[Swift-commit] r5777 - usertools/plotter/src/plotter
    wozniak at ci.uchicago.edu
    Mon Apr 30 11:41:56 CDT 2012
Author: wozniak
Date: 2012-04-30 11:41:55 -0500 (Mon, 30 Apr 2012)
New Revision: 5777
Modified:
   usertools/plotter/src/plotter/Dual.java
Log:
Dual plot features: logarithmic, labels, legend.enabled
Modified: usertools/plotter/src/plotter/Dual.java
--- usertools/plotter/src/plotter/Dual.java	2012-04-30 16:40:09 UTC (rev 5776)
+++ usertools/plotter/src/plotter/Dual.java	2012-04-30 16:41:55 UTC (rev 5777)
@@ -12,6 +12,7 @@
 import org.apache.xmlgraphics.java2d.ps.EPSDocumentGraphics2D;
 import org.jfree.chart.ChartFactory;
 import org.jfree.chart.JFreeChart;
+import org.jfree.chart.axis.LogarithmicAxis;
 import org.jfree.chart.axis.NumberAxis;
 import org.jfree.chart.plot.PlotOrientation;
 import org.jfree.chart.plot.XYPlot;
@@ -27,96 +28,107 @@
 public class Dual
-    static Properties properties;
+  static Properties properties;
-    public static boolean bw = false;
+  static String title = null;
+  static String xlabel = "x";
+  static String ylabel1 = "y1";
+  static String ylabel2 = "y2";
-    static int width = 400;
-    static int height = 400;
+  public static boolean bw = false;
-    // null indicates the value was not set by the user
-    static Double xmin = null;
-    static Double xmax = null;
-    static Double ymin1 = null;
-    static Double ymax1 = null;
-    static Double ymin2 = null;
-    static Double ymax2 = null;
+  static int width = 400;
+  static int height = 400;
+  // null indicates the value was not set by the user
+  static Double xmin = null;
+  static Double xmax = null;
+  static Double ymin1 = null;
+  static Double ymax1 = null;
+  static Double ymin2 = null;
+  static Double ymax2 = null;
+  static String axis_x_type = "normal";
+  static String axis_y1_type = "normal";
+  static String axis_y2_type = "normal";
+  static boolean withLegend = true;
        Args: Lines <properties> <output file> <data file>*
        Reads settings from properties: see scanProperties()
        Produces EPS output file
        Data files are two-columns of numbers each -
        see LineReader.read() and LineReader.array()
-    public void plotter(String[] args)
+  public void plotter(String[] args)
+    // Settings:
+    boolean verbose = false;
+    Getopt g = new Getopt("Dual", args, "v");
+    int c = -1;
+    while ((c = g.getopt()) != -1)
-        // Settings:
-        boolean verbose = false;
+      switch (c)
+        case 'v':
+          verbose = true;
-        Getopt g = new Getopt("Dual", args, "v");
-        int c = -1;
-        while ((c = g.getopt()) != -1)
-            switch (c)
-                case 'v':
-                    verbose = true;
+    Bits.init();
+    Util.verbose(verbose);
-        Bits.init();
-        Util.verbose(verbose);
+    String propFile = args[0];
+    String output = args[1];
+    List<String> names = new ArrayList<String>();
+    for (int i = 2; i < args.length; i++)
+      names.add(args[i]);
-        String propFile = args[0];
-        String output = args[1];
-        List<String> names = new ArrayList<String>();
-        for (int i = 2; i < args.length; i++)
-            names.add(args[i]);
+    String title = null;
+    String xlabel = null;
+    String ylabel1 = null;
+    String ylabel2 = null;
+    List<double[][]> data = new ArrayList<double[][]>();
+    List<String> labels = new ArrayList<String>();
-        String title = null;
-        String xlabel = null;
-        String ylabel1 = null;
-        String ylabel2 = null;
-        List<double[][]> data = new ArrayList<double[][]>();
-        List<String> labels = new ArrayList<String>();
+    properties = new Properties();
+    load(propFile);
+    title = properties.getProperty("title");
+    xlabel = properties.getProperty("xlabel");
+    ylabel1 = properties.getProperty("ylabel1");
