mean, standard error)
+           !adm jr., 7/01
+C    C     600.000     1.3350 ! ALLOW ARO HEM
+                ! Heme vinyl substituent (KK, from propene (JCS))
+CA   CA    305.000     1.3750 ! ALLOW   ARO
+                ! benzene, JES 8/25/89
+CE1  CE1   440.000     1.3400   !
+		! for butene; from propene, yin/adm jr., 12/95
+CE1  CE2   500.000     1.3420   !
+		! for propene, yin/adm jr., 12/95
+CE1  CT2   365.000     1.5020   !
+CE1  CT3   383.000     1.5040   !
+		! for butene, yin/adm jr., 12/95
+CE2  CE2   510.000     1.3300   !
+		! for ethene, yin/adm jr., 12/95
+CP1  C     250.000     1.4900 ! ALLOW PRO
+                ! 6-31g* AcProNH2, ProNH2, 6-31g*//3-21g AcProNHCH3 RLD 4/23/93
+CP1  CC    250.000     1.4900 ! ALLOW PRO
+CP1  CD    200.000     1.4900 ! ALLOW PRO
+CP2  CP1   222.500     1.5270 ! ALLOW PRO
+CP2  CP2   222.500     1.5370 ! ALLOW PRO
+CP3  CP2   222.500     1.5370 ! ALLOW PRO
+CPB  CE1   450.000     1.3800 ! ALLOW HEM
+                ! Heme (6-liganded): substituents (KK 05/13/91)
+CPB  CPA   299.800     1.4432 ! ALLOW HEM
+                ! Heme (6-liganded): porphyrin macrocycle (KK 05/13/91)
+CPB  CPB   340.700     1.3464 ! ALLOW HEM
+CPH1 CPH1  410.000     1.3600 ! ALLOW ARO
+                ! histidine, adm jr., 6/27/90
+CPM  CPA   360.000     1.3716 ! ALLOW HEM
+CPT  CA    305.000     1.3680 ! ALLOW   ARO
+                ! adm jr., 12/30/91, for jwk
+CPT  CPT   360.000     1.4000 ! ALLOW   ARO
+                !adm jr., 12/30/91, for jwk
+CT1  C     250.000     1.4900 ! ALLOW   ALI PEP POL ARO
+                ! Ala Dipeptide ab initio calc's (LK) fixed from 10/90 (5/91)
+CT1  CC    200.000     1.5220 ! ALLOW   POL
+                ! adm jr. 4/05/91, for asn,asp,gln,glu and cters
+CT1  CD    200.000     1.5220 ! ALLOW   POL
+                ! adm jr. 5/02/91, acetic acid pure solvent
+CT1  CT1   222.500     1.5000 ! ALLOW   ALI
+                ! alkane update, adm jr., 3/2/92
+CT2  C     250.000     1.4900 ! ALLOW   ALI PEP POL ARO
+CT2  CA    230.000     1.4900 ! ALLOW   ALI ARO
+                ! phe,tyr, JES 8/25/89
+CT2  CC    200.000     1.5220 ! ALLOW   POL
+CT2  CD    200.000     1.5220 ! ALLOW   POL
+CT2  CPB   230.000     1.4900 ! ALLOW HEM
+CT2  CPH1  229.630     1.5000 ! ALLOW ARO
+                ! his, adm jr., 7/22/89, FC from CT2CT, BL from crystals
+CT2  CT1   222.500     1.5380 ! ALLOW   ALI
+CT2  CT2   222.500     1.5300 ! ALLOW   ALI
+CT3  C     250.000     1.4900 ! ALLOW   ALI PEP POL ARO
+CT3  CA    230.000     1.4900 ! ALLOW   ALI ARO
+                ! toluene, adm jr. 3/7/92
+CT3  CC    200.000     1.5220 ! ALLOW   POL
+CT3  CD    200.000     1.5220 ! ALLOW   POL
+CT3  CPB   230.000     1.4900 ! ALLOW HEM
+CT3  CPH1  229.630     1.5000 ! ALLOW ARO
+CT3  CS    190.000     1.5310 ! ALLOW   SUL
+                ! ethylthiolate 6-31+G* geom/freq, adm jr., 6/1/92
+CT3  CT1   222.500     1.5380 ! ALLOW   ALI
+CT3  CT2   222.500     1.5280 ! ALLOW   ALI
+CT3  CT3   222.500     1.5300 ! ALLOW   ALI
+CY   CA    350.000     1.3650 ! ALLOW   ARO
+                !adm jr., 5/08/91, indole CCDB structure search
+CY   CPT   350.000     1.4400 ! ALLOW   ARO
+CY   CT2   230.000     1.5100 ! ALLOW ARO
+                !JWK  Kb from alkane freq.. b0 from TRP crystal
+FE   CM    258.000     1.9000 ! ALLOW HEM
+                ! Heme (6-liganded): CO ligand (KK 05/13/91)
+FE   CPM     0.000     3.3814 ! ALLOW HEM
+                ! Heme (6-liganded): for "ic para" only (KK 05/13/91)
+H    CD    330.000     1.1100 ! ALLOW   PEP POL ARO
+!HA   C     330.000     1.1000 ! ALLOW ARO HEM
+HA   CA    340.000     1.0830 ! ALLOW ARO
+                ! trp, adm jr., 10/02/89
+HA   CC    317.130     1.1000 ! ALLOW POL
+                ! adm jr., 5/13/91, formamide geometry and vibrations
+HA   CP2   309.000     1.1110 ! ALLOW PRO
+HA   CP3   309.000     1.1110 ! ALLOW PRO
+HA   CPM   367.600     1.0900 ! ALLOW HEM
+HA   CS    300.000     1.1110 ! ALLOW   SUL
+                ! methylthiolate 6-31+G* geom/freq, adm jr., 6/1/92
+HA   CT1   309.000     1.1110 ! ALLOW   ALI
+HA   CT2   309.000     1.1110 ! ALLOW   ALI
+HA   CT3   322.000     1.1110 ! ALLOW   ALI
+HA   CY    330.000     1.0800 ! ALLOW   ARO
+                ! JWK 05/14/91 new r0 from indole
+HE1  CE1   360.500     1.1000   !
+HE2  CE2   365.000     1.1000   !
+HB   CP1   330.000     1.0800 ! ALLOW PRO
+HB   CT1   330.000     1.0800 ! ALLOW   PEP
+                ! Alanine Dipeptide ab initio calc's (LK)
+HB   CT2   330.000     1.0800 ! ALLOW   PEP
+HB   CT3   330.000     1.0800 ! ALLOW   PEP
+HP   CA    340.000     1.0800 ! ALLOW   ARO
+                ! phe,tyr JES 8/25/89
+HP   CY    350.000     1.0800 ! ALLOW   ARO
+HR1  CPH1  375.000     1.0830 ! ALLOW ARO
+                ! his, adm jr., 6/27/90
+HR1  CPH2  340.000     1.0900 ! ALLOW ARO
+                ! his, adm jr., 6/28/29
+HR2  CPH2  333.000     1.0700 ! ALLOW ARO
+HR3  CPH1  365.000     1.0830 ! ALLOW ARO
+                ! adm jr., 3/24/92, maintain old aliphatic H VDW params
+HT   HT      0.000     1.5139 ! ALLOW WAT
+                ! FROM TIPS3P GEOMETRY (FOR SHAKE/W PARAM)
+N    C     260.000     1.3000 ! ALLOW PEP POL ARO PRO
+N    CP1   320.000     1.4340 ! ALLOW PRO
+N    CP3   320.000     1.4550 ! ALLOW PRO
+NC2  C     463.000     1.3650 ! ALLOW   PEP POL ARO
+                ! 403.0->463.0, 1.305->1.365 guanidinium (KK)
+NC2  CT2   261.000     1.4900 ! ALLOW   ALI POL
+                ! arg, (DS)
+NC2  CT3   261.000     1.4900 ! ALLOW   ALI POL
+                ! methylguanidinium, adm jr., 3/26/92
+NC2  HC    455.000     1.0000 ! ALLOW   POL
+                ! 405.0->455.0 GUANIDINIUM (KK)
+NH1  C     370.000     1.3450 ! ALLOW   PEP POL ARO
+NH1  CT1   320.000     1.4300 ! ALLOW   ALI PEP POL ARO
+                ! NMA Gas & Liquid Phase IR Spectra (LK)
+NH1  CT2   320.000     1.4300 ! ALLOW   ALI PEP POL ARO
+NH1  CT3   320.000     1.4300 ! ALLOW   ALI PEP POL ARO
+NH1  H     440.000     0.9970 ! ALLOW   PEP POL ARO
+NH1  HC    405.000     0.9800 ! ALLOW   PEP POL ARO
+                ! (DS)
+NH2  CC    430.000     1.3600 ! ALLOW   PEP POL ARO
+                ! adm jr. 4/10/91, acetamide
+NH2  CT2   240.000     1.4550
+                ! from NH2  CT3, neutral glycine, adm jr.
+NH2  CT3   240.000     1.4550 ! ALLOW   POL
+                ! methylamine geom/freq, adm jr., 6/2/92
+NH2  H     480.000     1.0000 ! ALLOW   POL
+                ! adm jr. 8/13/90 acetamide geometry and vibrations
+NH2  HC    460.000     1.0000 ! ALLOW   POL
+NH3  CT1   200.000     1.4800 ! ALLOW   ALI POL
+                ! new stretch and bend; methylammonium (KK 03/10/92)
+NH3  CT2   200.000     1.4800 ! ALLOW   ALI POL
+NH3  CT3   200.000     1.4800 ! ALLOW   ALI POL
+NH3  HC    403.000     1.0400 ! ALLOW   POL
+NP   CP1   320.000     1.4850 ! ALLOW PRO
+NP   CP3   320.000     1.5020 ! ALLOW PRO
+NP   HC    460.000     1.0060 ! ALLOW PRO
+NPH  CPA   377.200     1.3757 ! ALLOW HEM
+NPH  FE    270.200     1.9580 ! ALLOW HEM
+NR1  CPH1  400.000     1.3800 ! ALLOW ARO
+                ! his, ADM JR., 7/20/89
+NR1  CPH2  400.000     1.3600 ! ALLOW ARO
+NR1  H     466.000     1.0000 ! ALLOW ARO
+NR2  CPH1  400.000     1.3800 ! ALLOW ARO
+NR2  CPH2  400.000     1.3200 ! ALLOW ARO
+NR2  FE     65.000     2.2000 ! ALLOW HEM
+                ! Heme (6-liganded): His ligand (KK 05/13/91)
+NR3  CPH1  380.000     1.3700 ! ALLOW ARO
+                ! his, adm jr., 6/28/90
+NR3  CPH2  380.000     1.3200 ! ALLOW ARO
+NR3  H     453.000     1.0000 ! ALLOW ARO
+NY   CA    270.000     1.3700 ! ALLOW   ARO
+NY   CPT   270.000     1.3750 ! ALLOW   ARO
+NY   H     465.000     0.9760 ! ALLOW   ARO
+                ! indole JWK   08/28/89
+O    C     620.000     1.2300 ! ALLOW   PEP POL ARO
+                ! Peptide geometry, condensed phase (LK)
+O    CC    650.000     1.2300 ! ALLOW   PEP POL ARO
+OB   CC    750.000     1.2200 ! ALLOW   PEP POL ARO
+                ! adm jr., 10/17/90, acetic acid vibrations and geom.
+OB   CD    750.000     1.2200 ! ALLOW   PEP POL ARO
+OC   CA    525.000     1.2600 ! ALLOW   PEP POL ARO ION
+                ! adm jr. 8/27/91, phenoxide
+OC   CC    525.000     1.2600 ! ALLOW   PEP POL ARO ION
+                ! adm jr. 7/23/91, acetic acid
+OC   CT2   450.000     1.3300 ! ALLOW   ALC
+                ! ethoxide 6-31+G* geom/freq, adm jr., 6/1/92
+OC   CT3   450.000     1.3300 ! ALLOW   ALC
+                ! methoxide 6-31+G* geom/freq, adm jr., 6/1/92
+OH1  CA    334.300     1.4110 ! ALLOW   ARO ALC
+                ! MeOH, EMB 10/10/89,
+OH1  CD    230.000     1.4000 ! ALLOW   PEP POL ARO ALC
+OH1  CT1   428.000     1.4200 ! ALLOW   ALI ALC ARO
+                ! methanol vib fit EMB 11/21/89
+OH1  CT2   428.000     1.4200 ! ALLOW   ALI ALC ARO
+OH1  CT3   428.000     1.4200 ! ALLOW   ALI ALC ARO
+OH1  H     545.000     0.9600 ! ALLOW   ALC ARO
+                ! EMB 11/21/89 methanol vib fit
+OM   CM   1115.000     1.1280 ! ALLOW HEM
+OM   FE    250.000     1.8000 ! ALLOW HEM
+                ! Heme (6-liganded): O2 ligand (KK 05/13/91)
+OM   OM    600.000     1.2300 ! ALLOW HEM
+OS   CD    150.000     1.3340 ! ALLOW POL PEP
+OS   CT3   340.000     1.4300 ! ALLOW POL PEP
+                ! adm jr., 4/05/91, for PRES CT1 from methylacetate
+OT   HT    450.000     0.9572 ! ALLOW   WAT
+S    CT2   198.000     1.8180 ! ALLOW   ALI SUL ION
+                ! fitted to C-S s   9/26/92 (FL)
+S    CT3   240.000     1.8160 ! ALLOW   ALI SUL ION
+S    HS    275.000     1.3250 ! ALLOW   SUL ION
+                ! methanethiol pure solvent, adm jr., 6/22/92
+SM   CT2   214.000     1.8160 ! ALLOW   SUL ION
+                ! improved CSSC dihedral in DMDS  5/15/92 (FL)
+SM   CT3   214.000     1.8160 ! ALLOW   SUL ION
+SM   SM    173.000     2.0290 ! ALLOW   SUL ION
+SS   CS    205.000     1.8360 ! ALLOW   SUL
+ANGLES
+!V(angle) = Ktheta(Theta - Theta0)**2
+!V(Urey-Bradley) = Kub(S - S0)**2
+!Ktheta: kcal/mole/rad**2
+!Theta0: degrees
+!Kub: kcal/mole/A**2 (Urey-Bradley)
+!S0: A
+!atom types     Ktheta    Theta0   Kub     S0
+H    NH2  CT1   50.000    111.00              ! From LSN HC-NH2-CT2
+NH2  CT1  CT2   67.700    110.00              ! From LSN NH2-CT2-CT2
+NH2  CT1  CT3   67.700    110.00              ! From LSN NH2-CT2-CT2
+CT1  CD   OH1   55.000    110.50              ! From ASPP CT2-CD-OH1
+CT3  CT1  CD    52.000    108.00              ! Ala cter
+NH2  CT1  HB    38.000    109.50   50.00   2.1400 ! From LSN NH2-CT2-HA
+NH2  CT1  C     50.000    107.00              ! From ALA Dipep. NH1-CT2-C
+!Carbon Dioxide, JES
+OST  CST  OST    3000.00  180.0000 ! CO2, JES
+CS   SS   FE    50.0      100.6    !force constant a guess
+                !equilibrium angle optimized to reproduce
+                !107.5pm0.6 (mean, standard error)
+                !adm jr., 7/01
+SS   FE   NPH   100.0       90.0    !force constant a guess
+                !adm jr., 7/01
+CA   CA   CA    40.000    120.00   35.00   2.41620 ! ALLOW   ARO
+                ! JES 8/25/89
+CE1  CE1  CT2    48.00    123.50   !
+                ! for 2-butene, yin/adm jr., 12/95
+CE1  CE1  CT3    48.00    123.50   !
+CE1  CT2  CT3    32.00    112.20   !
+		! for 1-butene; from propene, yin/adm jr., 12/95
+CE2  CE1  CT2    48.00    126.00   !
+CE2  CE1  CT3    47.00    125.20   !
+CP1  N    C      60.000   117.0000 ! ALLOW PRO
+CP2  CP1  C      52.000   112.3000 ! ALLOW PRO
+CP2  CP1  CC     52.000   112.3000 ! ALLOW PRO
+CP2  CP1  CD     50.000   112.3000 ! ALLOW PRO PEP
+CP2  CP2  CP1    70.000   108.5000 ! ALLOW PRO
+CP3  CP2  CP2    70.000   108.5000 ! ALLOW PRO
+CP3  N    C      60.000   117.0000 ! ALLOW PRO
+CP3  N    CP1   100.000   114.2000 ! ALLOW PRO
+CP3  NP   CP1   100.000   111.0000 ! ALLOW PRO
+CPA  CPB  CE1    70.000   126.7400 ! ALLOW HEM
+CPA  CPM  CPA    94.200   125.1200 ! ALLOW HEM
+CPA  NPH  CPA   139.300   103.9000 ! ALLOW HEM
+CPB  CE1  CE2    70.000   121.5000 ! ALLOW HEM
+CPB  CPB  CE1    70.000   126.7500 ! ALLOW HEM
+CPB  CPB  CPA    30.800   106.5100 ! ALLOW HEM
+CPH2 NR1  CPH1  130.000   107.5000 ! ALLOW ARO
+CPH2 NR2  CPH1  130.000   104.0000 ! ALLOW ARO
+CPH2 NR3  CPH1  145.000   108.0000 ! ALLOW ARO
+CPM  CPA  CPB    61.600   124.0700 ! ALLOW HEM
+CPT  CA   CA     60.000   118.0000 ! ALLOW   ARO
+CPT  CPT  CA     60.000   122.0000 ! ALLOW   ARO
+CPT  CY   CA   120.000    107.40   25.00   2.26100 ! ALLOW   ARO
+CPT  NY   CA    110.000   108.0000 ! ALLOW   ARO
+CT1  CT1  C      52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT1  CT1  CC     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT1  CT1  CT1   53.350    111.00    8.00   2.56100 ! ALLOW ALI
+CT1  CT2  CA     51.800   107.5000 ! ALLOW   ALI ARO
+                ! PARALLH19 (JES)
+CT1  CT2  CC     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT1  CT2  CD     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT1  CT2  CPH1   58.350   113.0000 ! ALLOW ARO
+                ! his, ADM JR., 7/22/89, from CT2CT2CT, U-B omitted
+CT1  CT2  CT1   58.350    113.50   11.16   2.56100 ! ALLOW   ALI
+                ! alkane frequencies (MJF), alkane geometries (SF)
+CT1  NH1  C      50.000   120.0000 ! ALLOW   ALI PEP POL ARO
+                ! NMA Vib Modes (LK)
+CT2  CA   CA     45.800   122.3000 ! ALLOW   ALI ARO
+                ! PARALLH19 (JES)
+CT2  CPB  CPA    65.000   126.7400 ! ALLOW HEM
+CT2  CPB  CPB    65.000   126.7500 ! ALLOW HEM
+CT2  CPH1 CPH1   45.800   130.0000 ! ALLOW ARO
+                ! his, ADM JR., 7/22/89, FC=>CT2CA CA,BA=> CRYSTALS
+CT2  CT1  C      52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT2  CT1  CC     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT2  CT1  CD     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT2  CT1  CT1   53.350    111.00    8.00   2.56100 ! ALLOW   ALI
+CT2  CT2  C      52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+                ! from CT2  CT1  C, for lactams, adm jr.
