[Swift-commit] r5915 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Sat Sep 1 09:58:36 CDT 2012
Author: wozniak
Date: 2012-09-01 09:58:35 -0500 (Sat, 01 Sep 2012)
New Revision: 5915
Added:
   usertools/plotter/src/plotter/UserInputException.java
Modified:
   usertools/plotter/src/plotter/Lines.java
   usertools/plotter/src/plotter/Plotter.java
Log:
Better error checking
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java	2012-09-01 00:47:24 UTC (rev 5914)
+++ usertools/plotter/src/plotter/Lines.java	2012-09-01 14:58:35 UTC (rev 5915)
@@ -63,6 +63,7 @@
        see LineReader.read() and LineReader.array()
   public void plotter(String[] args)
+  throws UserInputException
     // Settings:
     boolean verbose = false;
@@ -115,6 +116,8 @@
         System.exit(1);
       double[][] array = LineReader.array(lines);
+      if (array[0].length != 2)
+        throw new UserInputException("file is not two-column: " + name);
       data.add(array);
       addLabel(name, labels);
       Util.verbose("array:\n" + toString(array));
@@ -187,12 +190,13 @@
     return true;
+       Stores the data in the given resulting Collection
        Stores the label as the Series key.
        Stores the filename as the Series description.
   static XYSeriesCollection collection(List<double[][]> data,
-      List<String> labels,
-      List<String> names)
+                                       List<String> labels,
+                                       List<String> names)
     final XYSeriesCollection collection = new XYSeriesCollection();
Modified: usertools/plotter/src/plotter/Plotter.java
--- usertools/plotter/src/plotter/Plotter.java	2012-09-01 00:47:24 UTC (rev 5914)
+++ usertools/plotter/src/plotter/Plotter.java	2012-09-01 14:58:35 UTC (rev 5915)
@@ -10,24 +10,26 @@
   public static void main(String[] args)
-    Getopt plot = new Getopt( "Plotter", args, "bdhs");
-     * Fix this check: Need to check to see if the specify one of the types of plots first
-     * then check to see if the argument counts is correct.
-    if (args.length < 4 )
+    try
-      usage();
+      Getopt plot = new Getopt( "Plotter", args, "bdhs");
+       * Fix this check: Need to check to see if the specify one of the types of plots first
+       * then check to see if the argument counts is correct.
+      if (args.length < 4 )
+        usage();
-    /* Gather the arguments except the first one */
-    String[] tmp = new String[args.length - 1];
-    for( int i = 0; i < tmp.length; ++i )
-      tmp[i] = args[i+1];
-    switch( plot.getopt() )
+      /* Gather the arguments except the first one */
+      String[] tmp = new String[args.length - 1];
+      for( int i = 0; i < tmp.length; ++i )
+        tmp[i] = args[i+1];
+      switch( plot.getopt() )
       /* If asking for a single labeled Y-axis */
       case 's':
@@ -55,7 +57,14 @@
         usage();
+    catch (UserInputException e)
+      System.out.println("input error: ");
+      System.out.println(e.getMessage());
+      // e.printStackTrace();
   static List<String> dataFileList(String[] args, int start)
Added: usertools/plotter/src/plotter/UserInputException.java
--- usertools/plotter/src/plotter/UserInputException.java	                        (rev 0)
+++ usertools/plotter/src/plotter/UserInputException.java	2012-09-01 14:58:35 UTC (rev 5915)
@@ -0,0 +1,12 @@
+package plotter;
+public class UserInputException extends Exception
+  public UserInputException(String s)
+    super(s);
+  private static final long serialVersionUID = 1L;
