[Swift-commit] r5140 - trunk/src/org/griphyn/vdl/engine
hategan at ci.uchicago.edu
Tue Sep 20 17:28:37 CDT 2011
Author: hategan
Date: 2011-09-20 17:28:37 -0500 (Tue, 20 Sep 2011)
New Revision: 5140
Modified:
trunk/src/org/griphyn/vdl/engine/Karajan.java
trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
Log:
fixed capitalization issues (added definitions for relevant functions) and added deprecation warnings when using the wrong capitalization
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java 2011-09-20 22:27:00 UTC (rev 5139)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java 2011-09-20 22:28:37 UTC (rev 5140)
@@ -155,9 +155,28 @@
protected StringTemplate template(String name) {
return m_templates.getInstanceOf(name);
+ private void warn(XmlObject obj, String msg) {
+ msg = "Warning: " + msg + ", at " + getLine(obj.getDomNode());
+ logger.info(msg);
+ System.err.println(msg);
- private void processImports(Program prog) throws CompilationException {
+ private String getLine(Node n) {
+ if (n == null) {
+ return "line unknown";
+ Node src = n.getAttributes().getNamedItem("src");
+ if (src == null) {
+ return getLine(n.getParentNode());
+ else {
+ return src.getNodeValue();
+ private void processImports(Program prog) throws CompilationException {
Imports imports = prog.getImports();
if(imports!=null) {
logger.debug("Processing SwiftScript imports");
@@ -374,7 +393,7 @@
for (int i = 0; i < name.length(); i++) {
char c = name.charAt(i);
if (Character.isUpperCase(c)) {
- sb.append('-');
+ sb.append('_');
sb.append(Character.toLowerCase(c));
@@ -631,6 +650,11 @@
new HashMap<String, FormalArgumentSignature>();
ProcedureSignature proc = proceduresMap.get(procName);
+ if (proc.isDeprecated()) {
+ warn(call, "Procedure " + procName + " is deprecated");
StringTemplate callST;
if(proc.getInvocationMode() == ProcedureSignature.INVOCATION_USERDEFINED) {
callST = template("callUserDefined");
@@ -795,7 +819,7 @@
- public void iterateStat(Iterate iterate, VariableScope scope) throws CompilationException {
+ public void iterateStat(Iterate iterate, VariableScope scope) throws CompilationException {
VariableScope loopScope = new VariableScope(this, scope, VariableScope.ENCLOSURE_LOOP);
VariableScope innerScope = new VariableScope(this, loopScope, VariableScope.ENCLOSURE_LOOP);
@@ -1350,6 +1374,9 @@
if (funcSignature != null) {
/* Functions have only one output parameter */
st.setAttribute("datatype", funcSignature.getOutputArray(0).getType());
+ if (funcSignature.isDeprecated()) {
+ warn(f, "Function " + name + " is deprecated");
} else
throw new CompilationException("Function " + name + " is not defined.");
return st;
@@ -1371,6 +1398,8 @@
throw new CompilationException("Procedure " + name + " must have exactly one " +
"return value to be used in an expression.");
+ warn(c, "Procedure " + name + " is deprecated");
StringTemplate call = template("callexpr");
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2011-09-20 22:27:00 UTC (rev 5139)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java 2011-09-20 22:28:37 UTC (rev 5140)
@@ -16,6 +16,8 @@
private boolean anyNumOfInputArgs;
private boolean anyNumOfOutputArgs; /* this is maybe unnecessary*/
private int invocationMode;
+ private boolean deprecated;
/* Procedure is built in to Swift. */
static public final int INVOCATION_INTERNAL = 600;
@@ -114,64 +116,47 @@
public int getInvocationMode() {
return this.invocationMode;
+ public boolean isDeprecated() {
+ return deprecated;
+ public void setDeprecated(boolean deprecated) {
+ this.deprecated = deprecated;
+ public static final String STRING = "string";