+CT2  CT2  CC     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT3  CT2  CC     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT2  CT2  CD     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT2  CT2  CPB    70.000   113.0000 ! ALLOW HEM
+CT2  CT2  CT1   58.350    113.50   11.16   2.56100 ! ALLOW   ALI
+CT2  CT2  CT2   58.350    113.60   11.16   2.56100 ! ALLOW   ALI
+CT2  CT3  CT1   58.350    113.50   11.16   2.56100 ! ALLOW   ALI
+CT2  CY   CA     45.800   129.4000 ! ALLOW ARO
+CT2  CY   CPT    45.800   124.0000 ! ALLOW ARO
+CT2  NC2  C      62.300   120.0000 ! ALLOW   ALI POL PEP ARO
+                ! 107.5->120.0 to make planar Arg (KK)
+CT2  NH1  C      50.000   120.0000 ! ALLOW   ALI PEP POL ARO
+CT2  OS   CD    40.000    109.60   30.00   2.26510 ! ALLOW  POL PEP
+CT3  CA   CA     45.800   122.3000 ! ALLOW   ALI ARO
+                ! toluene, adm jr., 3/7/92
+CT3  CPB  CPA    65.000   126.7400 ! ALLOW HEM
+CT3  CPB  CPB    65.000   126.7500 ! ALLOW HEM
+CT3  CPH1 CPH1   45.800   130.0000 ! ALLOW ARO
+CT3  CT1  C      52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+CT3  CT1  CC     52.000   108.0000 ! ALLOW   ALI PEP POL ARO
+                ! adm jr. 4/09/92, for ALA cter
+CT3  CT1  CT1   53.350    108.50    8.00   2.56100 ! ALLOW   ALI
+CT3  CT1  CT2   53.350    114.00    8.00   2.56100 ! ALLOW   ALI
+CT3  CT1  CT3   53.350    114.00    8.00   2.56100 ! ALLOW   ALI
+CT3  CT2  CA     51.800   107.5000 ! ALLOW   ALI ARO
+                ! ethylbenzene, adm jr., 3/7/92
+CT3  CT2  CPH1   58.350   113.0000 ! ALLOW ARO
+CT3  CT2  CT1   58.350    113.50   11.16   2.56100 ! ALLOW   ALI
+CT3  CT2  CT2   58.000    115.00    8.00   2.56100 ! ALLOW   ALI
+CT3  CT2  CT3   53.350    114.00    8.00   2.56100 ! ALLOW   ALI
+CT3  NC2  C      62.300   120.0000 ! ALLOW   ALI POL PEP ARO
+CT3  NH1  C      50.000   120.0000 ! ALLOW   ALI PEP POL ARO
+CT3  OS   CD    40.000    109.60   30.00   2.26510 ! ALLOW  POL PEP
+CT3  S    CT2    34.000    95.0000 ! ALLOW   ALI SUL ION
+                ! expt. MeEtS,    3/26/92 (FL)
+CY   CPT  CA    160.000   130.6000 ! ALLOW   ARO
+CY   CPT  CPT   110.000   107.4000 ! ALLOW   ARO
+CY   CT2  CT1    58.350   114.0000 ! ALLOW ARO
+                ! from TRP crystal, JWK
+CY   CT2  CT3    58.350   114.0000 ! ALLOW ARO
+FE   NPH  CPA    96.150   128.0500 ! ALLOW HEM
+FE   NR2  CPH1   30.000   133.0000 ! ALLOW HEM
+                ! Heme (6-liganded): ligand links (KK 05/13/91)
+FE   NR2  CPH2   30.000   123.0000 ! ALLOW HEM
+H    NH1  C      34.000   123.0000 ! ALLOW   PEP POL ARO
+H    NH1  CT1    35.000   117.0000 ! ALLOW   PEP POL ARO ALI
+                ! NMA Vibrational Modes (LK)
+H    NH1  CT2    35.000   117.0000 ! ALLOW   PEP POL ARO ALI
+H    NH1  CT3    35.000   117.0000 ! ALLOW   PEP POL ARO ALI
+H    NH2  CC     50.000   120.0000 ! ALLOW   POL PEP ARO
+                ! his, adm jr. 8/13/90 acetamide geometry and vibrations
+H    NH2  H      23.000   120.0000 ! ALLOW   POL
+H    NR1  CPH1  30.000    125.50   20.00   2.15000 ! ALLOW ARO
+H    NR1  CPH2  30.000    127.00   20.00   2.14000 ! ALLOW ARO
+H    NR3  CPH1  25.000    126.00   15.00   2.13000 ! ALLOW ARO
+H    NR3  CPH2  25.000    126.00   15.00   2.09000 ! ALLOW ARO
+H    NY   CA     28.000   126.0000 ! ALLOW   ARO
+H    NY   CPT    28.000   126.0000 ! ALLOW   ARO
+H    OH1  CA     65.000   108.0000 ! ALLOW   ALC ARO
+                ! JES 8/25/89 phenol
+H    OH1  CD     55.000   115.0000 ! ALLOW   ALC ARO PEP POL
+H    OH1  CT1    57.500   106.0000 ! ALLOW   ALC ARO ALI
+H    OH1  CT2    57.500   106.0000 ! ALLOW   ALC ARO ALI
+H    OH1  CT3    57.500   106.0000 ! ALLOW   ALC ARO ALI
+!HA   C    C      50.000   120.5000 ! ALLOW   PEP POL ARO
+                ! Heme vinyl substituent (KK from propene (JCS))
+!HA   C    CPB    50.000   120.0000 ! ALLOW HEM
+!HA   C    HA     50.000   118.0000 ! ALLOW   PEP POL ARO
+HA   CA   CA    29.000    120.00   25.00   2.15250 ! ALLOW ARO
+HA   CA   CPT    41.000   122.0000 ! ALLOW   ARO
+HA   CA   CY    32.000    125.00   25.00   2.17300 ! ALLOW   ARO
+                ! JWK 05/14/91 new theta0 and r0UB from indole
+HA   CP2  CP1   33.430    110.10   22.53   2.17900 ! ALLOW ALI PRO
+HA   CP2  CP2   26.500    110.10   22.53   2.17900 ! ALLOW ALI PRO
+HA   CP2  CP3   26.500    110.10   22.53   2.17900 ! ALLOW ALI PRO
+HA   CP2  HA    35.500    109.00    5.40   1.80200 ! ALLOW ALI PRO
+HA   CP3  CP2   26.500    110.10   22.53   2.17900 ! ALLOW ALI PRO
+HA   CP3  HA    35.500    109.00    5.40   1.80200 ! ALLOW ALI PRO
+HA   CPM  CPA    12.700   117.4400 ! ALLOW HEM
+HA   CPM  FE      0.000   180.0000 ! ALLOW HEM
+HA   CS   CT3   34.600    110.10   22.53   2.17900 ! ALLOW SUL
+HA   CS   HA    35.500    108.40   14.00   1.77500 ! ALLOW SUL
+HA   CT1  C     33.000    109.50   30.00   2.16300 ! ALLOW   ALI PEP POL ARO
+                ! alanine dipeptide, LK, replaced, adm jr., 5/09/91
+HA   CT1  CD    33.000    109.50   30.00   2.16300 ! ALLOW   ALI PEP POL ARO
+HA   CT1  CT1   34.500    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT1  CT2   34.500    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT1  CT3   34.500    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT1  HA    35.500    109.00    5.40   1.80200 ! TEST for test cpd
+                ! based on HA   CT2  HA
+HA   CT2  C     33.000    109.50   30.00   2.16300 ! ALLOW   ALI PEP POL ARO
+HA   CT2  CA     49.300   107.5000 ! ALLOW   ALI ARO
+                ! PARALLH19 (JES)
+HA   CT2  CC    33.000    109.50   30.00   2.16300 ! ALLOW   ALI PEP POL ARO
+HA   CT2  CD    33.000    109.50   30.00   2.16300 ! ALLOW   ALI PEP POL ARO
+HA   CT2  CE1    45.00    111.50   !
+HA   CT2  CPB    50.000   109.5000 ! ALLOW HEM
+HA   CT2  CPH1   33.430   109.5000 ! ALLOW ARO
+                ! his, ADM JR., 7/22/89, from CT2CT2HA, U-B OMITTED
+HA   CT2  CT1   33.430    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT2  CT2   26.500    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT2  CT3   34.600    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT2  CY     33.430   109.5000 ! ALLOW ARO
+                ! ADM JR., 10/02/89, from CT2CT2HA (U-B OMITTED), FOR JOANNA
+HA   CT2  HA    35.500    109.00    5.40   1.80200 ! ALLOW   ALI
+HA   CT3  C     33.000    109.50   30.00   2.16300 ! ALLOW   ALI PEP POL ARO
+HA   CT3  CA     49.300   107.5000 ! ALLOW   ALI ARO
+HA   CT3  CC    33.000    109.50   30.00   2.16300 ! ALLOW   ALI PEP POL ARO
+HA   CT3  CD    33.000    109.50   30.00   2.16300 ! ALLOW   ALI PEP POL ARO
+HA   CT3  CE1    42.00    111.50   !
+HA   CT3  CPB    50.000   109.5000 ! ALLOW HEM
+HA   CT3  CPH1   33.430   109.5000 ! ALLOW ARO
+HA   CT3  CS    34.600    110.10   22.53   2.17900 ! ALLOW SUL
+HA   CT3  CT1   33.430    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT3  CT2   34.600    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT3  CT3   37.500    110.10   22.53   2.17900 ! ALLOW   ALI
+HA   CT3  HA    35.500    108.40    5.40   1.80200 ! ALLOW   ALI
+HA   CY   CA    20.000    126.40   25.00   2.18600 ! ALLOW   ARO
+HA   CY   CPT   32.000    126.40   25.00   2.25500 ! ALLOW   ARO
+HE1  CE1  CE1    52.00    119.50   !
+HE1  CE1  CE2    42.00    118.00   !
+HE1  CE1  CT2    40.00    116.00   !
+HE1  CE1  CT3    22.00    117.00   !
+HE1  CE1  CPB    50.000   120.0000 ! ALLOW HEM
+HE2  CE2  CE1    45.00    120.50   !
+HE2  CE2  CE2    55.50    120.50   !
+HE2  CE2  HE2    19.00    119.00   !
+HB   CP1  C      50.000   112.0000 ! ALLOW PEP PRO
+HB   CP1  CC     50.000   112.0000 ! ALLOW PEP PRO
+HB   CP1  CD     50.000   112.0000 ! ALLOW PEP POL PRO
+HB   CP1  CP2    35.000   118.0000 ! ALLOW PEP PRO
+HB   CT1  C      50.000   109.5000 ! ALLOW  PEP
+HB   CT1  CC     50.000   109.5000 ! ALLOW  PEP POL
+HB   CT1  CD     50.000   109.5000 ! ALLOW  PEP POL
+HB   CT1  CT1    35.000   111.0000 ! ALLOW  PEP
+HB   CT1  CT2    35.000   111.0000 ! ALLOW  PEP
+HB   CT1  CT3    35.000   111.0000 ! ALLOW  PEP
+HB   CT2  C      50.000   109.5000 ! ALLOW  PEP
+HB   CT2  CC     50.000   109.5000 ! ALLOW  PEP POL
+HB   CT2  CD     50.000   109.5000 ! ALLOW  PEP POL
+HB   CT2  HB     36.000   115.0000 ! ALLOW   PEP
+HB   CT3  C      50.000   109.5000 ! ALLOW  PEP
+HC   NC2  C      49.000   120.0000 ! ALLOW   POL PEP ARO
+                ! 35.3->49.0 GUANIDINIUM (KK)
+HC   NC2  CT2    40.400   120.0000 ! ALLOW   POL ALI
+HC   NC2  CT3    40.400   120.0000 ! ALLOW   POL ALI
+HC   NC2  HC     25.000   120.0000 ! ALLOW   POL
+                ! 40.0->25.0 GUANIDINIUM (KK)
+HC   NH2  CT2    50.000   111.0000 ! ALLOW   POL
+                ! from HC NH2 CT3, neutral glycine, adm jr.
+HC   NH2  CT3    50.000   111.0000 ! ALLOW   POL
+HC   NH2  HC     39.000   106.5000 ! ALLOW   POL
+HC   NH3  CT1   30.000    109.50   20.00   2.07400 ! ALLOW   POL ALI
+HC   NH3  CT2   30.000    109.50   20.00   2.07400 ! ALLOW   POL ALI
+HC   NH3  CT3   30.000    109.50   20.00   2.07400 ! ALLOW   POL ALI
+HC   NH3  HC     44.000   109.5000 ! ALLOW   POL
+HC   NP   CP1   33.000    109.50    4.00   2.05600 ! ALLOW POL ALI PRO
+HC   NP   CP3   33.000    109.50    4.00   2.05600 ! ALLOW POL ALI PRO
+HC   NP   HC     51.000   107.5000 ! ALLOW PRO
+HP   CA   CA    30.000    120.00   22.00   2.15250 ! ALLOW   ARO
+                ! JES 8/25/89 benzene
+HP   CA   CPT   30.000    122.00   22.00   2.14600 ! ALLOW   ARO
+HP   CA   CY    32.000    125.00   25.00   2.17300 ! ALLOW   ARO
+HP   CY   CA    32.000    126.40   25.00   2.18600 ! ALLOW   ARO
+HP   CY   CPT   32.000    126.40   25.00   2.25500 ! ALLOW   ARO
+HR1  CPH1 CPH1  22.000    130.00   15.00   2.21500 ! ALLOW ARO
+                ! adm jr., 6/27/90, his
+HR3  CPH1 CPH1  25.000    130.00   20.00   2.20000 ! ALLOW ARO
+HS   S    CT2    38.800    95.0000 ! ALLOW   SUL ION ALI
+HS   S    CT3    43.000    95.0000 ! ALLOW   SUL ION ALI
+HT   OT   HT     55.000   104.5200 ! ALLOW WAT
+                ! TIP3P GEOMETRY, ADM JR.
+N    C    CP1    20.000   112.5000 ! ALLOW PRO
+N    C    CT1    20.000   112.5000 ! ALLOW ALI PEP POL ARO PRO
+N    C    CT2    20.000   112.5000 ! ALLOW ALI PEP POL ARO PRO
+N    C    CT3    20.000   112.5000 ! ALLOW ALI PEP POL ARO PRO
+N    CP1  C      50.000   108.2000 ! ALLOW PRO
+N    CP1  CC     50.000   108.2000 ! ALLOW PRO
+N    CP1  CD     50.000   108.2000 ! ALLOW PRO PEP
+N    CP1  CP2    70.000   110.8000 ! ALLOW PRO
+N    CP1  HB     48.000   112.0000 ! ALLOW PEP PRO
+N    CP3  CP2    70.000   110.5000 ! ALLOW PRO
+N    CP3  HA     48.000   108.0000 ! ALLOW PEP PRO
+NC2  C    NC2   52.000    120.00   90.00   2.36420 ! ALLOW   POL PEP ARO
+                ! changed from 60.0/120.3 for guanidinium (KK)
+NC2  CT2  CT2    67.700   107.5000 ! ALLOW   ALI POL
+                ! arg, (DS)
+NC2  CT2  HA     51.500   107.5000 ! ALLOW   ALI POL
+                ! arg, (DS)
+NC2  CT3  HA     51.500   107.5000 ! ALLOW   ALI POL
+NH1  C    CP1    80.000   116.5000 ! ALLOW PEP PRO
+NH1  C    CT1    80.000   116.5000 ! ALLOW   ALI PEP POL ARO
+NH1  C    CT2    80.000   116.5000 ! ALLOW   ALI PEP POL ARO
+NH1  C    CT3    80.000   116.5000 ! ALLOW   ALI PEP POL ARO
+NH1  CT1  C      50.000   107.0000 ! ALLOW   PEP POL ARO ALI
+NH1  CT1  CC     50.000   107.0000 ! ALLOW   PEP POL ARO ALI
+NH1  CT1  CD     50.000   107.0000 ! ALLOW   PEP POL ARO ALI
+NH1  CT1  CT1    70.000   113.5000 ! ALLOW   ALI PEP POL ARO
+NH1  CT1  CT2    70.000   113.5000 ! ALLOW   ALI PEP POL ARO
+NH1  CT1  CT3    70.000   113.5000 ! ALLOW   ALI PEP POL ARO
+NH1  CT1  HB     48.000   108.0000 ! ALLOW PEP
+NH1  CT2  C      50.000   107.0000 ! ALLOW   PEP POL ARO ALI
+NH1  CT2  CC     50.000   107.0000 ! ALLOW   PEP POL ARO ALI
+                ! adm jr. 5/20/92, for asn,asp,gln,glu and cters
+NH1  CT2  CD     50.000   107.0000 ! ALLOW   PEP POL ARO ALI
+NH1  CT2  CT2    70.000   113.5000 ! ALLOW   ALI PEP POL ARO
+                ! from NH1  CT1  CT2, for lactams, adm jr.