+    ylabel2 = properties.getProperty("ylabel2");
-        properties = new Properties();
-        load(propFile);
-        title = properties.getProperty("title");
-        xlabel = properties.getProperty("xlabel");
-        ylabel1 = properties.getProperty("ylabel1");
-        ylabel2 = properties.getProperty("ylabel2");
+    scanProperties();
-        scanProperties();
+    for (String name : names)
+      File file = new File(name);
+      Util.verbose("open: " + file);
+      List<String> lines = null;
+      try
+        lines = LineReader.read(file);
+      catch (FileNotFoundException e)
+        System.err.println("not found: " + file);
+        System.exit(1);
+      double[][] array = LineReader.array(lines);
+      data.add(array);
+      addLabel(name, labels);
+      Util.verbose("array:\n" + toString(array));
-        for (String name : names)
-            File file = new File(name);
-            Util.verbose("open: " + file);
-            List<String> lines = null;
-            try
-                lines = LineReader.read(file);
-            catch (FileNotFoundException e)
-                System.err.println("not found: " + file);
-                System.exit(1);
-            double[][] array = LineReader.array(lines);
-            data.add(array);
-            addLabel(name, labels);
-            Util.verbose("array:\n" + toString(array));
+    XYSeriesCollection[] collections =
+        collections(data, labels, names);
-        XYSeriesCollection[] collections =
-            collections(data, labels, names);
+    plot(collections, title, xlabel, ylabel1, ylabel2, output);
-        plot(collections, title, xlabel, ylabel1, ylabel2, output);
        Generate simple plot
        @param collection The x,y data
        @param title Plot title
@@ -125,263 +137,312 @@
        @param ylabel2 Y label text
        @param output EPS filename
        @return true/false depending if the method completed without error or not
-    public static boolean plot(XYSeriesCollection[] collections,
-                               String title, String xlabel,
-                               String ylabel1, String ylabel2,
-                               String output)
+  public static boolean plot(XYSeriesCollection[] collections,
+                             String title, String xlabel,
+                             String ylabel1, String ylabel2,
+                             String output)
+    EPSDocumentGraphics2D g2d = null;
+    Rectangle2D.Double rectangle = null;
+    OutputStream out = null;
+    try
-        EPSDocumentGraphics2D g2d = null;
-        Rectangle2D.Double rectangle = null;
-        OutputStream out = null;
+      out = new FileOutputStream(output);
+      out = new BufferedOutputStream(out);
-        try
-            out = new FileOutputStream(output);
-            out = new BufferedOutputStream(out);
+      g2d = new EPSDocumentGraphics2D(false);
+      g2d.setGraphicContext
+      (new org.apache.xmlgraphics.java2d.GraphicContext());
-            g2d = new EPSDocumentGraphics2D(false);
-            g2d.setGraphicContext
-                (new org.apache.xmlgraphics.java2d.GraphicContext());
+      rectangle = new Rectangle2D.Double(0, 0, width, height);
-            rectangle = new Rectangle2D.Double(0, 0, width, height);
+      g2d.setupDocument(out, width, height);
+    catch (IOException e)
+      System.err.println("Problem with file: " + output);
+      return false;
-            g2d.setupDocument(out, width, height);
-        catch (IOException e)
-            System.err.println("Problem with file: " + output);
-            return false;
+    JFreeChart chart =
+        ChartFactory.createXYLineChart
+        (title, xlabel, ylabel1, collections[0],
+         PlotOrientation.VERTICAL, withLegend, false, false);
-        final boolean withLegend = true;
+    setupPlot(chart, collections, ylabel1, ylabel2);
+    chart.draw(g2d, rectangle);