+ public static final String STRING_ARRAY = "string[]";
+ public static final String INT = "int";
+ public static final String FLOAT = "float";
+ public static final String BOOLEAN = "boolean";
+ public static final String ANY = "-any";
+ public static final String VARGS = "-vargs";
public static Map<String,ProcedureSignature>
makeProcedureSignatures() {
Map<String,ProcedureSignature> proceduresMap =
new HashMap<String,ProcedureSignature>();
+ add(proceduresMap, "readData", returns(ANY), args(ANY));
+ add(proceduresMap, "readData2", returns(ANY), args(ANY));
+ add(proceduresMap, "readStructured", returns(ANY), args(ANY));
+ add(proceduresMap, "trace", returns(), args(VARGS));
+ add(proceduresMap, "tracef", returns(), args(VARGS));
+ add(proceduresMap, "fprintf", returns(), args(VARGS));
+ add(proceduresMap, "assert", returns(), args(VARGS));
+ add(proceduresMap, "writeData", returns(ANY), args(ANY));
+ // backwards compatible; to be removed in the future
+ addDeprecated(proceduresMap, "readdata", returns(ANY), args(ANY));
+ addDeprecated(proceduresMap, "readdata2", returns(ANY), args(ANY));
+ addDeprecated(proceduresMap, "readstructured", returns(ANY), args(ANY));
+ addDeprecated(proceduresMap, "writedata", returns(ANY), args(ANY));
+ for (Map.Entry<String, ProcedureSignature> e : proceduresMap.entrySet()) {
+ e.getValue().setInvocationMode(INVOCATION_INTERNAL);
- ProcedureSignature readData = new ProcedureSignature("readData");
- FormalArgumentSignature rdInputArg = new FormalArgumentSignature(true);
- readData.addInputArg(rdInputArg);
- FormalArgumentSignature rdOutputArg = new FormalArgumentSignature(true);
- readData.addOutputArg(rdOutputArg);
- readData.setInvocationMode(INVOCATION_INTERNAL);
- proceduresMap.put("readData", readData);
- ProcedureSignature readData2 = new ProcedureSignature("readData2");
- FormalArgumentSignature rd2InputArg = new FormalArgumentSignature(true);
- readData2.addInputArg(rd2InputArg);
- FormalArgumentSignature rd2OutputArg = new FormalArgumentSignature(true);
- readData2.addOutputArg(rd2OutputArg);
- readData2.setInvocationMode(INVOCATION_INTERNAL);
- proceduresMap.put("readData2", readData2);
- ProcedureSignature readStructured = new ProcedureSignature("readStructured");
- FormalArgumentSignature rStInputArg = new FormalArgumentSignature(true);
- readStructured.addInputArg(rStInputArg);
- FormalArgumentSignature rStOutputArg = new FormalArgumentSignature(true);
- readStructured.addOutputArg(rStOutputArg);
- readStructured.setInvocationMode(INVOCATION_INTERNAL);
- proceduresMap.put("readStructured", readStructured);
- ProcedureSignature trace = new ProcedureSignature("trace");
- trace.setAnyNumOfInputArgs();
- trace.setInvocationMode(INVOCATION_INTERNAL);
- proceduresMap.put("trace", trace);
- ProcedureSignature tracef = new ProcedureSignature("tracef");
- tracef.setAnyNumOfInputArgs();
- tracef.setInvocationMode(INVOCATION_INTERNAL);
- proceduresMap.put("tracef", tracef);
- ProcedureSignature fprintf = new ProcedureSignature("ftracef");
- fprintf.setAnyNumOfInputArgs();
- fprintf.setInvocationMode(INVOCATION_INTERNAL);
- proceduresMap.put("fprintf", fprintf);
- ProcedureSignature assrt = new ProcedureSignature("assert");
- assrt.setAnyNumOfInputArgs();
- assrt.setInvocationMode(INVOCATION_INTERNAL);
- proceduresMap.put("assert", assrt);
- ProcedureSignature writeData = new ProcedureSignature("writeData");
- FormalArgumentSignature wdInputArg = new FormalArgumentSignature(true);
- writeData.addInputArg(wdInputArg);
- FormalArgumentSignature wdOutputArg = new FormalArgumentSignature(true);
- writeData.addOutputArg(wdOutputArg);
