[Swift-commit] r5776 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu
Mon Apr 30 11:40:09 CDT 2012
Author: wozniak
Date: 2012-04-30 11:40:09 -0500 (Mon, 30 Apr 2012)
New Revision: 5776
Modified:
usertools/plotter/src/plotter/Lines.java
Log:
Rearrange variables
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java 2012-04-29 04:26:35 UTC (rev 5775)
+++ usertools/plotter/src/plotter/Lines.java 2012-04-30 16:40:09 UTC (rev 5776)
@@ -1,3 +1,4 @@
package plotter;
import gnu.getopt.Getopt;
@@ -87,9 +88,6 @@
properties = new Properties();
load(propFile);
- title = properties.getProperty("title");
- xlabel = properties.getProperty("xlabel");
- ylabel = properties.getProperty("ylabel");
scanProperties();
@@ -309,10 +307,14 @@
xmin, xmax, ymin, ymax (auto-selected if not given)
bw (Black and white, true/false, default false)
legend.enabled (true/false, default true)
+ axis.x, axis.y (normal/logarithmic, default normal)
static void scanProperties()
String tmp;
+ title = properties.getProperty("title");
+ xlabel = properties.getProperty("xlabel");
+ ylabel = properties.getProperty("ylabel");
tmp = properties.getProperty("width");
if (tmp != null)
width = Integer.parseInt(tmp.trim());
More information about the Swift-commit
