[Swift-commit] r5148 - trunk/docs
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Wed Sep 21 11:37:55 CDT 2011
Author: wozniak
Date: 2011-09-21 11:37:55 -0500 (Wed, 21 Sep 2011)
New Revision: 5148
Modified:
   trunk/docs/build_docs.sh
Log:
Allow user to suppress creation of PDFs via -d
Modified: trunk/docs/build_docs.sh
--- trunk/docs/build_docs.sh	2011-09-21 16:33:50 UTC (rev 5147)
+++ trunk/docs/build_docs.sh	2011-09-21 16:37:55 UTC (rev 5148)
@@ -1,5 +1,7 @@
 #!/bin/bash
+# Usage: See usage() for usage
 # crash: Report a problem and exit
 crash()
@@ -8,18 +10,44 @@
     exit 1
-# Change file permissions to values set below
+# Output directory mode
 CHMOD_DIRECTORY_MODE="775"
+# Output file mode
 CHMOD_FILE_MODE="664"
+# Output group
 GROUP="vdl2-svn"
+# Make PDFs iff MAKE_PDF=1
+MAKE_PDF=1
-# Verify correct arguments
-if [ -z "$1" ] || [ "$1" == "-h" ] || [ "$1" == "-help" ]; then
-   crash "Usage: ./build_docs.sh /path/to/copy/output"
-fi
+# See getopts loop below for options
+usage()
+  echo "Usage: ./build_docs.sh <opts> <installation directory>"
+while getopts "dh" OPTION
+do
+  case ${OPTION} in
+    d)
+      MAKE_PDF=0
+      shift
+    h)
+      usage
+      exit 0
+  esac
+done
 INSTALLATION_DIRECTORY=$1
+if [[ $INSTALLATION_DIRECTORY == "" ]]
+then
+  echo "Not given: installation directory"
+  usage
+  exit 1
+fi
 # Create installation directory if needed
 if [ ! -d "$INSTALLATION_DIRECTORY" ]; then
    mkdir $INSTALLATION_DIRECTORY || crash "Unable to create directory $INSTALLATION_DIRECTORY"
@@ -43,9 +71,16 @@
    for file in $FILES
    do
       echo Converting $directory"$file" to HTML
-      asciidoc -a toc -a toclevels=2 -a max-width=750px -a textwidth=80 -a stylesheet=$(pwd)/../stylesheets/asciidoc.css $file
-      echo Converting $directory"$file" to PDF
-      a2x --format=pdf --no-xmllint $file
+      asciidoc -a toc -a toclevels=2                            \
+               -a max-width=750px                               \
+               -a textwidth=80                                  \
+               -a stylesheet=$(pwd)/../stylesheets/asciidoc.css \
+               $file
+      if (( MAKE_PDF ))
+      then
+        echo Converting $directory"$file" to PDF
+        a2x --format=pdf --no-xmllint $file
+      fi
    done
    if [ ! -d "$INSTALLATION_DIRECTORY/$VERSION" ]; then