- writeData.setInvocationMode(INVOCATION_INTERNAL);
- proceduresMap.put("writeData", writeData);
return proceduresMap;
@@ -180,156 +165,113 @@
Map<String,ProcedureSignature> functionsMap =
- ProcedureSignature arg = new ProcedureSignature("arg");
- FormalArgumentSignature argIn1 = new FormalArgumentSignature("string");
- arg.addInputArg(argIn1);
- FormalArgumentSignature argIn2 = new FormalArgumentSignature("string");
- argIn2.setOptional(true);
- arg.addInputArg(argIn2);
- FormalArgumentSignature argOut1 = new FormalArgumentSignature("string");
- arg.addOutputArg(argOut1);
- functionsMap.put(arg.getName(), arg);
+ add(functionsMap, "arg", returns(STRING), args(STRING, optional(STRING)));
- ProcedureSignature extractint = new ProcedureSignature("extractint");
- FormalArgumentSignature extractintIn1 = new FormalArgumentSignature(true); /* file can be specified as any type */
- extractint.addInputArg(extractintIn1);
- FormalArgumentSignature extractintOut1 = new FormalArgumentSignature("int");
- extractint.addOutputArg(extractintOut1);
- functionsMap.put(extractint.getName(), extractint);
+ add(functionsMap, "extractInt", returns(INT), args(ANY));
+ add(functionsMap, "filename", returns(STRING), args(ANY));
+ add(functionsMap, "filenames", returns(STRING_ARRAY), args(ANY));
+ add(functionsMap, "dirname", returns(STRING), args(ANY));
+ add(functionsMap, "length", returns(INT), args(ANY));
+ add(functionsMap, "regexp", returns(STRING), args(STRING, STRING, STRING));
+ add(functionsMap, "strcat", returns(STRING), args(VARGS));
+ add(functionsMap, "sprintf", returns(STRING), args(VARGS));
+ add(functionsMap, "strcut", returns(STRING), args(STRING, STRING));
+ add(functionsMap, "strstr", returns(INT), args(STRING, STRING));
+ add(functionsMap, "strsplit", returns(STRING_ARRAY), args(STRING, STRING));
+ add(functionsMap, "toInt", returns(INT), args(ANY));
+ add(functionsMap, "toFloat", returns(FLOAT), args(ANY));
+ add(functionsMap, "toString", returns(STRING), args(ANY));
+ add(functionsMap, "format", returns(STRING), args(FLOAT, INT));
+ add(functionsMap, "pad", returns(STRING), args(INT, INT));
+ add(functionsMap, "java", returns("java"), args(VARGS));
- ProcedureSignature filename = new ProcedureSignature("filename");
- FormalArgumentSignature filenameIn1 = new FormalArgumentSignature(true); /* file can be specified as any type */
- filename.addInputArg(filenameIn1);
- FormalArgumentSignature filenameOut1 = new FormalArgumentSignature("string");
- filename.addOutputArg(filenameOut1);
- functionsMap.put(filename.getName(), filename);
+ add(functionsMap, "exists", returns(BOOLEAN), args(VARGS));
+ // backwards compatible and deprecated lower case version
+ addDeprecated(functionsMap, "extractint", returns(INT), args(ANY));
+ addDeprecated(functionsMap, "toint", returns(INT), args(ANY));
+ addDeprecated(functionsMap, "tofloat", returns(FLOAT), args(ANY));
+ addDeprecated(functionsMap, "tostring", returns(STRING), args(ANY));
- ProcedureSignature filenames = new ProcedureSignature("filenames");
- FormalArgumentSignature filenamesIn1 = new FormalArgumentSignature(true); /* file can be specified as any type */
- filenames.addInputArg(filenamesIn1);
- FormalArgumentSignature filenamesOut1 = new FormalArgumentSignature("string[]"); /* i think this is what it returns */
- filenames.addOutputArg(filenamesOut1);
- functionsMap.put(filenames.getName(), filenames);
+ return functionsMap;
+ public static final FormalArgumentSignature VARG_SIG = new FormalArgumentSignature(true);
- ProcedureSignature dirname = new ProcedureSignature("dirname");
