[Swift-commit] r5128 - trunk/libexec
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Sep 19 03:12:52 CDT 2011
Author: hategan
Date: 2011-09-19 03:12:51 -0500 (Mon, 19 Sep 2011)
New Revision: 5128
Modified:
   trunk/libexec/vdl-lib.xml
Log:
use the new "case-sensitive" format
Modified: trunk/libexec/vdl-lib.xml
--- trunk/libexec/vdl-lib.xml	2011-09-19 08:12:17 UTC (rev 5127)
+++ trunk/libexec/vdl-lib.xml	2011-09-19 08:12:51 UTC (rev 5128)
@@ -2,30 +2,30 @@
   <namespace prefix="swiftscript">
 	<!-- string functions library -->
-	<export name="extractint"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ExtractInt"/></export>
-	<export name="readdata"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadData"/></export>
-	<export name="readdata2"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
-	<export name="readstructured"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
-	<export name="writedata"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.WriteData"/></export>
+	<export name="extract-int"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ExtractInt"/></export>
+	<export name="read-data"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadData"/></export>
+	<export name="read-data2"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
+	<export name="read-structured"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.ReadStructured"/></export>
+	<export name="write-data"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.WriteData"/></export>
 	<export name="strcat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="strcut"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="strstr"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="strsplit"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="regexp"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
-	<export name="toint"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
-	<export name="tofloat"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+	<export name="to-int"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+	<export name="to-float"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="format"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="pad"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="sprintf"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Sprintf"/></export>
-	<export name="tostring"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
+	<export name="to-string"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="assert"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Assert"/></export>
 	<export name="trace"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="tracef"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Tracef"/></export>
 	<export name="fprintf"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Fprintf"/></export>
 	<export name="java"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Java"/></export>
-	<export name="fileName"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileName"/></export>
-	<export name="fileNames"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileNames"/></export>
+	<export name="filename"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileName"/></export>
+	<export name="filenames"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.FileNames"/></export>
 	<export name="dirname"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="length"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
 	<export name="exists"><elementDef classname="org.griphyn.vdl.karajan.lib.swiftscript.Misc"/></export>