-        JFreeChart chart =
-            ChartFactory.createXYLineChart
-            (title, xlabel, ylabel1, collections[0],
-             PlotOrientation.VERTICAL, withLegend, false, false);
+    try
+      g2d.finish();
+    catch (Exception e)
+      System.err.println("Err!" + e);
-        setupPlot(chart, collections, ylabel1, ylabel2);
-        chart.draw(g2d, rectangle);
+    IOUtils.closeQuietly(out);
+    System.out.println("PLOTTED: " + output);
-        try
-            g2d.finish();
-        catch (Exception e)
-            System.err.println("Err!" + e);
+    return true;
-        IOUtils.closeQuietly(out);
-        System.out.println("PLOTTED: " + output);
+  private static void setupPlot(JFreeChart chart,
+                                XYSeriesCollection[] collections,
+                                String ylabel1, String ylabel2)
+    XYPlot plot = chart.getXYPlot();
+    XYLineAndShapeRenderer renderer1 = new XYLineAndShapeRenderer();
+    XYLineAndShapeRenderer renderer2 = new XYLineAndShapeRenderer();
-        return true;
+    int count = plot.getSeriesCount();
+    if (bw)
+      for (int i = 0; i < count; i++)
+        renderer1.setSeriesPaint(i, Color.BLACK);
+        renderer2.setSeriesPaint(i, Color.BLACK);
-    private static void setupPlot(JFreeChart chart,
-                                  XYSeriesCollection[] collections,
-                                  String ylabel1, String ylabel2)
-        XYPlot plot = chart.getXYPlot();
-        XYLineAndShapeRenderer renderer1 = new XYLineAndShapeRenderer();
-        XYLineAndShapeRenderer renderer2 = new XYLineAndShapeRenderer();
+    Series series1 = collections[0].getSeries(0);
+    if (! showShape(series1.getDescription()))
+      renderer1.setSeriesShapesVisible(0, false);
+    Series series2 = collections[1].getSeries(0);
+    if (! showShape(series2.getDescription()))
+      renderer2.setSeriesShapesVisible(1, false);
-        int count = plot.getSeriesCount();
-        if (bw)
-            for (int i = 0; i < count; i++)
-                renderer1.setSeriesPaint(i, Color.BLACK);
-                renderer2.setSeriesPaint(i, Color.BLACK);
+    Plots.setupLegend(chart, properties);
+    setAxes(plot, collections[1]);
+    plot.setRenderer(0, renderer1);
+    plot.setRenderer(1, renderer2);
+    plot.setBackgroundPaint(Color.WHITE);
-        Series series1 = collections[0].getSeries(0);
-        if (! showShape(series1.getDescription()))
-            renderer1.setSeriesShapesVisible(0, false);
-        Series series2 = collections[1].getSeries(0);
-        if (! showShape(series2.getDescription()))
-            renderer2.setSeriesShapesVisible(1, false);
+  static void setAxes(XYPlot plot,
+                      XYSeriesCollection collection)
+    setAxisTypes(plot);
+    plot.setDataset(1, collection);
-        Plots.setupLegend(chart, properties);
-        setAxes(plot, ylabel1, ylabel2, collections[1]);
-        plot.setRenderer(0, renderer1);
-        plot.setRenderer(1, renderer2);
-        plot.setBackgroundPaint(Color.WHITE);
+    // Actual values: modify if necessary
+    double axmin, axmax, aymin1, aymax1, aymin2, aymax2;
+    if (xmin != null || xmax != null)
+      NumberAxis axis = new NumberAxis();
+      plot.setDomainAxis(axis);
+      Range range = axis.getRange();
+      axmin = range.getLowerBound();
+      axmax = range.getUpperBound();
+      if (xmin != null) axmin = xmin;
+      if (xmax != null) axmax = xmax;
+      axis.setRange(axmin, axmax);
-    static void setAxes(XYPlot plot, String ylabel1, String ylabel2,
-                        XYSeriesCollection collection)
+    // Left Y axis
+    if (ymin1 != null || ymax1 != null)
-        plot.setDataset(1, collection);
+      NumberAxis axis = (NumberAxis) plot.getRangeAxis(0);
+      aymin1 = range.getLowerBound();
+      aymax1 = range.getUpperBound();