+NH1  CT2  HA     51.500   109.5000 ! ALLOW   ALI PEP POL ARO
+                ! from NH1  CT3  HA, for lactams, adm jr.
+NH1  CT2  HB     48.000   108.0000 ! ALLOW PEP
+NH1  CT3  HA     51.500   109.5000 ! ALLOW   ALI PEP POL ARO
+                ! NMA crystal (JCS)
+NH2  CC   CP1    80.000   112.5000 ! ALLOW ALI PEP POL ARO PRO
+NH2  CC   CT1   50.000    116.50   50.00   2.45000 ! ALLOW   ALI PEP POL ARO
+NH2  CC   CT2   50.000    116.50   50.00   2.45000 ! ALLOW   ALI PEP POL ARO
+NH2  CC   CT3   50.000    116.50   50.00   2.45000 ! ALLOW   ALI PEP POL ARO
+NH2  CC   HA    44.000    111.00   50.00   1.98000 ! ALLOW POL
+NH2  CT2  HA    38.000    109.50   50.00   2.14000
+                !from NH2  CT3  HA, neutral lysine
+NH2  CT2  HB    38.000    109.50   50.00   2.14000
+                !from NH2  CT3  HA, neutral glycine, adm jr.
+NH2  CT2  CD    52.000   108.0000
+                !from CT2 CT2 CD, neutral glycine, adm jr.
+NH2  CT2  CT2    67.700   110.0000 ! ALLOW   ALI POL
+                !from NH3  CT2  CT2, neutral lysine
+NH2  CT3  HA    38.000    109.50   50.00   2.14000 ! ALLOW POL
+NH3  CT1  C      43.700   110.0000 ! ALLOW   PEP POL ARO ALI
+                ! new aliphatics, adm jr., 2/3/92
+NH3  CT1  CC     43.700   110.0000 ! ALLOW   PEP POL ARO ALI
+NH3  CT1  CT1    67.700   110.0000 ! ALLOW   ALI POL
+NH3  CT1  CT2    67.700   110.0000 ! ALLOW   ALI POL
+NH3  CT1  CT3    67.700   110.0000 ! ALLOW   ALI POL
+NH3  CT1  HB     51.500   107.5000 ! ALLOW   ALI POL PEP
+NH3  CT2  C      43.700   110.0000 ! ALLOW   PEP POL ARO ALI
+                ! alanine (JCS)
+NH3  CT2  CC     43.700   110.0000 ! ALLOW   PEP POL ARO ALI
+NH3  CT2  CD     43.700   110.0000 ! ALLOW   PEP POL ARO ALI
+NH3  CT2  CT2    67.700   110.0000 ! ALLOW   ALI POL
+                ! alanine (JCS)
+NH3  CT2  CT3    67.700   110.0000 ! ALLOW   ALI POL
+                ! alanine (JCS)
+NH3  CT2  HA    45.000    107.50   35.00   2.10100 ! ALLOW   ALI POL
+NH3  CT2  HB     51.500   107.5000 ! ALLOW   ALI POL PEP
+                ! for use on NTER -- from NH3 CT2HA (JCS) -- (LK)
+NH3  CT3  HA    45.000    107.50   35.00   2.10100 ! ALLOW   ALI POL
+NP   CP1  C      50.000   106.0000 ! ALLOW PRO
+NP   CP1  CC     50.000   106.0000 ! ALLOW PRO
+NP   CP1  CD     50.000   106.0000 ! ALLOW PRO PEP
+NP   CP1  CP2    70.000   108.5000 ! ALLOW PRO
+NP   CP1  HB     51.500   107.5000 ! ALLOW ALI POL PEP PRO
+NP   CP3  CP2    70.000   108.5000 ! ALLOW PRO
+NP   CP3  HA     51.500   109.1500 ! ALLOW PEP PRO
+NPH  CPA  CPB   122.000   111.5400 ! ALLOW HEM
+NPH  CPA  CPM    88.000   124.3900 ! ALLOW HEM
+NPH  FE   CM     50.000    90.0000 ! ALLOW HEM
+NPH  FE   CPM     0.000    45.0000 ! ALLOW HEM
+NPH  FE   NPH    14.390    90.0000 ! ALLOW HEM
+NR1  CPH1 CPH1  130.000   106.0000 ! ALLOW ARO
+NR1  CPH1 CT2    45.800   124.0000 ! ALLOW ARO
+                ! his, ADM JR., 7/22/89, FC FROM CA CT2CT
+NR1  CPH1 CT3    45.800   124.0000 ! ALLOW ARO
+NR1  CPH1 HR3   25.000    124.00   20.00   2.14000 ! ALLOW ARO
+NR1  CPH2 HR1   25.000    122.50   20.00   2.14000 ! ALLOW ARO
+NR2  CPH1 CPH1  130.000   110.0000 ! ALLOW ARO
+NR2  CPH1 CT2    45.800   120.0000 ! ALLOW ARO
+NR2  CPH1 HR3   25.000    120.00   20.00   2.14000 ! ALLOW ARO
+NR2  CPH2 HR1   25.000    125.00   20.00   2.12000 ! ALLOW ARO
+NR2  CPH2 NR1   130.000   112.5000 ! ALLOW ARO
+NR2  FE   CM     50.000   180.0000 ! ALLOW HEM
+NR2  FE   NPH    50.000    90.0000 ! ALLOW HEM
+NR3  CPH1 CPH1  145.000   108.0000 ! ALLOW ARO
+NR3  CPH1 CT2    45.800   122.0000 ! ALLOW ARO
+NR3  CPH1 HR1   22.000    122.00   15.00   2.18000 ! ALLOW ARO
+NR3  CPH2 HR2   32.000    126.00   25.00   2.14000 ! ALLOW ARO
+NR3  CPH2 NR3   145.000   108.0000 ! ALLOW ARO
+NY   CA   CY   120.000    110.00   25.00   2.24000 ! ALLOW   ARO
+NY   CA   HA    32.000    125.00   25.00   2.17700 ! ALLOW   ARO
+NY   CA   HP    32.000    125.00   25.00   2.17700 ! ALLOW   ARO
+NY   CPT  CA    160.000   130.6000 ! ALLOW   ARO
+NY   CPT  CPT   110.000   107.4000 ! ALLOW   ARO
+O    C    CP1    80.000   118.0000 ! ALLOW PEP PRO
+O    C    CT1    80.000   121.0000 ! ALLOW   ALI PEP POL ARO
+O    C    CT2    80.000   121.0000 ! ALLOW   ALI PEP POL ARO
+O    C    CT3    80.000   121.0000 ! ALLOW   ALI PEP POL ARO
+O    C    H      50.000   121.7000 ! ALLOW   PEP POL ARO
+                ! acetaldehyde (JCS)
+O    C    N      80.000   122.5000 ! ALLOW PRO PEP POL ARO
+O    C    NH1    80.000   122.5000 ! ALLOW   PEP POL ARO
+O    CC   CP1    80.000   118.0000 ! ALLOW ALI PEP POL ARO PRO
+O    CC   CT1   15.000    121.00   50.00   2.44000 ! ALLOW   ALI PEP POL ARO
+                ! adm jr. 4/10/91, acetamide update
+O    CC   CT2   15.000    121.00   50.00   2.44000 ! ALLOW   ALI PEP POL ARO
+O    CC   CT3   15.000    121.00   50.00   2.44000 ! ALLOW   ALI PEP POL ARO
+O    CC   HA     44.000   122.0000 ! ALLOW POL
+O    CC   NH2   75.000    122.50   50.00   2.37000 ! ALLOW   POL PEP ARO
+OB   CD   CP1   70.000    125.00   20.00   2.44200 ! ALLOW ALI PEP POL ARO PRO
+OB   CD   CT1   70.000    125.00   20.00   2.44200 ! ALLOW   ALI PEP POL ARO
+OB   CD   CT2   70.000    125.00   20.00   2.44200 ! ALLOW   ALI PEP POL ARO
+OB   CD   CT3   70.000    125.00   20.00   2.44200 ! ALLOW   ALI PEP POL ARO
+OC   CA   CA     40.000   120.0000 ! ALLOW  POL ARO
+OC   CC   CP1   40.000    118.00   50.00   2.38800 ! ALLOW ALI PEP POL ARO ION PRO
+OC   CC   CT1   40.000    118.00   50.00   2.38800 ! ALLOW   ALI PEP POL ARO ION
+                ! adm jr. 7/23/91, correction, ACETATE (KK)
+OC   CC   CT2   40.000    118.00   50.00   2.38800 ! ALLOW   ALI PEP POL ARO ION
+OC   CC   CT3   40.000    118.00   50.00   2.38800 ! ALLOW   ALI PEP POL ARO ION
+OC   CC   OC   100.000    124.00   70.00   2.22500 ! ALLOW   POL ION PEP ARO
+OC   CT2  CT3    65.000   122.0000 ! ALLOW  ALC
+OC   CT2  HA     65.000   118.3000 ! ALLOW  ALC
+OC   CT3  HA     65.000   118.3000 ! ALLOW  ALC
+OH1  CA   CA     45.200   120.0000 ! ALLOW   ARO ALC
+                ! PARALLH19 WITH [122.3] (JES)
+OH1  CD   CT2    55.000   110.5000 ! ALLOW   ALI PEP POL ARO ALC
+                ! adm jr, 10/17/90, acetic acid vibrations
+OH1  CD   CT3    55.000   110.5000 ! ALLOW   ALI PEP POL ARO ALC
+OH1  CD   OB    50.000    123.00  210.00   2.26200 ! ALLOW   PEP POL ARO ALC
+OH1  CT1  CT1    75.700   110.1000 ! ALLOW   ALI ALC ARO
+                ! MeOH, EMB, 10/10/89
+OH1  CT1  CT3    75.700   110.1000 ! ALLOW   ALI ALC ARO
+OH1  CT1  HA     45.900   108.8900 ! ALLOW   ALI ALC ARO
+OH1  CT2  CT1    75.700   110.1000 ! ALLOW   ALI ALC ARO
+OH1  CT2  CT2    75.700   110.1000 ! ALLOW   ALI ALC ARO
+OH1  CT2  CT3    75.700   110.1000 ! ALLOW   ALI ALC ARO
+OH1  CT2  HA     45.900   108.8900 ! ALLOW   ALI ALC ARO
+OH1  CT3  HA     45.900   108.8900 ! ALLOW   ALI ALC ARO
+OM   CM   FE     35.000   180.0000 ! ALLOW HEM
+OM   FE   NPH     5.000    90.0000 ! ALLOW HEM
+OM   OM   FE      0.000   180.0000 ! ALLOW HEM
+OS   CD   CP1   55.000    109.00   20.00   2.32600 ! ALLOW POL PEP PRO
+OS   CD   CT1   55.000    109.00   20.00   2.32600 ! ALLOW POL PEP
+OS   CD   CT2   55.000    109.00   20.00   2.32600 ! ALLOW POL PEP
+OS   CD   CT3   55.000    109.00   20.00   2.32600 ! ALLOW POL PEP
+OS   CD   OB    90.000    125.90  160.00   2.25760 ! ALLOW  PEP POL
+                ! adm jr. 3/19/92, from lipid methyl acetate
+OS   CT2  HA     60.000   109.5000 ! ALLOW PEP POL
+                ! adm jr. 4/05/91, for PRES CT1 from methyl acetate
+OS   CT3  HA     60.000   109.5000 ! ALLOW PEP POL
+S    CT2  CT1    58.000   112.5000 ! ALLOW   ALI SUL ION
+                ! as in expt.MeEtS & DALC crystal,  5/15/92
+S    CT2  CT2    58.000   114.5000 ! ALLOW   ALI SUL ION
+S    CT2  CT3    58.000   114.5000 ! ALLOW   ALI SUL ION
+S    CT2  HA     46.100   111.3000 ! ALLOW   ALI SUL ION
+                ! vib. freq. and HF/6-31G* geo. (DTN) 8/24/90
+S    CT3  HA     46.100   111.3000 ! ALLOW   ALI SUL ION
+SM   CT2  CT1    58.000   112.5000 ! ALLOW   ALI SUL ION
+SM   CT2  CT2    58.000   112.5000 ! ALLOW   ALI SUL ION
+SM   CT2  CT3    58.000   112.5000 ! ALLOW   ALI SUL ION
+SM   CT2  HA     38.000   111.0000 ! ALLOW   ALI SUL ION
+                ! new S-S atom type 8/24/90
+SM   CT3  HA     38.000   111.0000 ! ALLOW   ALI SUL ION
+SM   SM   CT2    72.500   103.3000 ! ALLOW   ALI SUL ION
+                ! expt. dimethyldisulfide,    3/26/92 (FL)
+SM   SM   CT3    72.500   103.3000 ! ALLOW   ALI SUL ION
+SS   CS   CT3    55.000   118.0000 ! ALLOW SUL
+SS   CS   HA     40.000   112.3000 ! ALLOW SUL
+DIHEDRALS
+!V(dihedral) = Kchi(1 + cos(n(chi) - delta))
+!Kchi: kcal/mole
+!n: multiplicity
+!delta: degrees
+!atom types             Kchi    n   delta
+!Neutral N terminus
+NH2  CT1  C    O        0.0000  1     0.00
+NH2  CT1  C    NH1      0.0000  1     0.00
+H    NH2  CT1  CT1      0.0000  1     0.00
+H    NH2  CT1  C        0.000   1     0.00
+H    NH2  CT1  HB       0.110   3     0.00   ! From LSN HC-NH2-CT2-HA
+H    NH2  CT1  CT2      0.110   3     0.00   ! From LSN HC-NH2-CT2-CT2
+H    NH2  CT1  CT3      0.110   3     0.00   ! From LSN HC-NH2-CT2-CT2
+X    FE   SS   X        0.0000  4     0.00 ! guess
+                !adm jr., 7/01
+X    CS   SS   X        0.0000  3     0.20 ! guess
+                !from methanethiol, HS S CT3 HA
+                !adm jr., 7/01
+C    CT1  NH1  C        0.2000  1   180.00 ! ALLOW PEP
+                ! ala dipeptide update for new C VDW Rmin, adm jr., 3/3/93c
+C    CT2  NH1  C        0.2000  1   180.00 ! ALLOW PEP
+C    N    CP1  C        0.8000  3     0.00 ! ALLOW PRO PEP
+CA   CA   CA   CA       3.1000  2   180.00 ! ALLOW   ARO
+                ! JES 8/25/89
+CA   CPT  CPT  CA       3.1000  2   180.00 ! ALLOW   ARO
+                ! JWK 05/14/91 fit to indole
+CA   CT2  CT1  C        0.0400  3     0.00 ! ALLOW   ARO
+                ! 2.7 kcal/mole CH3 rot in ethylbenzene, adm jr, 3/7/92
+CA   CY   CPT  CA       3.0000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+CA   NY   CPT  CA       3.0000  2   180.00 ! ALLOW   ARO
+CC   CP1  N    C        0.8000  3     0.00 ! ALLOW PRO PEP
+CC   CT1  CT2  CA       0.0400  3     0.00 ! ALLOW   ARO
+CC   CT1  NH1  C        0.2000  1   180.00 ! ALLOW PEP POL
+CC   CT2  NH1  C        0.2000  1   180.00 ! ALLOW PEP POL
+                ! Alanine dipeptide; NMA; acetate; etc. adm jr., 3/3/93c
+CD   CP1  N    C        0.0000  1   180.00 ! ALLOW PRO PEP
+CD   CT1  NH1  C        0.2000  1   180.00 ! ALLOW PEP POL
+CD   CT2  NH1  C        0.2000  1   180.00 ! ALLOW PEP POL
+                ! Alanine dipeptide; NMA; acetate; etc. backbon adm jr., 3/3/93c
+CE1  CE1  CT3  HA       0.0300  3     0.00 !
+CE2  CE1  CT2  CT3      0.5000  1   180.00 !
+                ! 1-butene, adm jr., 2/00 update
+CE2  CE1  CT2  CT3      1.3000  3   180.00 !
+CE2  CE1  CT2  HA       0.1200  3     0.00 !
+CE2  CE1  CT3  HA       0.0500  3   180.00 !