- FormalArgumentSignature dirnameIn1 = new FormalArgumentSignature(true); /* dir can be specified as any type */
- dirname.addInputArg(dirnameIn1);
- FormalArgumentSignature dirnameOut1 = new FormalArgumentSignature("string");
- dirname.addOutputArg(dirnameOut1);
- functionsMap.put(dirname.getName(), dirname);
+ private static void addDeprecated(Map<String, ProcedureSignature> map,
+ String name, FormalArgumentSignature[] returns, FormalArgumentSignature[] args) {
+ ProcedureSignature sig = buildSig(name, returns, args);
+ sig.setDeprecated(true);
+ map.put(name, sig);
+ private static void add(Map<String, ProcedureSignature> map,
+ map.put(name, buildSig(name, returns, args));
- ProcedureSignature length = new ProcedureSignature("length");
- FormalArgumentSignature lengthIn1 = new FormalArgumentSignature(true);
- length.addInputArg(lengthIn1);
- FormalArgumentSignature lengthOut1 = new FormalArgumentSignature("int");
- length.addOutputArg(lengthOut1);
- functionsMap.put(length.getName(), length);
+ private static ProcedureSignature buildSig(String name,
+ FormalArgumentSignature[] returns, FormalArgumentSignature[] args) {
+ ProcedureSignature sig = new ProcedureSignature(name);
+ for (FormalArgumentSignature arg : args) {
+ if (arg == VARG_SIG) {
+ sig.setAnyNumOfInputArgs();
+ else {
+ sig.addInputArg(arg);
+ for (FormalArgumentSignature ret : returns) {
+ sig.addOutputArg(ret);
+ return sig;
- ProcedureSignature regexp = new ProcedureSignature("regexp");
- FormalArgumentSignature regexpIn1 = new FormalArgumentSignature("string");
- regexp.addInputArg(regexpIn1);
- FormalArgumentSignature regexpIn2 = new FormalArgumentSignature("string");
- regexp.addInputArg(regexpIn2);
- FormalArgumentSignature regexpIn3 = new FormalArgumentSignature("string");
- regexp.addInputArg(regexpIn3);
- FormalArgumentSignature regexpOut1 = new FormalArgumentSignature("string");
- regexp.addOutputArg(regexpOut1);
- functionsMap.put(regexp.getName(), regexp);
+ private static FormalArgumentSignature arg(String type) {
+ if (type.equals(ANY)) {
+ return new FormalArgumentSignature(true);
+ else if (type.equals(VARGS)) {
+ return VARG_SIG;
+ else {
+ return new FormalArgumentSignature(type);
- ProcedureSignature strcat = new ProcedureSignature("strcat");
- strcat.setAnyNumOfInputArgs();
- FormalArgumentSignature strcatOut1 = new FormalArgumentSignature("string");
- strcat.addOutputArg(strcatOut1);
- functionsMap.put(strcat.getName(), strcat);
+ private static FormalArgumentSignature[] returns(Object ... returns) {
+ return buildArgs(returns);
- ProcedureSignature sprintf = new ProcedureSignature("sprintf");
- sprintf.setAnyNumOfInputArgs();
- FormalArgumentSignature sprintfOut1 = new FormalArgumentSignature("string");
- sprintf.addOutputArg(sprintfOut1);
- functionsMap.put(sprintf.getName(), sprintf);
+ private static FormalArgumentSignature[] args(Object ... args) {
+ return buildArgs(args);
- ProcedureSignature strcut = new ProcedureSignature("strcut");
- FormalArgumentSignature strcutIn1 = new FormalArgumentSignature("string");
- strcut.addInputArg(strcutIn1);
- FormalArgumentSignature strcutIn2 = new FormalArgumentSignature("string");
- strcut.addInputArg(strcutIn2);
- FormalArgumentSignature strcutOut1 = new FormalArgumentSignature("string");
- strcut.addOutputArg(strcutOut1);
- functionsMap.put(strcut.getName(), strcut);
+ private static FormalArgumentSignature[] buildArgs(Object[] args) {
+ FormalArgumentSignature[] r = new FormalArgumentSignature[args.length];
+ for (int i = 0; i < args.length; i++) {
+ if (args[i] instanceof FormalArgumentSignature) {
+ r[i] = (FormalArgumentSignature) args[i];
