[Swift-commit] r5129 - in trunk/tests: . cdm
wozniak at ci.uchicago.edu
Mon Sep 19 13:18:05 CDT 2011
Author: wozniak
Date: 2011-09-19 13:18:05 -0500 (Mon, 19 Sep 2011)
New Revision: 5129
Modified:
trunk/tests/USAGENOTES.txt
trunk/tests/cdm/301-bcast.swift
trunk/tests/suite.sh
Log:
New SKIP-THIS-TEST feature
Modified: trunk/tests/USAGENOTES.txt
--- trunk/tests/USAGENOTES.txt 2011-09-19 08:12:51 UTC (rev 5128)
+++ trunk/tests/USAGENOTES.txt 2011-09-19 18:18:05 UTC (rev 5129)
@@ -18,19 +18,19 @@
[width="30%",cols="s,15",options="header"]
|Options | Output
-|-a | Do not run ant dist.
-|-c | Do not remove dist (clean)
-|-f | Generate plain text output file.
-|-h | This table.
-|-k <N> | Skip first N tests.
-|-n <N> | Run N tests and quit.
-|-p | Do not build the package.
-|-s | Do not do a fresh svn checkout.
-|-t | Tree mode (alias: -a,-c,-g,-p,-s)
-|-x | Do not continue after a failure.
-|-v | Verbose (set -x, HTML comments).
-|-o output| Location for cog and output.
-|<GROUP> | GROUP argument.
+|-a | Do not run ant dist.
+|-c | Do not remove dist (clean)
+|-f | Generate plain text output file.
+|-h | This table.
+|-k <N> | Skip first N tests.
+|-n <N> | Run N tests and quit.
+|-p | Do not build the package.
+|-s | Do not do a fresh svn checkout.
+|-t | Tree mode (alias: -a,-c,-g,-p,-s)
+|-x | Do not continue after a failure.
+|-v | Verbose (set -x, HTML comments).
+|-o output| Location for cog and output.
+|<GROUP> | GROUP argument.
Assuming your code is in *_/tmp/cog_*, where you
have the conventional *_cog/modules/swift_* configuration,
@@ -48,7 +48,7 @@
When something goes wrong, find and check *tests.log* or use *-v*
The script generates by default an HTML report, use *-f* to change
-the output to plain text.
+the output to plain text.
2. Swift Location
@@ -70,13 +70,13 @@
Each *.swift* test may be accompanied by a:
-- *.setup.sh*
+- *.setup.sh*
- *.check.sh*
- *.clean.sh*
- *.timeout specifier.*
-The scripts may setup and inspect files in *RUNDIR*
-including *exec.out* which must be accessed in *stdout.txt*
+The scripts may setup and inspect files in *RUNDIR*
+including *exec.out* which must be accessed in *stdout.txt*
because the currently running tested process writes to
*exec.out*; *stdout.txt* is a copy.
@@ -150,6 +150,10 @@
The response of *suite.sh* to the exit code of these Swift
executions is reversed.
+Additionally, some tests may be in a known state of disrepair. These
+SwiftScripts contain the token *_SKIP-THIS-TEST_* somewhere, which will
+cause the test suite to skip that test.
8. Schedulers
Environment must contain *PROJECT*, *QUEUE*, and *WORK*.
@@ -207,7 +211,7 @@
The prefix number on each test is simply for sorting
.E.g.,
ls *.swift
@@ -225,7 +229,7 @@
- Run it! Report problems to swift-devel.
- Fix broken tests.
- Break down test *GROUPs* into smaller, meaningful *GROUPs* ; it would be good to limit *GROUP* sizes to 20 or so tests.
-- Current work has focused on the HTML and stdout output, which is intended to be high-level and clean.
+- Current work has focused on the HTML and stdout output, which is intended to be high-level and clean.
Using -v results in extremely verbose output.
Modified: trunk/tests/cdm/301-bcast.swift
--- trunk/tests/cdm/301-bcast.swift 2011-09-19 08:12:51 UTC (rev 5128)
+++ trunk/tests/cdm/301-bcast.swift 2011-09-19 18:18:05 UTC (rev 5129)
@@ -1,4 +1,6 @@
+// SKIP-THIS-TEST
type file;
app (file o) copy (file i)
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-09-19 08:12:51 UTC (rev 5128)
+++ trunk/tests/suite.sh 2011-09-19 18:18:05 UTC (rev 5129)
@@ -24,6 +24,7 @@
TEXTREPORT=0
DEFAULT_TIMEOUT=30 # seconds
RUN_ANT=1
+# If true, run "ant clean"
CLEAN=1
SKIP_TESTS=0
NUMBER_OF_TESTS=1000000 # Run all tests by default
@@ -386,8 +387,8 @@
html_a_href $TEST_LOG "$LABEL"
elif [ "$RESULT" == "None" ]; then
html_td width 25
- html " "
- html_~td
+ html " "
+ html_~td
else
echo -e "${RED}FAILED${GRAY}"
cat $RUNDIR/$TEST_LOG < /dev/null
@@ -793,6 +794,12 @@
SWIFTSCRIPT=$1
NAME=${SWIFTSCRIPT%.swift}
+ if grep -q "SKIP-THIS-TEST" $SWIFTSCRIPT ; then
+ echo SKIP-THIS-TEST
+ INDIVIDUAL_TEST_TIME=0
+ return 0
+ fi
SETUPSCRIPT=$NAME.setup.sh
CHECKSCRIPT=$NAME.check.sh
CLEANSCRIPT=$NAME.clean.sh
More information about the Swift-commit