+      if (ymin1 != null) aymin1 = ymin1;
+      if (ymax1 != null) aymax1 = ymax1;
+      axis.setRange(aymin1, aymax1);
-        // Actual values: modify if necessary
-        double axmin, axmax, aymin1, aymax1, aymin2, aymax2;
+    // Right Y axis setup
+    Font font = plot.getRangeAxis().getLabelFont();
+    final NumberAxis rightAxis = new NumberAxis(ylabel2);
+    rightAxis.setLabelFont(font);
+    plot.setRangeAxis(1, rightAxis);
-        if (xmin != null || xmax != null)
-            NumberAxis axis = new NumberAxis();
-            plot.setDomainAxis(axis);
-            Range range = axis.getRange();
-            axmin = range.getLowerBound();
-            axmax = range.getUpperBound();
-            if (xmin != null) axmin = xmin;
-            if (xmax != null) axmax = xmax;
-            axis.setRange(axmin, axmax);
+    // Right Y axis
+    if (ymin2 != null || ymax2 != null)
+      Range range = rightAxis.getRange();
+      aymin2 = range.getLowerBound();
+      aymax2 = range.getUpperBound();
+      if (ymin2 != null) aymin2 = ymin2;
+      if (ymax2 != null) aymax2 = ymax2;
+      rightAxis.setRange(aymin2, aymax2);
-        // Left Y axis
-        if (ymin1 != null || ymax1 != null)
-            NumberAxis axis = new NumberAxis(ylabel1);
-            plot.setRangeAxis(0, axis);
-            aymin1 = range.getLowerBound();
-            aymax1 = range.getUpperBound();
-            if (ymin1 != null) aymin1 = ymin1;
-            if (ymax1 != null) aymax1 = ymax1;
-            axis.setRange(aymin1, aymax1);
+    plot.mapDatasetToRangeAxis(0, 0);
+    plot.mapDatasetToRangeAxis(1, 1);
+    plot.configureRangeAxes();
-        // Right Y axis setup
-        Font font = plot.getRangeAxis().getLabelFont();
-        final NumberAxis rightAxis = new NumberAxis(ylabel2);
-        rightAxis.setLabelFont(font);
-        plot.setRangeAxis(1, rightAxis);
+  static void setAxisTypes(XYPlot plot)
+    NumberAxis axis_x;
+    if (axis_x_type.equals("normal"))
+      axis_x = new NumberAxis(xlabel);
+    else if (axis_x_type.equals("logarithmic"))
+      axis_x = new LogarithmicAxis(xlabel);
+    else
+      throw new RuntimeException
+      ("Invalid axis.x type: " + axis_x_type);
-        // Right Y axis
-        if (ymin2 != null || ymax2 != null)
-            Range range = rightAxis.getRange();
-            aymin2 = range.getLowerBound();
-            aymax2 = range.getUpperBound();
-            if (ymin2 != null) aymin2 = ymin2;
-            if (ymax2 != null) aymax2 = ymax2;
-            rightAxis.setRange(aymin2, aymax2);
-        plot.mapDatasetToRangeAxis(0, 0);
-        plot.mapDatasetToRangeAxis(1, 1);
-        plot.configureRangeAxes();
+    NumberAxis axis_y1;
+    if (axis_y1_type.equals("normal"))
+      axis_y1 = new NumberAxis(ylabel1);
+    else if (axis_y1_type.equals("logarithmic"))
+      axis_y1 = new LogarithmicAxis(ylabel1);
+    else
+      ("unknown axis.y1: " + axis_y1_type);
-    static XYSeriesCollection[] collections(List<double[][]> data,
-                                            List<String> labels,
-                                            List<String> names)
+    NumberAxis axis_y2;
+    if (axis_y2_type.equals("normal"))
+      axis_y2 = new NumberAxis(ylabel2);
+    else if (axis_y2_type.equals("logarithmic"))
+      axis_y2 = new LogarithmicAxis(ylabel2);
+    else
+      ("unknown axis.y2: " + axis_y2_type);
+    plot.setDomainAxis(axis_x);
+    plot.setRangeAxis(0, axis_y1);
+    plot.setRangeAxis(1, axis_y2);
+  static XYSeriesCollection[] collections(List<double[][]> data,
+                                          List<String> labels,
+                                          List<String> names)
+    final XYSeriesCollection[] result = new XYSeriesCollection[2];
+    result[0] = new XYSeriesCollection();
+    result[1] = new XYSeriesCollection();
+    int count = 0;
+    for (int i = 0; i < 2; i++)