+CP1  C    N    CP1      2.7500  2   180.00 ! ALLOW PRO
+CP1  C    N    CP1      0.3000  4     0.00 ! ALLOW PRO
+CP2  CP1  N    C        0.8000  3     0.00 ! ALLOW PRO PEP
+CP2  CP3  N    C        0.0000  3   180.00 ! ALLOW PRO PEP
+CP2  CP3  N    CP1      0.1000  3     0.00 ! ALLOW PRO
+CP2  CP3  NP   CP1      0.0800  3     0.00 ! ALLOW PRO
+CP3  N    C    CP1      2.7500  2   180.00 ! ALLOW PRO
+CP3  N    C    CP1      0.3000  4     0.00 ! ALLOW PRO
+CP3  N    CP1  C        0.1000  3     0.00 ! ALLOW PRO
+CP3  N    CP1  CC       0.1000  3     0.00 ! ALLOW PRO
+CP3  N    CP1  CP2      0.1000  3     0.00 ! ALLOW PRO
+CP3  NP   CP1  C        0.0800  3     0.00 ! ALLOW PRO
+CP3  NP   CP1  CC       0.0800  3     0.00 ! ALLOW PRO
+CP3  NP   CP1  CD       0.0800  3     0.00 ! ALLOW PRO PEP
+CP3  NP   CP1  CP2      0.0800  3     0.00 ! ALLOW PRO
+CPH2 NR1  CPH1 CPH1    14.0000  2   180.00 ! ALLOW ARO
+CPH2 NR2  CPH1 CPH1    14.0000  2   180.00 ! ALLOW ARO
+CPH2 NR3  CPH1 CPH1    12.0000  2   180.00 ! ALLOW ARO
+CPT  CA   CA   CA       3.1000  2   180.00 ! ALLOW   ARO
+CPT  CPT  CA   CA       3.1000  2   180.00 ! ALLOW   ARO
+CPT  CPT  CY   CA       4.0000  2   180.00 ! ALLOW   ARO
+CPT  CPT  NY   CA       5.0000  2   180.00 ! ALLOW   ARO
+CT1  C    N    CP1      2.7500  2   180.00 ! ALLOW PRO
+CT1  C    N    CP1      0.3000  4     0.00 ! ALLOW PRO
+CT1  C    N    CP3      2.7500  2   180.00 ! ALLOW PRO
+CT1  C    N    CP3      0.3000  4     0.00 ! ALLOW PRO
+CT1  C    NH1  CT1      1.6000  1     0.00 !  ALLOW PEP
+                ! Revised to adjust NMA cis/trans energy difference. (LK)
+CT1  C    NH1  CT1      2.5000  2   180.00 !  ALLOW PEP
+                ! Gives appropriate NMA cis/trans barrier. (LK)
+CT1  CT1  NH1  C        1.8000  1     0.00 ! ALLOW PEP
+CT1  CT2  CA   CA       0.2300  2   180.00 ! ALLOW   ARO ALI
+                ! ethylbenzene ethyl rotation, adm jr. 3/7/92
+CT1  CT2  CPH1 CPH1     0.2000  1     0.00 ! ALLOW ARO
+                ! 4-ethylimidazole 4-21G rot bar, adm jr. 3/4/92
+CT1  CT2  CPH1 CPH1     0.2700  2     0.00 ! ALLOW ARO
+CT1  CT2  CPH1 CPH1     0.0000  3     0.00 ! ALLOW ARO
+CT1  CT2  CY   CA       0.2300  2   180.00 ! ALLOW ARO
+                ! from ethylbenzene, adm jr., 3/7/92
+CT1  CT2  CY   CPT      0.2300  2   180.00 ! ALLOW ARO
+CT1  NH1  C    CP1      1.6000  1     0.00 ! ALLOW PEP PRO
+CT1  NH1  C    CP1      2.5000  2   180.00 ! ALLOW PEP PRO
+CT2  C    N    CP1      2.7500  2   180.00 ! ALLOW PRO
+CT2  C    N    CP1      0.3000  4     0.00 ! ALLOW PRO
+CT2  C    N    CP3      2.7500  2   180.00 ! ALLOW PRO
+CT2  C    N    CP3      0.3000  4     0.00 ! ALLOW PRO
+CT2  C    NH1  CT1      1.6000  1     0.00 !  ALLOW PEP
+CT2  C    NH1  CT1      2.5000  2   180.00 !  ALLOW PEP
+CT2  C    NH1  CT2      1.6000  1     0.00 !  ALLOW PEP
+CT2  C    NH1  CT2      2.5000  2   180.00 !  ALLOW PEP
+CT2  C    NH1  CT3      1.6000  1     0.00 !  ALLOW PEP
+                ! from CT2  C    NH1  CT2, adm jr. 10/21/96
+CT2  C    NH1  CT3      2.5000  2   180.00 !  ALLOW PEP
+CT2  CA   CA   CA       3.1000  2   180.00 ! ALLOW   ARO
+                ! JES 8/25/89 toluene and ethylbenzene
+CT2  CPH1 NR1  CPH2     3.0000  2   180.00 ! ALLOW ARO
+                ! his, ADM JR., 7/22/89, FROM HA CPH1 NR1 CPH2
+CT2  CPH1 NR2  CPH2     3.0000  2   180.00 ! ALLOW ARO
+                ! his, ADM JR., 7/22/89, FROM HA CPH1 NR2 CPH2
+CT2  CPH1 NR3  CPH2     2.5000  2   180.00 ! ALLOW ARO
+CT2  CT1  NH1  C        1.8000  1     0.00 ! ALLOW PEP
+CT2  CT2  CPH1 CPH1     0.4000  1     0.00 ! ALLOW ARO
+                ! 4-methylimidazole 4-21G//6-31G* rot bar. ADM JR., 9/4/89
+CT2  CT2  CT2  CT2      0.1500  1     0.00 ! ALLOW ALI
+                ! alkane update, adm jr., 3/2/92, butane trans/gauche
+CT2  CT2  NH1  C        1.8000  1     0.00 ! ALLOW PEP
+                ! from CT2  CT1  NH1  C, for lactams, adm jr.
+CT2  CY   CPT  CA       3.0000  2   180.00 ! ALLOW ARO
+                ! JWK
+CT2  CY   CPT  CPT      3.0000  2   180.00 ! ALLOW ARO
+                !JWK
+CT2  NH1  C    CP1      1.6000  1     0.00 ! ALLOW PEP PRO
+CT2  NH1  C    CP1      2.5000  2   180.00 ! ALLOW PEP PRO
+CT2  NH1  C    CT1      1.6000  1     0.00 !  ALLOW PEP
+CT2  NH1  C    CT1      2.5000  2   180.00 !  ALLOW PEP
+CT2  SM   SM   CT2      1.0000  1     0.00 ! ALLOW   ALI SUL ION
+CT2  SM   SM   CT2      4.1000  2     0.00 ! ALLOW   ALI SUL ION
+                ! mp 6-311G** dimethyldisulfide,  3/26/92 (FL)
+CT2  SM   SM   CT2      0.9000  3     0.00 ! ALLOW   ALI SUL ION
+CT3  C    N    CP1      2.7500  2   180.00 ! ALLOW PRO
+CT3  C    N    CP1      0.3000  4     0.00 ! ALLOW PRO
+CT3  C    N    CP3      2.7500  2   180.00 ! ALLOW PRO
+CT3  C    N    CP3      0.3000  4     0.00 ! ALLOW PRO
+CT3  C    NH1  CT1      1.6000  1     0.00 !  ALLOW PEP
+CT3  C    NH1  CT1      2.5000  2   180.00 !  ALLOW PEP
+CT3  C    NH1  CT2      1.6000  1     0.00 !  ALLOW PEP
+                ! for acetylated GLY N-terminus, adm jr.
+CT3  C    NH1  CT2      2.5000  2   180.00 !  ALLOW PEP
+CT3  C    NH1  CT3      1.6000  1     0.00 !  ALLOW PEP
+CT3  C    NH1  CT3      2.5000  2   180.00 !  ALLOW PEP
+CT3  CA   CA   CA       3.1000  2   180.00 ! ALLOW   ARO
+CT3  CE1  CE2  HE2      5.2000  2   180.00 !
+CT3  CPH1 NR1  CPH2     3.0000  2   180.00 ! ALLOW ARO
+CT3  CT1  NH1  C        1.8000  1     0.00 ! ALLOW PEP
+CT3  CT2  CA   CA       0.2300  2   180.00 ! ALLOW   ARO ALI
+CT3  CT2  CPH1 CPH1     0.2000  1     0.00 ! ALLOW ARO
+CT3  CT2  CPH1 CPH1     0.2700  2     0.00 ! ALLOW ARO
+CT3  CT2  CPH1 CPH1     0.0000  3     0.00 ! ALLOW ARO
+CT3  CT2  CT2  CT2      0.1500  1     0.00 ! ALLOW ALI
+CT3  CT2  CT2  CT3      0.1500  1     0.00 ! ALLOW ALI
+CT3  CT2  CY   CA       0.2300  2   180.00 ! ALLOW ARO
+CT3  CT2  CY   CPT      0.2300  2   180.00 ! ALLOW ARO
+CT3  CT2  S    CT3      0.2400  1   180.00 ! ALOW    ALI SUL ION
+CT3  CT2  S    CT3      0.3700  3     0.00 ! ALOW    ALI SUL ION
+                ! DTN 8/24/90
+CT3  NH1  C    CP1      1.6000  1     0.00 ! ALLOW PEP PRO
+CT3  NH1  C    CP1      2.5000  2   180.00 ! ALLOW PEP PRO
+CT3  NH1  C    CT1      1.6000  1     0.00 !  ALLOW PEP
+CT3  NH1  C    CT1      2.5000  2   180.00 !  ALLOW PEP
+CT3  S    CT2  CT2      0.2400  1   180.00 ! ALOW    ALI SUL ION
+CT3  S    CT2  CT2      0.3700  3     0.00 ! ALOW    ALI SUL ION
+CT3  SM   SM   CT3      1.0000  1     0.00 ! ALLOW   ALI SUL ION
+CT3  SM   SM   CT3      4.1000  2     0.00 ! ALLOW   ALI SUL ION
+CT3  SM   SM   CT3      0.9000  3     0.00 ! ALLOW   ALI SUL ION
+CY   CA   NY   CPT      5.0000  2   180.00 ! ALLOW   ARO
+CY   CPT  CA   CA       3.0000  2   180.00 ! ALLOW   ARO
+CY   CPT  CPT  CA      10.0000  2   180.00 ! ALLOW   ARO
+H    NH1  C    CP1      2.5000  2   180.00 ! ALLOW PEP PRO
+H    NH1  C    CT1      2.5000  2   180.00 !  ALLOW PEP
+H    NH1  C    CT2      2.5000  2   180.00 !  ALLOW PEP
+H    NH1  C    CT3      2.5000  2   180.00 !  ALLOW PEP
+H    NH1  CT1  C        0.0000  1     0.00 ! ALLOW PEP
+H    NH1  CT1  CC       0.0000  1     0.00 ! ALLOW PEP POL
+H    NH1  CT1  CD       0.0000  1     0.00 ! ALLOW PEP POL
+H    NH1  CT1  CT1      0.0000  1     0.00 ! ALLOW PEP
+H    NH1  CT1  CT2      0.0000  1     0.00 ! ALLOW PEP
+H    NH1  CT1  CT3      0.0000  1     0.00 ! ALLOW PEP
+H    NH1  CT2  C        0.0000  1     0.00 ! ALLOW PEP
+H    NH1  CT2  CC       0.0000  1     0.00 ! ALLOW PEP POL
+                ! Alanine dipeptide; NMA; acetate; etc. backbone param. RLD 3/22/92
+H    NH1  CT2  CD       0.0000  1     0.00 ! ALLOW PEP POL
+H    NH1  CT2  CT2      0.0000  1     0.00 ! ALLOW PEP
+                ! from H    NH1  CT2  CT3, for lactams, adm jr.
+H    NH1  CT2  CT3      0.0000  1     0.00 ! ALLOW PEP
+H    NH2  CC   CT1      1.4000  2   180.00 !  ALLOW   PEP POL ARO PRO
+H    NH2  CC   CT2      1.4000  2   180.00 !  ALLOW   PEP POL ARO PRO
+H    NH2  CC   CT3      1.4000  2   180.00 !  ALLOW   PEP POL ARO PRO
+H    NH2  CC   CP1      2.5000  2   180.00 ! ALLOW PEP POL ARO PRO
+H    NR1  CPH1 CPH1     1.0000  2   180.00 ! ALLOW ARO
+                ! his, adm jr., 7/20/89
+H    NR1  CPH1 CT2      1.0000  2   180.00 ! ALLOW ARO
+                ! his, adm jr., 7/22/89, FROM HA CPH1 NR1 H
+H    NR1  CPH1 CT3      1.0000  2   180.00 ! ALLOW ARO
+H    NR3  CPH1 CPH1     1.4000  2   180.00 ! ALLOW ARO
+H    NR3  CPH1 CT2      3.0000  2   180.00 ! ALLOW ARO
+                ! his, adm jr., 7/22/89, FROM HC NR3 CPH1 HA
+H    NR3  CPH1 CT3      3.0000  2   180.00 ! ALLOW ARO
+H    NY   CA   CY       0.8000  2   180.00 ! ALLOW   ARO
+H    NY   CPT  CA       0.8000  2   180.00 ! ALLOW   ARO
+H    NY   CPT  CPT      0.8000  2   180.00 ! ALLOW   ARO
+H    OH1  CA   CA       0.9900  2   180.00 ! ALLOW   ARO ALC
+                ! phenol OH rot bar, 3.37 kcal/mole, adm jr. 3/7/92
+H    OH1  CT1  CT1      1.3300  1     0.00 ! ALLOW ALC
+                ! 2-propanol OH hf/6-31g* torsional surface, adm jr., 3/2/93
+H    OH1  CT1  CT1      0.1800  2     0.00 ! ALLOW ALC
+H    OH1  CT1  CT1      0.3200  3     0.00 ! ALLOW ALC
+H    OH1  CT1  CT3      1.3300  1     0.00 ! ALLOW ALC
+H    OH1  CT1  CT3      0.1800  2     0.00 ! ALLOW ALC
+H    OH1  CT1  CT3      0.3200  3     0.00 ! ALLOW ALC
+H    OH1  CT2  CT1      1.3000  1     0.00 ! ALLOW ALC
+                ! ethanol OH hf/6-31g* torsional surface, adm jr., 3/2/93
+H    OH1  CT2  CT1      0.3000  2     0.00 ! ALLOW ALC
+H    OH1  CT2  CT1      0.4200  3     0.00 ! ALLOW ALC
+H    OH1  CT2  CT2      1.3000  1     0.00 ! ALLOW ALC
+H    OH1  CT2  CT2      0.3000  2     0.00 ! ALLOW ALC
+H    OH1  CT2  CT2      0.4200  3     0.00 ! ALLOW ALC
+H    OH1  CT2  CT3      1.3000  1     0.00 ! ALLOW ALC
+H    OH1  CT2  CT3      0.3000  2     0.00 ! ALLOW ALC
+H    OH1  CT2  CT3      0.4200  3     0.00 ! ALLOW ALC
+HA   CA   CA   CA       3.5000  2   180.00 ! ALLOW ARO
+                ! adm jr., 10/02/89
+HA   CA   CA   CPT      3.5000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+HA   CA   CA   HA       2.5000  2   180.00 ! ALLOW ARO
+HA   CA   CPT  CPT      3.0000  2   180.00 ! ALLOW   ARO
+                ! TRP (JES)
+HA   CA   CPT  CY       4.0000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+HA   CA   CY   CPT      1.2000  2   180.00 ! ALLOW ARO
+                ! JWK
+HA   CA   CY   CT2      1.2000  2   180.00 ! ALLOW ARO
+                ! JWK
+HA   CA   NY   CPT      3.0000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+HA   CA   NY   H        1.0000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+HA   CC   NH2  H        1.4000  2   180.00 !  ALLOW PEP POL
+HA   CP3  N    C        0.0000  3   180.00 ! ALLOW PRO PEP
+HA   CP3  N    CP1      0.1000  3     0.00 ! ALLOW PRO
+HA   CP3  NP   CP1      0.0800  3     0.00 ! ALLOW PRO
+HA   CT1  CT2  CA       0.0400  3     0.00 ! ALLOW   ARO
+HA   CT2  CPH1 CPH1     0.0000  3     0.00 ! ALLOW ARO
+                ! 4-methylimidazole 4-21G//6-31G* rot bar. adm jr., 9/4/89
+HA   CT2  CY   CA       0.2500  2   180.00 ! ALLOW ARO
+                ! JWK
+HA   CT2  CY   CPT      0.2500  2   180.00 ! ALLOW ARO
+                ! JWK
+HA   CT2  NH1  C        0.0000  3     0.00 ! ALLOW PEP
+                ! LK for autogenerate dihe, sp2-methyl, no dihedral potential
+HA   CT2  NH1  H        0.0000  3     0.00 ! ALLOW PEP
+HA   CT2  S    CT3      0.2800  3     0.00 ! ALLOW   ALI SUL ION
+                ! DTN 8/24/90
+HA   CT3  CPH1 CPH1     0.0000  3     0.00 ! ALLOW ARO
+HA   CT3  CS   HA       0.1600  3     0.00 ! ALLOW SUL
+HA   CT3  CT2  CA       0.0400  3     0.00 ! ALLOW   ARO
+HA   CT3  NH1  C        0.0000  3     0.00 ! ALLOW PEP
+HA   CT3  NH1  H        0.0000  3     0.00 ! ALLOW PEP
+HA   CT3  S    CT2      0.2800  3     0.00 ! ALLOW   ALI SUL ION
+                ! DTN 8/24/90
+HA   CY   CA   CPT      1.2000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+HA   CY   CA   HA       1.2000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+HA   CY   CPT  CA       3.0000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+HA   CY   CPT  CPT      3.0000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+HE1  CE1  CE1  HE1      1.0000  2   180.00 !
+                ! 2-butene, adm jr., 8/98 update
+CT3  CE1  CE1  HE1      1.0000  2   180.00 !
+HE1  CE1  CE2  HE2      5.2000  2   180.00 !
+HE1  CE1  CT2  HA       0.0000  3     0.00
+		! butene, adm jr., 2/00 update
+HE1  CE1  CT2  CT3      0.1200  3     0.00 !
+HE1  CE1  CT3  HA       0.0000  3     0.00
+HE2  CE2  CE1  CT2      5.2000  2   180.00 !
+HE2  CE2  CE1  CPB      5.2000  2   180.00 !
+                ! for vinyl, from butene, yin/adm jr., 12/95
+HB   CP1  N    C        0.8000  3     0.00 ! ALLOW PRO PEP
+HB   CP1  N    CP3      0.1000  3     0.00 ! ALLOW PRO
+HB   CP1  NP   CP3      0.0800  3     0.00 ! ALLOW PRO
+HB   CT1  NH1  C        0.0000  1     0.00 ! ALLOW PEP
+HB   CT1  NH1  H        0.0000  1     0.00 ! ALLOW PEP
+HB   CT2  NH1  C        0.0000  1     0.00 ! ALLOW PEP
+HB   CT2  NH1  H        0.0000  1     0.00 ! ALLOW PEP
+HB   CT3  NH1  C        0.0000  1     0.00 ! ALLOW PEP
+HB   CT3  NH1  H        0.0000  1     0.00 ! ALLOW PEP
+HC   NH2  CT2  CT2       0.1100  3     0.00
+                !from X CT3 NH2 X, neutral lysine
+HC   NH2  CT2  HA       0.1100  3     0.00
+HC   NH2  CT2  HB       0.1100  3     0.00
+                !from X CT3 NH2 X, neutral glycine, adm jr.