+ else {
+ r[i] = arg((String) args[i]);
+ return r;
+ private static FormalArgumentSignature optional(String type) {
+ FormalArgumentSignature arg = arg(type);
+ arg.setOptional(true);
+ return arg;
- ProcedureSignature strstr = new ProcedureSignature("strstr");
- FormalArgumentSignature strstrIn1 = new FormalArgumentSignature("string");
- strstr.addInputArg(strstrIn1);
- FormalArgumentSignature strstrIn2 = new FormalArgumentSignature("string");
- strstr.addInputArg(strstrIn2);
- FormalArgumentSignature strstrOut1 = new FormalArgumentSignature("int");
- strstr.addOutputArg(strstrOut1);
- functionsMap.put(strstr.getName(), strstr);
- ProcedureSignature strsplit = new ProcedureSignature("strsplit");
- FormalArgumentSignature strsplitIn1 = new FormalArgumentSignature("string");
- strsplit.addInputArg(strsplitIn1);
- FormalArgumentSignature strsplitIn2 = new FormalArgumentSignature("string");
- strsplit.addInputArg(strsplitIn2);
- FormalArgumentSignature strsplitOut1 = new FormalArgumentSignature("string[]");
- strsplit.addOutputArg(strsplitOut1);
- functionsMap.put(strsplit.getName(), strsplit);
- ProcedureSignature toint = new ProcedureSignature("toint");
- FormalArgumentSignature tointIn1 = new FormalArgumentSignature(true);
- toint.addInputArg(tointIn1);
- FormalArgumentSignature toOut1 = new FormalArgumentSignature("int");
- toint.addOutputArg(toOut1);
- functionsMap.put(toint.getName(), toint);
- ProcedureSignature tofloat = new ProcedureSignature("tofloat");
- FormalArgumentSignature tofloatIn1 = new FormalArgumentSignature(true);
- tofloat.addInputArg(tofloatIn1);
- FormalArgumentSignature tofloatOut1 = new FormalArgumentSignature("float");
- tofloat.addOutputArg(tofloatOut1);
- functionsMap.put(tofloat.getName(), tofloat);
- ProcedureSignature format = new ProcedureSignature("format");
- FormalArgumentSignature formatIn1 = new FormalArgumentSignature("float");
- FormalArgumentSignature formatIn2 = new FormalArgumentSignature("int");
- format.addInputArg(formatIn1);
- format.addInputArg(formatIn2);
- FormalArgumentSignature formatOut = new FormalArgumentSignature("string");
- format.addOutputArg(formatOut);
- functionsMap.put(format.getName(), format);
- ProcedureSignature pad = new ProcedureSignature("pad");
- FormalArgumentSignature padIn1 = new FormalArgumentSignature("int");
- FormalArgumentSignature padIn2 = new FormalArgumentSignature("int");
- pad.addInputArg(padIn1);
- pad.addInputArg(padIn2);
- FormalArgumentSignature padOut = new FormalArgumentSignature("string");
- pad.addOutputArg(padOut);
- functionsMap.put(pad.getName(), pad);
- ProcedureSignature tostring = new ProcedureSignature("tostring");
- FormalArgumentSignature tostringIn1 = new FormalArgumentSignature(true);
- tostring.addInputArg(tostringIn1);
- FormalArgumentSignature tostringOut1 = new FormalArgumentSignature("string");
- tostring.addOutputArg(tostringOut1);
- functionsMap.put(tostring.getName(), tostring);
- ProcedureSignature java = new ProcedureSignature("java");
- java.setAnyNumOfInputArgs();
- FormalArgumentSignature output = new FormalArgumentSignature("java");
- java.addOutputArg(output);
- functionsMap.put(java.getName(), java);
- ProcedureSignature exists = new ProcedureSignature("exists");
- exists.setAnyNumOfInputArgs();
- FormalArgumentSignature existsOut1 = new FormalArgumentSignature("boolean");
- exists.addOutputArg(existsOut1);
- functionsMap.put(exists.getName(), exists);
- return functionsMap;
- public String toString() {
+ public String toString() {
return outputArgs + " " + name + inputArgs;
More information about the Swift-commit
