[Swift-commit] r5149 - trunk/docs/userguide
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Wed Sep 21 11:38:31 CDT 2011
Author: wozniak
Date: 2011-09-21 11:38:31 -0500 (Wed, 21 Sep 2011)
New Revision: 5149
Modified:
   trunk/docs/userguide/cdm
Log:
Clean up CDM usage guide
Modified: trunk/docs/userguide/cdm
--- trunk/docs/userguide/cdm	2011-09-21 16:37:55 UTC (rev 5148)
+++ trunk/docs/userguide/cdm	2011-09-21 16:38:31 UTC (rev 5149)
@@ -1,28 +1,34 @@
-Collective Data Management
-Overview
-. The user specifies a CDM policy in a file, customarily fs.data.
-. fs.data is given to Swift on the command line.
-. The Swift data module (org.globus.swift.data) is informed of the CDM policy.
-. At job launch time, the VDL Karajan code queries the CDM policy,
+== Collective Data Management
+=== Description
+Collective Data Management (CDM) is a set of optimizations in Swift to
+improve data access patterns by Swift.  In particular, it can be used
+to avoid data staging (extra file copies) on an HPC system or cluster
+with a shared file system.
+=== Usage Overview
+. The user specifies a CDM policy in a file, customarily +fs.data+.
+. +fs.data+ is given to Swift on the command line.
+. The Swift data module is informed of the CDM policy.
+. At job launch time, for each file, the Swift mechanics query the CDM policy,
    .. altering the file staging phase, and
-   .. sending fs.data to the compute site.
+   .. sending +fs.data+ to the compute site.
 . At job run time, the Swift wrapper script
-   .. consults a Perl script to obtain policy, and
+   .. consults a Perl script to obtain policy from +fs.data+, and
    .. uses wrapper extensions to modify data movement.
 . Similarly, stage out can be changed.
 .Command line
 $ swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
-CDM policy file format
-.Example
+=== CDM policy file format
+==== Example
 # Describe CDM for my job
 property GATHER_LIMIT 1
@@ -35,169 +41,167 @@
 . A directive, either rule or property
 . A rule has:
-   .. A regular expression
+   .. A regular expression to match on the file name
    .. A policy token
    .. Additional policy-specific arguments
 . A property has
    .. A policy property token
    .. The token value
-. Comments with # .
+. Comments with +#+ .
 . Blank lines are ignored.
+==== Notes
-.Notes
-. The policy file is used as a lookup database by Swift and Perl methods.
-. For example, a lookup with the database above given the argument input.txt would result in the Direct policy.
+. The policy file is used as a lookup database by Swift and Perl
+methods.  Thus, one should only use basic features such as +.*+ .
+. Swift treats file names as URLs, while the wrapper script treats
+them as Unix file names.  Thus, one should use a wildcard in the
+beginning of each file name.
+. For example, a lookup with the database above given the argument
++input.txt+ would result in the DIRECT policy.
 . If the lookup does not succeed, the result is DEFAULT.
- . Policies are listed as subclasses of org.globus.swift.data.policy.Policy .
-Policy Descriptions
-.Default
+=== Policy Descriptions
+==== DEFAULT
-* Just use file staging as provided by Swift/CoG.  Identical to behavior if no CDM file is given.
+* Just use file staging as provided by Swift.
+Identical to behavior if no CDM file is given.
-.Broadcast
+==== DIRECT
-rule .*xfile*.data BROADCAST /dev/shm
-* The input files matching the pattern will be stored in the given directory, an LFS location, with links in the job directory.
-* On the BG/P, this will make use of the f2cn tool.
-* On machines not implementing an efficient broadcast, we will just ensure correctness.  For example, on a workstation, the location could be in a /tmp RAM FS.
-.Direct
 rule .*input.txt DIRECT /gpfs/scratch/wozniak/
 * Allows for direct I/O to the parallel FS without staging.
-* The input files matching the pattern must already exist in the given directory, a GFS location.  Links will be placed in the job directory.
-* The output files matching the pattern will be stored in the given directory, with links in the job directory.
-* Example: In the rule above, the Swift-generated file name ./data/input.txt would be accessed by the user job in /gpfs/homes/wozniak/data/input.txt .
+* The input files matching the pattern must already exist in the
+given directory, a shared file system location.
+Links will be placed in the job directory.
+* The output files matching the pattern will be stored in the given
+directory, with links in the job directory.
+* Example: In the rule above, the Swift-generated file name
++./data/input.txt+ would be accessed by the user job in
++/gpfs/homes/wozniak/data/input.txt+ .