+HC   NH2  CT2  CD       0.1100  3     0.00
+HC   NP   CP1  C        0.0800  3     0.00 ! ALLOW PRO
+HC   NP   CP1  CC       0.0800  3     0.00 ! ALLOW PRO
+HC   NP   CP1  CD       0.0800  3     0.00 ! ALLOW PRO PEP
+HC   NP   CP1  CP2      0.0800  3     0.00 ! ALLOW PRO
+HC   NP   CP1  HB       0.0800  3     0.00 ! ALLOW PRO
+HC   NP   CP3  CP2      0.0800  3     0.00 ! ALLOW PRO
+HC   NP   CP3  HA       0.0800  3     0.00 ! ALLOW PRO
+HP   CA   CA   CA       4.2000  2   180.00 ! ALLOW   ARO
+HP   CA   CA   CPT      3.0000  2   180.00 ! ALLOW   ARO
+HP   CA   CA   CT2      4.2000  2   180.00 ! ALLOW   ARO
+HP   CA   CA   CT3      4.2000  2   180.00 ! ALLOW   ARO
+HP   CA   CA   HP       2.4000  2   180.00 ! ALLOW   ARO
+HP   CA   CPT  CPT      3.0000  2   180.00 ! ALLOW   ARO
+                ! JWK indole 05/14/91
+HP   CA   CPT  CY       3.0000  2   180.00 ! ALLOW   ARO
+HP   CA   CY   CPT      2.0000  2   180.00 ! ALLOW ARO
+HP   CA   CY   CT2      1.2000  2   180.00 ! ALLOW ARO
+HP   CA   NY   CPT      2.0000  2   180.00 ! ALLOW   ARO
+HP   CA   NY   H        0.4000  2   180.00 ! ALLOW   ARO
+HP   CY   CA   HP       1.0000  2   180.00 ! ALLOW   ARO
+HP   CY   CPT  CA       2.8000  2   180.00 ! ALLOW   ARO
+HP   CY   CPT  CPT      2.8000  2   180.00 ! ALLOW   ARO
+HR1  CPH1 CPH1 CT2      1.0000  2   180.00 ! ALLOW ARO
+HR1  CPH1 CPH1 CT3      1.0000  2   180.00 ! ALLOW ARO
+HR1  CPH1 CPH1 HR1      1.0000  2   180.00 ! ALLOW ARO
+                ! his, adm jr., 6/27/90, his
+HR1  CPH1 NR3  CPH2     2.5000  2   180.00 ! ALLOW ARO
+HR1  CPH1 NR3  H        3.0000  2   180.00 ! ALLOW ARO
+HR1  CPH2 NR1  CPH1     3.0000  2   180.00 ! ALLOW ARO
+HR1  CPH2 NR1  H        1.0000  2   180.00 ! ALLOW ARO
+HR1  CPH2 NR2  CPH1     3.0000  2   180.00 ! ALLOW ARO
+HR2  CPH2 NR3  CPH1     3.0000  2   180.00 ! ALLOW ARO
+HR2  CPH2 NR3  H        0.0000  2   180.00 ! ALLOW ARO
+                ! his, adm jr., 6/27/90, YES, 0.0
+HR3  CPH1 CPH1 CT2      2.0000  2   180.00 ! ALLOW ARO
+HR3  CPH1 CPH1 CT3      2.0000  2   180.00 ! ALLOW ARO
+HR3  CPH1 CPH1 HR3      2.0000  2   180.00 ! ALLOW ARO
+HR3  CPH1 NR1  CPH2     3.0000  2   180.00 ! ALLOW ARO
+HR3  CPH1 NR1  H        1.0000  2   180.00 ! ALLOW ARO
+HR3  CPH1 NR2  CPH2     3.0000  2   180.00 ! ALLOW ARO
+HS   S    CT2  CT1      0.2400  1     0.00 ! ALLOW   ALI SUL ION
+HS   S    CT2  CT1      0.1500  2     0.00 ! ALLOW   ALI SUL ION
+HS   S    CT2  CT1      0.2700  3     0.00 ! ALLOW   ALI SUL ION
+HS   S    CT2  CT3      0.2400  1     0.00 ! ALLOW   ALI SUL ION
+                ! ethanethiol C-C-S-H surface, adm jr., 4/18/93
+HS   S    CT2  CT3      0.1500  2     0.00 ! ALLOW   ALI SUL ION
+HS   S    CT2  CT3      0.2700  3     0.00 ! ALLOW   ALI SUL ION
+HS   S    CT2  HA       0.2000  3     0.00 ! ALLOW   ALI SUL ION
+HS   S    CT3  HA       0.2000  3     0.00 ! ALLOW   ALI SUL ION
+N    C    CP1  CP2      0.4000  1     0.00 ! ALLOW PEP PRO
+N    C    CP1  CP2      0.6000  2     0.00 ! ALLOW PEP PRO
+N    C    CP1  HB       0.4000  1   180.00 ! ALLOW PEP PRO
+N    C    CP1  HB       0.6000  2     0.00 ! ALLOW PEP PRO
+N    C    CP1  N        0.3000  1     0.00 ! ALLOW PEP PRO
+N    C    CP1  N       -0.3000  4     0.00 ! ALLOW PEP PRO
+N    C    CT1  CT1      0.0000  1     0.00 ! ALLOW PEP PRO
+N    C    CT1  CT2      0.0000  1     0.00 ! ALLOW PEP PRO
+N    C    CT1  CT3      0.0000  1     0.00 ! ALLOW PEP PRO
+N    C    CT1  HB       0.0000  1     0.00 ! ALLOW PEP PRO
+N    C    CT2  HB       0.0000  1     0.00 ! ALLOW PEP PRO
+N    C    CT3  HA       0.0000  1     0.00 ! ALLOW PEP PRO
+N    CT1  CT2  CA       0.0400  3     0.00 ! ALLOW   ARO
+NH1  C    CP1  CP2      0.4000  1     0.00 ! ALLOW PEP PRO
+NH1  C    CP1  CP2      0.6000  2     0.00 ! ALLOW PEP PRO
+NH1  C    CP1  HB       0.4000  1   180.00 ! ALLOW PEP PRO
+NH1  C    CP1  HB       0.6000  2     0.00 ! ALLOW PEP PRO
+NH1  C    CP1  N        0.3000  1     0.00 ! ALLOW PEP PRO
+NH1  C    CP1  N       -0.3000  4     0.00 ! ALLOW PEP PRO
+NH1  C    CT1  CT1      0.0000  1     0.00 !   ALLOW PEP
+                ! ala dipeptide corrxn for new C VDW Rmin, 4/10/93 (LK)
+NH1  C    CT1  CT2      0.0000  1     0.00 !   ALLOW PEP
+NH1  C    CT1  CT3      0.0000  1     0.00 !   ALLOW PEP
+NH1  C    CT1  HB       0.0000  1     0.00 !   ALLOW PEP
+NH1  C    CT1  NH1      0.6000  1     0.00 !   ALLOW PEP
+NH1  C    CT2  CT2      0.0000  1     0.00 !   ALLOW PEP
+                ! from NH1  C    CT1  CT2, for lactams, adm jr.
+NH1  C    CT2  HA       0.0000  3     0.00 ! ALLOW PEP
+NH1  C    CT2  HB       0.0000  1     0.00 !   ALLOW PEP
+NH1  C    CT2  NH1      0.6000  1     0.00 !   ALLOW PEP
+NH1  C    CT3  HA       0.0000  3     0.00 ! ALLOW PEP
+NH1  CT1  C    N        0.4000  1     0.00 ! ALLOW PEP PRO
+NH1  CT2  C    N        0.4000  1     0.00 ! ALLOW PEP PRO
+NH2  CC   CP1  CP2      0.4000  1     0.00 ! ALLOW PEP PRO
+NH2  CC   CP1  CP2      0.6000  2     0.00 ! ALLOW PEP PRO
+NH2  CC   CP1  HB       0.4000  1   180.00 ! ALLOW PEP PRO
+NH2  CC   CP1  HB       0.6000  2     0.00 ! ALLOW PEP PRO
+NH2  CC   CP1  N        0.3000  1     0.00 ! ALLOW PEP PRO
+NH2  CC   CP1  N       -0.3000  4     0.00 ! ALLOW PEP PRO
+NH2  CC   CT2  HA       0.0000  3   180.00 ! ALLOW POL
+                ! adm jr., 8/13/90 acetamide geometry and vibrations
+NH3  CT1  C    N        0.4000  1     0.00 ! ALLOW PEP PRO
+NH3  CT1  C    NH1      0.6000  1     0.00 ! ALLOW PEP PRO
+NH3  CT1  CC   NH2      0.4000  1     0.00 ! ALLOW PEP PRO
+NH3  CT2  C    N        0.4000  1     0.00 ! ALLOW PEP PRO
+NH3  CT2  C    NH1      0.4000  1     0.00 ! ALLOW PEP PRO
+                ! adm jr. 3/24/92, for PRES GLYP
+NH3  CT2  CC   NH2      0.4000  1     0.00 ! ALLOW PEP PRO
+NP   CP1  C    N        0.3000  1     0.00 ! ALLOW PEP PRO
+NP   CP1  C    NH1      0.3000  1     0.00 ! ALLOW PEP PRO
+NP   CP1  CC   NH2      0.3000  1     0.00 ! ALLOW PEP PRO
+NR1  CPH1 CPH1 CT2      3.0000  2   180.00 ! ALLOW ARO
+                ! his, ADM JR., 7/22/89, FROM NR1 CPH1 CPH1 HA
+NR1  CPH1 CPH1 CT3      3.0000  2   180.00 ! ALLOW ARO
+NR1  CPH1 CPH1 HR3      3.0000  2   180.00 ! ALLOW ARO
+NR1  CPH1 CT2  CT1      0.1900  3     0.00 ! ALLOW ARO
+                ! 4-METHYLIMIDAZOLE 4-21G//6-31G* ROT BAR. ADM JR., 9/4/89
+NR1  CPH1 CT2  CT2      0.1900  3     0.00 ! ALLOW ARO
+NR1  CPH1 CT2  CT3      0.1900  3     0.00 ! ALLOW ARO
+NR1  CPH1 CT2  HA       0.1900  3     0.00 ! ALLOW ARO
+NR1  CPH1 CT3  HA       0.1900  3     0.00 ! ALLOW ARO
+NR1  CPH2 NR2  CPH1    14.0000  2   180.00 ! ALLOW ARO
+NR2  CPH1 CPH1 CT2      3.0000  2   180.00 ! ALLOW ARO
+                ! his, ADM JR., 7/22/89, FROM NR2 CPH1 CPH1 HA
+NR2  CPH1 CPH1 CT3      3.0000  2   180.00 ! ALLOW ARO
+NR2  CPH1 CPH1 HR3      3.0000  2   180.00 ! ALLOW ARO
+NR2  CPH1 CPH1 NR1     14.0000  2   180.00 ! ALLOW ARO
+NR2  CPH1 CT2  CT1      0.1900  3     0.00 ! ALLOW ARO
+                ! HIS CB-CG TORSION,
+NR2  CPH1 CT2  CT2      0.1900  3     0.00 ! ALLOW ARO
+NR2  CPH1 CT2  CT3      0.1900  3     0.00 ! ALLOW ARO
+NR2  CPH1 CT2  HA       0.1900  3     0.00 ! ALLOW ARO
+NR2  CPH1 CT3  HA       0.1900  3     0.00 ! ALLOW ARO
+NR2  CPH2 NR1  CPH1    14.0000  2   180.00 ! ALLOW ARO
+NR2  CPH2 NR1  H        1.0000  2   180.00 ! ALLOW ARO
+NR3  CPH1 CPH1 CT2      2.5000  2   180.00 ! ALLOW ARO
+NR3  CPH1 CPH1 CT3      2.5000  2   180.00 ! ALLOW ARO
+NR3  CPH1 CPH1 HR1      2.5000  2   180.00 ! ALLOW ARO
+NR3  CPH1 CPH1 NR3     12.0000  2   180.00 ! ALLOW ARO
+NR3  CPH1 CT2  CT1      0.1900  3     0.00 ! ALLOW ARO
+NR3  CPH1 CT2  CT2      0.1900  3     0.00 ! ALLOW ARO
+NR3  CPH1 CT2  CT3      0.1900  3     0.00 ! ALLOW ARO
+NR3  CPH1 CT2  HA       0.1900  3     0.00 ! ALLOW ARO
+NR3  CPH1 CT3  HA       0.1900  3     0.00 ! ALLOW ARO
+NR3  CPH2 NR3  CPH1    12.0000  2   180.00 ! ALLOW ARO
+NR3  CPH2 NR3  H        1.4000  2   180.00 ! ALLOW ARO
+NY   CA   CY   CPT      4.0000  2   180.00 ! ALLOW   ARO
+NY   CA   CY   CT2      3.5000  2   180.00 ! ALLOW ARO
+                ! JWK
+NY   CA   CY   HA       3.5000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+NY   CA   CY   HP       3.5000  2   180.00 ! ALLOW   ARO
+NY   CPT  CA   CA       2.8000  2   180.00 ! ALLOW   ARO
+NY   CPT  CA   HA       4.0000  2   180.00 ! ALLOW   ARO
+                ! JWK 09/05/89
+NY   CPT  CA   HP       3.0000  2   180.00 ! ALLOW   ARO
+NY   CPT  CPT  CA      10.0000  2   180.00 ! ALLOW   ARO
+NY   CPT  CPT  CY       5.0000  2   180.00 ! ALLOW   ARO
+O    C    CP1  CP2      0.4000  1   180.00 ! ALLOW PEP PRO
+O    C    CP1  CP2      0.6000  2     0.00 ! ALLOW PEP PRO
+O    C    CP1  HB       0.4000  1     0.00 ! ALLOW PEP PRO
+O    C    CP1  HB       0.6000  2     0.00 ! ALLOW PEP PRO
+O    C    CP1  N       -0.3000  4     0.00 ! ALLOW PEP PRO
+O    C    CT1  CT1      1.4000  1     0.00 !   ALLOW PEP
+O    C    CT1  CT2      1.4000  1     0.00 !   ALLOW PEP
+O    C    CT1  CT3      1.4000  1     0.00 !   ALLOW PEP
+O    C    CT1  HB       0.0000  1     0.00 !   ALLOW PEP
+O    C    CT1  NH1      0.0000  1     0.00 !   ALLOW PEP
+O    C    CT1  NH3      0.0000  1     0.00 ! ALLOW PEP PRO
+                ! Backbone parameter set made complete RLD 8/8/90
+O    C    CT2  CT2      1.4000  1     0.00 !   ALLOW PEP
+                ! from O    C    CT1  CT2, for lactams, adm jr.
+O    C    CT2  HA       0.0000  3   180.00 ! ALLOW POL
+O    C    CT2  HB       0.0000  1     0.00 !   ALLOW PEP
+O    C    CT2  NH1      0.0000  1     0.00 !   ALLOW PEP
+O    C    CT2  NH3      0.0000  1     0.00 ! ALLOW PEP PRO
+O    C    CT3  HA       0.0000  3   180.00 ! ALLOW POL
+O    C    N    CP1      2.7500  2   180.00 ! ALLOW PRO
+O    C    N    CP1      0.3000  4     0.00 ! ALLOW PRO
+O    C    N    CP3      2.7500  2   180.00 ! ALLOW PRO
+O    C    N    CP3      0.3000  4     0.00 ! ALLOW PRO
+O    C    NH1  CT1      2.5000  2   180.00 !  ALLOW PEP
+O    C    NH1  CT2      2.5000  2   180.00 !  ALLOW PEP
+O    C    NH1  CT3      2.5000  2   180.00 !  ALLOW PEP
+O    C    NH1  H        2.5000  2   180.00 !  ALLOW PEP
+O    CC   CP1  CP2      0.4000  1   180.00 ! ALLOW PEP PRO
+O    CC   CP1  CP2      0.6000  2     0.00 ! ALLOW PEP PRO
+O    CC   CP1  HB       0.4000  1     0.00 ! ALLOW PEP PRO
+O    CC   CP1  HB       0.6000  2     0.00 ! ALLOW PEP PRO
+O    CC   CP1  N       -0.3000  4     0.00 ! ALLOW PEP PRO
+O    CC   CT2  HA       0.0000  3   180.00 ! ALLOW POL
+O    CC   NH2  H        1.4000  2   180.00 !  ALLOW PEP POL ARO PRO
+OB   CD   OS   CT2      0.9650  1   180.00 ! ALLOW   PEP POL
+OB   CD   OS   CT2      3.8500  2   180.00 ! ALLOW   PEP POL
+OB   CD   OS   CT3      0.9650  1   180.00 ! ALLOW   PEP POL
+OB   CD   OS   CT3      3.8500  2   180.00 ! ALLOW   PEP POL
+OC   CA   CA   CA       3.1000  2   180.00 ! ALLOW   ARO
+OC   CA   CA   HP       4.2000  2   180.00 ! ALLOW   ARO
+OC   CC   CP1  CP2      0.1600  3     0.00 ! ALLOW PEP PRO POL
+OC   CC   CP1  HB       0.1600  3     0.00 ! ALLOW PEP PRO POL
+OC   CC   CP1  N        0.1600  3     0.00 ! ALLOW PEP PRO POL
+OC   CC   CP1  NP       0.1600  3     0.00 ! ALLOW PEP PRO POL
+OC   CC   CT1  NH3      3.2000  2   180.00 ! ALLOW PEP PRO
+                ! adm jr. 4/17/94, zwitterionic glycine
+OC   CC   CT2  NH3      3.2000  2   180.00 ! ALLOW PEP PRO
+OH1  CA   CA   CA       3.1000  2   180.00 ! ALLOW   ARO
+OH1  CA   CA   HP       4.2000  2   180.00 ! ALLOW   ARO
+S    CT2  CT2  HA       0.0100  3     0.00 ! ALLOW   ALI SUL ION
+                ! DTN 8/24/90
+SM   CT2  CT2  HA       0.0100  3     0.00 ! ALLOW   ALI SUL ION
+                ! DTN 8/24/90
+SM   SM   CT2  CT1      0.3100  3     0.00 ! ALLOW  SUL ALI
+                ! S-S for cys-cys, dummy parameter for now ... DTN  9/04/90
+SM   SM   CT2  CT2      0.3100  3     0.00 ! ALLOW  SUL ALI
+SM   SM   CT2  HA       0.1580  3     0.00 ! ALLOW   ALI SUL ION
+SM   SM   CT3  HA       0.1580  3     0.00 ! ALLOW   ALI SUL ION
+SS   CS   CT3  HA       0.1500  3     0.00 ! ALLOW SUL
+!X    C    C    X        4.0000  2   180.00 ! ALLOW HEM
+X    C    NC2  X        2.2500  2   180.00 ! ALLOW   PEP POL ARO
+                ! 9.0->2.25 GUANIDINIUM (KK)
+X    CD   OH1  X        2.0500  2   180.00 ! ALLOW   PEP POL ARO ALC
+                ! adm jr, 10/17/90, acetic acid C-Oh rotation barrier
+X    CD   OS   X        2.0500  2   180.00 ! ALLOW   PEP POL
+X    CE1  CE1  X        0.1500  1     0.00
+                ! 2-butene, adm jr., 2/00 update
+X    CE1  CE1  X        8.5000  2   180.00
+X    CE2  CE2  X        4.9000  2   180.00 !