-        final XYSeriesCollection[] result = new XYSeriesCollection[2];
-        result[0] = new XYSeriesCollection();
-        result[1] = new XYSeriesCollection();
+      double[][] d = data.get(i);
+      String label = "data: " + count;
+      try
+        String s = labels.get(count);
+        if( !(s.equals("")) )
+          label = s;
+      catch (IndexOutOfBoundsException e)
-        int count = 0;
-        for (int i = 0; i < 2; i++)
-            double[][] d = data.get(i);
-            String label = "data: " + count;
-            try
-                String s = labels.get(count);
-                if( !(s.equals("")) )
-                    label = s;
-            catch (IndexOutOfBoundsException e)
+      Util.verbose( "label: "+label );
+      XYSeries series = new XYSeries(label);
+      for (int j = 0; j < d.length; j++)
+        series.add(d[j][0], d[j][1]);
-            Util.verbose( "label: "+label );
-            XYSeries series = new XYSeries(label);
-            for (int j = 0; j < d.length; j++)
-                series.add(d[j][0], d[j][1]);
-            series.setDescription(names.get(count));
-            result[i].addSeries(series);
-            count++;
-        return result;
+      series.setDescription(names.get(count));
+      result[i].addSeries(series);
+      count++;
+    return result;
-    static void load(String propFile)
+  static void load(String propFile)
+    try
-        try
-            if (propFile.equals("-"))
-                properties.load(System.in);
-            else
-                properties.load(new FileInputStream(propFile));
-            System.err.println(e);
-            System.exit(1);
-            e.printStackTrace();
-            System.exit(1);
+      if (propFile.equals("-"))
+        properties.load(System.in);
+      else
+        properties.load(new FileInputStream(propFile));
+      System.err.println(e);
+      System.exit(1);
+      e.printStackTrace();
+      System.exit(1);
-       Various plot properties.  All are currently optional
+     Various plot properties.  All are currently optional
-       Example.
-       Assume you want to plot a two-column table in file.data.
-       The first column is the x values and the second column
-       is the y values.  See LineReader for details.
+     Example.
+     Assume you want to plot a two-column table in file.data.
+     The first column is the x values and the second column
+     is the y values.  See LineReader for details.
-       Your properties may include:
-       title = Plot
-       xlabel = size
-       ylabel = speed
-       label.file.data = legend text
-       width (output image width)
-       height (output image height)
-       xmin, xmax, ymin1, ymax1, ymin2, ymax2
-       (auto-selected if not given)
-       bw (Black and white, true/false, default false)
-    static void scanProperties()
-        String tmp;
-        tmp = properties.getProperty("width");
-        if (tmp != null)
-            width = Integer.parseInt(tmp.trim());
-        tmp = properties.getProperty("height");
-        if (tmp != null)
-            height = Integer.parseInt(tmp.trim());
-        tmp = properties.getProperty("xmin");
-        if (tmp != null)
-            xmin = Double.parseDouble(tmp);
-        tmp = properties.getProperty("xmax");
-        if (tmp != null)
-            xmax = Double.parseDouble(tmp);
-        tmp = properties.getProperty("ymin1");
-        if (tmp != null)
-            ymin1 = Double.parseDouble(tmp);
-        tmp = properties.getProperty("ymax1");
-        if (tmp != null)
-            ymax1 = Double.parseDouble(tmp);
-        tmp = properties.getProperty("ymin2");
-        if (tmp != null)
-            ymin2 = Double.parseDouble(tmp);
-        tmp = properties.getProperty("ymax2");
-        if (tmp != null)
-            ymax2 = Double.parseDouble(tmp);
+     Your properties may include:
+     title = title string