-.Local
+==== LOCAL
-rule .*input.txt LOCAL dd /gpfs/homes/wozniak/data obs=64K
+rule .*input.txt LOCAL dd /gpfs/homes/user/data obs=64K
 * Allows for client-directed input copy to the compute node.
-* The user may specify cp or dd as the input transfer program.
-* The input files matching the pattern must already exist in the given directory, a GFS location.  Copies will be placed in the job directory.
-* Argument list: [tool] [GFS directory] [tool arguments]*
+* The user may specify +cp+ or +dd+ as the input transfer program.
+Copies will be placed in the job directory for use by the user job.
+* Argument list: [tool] [directory] [tool arguments]*
+// .Gather
+// property GATHER_LIMIT 500000000 # 500 MB
+// property GATHER_DIR /dev/shm/gather
+// property GATHER_TARGET /gpfs/wozniak/data/gather_target
+// rule .*.output.txt GATHER
-.Gather
-property GATHER_LIMIT 500000000 # 500 MB
-property GATHER_DIR /dev/shm/gather
-property GATHER_TARGET /gpfs/wozniak/data/gather_target
-rule .*.output.txt GATHER
+// * The output files matching the pattern will be present to tasks in the job directory as usual but noted in a _swiftwrap shell array GATHER_OUTPUT.
+// * The GATHER_OUTPUT files will be cached in the GATHER_DIR, an LFS location.
+// * The cache will be flushed when a job ends if a du on GATHER_DIR exceeds GATHER_LIMIT.
+// * As the cache fills or on stage out, the files will be bundled into randomly named tarballs in GATHER_TARGET, a GFS location.
+// * If the compute node is an SMP, GATHER_DIR is a shared resource.  It is protected by the link file GATHER_DIR/.cdm.lock .
+// * Unpacking the tarballs in GATHER_TARGET will produce the user-specified filenames.
-* The output files matching the pattern will be present to tasks in the job directory as usual but noted in a _swiftwrap shell array GATHER_OUTPUT.
-* The GATHER_OUTPUT files will be cached in the GATHER_DIR, an LFS location.
-* The cache will be flushed when a job ends if a du on GATHER_DIR exceeds GATHER_LIMIT.
-* As the cache fills or on stage out, the files will be bundled into randomly named tarballs in GATHER_TARGET, a GFS location.
-* If the compute node is an SMP, GATHER_DIR is a shared resource.  It is protected by the link file GATHER_DIR/.cdm.lock .
-* Unpacking the tarballs in GATHER_TARGET will produce the user-specified filenames.
+// .Summary
-.Summary
+// . Files created by application
+// . Acquire lock
+// . Move files to cache
+// . Check cache size
+// . If limit exceeded, move all cache files to outbox
+// . Release lock
+// . If limit was exceeded, stream outbox as tarball to target
-. Files created by application
-. Acquire lock
-. Move files to cache
-. Check cache size
-. If limit exceeded, move all cache files to outbox
-. Release lock
-. If limit was exceeded, stream outbox as tarball to target
+// .Notes
-.Notes
+// * Gather required quite a bit of shell functionality to manage the lock, etc. This is placed in cdm_lib.sh .
+// * vdl_int.k needed an additional task submission (cdm_cleanup.sh) to perform the final flush at workflow completion time .  This task also uses cdm_lib.sh .
-* Gather required quite a bit of shell functionality to manage the lock, etc. This is placed in cdm_lib.sh .
-* vdl_int.k needed an additional task submission (cdm_cleanup.sh) to perform the final flush at workflow completion time .  This task also uses cdm_lib.sh .
+// VDL/Karajan processing
+// . CDM functions are available in Karajan via the cdm namespace.
+// . These functions are defined in org.globus.swift.data.Query .
+// . If CDM is enabled, VDL skips file staging for files unless the policy is DEFAULT.
-VDL/Karajan processing
-. CDM functions are available in Karajan via the cdm namespace.
-. These functions are defined in org.globus.swift.data.Query .
-. If CDM is enabled, VDL skips file staging for files unless the policy is DEFAULT.
+// Swift wrapper CDM routines
+// . The cdm.pl script is shipped to the compute node if CDM is enabled.
+// . When linking in inputs, CDM is consulted by _swiftwrap:cdm_lookup().
+// . The cdm_action() shell function handles CDM methods, typically just producing a link.
-Swift wrapper CDM routines
-. The cdm.pl script is shipped to the compute node if CDM is enabled.
-. When linking in inputs, CDM is consulted by _swiftwrap:cdm_lookup().
-. The cdm_action() shell function handles CDM methods, typically just producing a link.