+X    CP1  C    X        0.0000  6   180.00 ! ALLOW   POL PEP PRO
+X    CP1  CC   X        0.0000  6   180.00 ! ALLOW   POL PEP
+                ! changed to 0.0 RLD 5/19/92
+X    CP1  CD   X        0.0000  6   180.00 ! ALLOW   POL PEP
+X    CP1  CP2  X        0.1400  3     0.00 ! ALLOW PRO
+X    CP2  CP2  X        0.1600  3     0.00 ! ALLOW PRO
+X    CP3  CP2  X        0.1400  3     0.00 ! ALLOW PRO
+X    CPA  CPB  X        0.0000  2     0.00 ! ALLOW HEM
+                ! Heme (6-liganded): dummy for "auto dihe" (KK 05/13/91)
+X    CPA  CPM  X        0.0000  2     0.00 ! ALLOW HEM
+X    CPB  CE1  X        3.0000  2   180.00 ! ALLOW HEM
+X    CPB  CPB  X        0.0000  2     0.00 ! ALLOW HEM
+X    CPB  CT2  X        0.0000  6     0.00 ! ALLOW HEM
+X    CPB  CT3  X        0.0000  6     0.00 ! ALLOW HEM
+X    CPT  CPT  X        0.0000  2   180.00 ! ALLOW   ARO
+X    CT1  CC   X        0.0500  6   180.00 ! ALLOW   POL PEP
+                ! For side chains of asp,asn,glu,gln, (n=6) from KK(LK)
+X    CT1  CD   X        0.0000  6   180.00 ! ALLOW   POL PEP
+X    CT1  CT1  X        0.2000  3     0.00 ! ALLOW   ALI
+X    CT1  CT2  X        0.2000  3     0.00 ! ALLOW   ALI
+X    CT1  CT3  X        0.2000  3     0.00 ! ALLOW   ALI
+X    CT1  NH3  X        0.1000  3     0.00 ! ALLOW   ALI POL
+                ! 0.715->0.10 METHYLAMMONIUM (KK)
+X    CT1  OH1  X        0.1400  3     0.00 ! ALLOW   ALI ALC ARO
+X    CT1  OS   X       -0.1000  3     0.00 ! ALLOW   PEP POL
+X    CT2  CA   X        0.0000  6     0.00 ! ALLOW   ALI ARO
+X    CT2  CC   X        0.0500  6   180.00 ! ALLOW   POL PEP
+X    CT2  CD   X        0.0000  6   180.00 ! ALLOW   POL PEP
+X    CT2  CT2  X        0.1950  3     0.00 ! ALLOW   ALI
+X    CT2  CT3  X        0.1600  3     0.00 ! ALLOW   ALI
+                ! rotation barrier in Ethane (SF)
+X    CT2  NC2  X        0.0000  6   180.00 ! ALLOW   ALI POL
+X    CT2  NH3  X        0.1000  3     0.00 ! ALLOW   ALI POL
+X    CT2  OH1  X        0.1400  3     0.00 ! ALLOW   ALI ALC ARO
+X    CT2  OS   X       -0.1000  3     0.00 ! ALLOW   PEP POL
+X    CT3  CA   X        0.0000  6     0.00 ! ALLOW   ALI ARO
+X    CT3  CC   X        0.0500  6   180.00 ! ALLOW   POL PEP
+X    CT3  CD   X        0.0000  6   180.00 ! ALLOW   POL PEP
+X    CT3  CT3  X        0.1550  3     0.00 ! ALLOW   ALI
+X    CT3  NC2  X        0.0000  6   180.00 ! ALLOW   ALI POL
+X    CT3  NH2  X        0.1100  3     0.00 ! ALLOW   POL
+X    CT3  NH3  X        0.0900  3     0.00 ! ALLOW   ALI POL
+                ! fine-tuned to ab initio; METHYLAMMONIUM, KK 03/10/92
+X    CT3  OH1  X        0.1400  3     0.00 ! ALLOW   ALI ALC ARO
+X    CT3  OS   X       -0.1000  3     0.00 ! ALLOW   PEP POL
+X    FE   CM   X        0.0500  4     0.00 ! ALLOW HEM
+                ! Heme (6-liganded): ligands (KK 05/13/91)
+X    FE   NPH  X        0.0000  2     0.00 ! ALLOW HEM
+X    FE   NR2  X        0.0500  4     0.00 ! ALLOW HEM
+                ! Heme (6-liganded): from param19.inp
+X    FE   OM   X        0.0000  4     0.00 ! ALLOW HEM
+X    NPH  CPA  X        0.0000  2     0.00 ! ALLOW HEM
+IMPROPER
+!V(improper) = Kpsi(psi - psi0)**2
+!Kpsi: kcal/mole/rad**2
+!psi0: degrees
+!note that the second column of numbers (0) is ignored
+!atom types           Kpsi                   psi0
+CPB  CPA  NPH  CPA    20.8000         0      0.0000 ! ALLOW HEM
+CPB  X    X    CE1    90.0000         0      0.0000 ! ALLOW HEM
+CT2  X    X    CPB    90.0000         0      0.0000 ! ALLOW HEM
+CT3  X    X    CPB    90.0000         0      0.0000 ! ALLOW HEM
+!HA   C    C    HA     20.0000         0      0.0000 ! ALLOW   PEP POL ARO
+HA   CPA  CPA  CPM    29.4000         0      0.0000 ! ALLOW HEM
+!HA   CPB  C    C      20.0000         0      0.0000 ! ALLOW HEM ARO
+!HA   HA   C    C      20.0000         0    180.0000 ! ALLOW   PEP POL ARO
+HE2  HE2  CE2  CE2     3.0            0      0.00   !
+HR1  NR1  NR2  CPH2    0.5000         0      0.0000 ! ALLOW ARO
+                ! his, adm jr., 7/05/90
+HR1  NR2  NR1  CPH2    0.5000         0      0.0000 ! ALLOW ARO
+HR3  CPH1 NR1  CPH1    0.5000         0      0.0000 ! ALLOW ARO
+HR3  CPH1 NR2  CPH1    0.5000         0      0.0000 ! ALLOW ARO
+HR3  CPH1 NR3  CPH1    1.0000         0      0.0000 ! ALLOW ARO
+HR3  NR1  CPH1 CPH1    0.5000         0      0.0000 ! ALLOW ARO
+HR3  NR2  CPH1 CPH1    0.5000         0      0.0000 ! ALLOW ARO
+N    C    CP1  CP3     0.0000         0      0.0000 ! ALLOW PRO
+                ! 6-31g* AcProNH2 and ProNH2  RLD 5/19/92
+NC2  X    X    C      40.0000         0      0.0000 ! ALLOW   PEP POL ARO
+                ! 5.75->40.0 GUANIDINIUM (KK)
+NH1  X    X    H      20.0000         0      0.0000 ! ALLOW   PEP POL ARO
+NH2  X    X    H       4.0000         0      0.0000 ! ALLOW   POL
+NPH  CPA  CPA  FE    137.4000         0      0.0000 ! ALLOW HEM
+NPH  CPA  CPB  CPB    40.6000         0      0.0000 ! ALLOW HEM
+NPH  CPA  CPM  CPA    18.3000         0      0.0000 ! ALLOW HEM
+NPH  CPM  CPB  CPA    32.7000         0      0.0000 ! ALLOW HEM
+NR1  CPH1 CPH2 H       0.4500         0      0.0000 ! ALLOW ARO
+NR1  CPH2 CPH1 H       0.4500         0      0.0000 ! ALLOW ARO
+NR3  CPH1 CPH2 H       1.2000         0      0.0000 ! ALLOW ARO
+NR3  CPH2 CPH1 H       1.2000         0      0.0000 ! ALLOW ARO
+NY   CA   CY   CPT   100.0000         0      0.0000 ! ALLOW ARO
+                !adm jr., 5/15/91,  indole 3-21G HE1 out-of-plane surf.
+O    CP1  NH2  CC     45.0000         0      0.0000 ! ALLOW PEP POL PRO
+O    CT1  NH2  CC     45.0000         0      0.0000 ! ALLOW PEP POL
+O    CT2  NH2  CC     45.0000         0      0.0000 ! ALLOW PEP POL
+O    CT3  NH2  CC     45.0000         0      0.0000 ! ALLOW PEP POL
+O    HA   NH2  CC     45.0000         0      0.0000 ! ALLOW PEP POL PRO
+O    N    CT2  CC    120.0000         0      0.0000 ! ALLOW PEP POL PRO
+O    NH2  CP1  CC     45.0000         0      0.0000 ! ALLOW PEP POL PRO
+O    NH2  CT1  CC     45.0000         0      0.0000 ! ALLOW PEP POL
+O    NH2  CT2  CC     45.0000         0      0.0000 ! ALLOW PEP POL
+O    NH2  CT3  CC     45.0000         0      0.0000 ! ALLOW PEP POL
+O    NH2  HA   CC     45.0000         0      0.0000 ! ALLOW PEP POL
+O    X    X    C     120.0000         0      0.0000 ! ALLOW   PEP POL ARO
+OB   X    X    CD    100.0000         0      0.0000 ! ALLOW   ALC ARO POL
+OC   X    X    CC     96.0000         0      0.0000 ! ALLOW   PEP POL ARO ION
+                ! 90.0->96.0 acetate, single impr (KK)
+CC   X    X    CT1    96.0000         0      0.0000 ! ALLOW   PEP POL ARO ION
+CC   X    X    CT2    96.0000         0      0.0000 ! ALLOW   PEP POL ARO ION
+CC   X    X    CT3    96.0000         0      0.0000 ! ALLOW   PEP POL ARO ION
+CMAP
+! 2D grid correction data.  The following surfaces are the correction
+! to the CHARMM22 phi, psi alanine, proline and glycine dipeptide surfaces.
+! Use of CMAP requires generation with the topology file containing the
+! CMAP specifications along with version 31 or later of CHARMM.  Note that
+! use of "skip CMAP" yields the charmm22 energy surfaces.
+! references
+!MacKerell, A.D., Jr., Feig, M., Brooks, C.L., III, Accurate Treatment of
+!Protein Backbone Conformational Energetics in Empirical Force Fields, Submitted
+!for publication.
+!MacKerell, A.D., Jr., Feig, M., Brooks, C.L., III, Improved Treatment of the
+!Protein Backbone in Empirical Force Fields, Journal of the American Chemical
+!Society, In Press.
+! alanine map
+C    NH1  CT1  C    NH1  CT1  C    NH1   24
+!-180
+0.126790 0.768700 0.971260 1.250970 2.121010
+2.695430 2.064440 1.764790 0.755870 -0.713470
+0.976130 -2.475520 -5.455650 -5.096450 -5.305850
+-3.975630 -3.088580 -2.784200 -2.677120 -2.646060
+-2.335350 -2.010440 -1.608040 -0.482250
+!-165
+-0.802290 1.377090 1.577020 1.872290 2.398990
+2.461630 2.333840 1.904070 1.061460 0.518400
+-0.116320 -3.575440 -5.284480 -5.160310 -4.196010
+-3.276210 -2.715340 -1.806200 -1.101780 -1.210320
+-1.008810 -0.637100 -1.603360 -1.776870
+!-150
+-0.634810 1.156210 1.624350 2.047200 2.653910
+2.691410 2.296420 1.960450 1.324930 2.038290
+-1.151510 -3.148610 -4.058280 -4.531850 -3.796370
+-2.572090 -1.727250 -0.961410 -0.282910 -0.479120
+-1.039340 -1.618060 -1.725460 -1.376360
+!-135
+0.214000 1.521370 1.977440 2.377950 2.929470
+2.893410 2.435810 2.162970 1.761500 1.190090
+-1.218610 -2.108900 -2.976100 -3.405340 -2.768440
+-1.836030 -0.957950 0.021790 -0.032760 -0.665880
+-1.321170 -1.212320 -0.893170 -0.897040
+!-120
+0.873950 1.959160 2.508990 2.841100 3.698960
+3.309330 2.614300 2.481720 2.694660 1.082440
+-0.398320 -1.761800 -2.945110 -3.294690 -2.308300
+-0.855480 -0.087320 0.439040 0.691880 -0.586330
+-1.027210 -0.976640 -0.467580 0.104020
+!-105
+1.767380 2.286650 2.818030 3.065500 3.370620
+3.397440 2.730310 2.878790 2.542010 1.545240
+-0.092150 -1.694440 -2.812310 -2.802430 -1.856360
+-0.306240 -0.122440 0.444680 0.810150 -0.058630
+-0.270290 -0.178830 0.202360 0.493810
+!-90
+1.456010 2.743180 2.589450 3.046230 3.451510
+3.319160 3.052900 3.873720 2.420650 0.949100
+0.008370 -1.382980 -2.138930 -2.087380 -1.268300
+-0.494370 0.267580 0.908250 0.537520 0.306260
+0.069540 0.097460 0.263060 0.603220
+!-75
+1.396790 3.349090 2.180920 2.942960 3.814070
+3.675800 3.555310 3.887290 2.101260 -0.190940
+-0.732240 -1.382040 -0.673880 -0.817390 -0.826980
+-0.111800 0.053710 0.296400 0.692240 0.428960
+-0.036100 -0.033820 -0.194300 0.400210
+!-60
+0.246650 1.229980 1.716960 3.168570 4.208190
+4.366860 4.251080 3.348110 0.997540 -1.287540
+-1.179900 -0.684300 -0.853660 -1.158760 -0.347550
+0.114810 0.242800 0.322420 0.370140 -0.374950
+-0.676940 -1.323430 -1.366650 -0.218770
+!-45
+-1.196730 0.078060 2.347410 4.211350 5.376000
+5.364940 4.355200 2.436510 0.408470 -0.590840
+-0.435960 -0.501210 -0.822230 -0.607210 0.057910
+0.246580 -0.070570 0.379430 0.247770 -0.571680
+-1.282910 -1.715770 -1.839820 -1.987110
+!-30
+-1.174720 1.067030 4.180460 6.741610 6.070770
+4.781470 2.758340 1.295810 0.571150 -0.196480
+0.251860 -0.732140 1.289360 1.497590 1.890550
+2.198490 0.169290 0.534000 0.331780 -1.276320
+-2.550070 -3.312150 -3.136670 -2.642260
+!-15
+0.293590 5.588070 3.732620 3.217620 3.272450
+2.492320 1.563700 1.356760 0.831410 0.630170
+1.591970 0.821920 0.486070 0.715760 0.996020
+1.591580 -0.367400 0.181770 -0.613920 -2.267900
+-3.516460 -3.597700 -3.043340 -1.765020
+!0
+2.832310 0.787990 0.323280 0.479230 0.628600
+0.976330 1.238750 1.671950 1.645480 2.520340
+1.606970 0.776350 0.119780 0.070390 0.121170
+-1.569230 -1.213010 -1.846360 -2.744510 -3.792530
+-3.934880 -3.615930 -2.675750 -0.924170
+!15
+-0.778340 -1.912680 -2.052140 -1.846280 -1.047430
+0.183400 1.682950 2.223500 1.358370 2.448660
+1.436920 0.678570 -0.237060 -0.535320 -0.790380
+-2.182580 -3.251140 -4.195110 -4.269270 -3.908210
+-3.455620 -2.773970 1.755370 0.313410
+!30
+-2.963810 -3.483730 -3.517080 -2.724860 -1.405510
+0.336200 1.428450 1.394630 0.970370 2.462720
+1.522430 0.553620 -0.407380 -1.482950 -3.613920
+-4.159810 -4.945580 -4.784040 -3.764540 -2.959140
+-1.963850 -1.071260 -1.599580 -2.445320
+!45
+-4.029070 -3.932660 -3.558480 -2.513980 -1.037320
+0.362000 0.814380 0.754110 0.502370 1.903420
+0.770220 -0.416420 -3.286310 -3.875270 -4.907800
+-5.704430 -5.645660 -4.396040 -2.865450 -2.368170
+-2.860490 -3.416560 -3.666490 -3.859070
+!60
+-3.338270 -2.960220 -2.311700 -1.272890 -0.246470
+0.722610 0.668070 0.438130 2.395330 1.632470
+-2.041450 -3.218100 -3.915080 -4.852510 -5.696500
+-6.314370 -5.683690 -4.170620 -3.141000 -3.508820
+-3.756430 -3.640810 -3.640430 -3.550690
+!75
+-2.244860 -1.632100 -1.000640 -0.170440 0.526440
+0.823710 0.517140 -0.013120 -0.370910 -1.213720
+-2.305650 -3.420580 -4.484960 -5.693140 -6.199150
+-6.253870 -5.211310 -4.174380 -3.685150 -4.151360
+-4.161970 -3.725150 -3.715310 -2.606760
+!90
+-1.720840 -1.177830 -0.428430 0.277730 0.807900
+0.803260 0.482510 -0.336900 -0.786270 -1.774070
+-2.793220 -3.828560 -5.211800 -6.636850 -6.989940
+-6.108800 -5.452410 -3.911450 -4.321000 -4.587240
+-4.102610 -3.772820 -3.157300 -2.648390
+!105
+-1.850640 -1.092420 -0.445020 0.128490 1.005520
+0.884820 0.485850 -0.218470 -0.857670 -1.682330
+-3.014400 -4.481110 -6.053510 -6.865400 -6.871130
+-5.728240 -3.912230 -4.802110 -5.034640 -4.715990
+-4.601080 -4.086220 -3.274630 -2.410940
