[Swift-commit] r5044 - trunk/libexec
wozniak at ci.uchicago.edu
Thu Sep 1 10:35:48 CDT 2011
Author: wozniak
Date: 2011-09-01 10:35:48 -0500 (Thu, 01 Sep 2011)
New Revision: 5044
Modified:
trunk/libexec/cdm.pl
Log:
Whitespace
Modified: trunk/libexec/cdm.pl
--- trunk/libexec/cdm.pl 2011-09-01 15:31:00 UTC (rev 5043)
+++ trunk/libexec/cdm.pl 2011-09-01 15:35:48 UTC (rev 5044)
@@ -1,10 +1,10 @@
-# CDM Lookup
+# CDM Lookup
sub print_hash
my $hash = $_[0];
- foreach (keys %$hash)
+ foreach (keys %$hash)
print "$_ : $$hash{$_} \n";
@@ -47,18 +47,18 @@
print "$result\n";
-# Command-line arguments:
+# Command-line arguments:
$task = $ARGV[0];
$arg = $ARGV[1];
-# Read fs.data off of stdin:
+# Read fs.data off of stdin:
@keys = ();
%map = ();
%properties = ();
while (<STDIN>)
chomp;
my $comment = index $_, "#";
if ($comment >= 0) {
$_ = substr($_, 0, $comment);
@@ -66,15 +66,15 @@
next if $_ eq "";
- @tokens = split(/[ \t]+/, $_);
- $type = shift(@tokens);
- if ($type eq "rule")
+ @tokens = split(/[ \t]+/, $_);
+ $type = shift(@tokens);
+ if ($type eq "rule")
$key = shift(@tokens);
- if (! defined $map{$key})
+ if (! defined $map{$key})
$rest = join(' ', @tokens);
- @keys = (@keys, $key);
+ @keys = (@keys, $key);
$map{$key} = $rest;
@@ -84,13 +84,13 @@
$properties{$property} = $rest;
- else
+ else
- die "Unknown directive: $type";
+ die "Unknown directive: $type";
-# Do the user task:
+# Do the user task:
if ($task eq "lookup")
cdm_lookup(\@keys, \%map, $arg);
More information about the Swift-commit
