[Swift-commit] r5916 - in trunk: docs/userguide libexec src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan/lib/swiftscript tests/language-behaviour/strings
davidk at ci.uchicago.edu
Sun Sep 2 13:38:33 CDT 2012
Author: davidk
Date: 2012-09-02 13:38:32 -0500 (Sun, 02 Sep 2012)
New Revision: 5916
Added:
trunk/tests/language-behaviour/strings/0055-strjoin.check.sh
trunk/tests/language-behaviour/strings/0055-strjoin.swift
Modified:
trunk/docs/userguide/app_procedures
trunk/libexec/vdl-lib.xml
trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
@strjoin
Modified: trunk/docs/userguide/app_procedures
--- trunk/docs/userguide/app_procedures 2012-09-01 14:58:35 UTC (rev 5915)
+++ trunk/docs/userguide/app_procedures 2012-09-02 18:38:32 UTC (rev 5916)
@@ -368,13 +368,28 @@
trace(out);
-will output the message: Your name is John.
+This will output the message: Your name is John.
+ at strjoin
+ at strjoin(array, delimiter) will combine the elements of an array
+into a single string separated by a given delimiter. The array
+passed to @strjoin must be of a primitive type (string, int, float,
+or boolean). It will not join the contents of an array of files.
+Example:
+string test[] = ["this", "is", "a", "test" ];
+string mystring = @strjoin(test, " ");
+tracef("%s\n", mystring);
+This will print the string "this is a test".
@strsplit
@strsplit(input,pattern) will split the input string based on
separators that match the given pattern and return a string array.
-(since Swift 0.9)
Example:
@@ -385,7 +400,7 @@
-will output one word of the sentence on each line (though not
+This will output one word of the sentence on each line (though not
necessarily in order, due to the fact that foreach iterations execute in
parallel).
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml 2012-09-01 14:58:35 UTC (rev 5915)
+++ trunk/libexec/vdl-lib.xml 2012-09-02 18:38:32 UTC (rev 5916)
@@ -11,6 +11,7 @@
<export name="strcut"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="strstr"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="strsplit"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="strjoin"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="regexp"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="to_int"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="to_float"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2012-09-01 14:58:35 UTC (rev 5915)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2012-09-02 18:38:32 UTC (rev 5916)
@@ -196,7 +196,7 @@
add(functionsMap, "strcut", returns(STRING), args(STRING, STRING));
add(functionsMap, "strstr", returns(INT), args(STRING, STRING));
add(functionsMap, "strsplit", returns(STRING_ARRAY), args(STRING, STRING));
+ add(functionsMap, "strjoin", returns(STRING), args(ANY, STRING));
add(functionsMap, "toInt", returns(INT), args(ANY));
add(functionsMap, "toFloat", returns(FLOAT), args(ANY));
add(functionsMap, "toString", returns(STRING), args(ANY));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2012-09-01 14:58:35 UTC (rev 5915)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java 2012-09-02 18:38:32 UTC (rev 5916)
@@ -61,6 +61,7 @@
setArguments("swiftscript_strcat", new Arg[] { Arg.VARGS });
setArguments("swiftscript_strcut", new Arg[] { PA_INPUT, PA_PATTERN });
setArguments("swiftscript_strsplit", new Arg[] { PA_INPUT, PA_PATTERN });
+ setArguments("swiftscript_strjoin", new Arg[] { PA_ARRAY, PA_INPUT });
setArguments("swiftscript_strstr", new Arg[] { PA_INPUT, PA_PATTERN });
setArguments("swiftscript_trace", new Arg[] { Arg.VARGS });
setArguments("swiftscript_to_int", new Arg[] { PA_INPUT });
@@ -69,7 +70,6 @@
setArguments("swiftscript_tofloat", new Arg[] { PA_INPUT });
setArguments("swiftscript_to_string", new Arg[] { PA_INPUT });
setArguments("swiftscript_tostring", new Arg[] { PA_INPUT });
private static final Logger traceLogger =
@@ -256,7 +256,31 @@
VDLFunction.logProvenanceParameter(provid, PA_PATTERN.getRawValue(stack), "pattern");
return handle;
+ * swiftscript_strjoin (@strjoin) - Combine elements of an array into a single string with a specified delimiter
+ * @param stack
+ * @return DSHandle representing the resulting string
+ * @throws ExecutionException
+ public DSHandle swiftscript_strjoin(VariableStack stack) throws ExecutionException
+ AbstractDataNode array = (AbstractDataNode) PA_ARRAY.getRawValue(stack);
+ String delim = TypeUtil.toString(PA_INPUT.getValue(stack));
+ String result = "";
+ array.waitFor();
+ Map<?, ?> arrayValues = array.getArrayValue();
+ for (Object value : arrayValues.values()) {
+ if (result == "") { result += ((DSHandle) value).getValue(); }
+ else { result += delim + ((DSHandle) value).getValue(); }
+ DSHandle handle = new RootDataNode(Types.STRING, result);
+ return handle;
public DSHandle swiftscript_regexp(VariableStack stack)
throws ExecutionException {
String inputString = TypeUtil.toString(PA_INPUT.getValue(stack));
Added: trunk/tests/language-behaviour/strings/0055-strjoin.check.sh
--- trunk/tests/language-behaviour/strings/0055-strjoin.check.sh (rev 0)
+++ trunk/tests/language-behaviour/strings/0055-strjoin.check.sh 2012-09-02 18:38:32 UTC (rev 5916)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+filename="0055-strjoin.stdout"
+grep -x "Empty: " $filename || exit 1
+grep -x "Integer array: 1:2:3:4:5" $filename || exit 1
+grep -x "String array: a:bb:ccc" $filename || exit 1
+grep -x "Boolean array: true:false:true:false" $filename || exit 1
+grep -x "Float array: 1.1:2.2:3.3:4.4:5.5" $filename || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/strings/0055-strjoin.check.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/language-behaviour/strings/0055-strjoin.swift
--- trunk/tests/language-behaviour/strings/0055-strjoin.swift (rev 0)
+++ trunk/tests/language-behaviour/strings/0055-strjoin.swift 2012-09-02 18:38:32 UTC (rev 5916)
@@ -0,0 +1,20 @@
+string sa[] = ["a", "bb", "ccc"];
+string sas = @strjoin(sa, ":");
+tracef("String array: %s\n", sas);
+int ia[] = [1, 2, 3, 4, 5];
+string ias = @strjoin(ia, ":");
+tracef("Integer array: %s\n", ias);
+float fa[] = [1.1, 2.2, 3.3, 4.4, 5.5];
+string fas = @strjoin(fa, ":");
+tracef("Float array: %s\n", fas);
+boolean ba[] = [true, false, true, false];
+string bas = @strjoin(ba, ":");
+tracef("Boolean array: %s\n", bas);
+string empty[];
+string emptystring = @strjoin(empty, ":");
+tracef("Empty: %s\n", emptystring);
Property changes on: trunk/tests/language-behaviour/strings/0055-strjoin.swift
More information about the Swift-commit