+!120
+-1.969230 -1.116650 -0.540250 -0.150330 0.763520
+1.038890 0.758480 0.313530 -0.333050 -1.872770
+-3.366270 -5.008260 -6.124810 -7.034830 -6.724320
+-3.700200 -4.510620 -5.185650 -5.361620 -4.847490
+-4.444320 -4.004260 -3.415720 -2.751230
+!135
+-2.111250 -1.168960 -0.322790 -0.006920 0.316660
+1.086270 0.939170 0.625340 -0.166360 -1.830310
+-3.469470 -4.946030 -6.112560 -1.915580 -4.047310
+-4.996740 -4.996730 -4.842690 -4.886620 -4.300540
+-4.494620 -4.442210 -4.163570 -3.183510
+!150
+-1.757590 -0.403620 0.023920 0.362390 0.634520
+1.264920 1.361360 0.948420 -0.073680 -1.483560
+-3.152820 1.835120 -1.762860 -5.093660 -5.744830
+-5.390070 -4.783930 -4.190630 -4.115420 -4.042280
+-4.125570 -4.028550 -4.026100 -2.937910
+!165
+-0.810590 -0.071500 0.378890 0.543310 1.277880
+1.641310 1.698840 1.519950 0.631950 -1.088670
+-2.736530 -0.735240 -4.563830 -6.408350 -5.889450
+-5.141750 -4.194970 -3.666490 -3.843450 -3.818830
+-3.826180 -3.596820 -2.994790 -2.231020
+! alanine before proline map
+C    NH1  CT1  C    NH1  CT1  C    N     24
+!-180
+!-165
+!-150
+!-135
+!-120
+!-105
+!-90
+!-75
+!-60
+!-45
+!-30
+!-15
+!0
+!15
+!30
+!45
+!60
+!75
+!90
+!105
+!120
+!135
+!150
+!165
+! proline
+C    N    CP1  C    N    CP1    C    NH1 24
+! -180.00
+-4.60660 -4.28920 -4.51420 -5.49210 -6.65460
+-7.18530 -7.63320 -8.41920 -9.12510 -8.97830
+-9.02750 -8.88890 -8.61060 -8.10240 -7.96680
+-7.98860 -7.96190 -7.56330 -7.73950 -8.31580
+-9.33380 -9.61880 -7.91860 -6.00570
+! -165.00
+-3.21030 -2.90350 -3.04340 -3.83720 -4.92360
+-5.41790 -5.78320 -6.62490 -7.17820 -7.59500
+-7.60980 -7.39440 -6.68190 -6.24950 -5.83810
+-5.90510 -5.57900 -4.89950 -5.18840 -6.13180
+-6.93510 -7.49160 -5.84410 -4.48890
+! -150.00
+-2.23750 -2.26520 -2.55120 -3.67610 -4.61620
+-5.01560 -5.36920 -5.93110 -6.16820 -6.48830
+-6.54220 -6.14310 -5.33350 -4.85090 -4.50790
+-4.44050 -4.34380 -4.13820 -4.35620 -5.24880
+-6.05280 -6.18610 -4.80390 -3.41730
+! -135.00
+-2.12830 -2.02010 -2.90220 -3.88240 -4.63610
+-5.02000 -5.46090 -5.79830 -5.63220 -6.41490
+-6.20330 -5.57550 -4.58160 -4.15850 -4.00710
+-3.95020 -3.76880 -4.09690 -4.52680 -5.33410
+-5.97380 -5.68710 -4.70040 -3.33790
+! -120.00
+-2.20610 -2.22370 -2.85110 -3.55370 -4.33320
+-4.57860 -4.95030 -5.23950 -5.37730 -6.14740
+-5.98660 -5.17760 -4.16090 -3.78450 -3.83210
+-3.86590 -4.21340 -4.26250 -4.16200 -4.62160
+-5.47440 -5.38280 -4.39100 -3.16760
+! -105.00
+-1.32980 -1.44660 -2.00420 -2.84440 -3.31580
+-3.15410 -2.83060 -3.04980 -4.04810 -5.02030
+-4.84090 -3.88520 -2.79540 -2.49190 -2.65990
+-3.34670 -3.60580 -3.76970 -4.07430 -4.21930
+-4.66740 -4.23940 -3.37160 -2.10050
+!  -90.00
+-0.27400 -0.41780 -0.92340 -1.48470 -1.84370
+-1.42480 -1.14210 -1.83280 -2.97900 -3.57000
+-3.33310 -2.24200 -1.31350 -0.96640  0.38300
+-0.57540 -0.74080 -0.59130 -0.41960 -2.64120
+-3.25380 -2.85540 -2.09970 -0.95660
+!  -75.00
+ 0.26880  0.18190  0.00300 -0.45390 -0.24210
+ 0.21240  0.33320 -0.95520 -2.17670 -2.66490
+-2.24910 -1.35480 -0.35030  1.84000  0.81880
+ 0.41530  0.58460  0.65350  0.54960  0.41300
+ 0.23350 -2.13490 -1.54900 -0.38340
+!  -60.00
+-0.48820 -0.40730 -0.25210 -0.20490  0.53370
+ 1.05990  0.72540 -0.68300 -2.10190 -2.83530
+-2.55500 -1.33940 -0.24710  1.63190  1.10600
+ 1.16350  1.30720  1.49310  1.16160  0.99320
+-2.33360 -2.59380 -2.01110 -1.46840
+!  -45.00
+-2.41010 -1.30740 -0.85960 -0.06830  0.20500
+ 0.00650 -0.59750 -2.39820 -3.98270 -4.46610
+-3.51230 -1.99330  0.96050  0.80870  0.64450
+ 0.82590  1.00550  1.28110  0.96670 -2.71140
+-4.18330 -4.83370 -4.49950 -3.47920
+!  -30.00
+-3.46300 -2.06680 -0.84260 -0.70440 -1.85140
+-2.59990 -3.62600 -5.08050 -6.35480 -6.08340
+-4.78650 -1.24210 -0.81660 -0.60170 -0.50040
+-0.41020 -0.28450 -0.14620 -3.14950 -5.16280
+-6.81940 -7.52060 -7.12480 -5.49420
+!  -15.00
+-2.70550 -1.11410 -0.82120 -3.80470 -4.50780
+-4.64960 -5.78530 -7.04450 -7.30810 -6.56450
+-3.47860 -2.68630 -1.78120 -1.48400 -1.45930
+-1.43060 -5.75320 -2.72500 -6.45790 -8.16530
+-9.86330 -9.80710 -8.62670 -6.49690
+!    0.00
+-2.73190 -3.83060 -5.26960 -5.91610 -6.71690
+-7.05420 -7.77520 -7.81220 -7.54160 -4.98400
+-5.05070 -4.28910 -3.78740 -3.64600 -3.91990
+-3.55740 -3.03470 -5.78910 -7.02720 -8.04090
+-8.60950 -8.27740 -7.10120 -5.12040
+!   15.00
+-3.17420 -4.66830 -6.17790 -7.26760 -8.22560
+-8.32120 -7.64880 -7.00240 -4.77210 -5.65380
+-5.36790 -4.43640 -4.37720 -4.45280 -4.47980
+-4.07260 -6.75420 -7.56910 -7.95830 -7.87760
+-7.88160 -7.29010 -7.15600 -5.19260
+!   30.00
+-2.96240 -4.87720 -6.64930 -7.95180 -8.47610
+-7.49950 -6.26260 -6.35040 -4.34190 -4.49790
+-4.27480 -1.75620 -3.89990 -3.81400 -3.99610
+-6.66430 -7.66400 -7.80660 -7.21980 -6.83750
+-6.88220 -7.10200 -5.10200 -2.38920
+!45
+0.000000 0.000000 0.000000 0.000000 0.000000
+!60
+!75
+!90
+!105
+!120
+!135
+!150
+!165
+!2 adjacent prolines
+C    N    CP1  C    N    CP1    C    N 24
+! -180.00
+! -165.00
+! -150.00
+! -135.00
+! -120.00
+! -105.00
+!  -90.00
+!  -75.00
+!  -60.00
+!  -45.00
+!  -30.00
+!  -15.00
+!    0.00
+!   15.00
+!   30.00
+!45
+!60
+!75
+!90
+!105
+!120
+!135
+!150
+!165
+! glycine map
+C    NH1  CT2  C    NH1  CT2  C    NH1   24
+!-180
+-0.549160 -0.535500 -0.588110 -0.754620 -0.679290
+-0.038150 0.298460 0.326040 -0.375610 -1.704360
+-3.061280 -3.956460 -3.576280 -1.038930 2.012450
+-1.714610 -0.377660 0.317310 0.294580 -0.042920
+-0.676620 -0.744600 -0.586590 -0.554770
+!-165
+-0.709450 -0.896700 -0.990850 -1.319240 -0.940260
+-0.126160 0.329180 0.258100 -0.534910 -1.715700
+-2.780320 -3.153350 -1.636020 1.822690 -2.675640
+-1.810120 -0.410680 0.180860 0.196710 -0.000430
+-0.271890 -0.462500 -0.348750 -0.477660
+!-150
+-1.224850 -1.482430 -1.665900 -1.656770 -1.119780
+-1.642540 -0.054220 -0.290670 -0.887080 -1.626260
+-2.165440 -1.546500 0.753400 -2.949180 -2.225630
+-1.664160 -0.628990 0.000490 0.033160 -0.092820
+-0.339050 -0.563330 -0.794980 -0.710760
+!-135
+-1.787640 -2.117750 -2.143020 -1.803720 -1.567160
+-0.886880 -0.801350 -0.851590 -1.020630 -1.337360
+-1.062570 0.338010 -4.372310 -2.435890 -2.220710
+-1.718060 -0.758950 -0.207560 0.100910 -0.055650
+-0.288370 -0.880610 -1.267450 -1.465530
+!-120
+-2.348270 -2.593790 -2.596140 -2.364070 -1.970070
+-1.705860 -1.435540 -1.289220 -1.358170 -0.975570
+-3.514390 -4.283210 -3.975820 -3.215190 -2.394430
+-1.455320 -0.553910 -0.158900 -0.173830 -0.297950
+-0.661220 -1.068330 -1.601800 -1.914850
+!-105
+-2.788800 -3.079570 -3.178150 -3.013710 -2.626630
+-2.266680 -1.951490 -1.681850 -1.195390 -2.567680
+-3.632800 -4.748210 -4.662850 -4.255190 -2.776760
+-1.695490 -0.893140 -0.633810 -0.467320 -0.540540
+-0.950190 -1.401500 -1.959970 -2.412680
+!-90
+-3.857170 -3.713610 -3.902110 -3.611370 -3.040850
+-2.406460 -1.975250 -1.452040 -0.971860 -2.808170
+-4.181160 -4.981430 -5.446890 -4.359900 -2.864390
+-1.898510 -1.139090 -0.971340 -1.065550 -1.020680
+-1.141350 -1.794480 -2.420970 -2.939990
+!-75
+-4.987770 -4.995210 -4.485310 -3.892550 -3.228630
+-2.345360 -1.664160 -1.105500 -1.945510 -3.715530
+-4.492140 -5.536170 -5.708500 -3.675410 -2.986660
+-1.859410 -0.756620 -1.269930 -1.312730 -1.607440
+-1.892510 -2.659400 -3.347950 -3.970600
+!-60
+-6.183650 -5.456080 -4.878940 -4.000820 -2.683230
+-2.067520 -1.094850 -1.119790 -2.962910 -3.687830
+-4.993340 -4.666260 -3.796280 -3.374140 -2.495430
+-1.453990 -0.877560 -1.002930 -1.337310 -2.431360
+-2.948140 -4.008100 -4.821040 -5.565810
+!-45
+-6.755760 -5.850030 -4.362190 -2.714090 -1.708710
+-0.526660 -0.536700 -2.037170 -3.892650 -4.558570
+-4.237410 -3.735160 -3.688580 -3.009910 -2.112940
+-1.455400 -0.925490 -1.121840 -1.561900 -2.751370
+-4.094860 -5.207530 -6.128530 -6.613030
+!-30
+-5.716250 -4.434060 -2.788600 -0.974400 -0.729200
+-0.904940 -1.833540 -3.017700 -3.313450 -3.336010
+-3.181640 -3.594720 -1.231370 -0.603790 0.128810
+-1.222610 -0.909150 -0.837700 -1.346820 -3.040880
+-4.731110 -5.844860 -6.428460 -6.424880
+!-15
+-3.991110 -2.046000 0.082550 -2.676110 -2.828500
+-2.596640 -2.843330 -3.011480 -2.312640 -2.405980
+-3.086210 -1.164620 -1.231660 -0.871900 -0.348980
+-1.735900 -0.914150 -0.484520 -1.818040 -3.602550
+-5.330320 -5.992270 -5.588080 -5.408360
+!0
+-1.147060 -3.317730 -4.305100 -4.615200 -4.533780
+-3.622950 -2.832800 -1.872810 -1.144300 -1.994070
+-0.741980 -1.115010 -1.229250 -1.103680 -0.742430
+-1.973970 -1.070020 -1.802220 -2.712770 -3.624130
+-4.537100 -4.619970 -4.310890 -3.318290
+!15
+-3.997710 -5.408360 -5.588080 -5.992270 -5.330320
+-3.602550 -1.818040 -0.484520 -0.914150 -1.735900
+-0.348980 -0.871900 -1.231660 -1.164620 -3.086210
+-2.405980 -2.312640 -3.011480 -2.843330 -2.596640
+-2.828500 -2.676110 0.082550 -2.046000
+!30
+-5.710850 -6.424880 -6.428460 -5.844860 -4.731110
+-3.040880 -1.346820 -0.837700 -0.909150 -1.222610
+0.128810 -0.603790 -1.231370 -3.594720 -3.181640
+-3.336010 -3.313450 -3.017700 -1.833540 -0.904940
+-0.729200 -0.974400 -2.788600 -4.434060
+!45
+-6.754940 -6.613030 -6.128530 -5.207530 -4.094860
+-2.751370 -1.561900 -1.121840 -0.925490 -1.455400
+-2.112940 -3.009910 -3.688580 -3.735160 -4.237410
+-4.558570 -3.892650 -2.037170 -0.536700 -0.526660
+-1.708710 -2.714090 -4.362190 -5.850030
+!60
+-6.188070 -5.565810 -4.821040 -4.008100 -2.948140
+-2.431360 -1.337310 -1.002930 -0.877560 -1.453990
+-2.495430 -3.374140 -3.796280 -4.666260 -4.993340
+-3.687830 -2.962910 -1.119790 -1.094850 -2.067520
+-2.683230 -4.000820 -4.878940 -5.456080
+!75
+-4.986080 -3.970600 -3.347950 -2.659400 -1.892510
+-1.607440 -1.312730 -1.269930 -0.756620 -1.859410
+-2.986660 -3.675410 -5.708500 -5.536170 -4.492140
+-3.715530 -1.945510 -1.105500 -1.664160 -2.345360
+-3.228630 -3.892550 -4.485310 -4.995210
+!90
+-3.879190 -2.939990 -2.420970 -1.794480 -1.141350
+-1.020680 -1.065550 -0.971340 -1.139090 -1.898510
+-2.864390 -4.359900 -5.446890 -4.981430 -4.181160
+-2.808170 -0.971860 -1.452040 -1.975250 -2.406460
+-3.040850 -3.611370 -3.902110 -3.713610
+!105
+-2.793280 -2.412680 -1.959970 -1.401500 -0.950190
+-0.540540 -0.467320 -0.633810 -0.893140 -1.695490
+-2.776760 -4.255190 -4.662850 -4.448210 -3.332800
+-2.567680 -1.195390 -1.681850 -1.951490 -2.266680
+-2.626630 -3.013710 -3.178150 -3.079570
+!120
+-2.330190 -1.914850 -1.601800 -1.068330 -0.661220
+-0.297950 -0.173830 -0.158900 -0.553910 -1.455320
+-2.394430 -3.215190 -3.975820 -3.783210 -3.014390
+-0.975570 -1.358170 -1.289220 -1.435540 -1.705860
+-1.970070 -2.364070 -2.596140 -2.593790
+!135
+-1.796120 -1.465530 -1.267450 -0.880610 -0.288370
+-0.055650 0.100910 -0.207560 -0.758950 -1.718060
+-2.220710 -2.435890 -4.372310 0.338010 -1.062570
+-1.337360 -1.020630 -0.851590 -0.801350 -0.886880
+-1.567160 -1.803720 -2.143020 -2.117750
+!150
+-1.263610 -0.710760 -0.794980 -0.563330 -0.339050
+-0.092820 0.033160 0.000490 -0.628990 -1.664160
+-2.225630 -2.949180 0.753400 -1.546500 -2.165440
+-1.626260 -0.887080 -0.290670 -0.054220 -1.642540
+-1.119780 -1.656770 -1.665900 -1.482430
+!165
+-0.684660 -0.477660 -0.348750 -0.462500 -0.271890
+-0.000430 0.196710 0.180860 -0.410680 -1.810120
+-2.675640 1.822690 -1.636020 -3.153350 -2.780320
+-1.715700 -0.534910 0.258100 0.329180 -0.126160
+-0.940260 -1.319240 -0.990850 -0.896700
+! glycine before proline map: use glycine map
+C    NH1  CT2  C    NH1  CT2  C    N   24
+!-180
+!-165
+!-150
+!-135
+!-120
+!-105
+!-90
+!-75
+!-60
+!-45
+!-30
+!-15
+!0
+!15
+!30
+!45
+!60
+!75
+!90
+!105
+!120
+!135
+!150
+!165
+NONBONDED nbxmod  5 atom cdiel shift vatom vdistance vswitch -
+cutnb 14.0 ctofnb 12.0 ctonnb 10.0 eps 1.0 e14fac 1.0 wmin 1.5
+                !adm jr., 5/08/91, suggested cutoff scheme
+!V(Lennard-Jones) = Eps,i,j[(Rmin,i,j/ri,j)**12 - 2(Rmin,i,j/ri,j)**6]
+!epsilon: kcal/mole, Eps,i,j = sqrt(eps,i * eps,j)
+!Rmin/2: A, Rmin,i,j = Rmin/2,i + Rmin/2,j
+!atom  ignored    epsilon      Rmin/2   ignored   eps,1-4       Rmin/2,1-4
+!carbons
+C      0.000000  -0.110000     2.000000 ! ALLOW   PEP POL ARO
+                ! NMA pure solvent, adm jr., 3/3/93
+CA     0.000000  -0.070000     1.992400 ! ALLOW   ARO
+                ! benzene (JES)
+CC     0.000000  -0.070000     2.000000 ! ALLOW   PEP POL ARO
+                ! adm jr. 3/3/92, acetic acid heat of solvation
+CD     0.000000  -0.070000     2.000000 ! ALLOW  POL
+                ! adm jr. 3/19/92, acetate a.i. and dH of solvation
+CE1    0.000000  -0.068000     2.090000 !