+// Test cases
-Test cases
+// . Simple test cases are in:
+//       https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/cdm-direct and
+//       https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/all-pairs
+// . Do a:
+//       mkdir cdm
+//       cd cdm
+//       svn co https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts
+// . In cdm-direct, run:
+//       source ./setup.sh local local local
+// . Run workflow:
+//       swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
+// . Note that staging is skipped for input.txt
+//       policy: file://localhost/input.txt : DIRECT
+//       FILE_STAGE_IN_START file=input.txt ...
+//       FILE_STAGE_IN_SKIP file=input.txt policy=DIRECT
+//       FILE_STAGE_IN_END file=input.txt ...
+// . In the wrapper output, the input file is handled by CDM functionality:
+//       Progress  2010-01-21 13:50:32.466572727-0600  LINK_INPUTS
+//       CDM_POLICY: DIRECT /homes/wozniak/cdm/scripts/cdm-direct
+//       CDM: jobs/t/cp_sh-tkul4nmj input.txt DIRECT /homes/wozniak/cdm/scripts/cdm-direct
+//       CDM[DIRECT]: Linking jobs/t/cp_sh-tkul4nmj/input.txt to /homes/wozniak/cdm/scripts/cdm-direct/input.txt
+//       Progress  2010-01-21 13:50:32.486016708-0600  EXECUTE
+// . all-pairs is quite similar but uses more policies.
-. Simple test cases are in:
-      https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/cdm-direct and
-      https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/all-pairs
-. Do a:
-      mkdir cdm
-      cd cdm
-      svn co https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts
-. In cdm-direct, run:
-      source ./setup.sh local local local
-. Run workflow:
-      swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
-. Note that staging is skipped for input.txt
-      policy: file://localhost/input.txt : DIRECT
-      FILE_STAGE_IN_START file=input.txt ...
-      FILE_STAGE_IN_SKIP file=input.txt policy=DIRECT
-      FILE_STAGE_IN_END file=input.txt ...
-. In the wrapper output, the input file is handled by CDM functionality:
-      Progress  2010-01-21 13:50:32.466572727-0600  LINK_INPUTS
-      CDM_POLICY: DIRECT /homes/wozniak/cdm/scripts/cdm-direct
-      CDM: jobs/t/cp_sh-tkul4nmj input.txt DIRECT /homes/wozniak/cdm/scripts/cdm-direct
-      CDM[DIRECT]: Linking jobs/t/cp_sh-tkul4nmj/input.txt to /homes/wozniak/cdm/scripts/cdm-direct/input.txt
-      Progress  2010-01-21 13:50:32.486016708-0600  EXECUTE
-. all-pairs is quite similar but uses more policies.
+// PTMap case
+// . Start with vanilla PTMap:
+//    .. cd cdm
+//    .. mkdir apps
+//    .. cd apps
+//    .. https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/apps/ptmap
+// . Source setup.sh
+// . Use start.sh, which
+//    .. applies CDM policy from fs.local.data
-PTMap case
-. Start with vanilla PTMap:
-   .. cd cdm
-   .. mkdir apps
-   .. cd apps
-   .. https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/apps/ptmap
-. Source setup.sh
-. Use start.sh, which
-   .. applies CDM policy from fs.local.data
+// CDM site-aware policy file format
-CDM site-aware policy file format
+// Example
-Example
+// #Describe CDM for my job
+// #Use DIRECT and BROADCAST if on cluster1, else use DEFAULT behavior
+// property GATHER_LIMIT 1
+// rule cluster1 .*input.txt DIRECT /gpfs/homes/wozniak/data
+// rule cluster1 .*xfile*.data BROADCAST /dev/shm
+// rule ANYWHERE .* DEFAULT
-#Describe CDM for my job
-#Use DIRECT and BROADCAST if on cluster1, else use DEFAULT behavior
-property GATHER_LIMIT 1
-rule cluster1 .*input.txt DIRECT /gpfs/homes/wozniak/data
-rule cluster1 .*xfile*.data BROADCAST /dev/shm
-rule ANYWHERE .* DEFAULT
+// The lines contain:
-The lines contain:
-. A directive, either rule or property
-. A rule has:
-   .. A regular expression for site matchin
-   .. A regular expression for filename matching
-   .. A policy token
-   .. Additional policy-specific arguments
-. A property has
-   .. A policy property token
-   .. The token value
-. Blank lines are ignored.
+// . A directive, either rule or property
+// . A rule has:
+//    .. A regular expression for site matchin
+//    .. A regular expression for filename matching
+//    .. A policy token
+//    .. Additional policy-specific arguments
+// . A property has
+//    .. A policy property token
+//    .. The token value
+// . Comments with # .
+// . Blank lines are ignored.