+     xlabel,ylabel1,ylabel2 = title string
+     label.file.data = legend text
+     width (output image width)
+     height (output image height)
+     xmin, xmax, ymin1, ymax1, ymin2, ymax2
+     (auto-selected if not given)
+     bw (Black and white, true/false, default false)
+     legend.enabled (true/false, default true)
+     axis.x,axis.y1,axis.y2 (normal/logarithmic, default normal)
+  static void scanProperties()
+    String tmp;
+    tmp = properties.getProperty("width");
+    if (tmp != null)
+      width = Integer.parseInt(tmp.trim());
+    tmp = properties.getProperty("height");
+    if (tmp != null)
+      height = Integer.parseInt(tmp.trim());
+    tmp = properties.getProperty("xmin");
+    if (tmp != null)
+      xmin = Double.parseDouble(tmp);
+    tmp = properties.getProperty("xmax");
+    if (tmp != null)
+      xmax = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymin1");
+    if (tmp != null)
+      ymin1 = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymax1");
+    if (tmp != null)
+      ymax1 = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymin2");
+    if (tmp != null)
+      ymin2 = Double.parseDouble(tmp);
+    tmp = properties.getProperty("ymax2");
+    if (tmp != null)
+      ymax2 = Double.parseDouble(tmp);
+    tmp = properties.getProperty("axis.x");
+    if (tmp != null)
+      axis_x_type = tmp;
+    tmp = properties.getProperty("axis.y1");
+    if (tmp != null)
+      axis_y1_type = tmp;
+    tmp = properties.getProperty("axis.y2");
+    if (tmp != null)
+      axis_y2_type = tmp;
+    tmp = properties.getProperty("bw");
+    if (tmp != null)
+      bw = Boolean.parseBoolean(tmp);
+    tmp = properties.getProperty("legend.enabled");
+    if (tmp != null)
+      withLegend = Boolean.parseBoolean(tmp);
-        tmp = properties.getProperty("bw");
-        if (tmp != null)
-            bw = Boolean.parseBoolean(tmp);
        Arrays.copyOfRange is a Java 1.6 feature.
        This has the same signature.
       static String[] select(String[] s, int p, int q)
       String[] result = new String[q-p];
@@ -390,41 +451,41 @@
       result[j++] = s[i];
       return result;
-    static void addLabel(String name,
-                         List<String> labels)
-        String label = properties.getProperty("label."+name);
-        if (label == null)
-            label = "";
-        labels.add(label);
+  static void addLabel(String name,
+                       List<String> labels)
+    String label = properties.getProperty("label."+name);
+    if (label == null)
+      label = "";
+    labels.add(label);
-    static boolean showShape(String name)
-        // System.out.println(name);
-        String mode = properties.getProperty("shape."+name);
-        // System.out.println(mode);
-        if ("none".equals(mode))
-            return false;
-        return true;
+  static boolean showShape(String name)
+    // System.out.println(name);
+    String mode = properties.getProperty("shape."+name);
+    // System.out.println(mode);
+    if ("none".equals(mode))
+      return false;
+    return true;
-    static String toString(double[][] array)
+  static String toString(double[][] array)
+    StringBuilder sb = new StringBuilder();
+    for (int i = 0; i < array.length; i++)
-        StringBuilder sb = new StringBuilder();
-        for (int i = 0; i < array.length; i++)
-            double[] row = array[i];
-            for (int j = 0; j < row.length; j++)
-                sb.append(array[i][j]);
-                if (j < row.length-1)
-                    sb.append(" ");
-            sb.append("\n");
-        return sb.toString();
+      double[] row = array[i];
+      for (int j = 0; j < row.length; j++)
+        sb.append(array[i][j]);
+        if (j < row.length-1)
+          sb.append(" ");
+      sb.append("\n");
+    return sb.toString();
More information about the Swift-commit