+		! for propene, yin/adm jr., 12/95
+CE2    0.000000  -0.064000     2.080000 !
+		! for ethene, yin/adm jr., 12/95
+CM     0.000000  -0.110000     2.100000 ! ALLOW HEM
+                ! Heme (6-liganded): CO ligand carbon (KK 05/13/91)
+CP1    0.000000  -0.020000     2.275000   0.000000  -0.010000     1.900000 ! ALLOW   ALI
+CP2    0.000000  -0.055000     2.175000   0.000000  -0.010000     1.900000 ! ALLOW   ALI
+CP3    0.000000  -0.055000     2.175000   0.000000  -0.010000     1.900000 ! ALLOW   ALI
+CPA    0.000000  -0.090000     1.800000 ! ALLOW HEM
+                ! Heme (6-liganded): porphyrin macrocycle (KK 05/13/91)
+CPB    0.000000  -0.090000     1.800000 ! ALLOW HEM
+CPH1   0.000000  -0.050000     1.800000 ! ALLOW ARO
+                ! adm jr., 10/23/91, imidazole solvation and sublimation
+CPH2   0.000000  -0.050000     1.800000 ! ALLOW ARO
+CPM    0.000000  -0.090000     1.800000 ! ALLOW HEM
+CPT    0.000000  -0.090000     1.800000   0.000000  -0.090000     1.900000 ! ALLOW   ARO
+                ! benzene (JES)
+CS     0.000000  -0.110000     2.200000 ! ALLOW SUL
+                ! methylthiolate to water and F.E. of solvation, adm jr. 6/1/92
+CST    0.000000  -0.058000     1.563000 !
+                ! carbon dioxide, JES
+CT1    0.000000  -0.020000     2.275000   0.000000  -0.010000     1.900000 ! ALLOW   ALI
+                ! isobutane pure solvent properties, adm jr, 2/3/92
+CT2    0.000000  -0.055000     2.175000   0.000000  -0.010000     1.900000 ! ALLOW   ALI
+                ! propane pure solvent properties, adm jr, 2/3/92
+CT3    0.000000  -0.080000     2.060000   0.000000  -0.010000     1.900000 ! ALLOW   ALI
+                ! methane/ethane a.i. and ethane pure solvent, adm jr, 2/3/92
+CY     0.000000  -0.070000     1.992400 ! ALLOW   ARO
+                ! TRP, JWK 08/29/89
+!new alkanes atoms types for conversion to new LJ parameters for c27 (see toppar_all22_prot_aliphatic_c27.str)
+CT       0.0       -0.0200    2.275 0.0 -0.01 1.9 ! from CT1x: needs work
+CT1x     0.0       -0.0200    2.275 0.0 -0.01 1.9 ! alkane, 3/92: needs work
+CT2x     0.0       -0.0560    2.010 0.0 -0.01 1.9 ! alkane, 4/98, yin, adm jr.
+CT3x     0.0       -0.0780    2.040 0.0 -0.01 1.9 ! alkane, 4/98, yin, adm jr.
+! hydrogens
+H      0.000000  -0.046000     0.224500 ! ALLOW PEP POL SUL ARO ALC
+                ! same as TIP3P hydrogen, adm jr., 7/20/89
+HA     0.000000  -0.022000     1.320000 ! ALLOW PEP ALI POL SUL ARO PRO ALC
+HE1    0.000000  -0.031000     1.250000 !
+HE2    0.000000  -0.026000     1.260000 !
+HB     0.000000  -0.022000     1.320000 ! ALLOW PEP ALI POL SUL ARO PRO ALC
+HC     0.000000  -0.046000     0.224500 ! ALLOW POL
+                ! new, small polar Hydrogen, see also adm jr. JG 8/27/89
+HP     0.000000  -0.030000     1.358200   0.000000  -0.030000     1.358200 ! ALLOW ARO
+                ! JES 8/25/89 values from Jorgensen fit to hydration energy
+HR1    0.000000  -0.046000     0.900000 ! ALLOW ARO
+HR2    0.000000  -0.046000     0.700000 ! ALLOW ARO
+HR3    0.000000  -0.007800     1.468000 ! ALLOW ARO
+                ! adm jr., 3/24/92, maintain old aliphatic H VDW params
+HS     0.000000  -0.100000     0.450000 ! ALLOW SUL
+                ! methanethiol pure solvent, adm jr., 6/22/92
+HT     0.000000  -0.046000     0.224500 ! ALLOW WAT
+                !TIP3P HYDROGEN PARAMETERS, adm jr., NBFIX obsolete
+HA1     0.0       -0.022     1.3200 ! alkane, 3/92
+HA2     0.0       -0.028     1.3400 ! alkane, yin and mackerell, 4/98
+HA3     0.0       -0.024     1.3400 ! alkane, yin and mackerell, 4/98
+!nitrogens
+N      0.000000  -0.200000     1.850000   0.000000  -0.000100     1.850000 ! ALLOW   PRO
+                ! 6-31g* AcProNH2, ProNH2, 6-31g*//3-21g AcProNHCH3 RLD 4/23/93
+NC2    0.000000  -0.200000     1.850000 ! ALLOW   POL
+                ! JG 8/27/89; note: NH1 in ARG was changed to NC2.
+NH1    0.000000  -0.200000     1.850000   0.000000  -0.200000     1.550000 ! ALLOW   PEP POL ARO
+                ! This 1,4 vdW allows the C5 dipeptide minimum to exist.(LK)
+NH2    0.000000  -0.200000     1.850000 ! ALLOW   POL
+                ! adm jr.
+NH3    0.000000  -0.200000     1.850000 ! ALLOW   POL
+                ! adm jr.
+NP     0.000000  -0.200000     1.850000 ! ALLOW  PRO
+                ! N-terminal proline; from 6-31g* +ProNH2  RLD 9/28/90
+NPH    0.000000  -0.200000     1.850000 ! ALLOW HEM
+NR1    0.000000  -0.200000     1.850000 ! ALLOW ARO
+                ! His, adm jr., 9/4/89
+NR2    0.000000  -0.200000     1.850000 ! ALLOW ARO
+NR3    0.000000  -0.200000     1.850000 ! ALLOW ARO
+NY     0.000000  -0.200000     1.850000 ! ALLOW   ARO
+                ! trp, JWK
+! oxygens
+O      0.000000  -0.120000     1.700000   0.000000  -0.120000     1.400000 ! ALLOW   PEP POL
+OB     0.000000  -0.120000     1.700000   0.000000  -0.120000     1.400000 ! ALLOW   PEP POL ARO
+                ! adm jr., 10/17/90, acetic acid carbonyl O
+OC     0.000000  -0.120000     1.700000 ! ALLOW   POL ION
+                ! JG 8/27/89
+OH1    0.000000  -0.152100     1.770000 ! ALLOW   ALC ARO
+                ! adm jr. 8/14/90, MeOH nonbond and solvent (same as TIP3P)
+OM     0.000000  -0.120000     1.700000 ! ALLOW HEM
+                ! Heme (6-liganded): CO ligand oxygen (KK 05/13/91)
+OS     0.000000  -0.152100     1.770000 ! ALLOW   ALC ARO
+                ! adm jr. 9/17/90, avoid O* wildcard
+OST    0.000000  -0.165000     1.692000 !
+OT     0.000000  -0.152100     1.768200 ! ALLOW   WAT
+                !TIP3P OXYGEN PARAMETERS, adm jr., NBFIX obsolete
+! sulfurs
+S      0.000000  -0.450000     2.000000 ! ALLOW   SUL ION
+                ! adm jr., 3/3/92, methanethiol/ethylmethylsulfide pure solvent
+SM     0.000000  -0.380000     1.975000 ! ALLOW  SUL  ION
+                ! adm jr., 3/3/92, dimethyldisulphide pure solvent
+SS     0.000000  -0.470000     2.200000 ! ALLOW  SUL
+! ions and miscellaneous types
+SOD      0.0     -0.0469    1.36375   ! sodium
+                   ! D. Beglovd and B. Roux, dA=-100.8 kcal/mol
+POT      0.0     -0.0870    1.76375   ! potassium
+                   ! D. Beglovd and B. Roux, dA=-82.36+2.8 = -79.56 kca/mol
+CLA      0.0     -0.150     2.27      ! chloride
+                   ! D. Beglovd and B. Roux, dA=-83.87+4.46 = -79.40 kcal/mol
+CAL      0.0     -0.120     1.367     ! Calcium
+                   ! S. Marchand and B. Roux, dA = -384.8 kcal/mol
+!CAL      0.000000  -0.120000     1.710000 ! Calcium (BP) in proteins prior
+                   ! to 2003; not recommended due to need for NBFIX terms
+MG       0.0     -0.0150    1.18500   ! Magnesium
+                   ! B. Roux dA = -441.65
+CES      0.0     -0.1900    2.100
+                   ! Cesium, so far untested.
+ZN     0.000000  -0.250000     1.090000 ! ALLOW  ION
+                ! RHS March 18, 1990
+FE     0.010000   0.000000     0.650000 ! ALLOW HEM
+                ! Heme (6-liganded): Iron atom (KK 05/13/91)
+HE     0.000000  -0.021270     1.4800   !
+                ! helium, experimental pot. energy surface, adm jr., 12/95
+NE     0.000000  -0.086000     1.5300
+                ! neon, semiempirical pot. energy surface, adm jr., 12/95
+CLAL   0.000000  -0.030000     1.908200 ! chlorine from Jorgensen/BOSS
+                ! for choroacetaldehyde
+DUM    0.000000  -0.000000     0.000000 !
+                ! dummy atom
+!pyridine series LJ parametes (see toppar_pyridines.str)
+CAP    0.000000  -0.070000     1.992400 !
+FA     0.000000  -0.12000      1.700000
+                ! from 1,3-difluorobenzene pure solvent
+CN     0.000000  -0.200000     1.750000 ! cyanopyridine
+NC     0.000000  -0.600000     1.850000 ! cyanopyridine
+OCA    0.000000  -0.120000     1.700000   0.000000  -0.120000 1.400000 ! 3acp
+COA    0.000000  -0.110000     2.000000 ! 3acp
+!fluorinated alkanes LJ parameters (see toppar_fluoro_alkanes.str)
+CF1    0.000000  -0.060000     1.900000
+CF2    0.000000  -0.042000     2.050000
+CF3    0.000000  -0.020000     2.300000
+HF1    0.000000  -0.028000     1.3200
+HF2    0.000000  -0.030000     1.3000
+F1     0.0       -0.135        1.63
+F2     0.0       -0.105        1.63
+F3     0.0       -0.097        1.60
+!protein model compounds (see toppar_all22_prot_model.str)
+C3     0.000000  -0.020000     2.275000 ! cyclopropane, JMW and CBP 4/04
+!retinol model compounds
+CC1A   0.0   -0.0680     2.0900 !
+CC1B   0.0   -0.0680     2.0900 !
+CC2    0.0   -0.0640     2.0800 !
+NS1    0.000000  -0.200000     1.850000 !N for deprotonated Schiff's base
+NS2    0.000000  -0.200000     1.850000 !N for protonated Schiff's base
+HBOND CUTHB 0.5  ! If you want to do hbond analysis (only), then use
+                 ! READ PARAM APPEND CARD
+                 ! to append hbond parameters from the file: par_hbond.inp
+END
Modified: SwiftApps/CMTS/scaling/namd_wrapper.sh
--- SwiftApps/CMTS/scaling/namd_wrapper.sh	2012-09-19 04:24:57 UTC (rev 5934)
+++ SwiftApps/CMTS/scaling/namd_wrapper.sh	2012-09-20 15:45:29 UTC (rev 5935)
@@ -1,10 +1,8 @@
-#!/bin/bash
+#!/bin/bash -x
-echo Args are: $@
-echo Node file is: $PBS_NODEFILE
-echo Contents of nodefile: $( cat $PBS_NODEFILE )
+numNodes=$1
+namdConf=h0_eq.$numNodes.conf
-sed -ei 's/_WORK_/$PWD/g' h0_eq.conf
-mpiexec namd2 h0_eq.conf
+echo Arguments are: $@
+sed -e "s/_JOB_/$numNodes/g" h0_eq.conf > $namdConf
+mpiexec namd2 $namdConf
Added: SwiftApps/CMTS/scaling/plot.sh
--- SwiftApps/CMTS/scaling/plot.sh	                        (rev 0)
+++ SwiftApps/CMTS/scaling/plot.sh	2012-09-20 15:45:29 UTC (rev 5935)
@@ -0,0 +1,3 @@
+# Get scaling results and plot them
+# CPUS vs days per ns
+grep -m 1 "Bench" logs/*.out | gawk -F" " '{print $4,$8}' > scale.dat
Modified: SwiftApps/CMTS/scaling/runscaling.sh
--- SwiftApps/CMTS/scaling/runscaling.sh	2012-09-19 04:24:57 UTC (rev 5934)
+++ SwiftApps/CMTS/scaling/runscaling.sh	2012-09-20 15:45:29 UTC (rev 5935)
@@ -66,6 +66,9 @@
 export WORK=$PWD/swiftwork
 mkdir -p $PWD/swiftwork/workers
+# Create CDM config
+# echo "rule .* DIRECT $PWD" >> fs.data
 # Use start-coaster-service if the site uses a .conf file
 if [ "$USE_SCS" == "1" ]; then
    cp ../conf/$execsite.conf coaster-service.conf
Modified: SwiftApps/CMTS/scaling/scaling.swift
--- SwiftApps/CMTS/scaling/scaling.swift	2012-09-19 04:24:57 UTC (rev 5934)
+++ SwiftApps/CMTS/scaling/scaling.swift	2012-09-20 15:45:29 UTC (rev 5935)
@@ -1,15 +1,23 @@
 type file;
-app (file out, file err) namd_wrapper (int numnodes, file psf_file, file pdb_file, file coord_restart_file,
-                                       file velocity_restart_file, file system_restart_file)
+// Namd wrapper
+app (file out, file err) namd_wrapper (int numnodes, file psf_file, file pdb_file,
+                                       file coord_restart_file, file velocity_restart_file,
+                                       file system_restart_file, file namd_conf, file charmm_params)
    profile "count" = numnodes;
-   namd_wrapper @psf_file @pdb_file @coord_restart_file @velocity_restart_file @system_restart_file stdout=@out stderr=@err;
+   namd_wrapper numnodes @namd_conf stdout=@out stderr=@err;
+// Plotting script
+app (file png) plot (file[] namdlogs)
+    plot @png @namdlogs;
 # Range of nodes to test on
 int minNodes=1;
-int maxNodes=2;
+int maxNodes=4;
 int delta=1;
 # Files
@@ -18,10 +26,20 @@
 file coord_restart <"h0_eq.0.restart.coor">;
 file velocity_restart <"h0_eq.0.restart.vel">;
 file system_restart <"h0_eq.0.restart.xsc">;
+file namd_config <"h0_eq.conf">;
+file charmm_parameters <"par_all22_prot.inp">;
+file logs[];
+// Run scaling tests
 foreach nodes in [minNodes:maxNodes:delta] {
-   file output <single_file_mapper; file=@strcat("logs/h0scale.", nodes, ".out")>;
-   file error <single_file_mapper; file=@strcat("logs/h0scale.", nodes, ".err")>;
-   (output, error) = namd_wrapper(nodes, psf, pdb, coord_restart, velocity_restart, system_restart);
+   file namd_output <single_file_mapper; file=@strcat("logs/h0scale.", nodes, ".out")>;
+   file namd_error <single_file_mapper; file=@strcat("logs/h0scale.", nodes, ".err")>;
+   (namd_output, namd_error) = namd_wrapper(nodes, psf, pdb, coord_restart, velocity_restart,
+                                            system_restart, namd_config, charmm_parameters);
+   logs[nodes] = namd_output;
+// Plot output
+file plot_output <"scale.dat">;
+plot_output = plot(logs);
