[Swift-commit] r5139 - trunk/libexec
hategan at ci.uchicago.edu
Tue Sep 20 17:27:00 CDT 2011
Author: hategan
Date: 2011-09-20 17:27:00 -0500 (Tue, 20 Sep 2011)
New Revision: 5139
Modified:
trunk/libexec/vdl-lib.xml
Log:
the hyphen was not a very good idea, since it does not work in the non-xml karajan
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml 2011-09-20 19:20:31 UTC (rev 5138)
+++ trunk/libexec/vdl-lib.xml 2011-09-20 22:27:00 UTC (rev 5139)
@@ -2,26 +2,35 @@
<namespace prefix="swiftscript">
<!-- string functions library -->
- <export name="extract-int"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ExtractInt"/></export>
- <export name="read-data"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadData"/></export>
- <export name="read-data2"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
- <export name="read-structured"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
+ <export name="extract_int"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ExtractInt"/></export>
+ <export name="read_data"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadData"/></export>
+ <export name="read_data2"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
+ <export name="read_structured"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
<export name="write-data"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.WriteData"/></export>
<export name="strcat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="strcut"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="strstr"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="strsplit"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="regexp"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
- <export name="to-int"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
- <export name="to-float"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="to_int"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="to_float"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="format"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="pad"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="sprintf"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Sprintf"/></export>
- <export name="to-string"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="to_string"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="assert"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Assert"/></export>
<export name="trace"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="tracef"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Tracef"/></export>
<export name="fprintf"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Fprintf"/></export>
+ <!-- included for backwards compatibility -->
+ <export name="readdata"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadData"/></export>
+ <export name="readdata2"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
+ <export name="readstructured"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
+ <export name="writedata"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.WriteData"/></export>
+ <export name="toint"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="tofloat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+ <export name="tostring"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
<export name="java"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Java"/></export>
<export name="filename"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileName"/></export>
More information about the Swift-commit
