[Swift-commit] r5043 - in SwiftApps: . DSSAT DSSAT/bin
ketan at ci.uchicago.edu
Thu Sep 1 10:31:00 CDT 2011
Author: ketan
Date: 2011-09-01 10:31:00 -0500 (Thu, 01 Sep 2011)
New Revision: 5043
Added:
SwiftApps/DSSAT/
SwiftApps/DSSAT/RunDSSAT.swift
SwiftApps/DSSAT/RunSwift.sh
SwiftApps/DSSAT/bin/
SwiftApps/DSSAT/bin/RunDSSAT.sh
SwiftApps/DSSAT/bin/gridCheck.sh
SwiftApps/DSSAT/counter.txt
SwiftApps/DSSAT/tc
Log:
added DSSAT app to SwiftApps repo
Added: SwiftApps/DSSAT/RunDSSAT.swift
--- SwiftApps/DSSAT/RunDSSAT.swift (rev 0)
+++ SwiftApps/DSSAT/RunDSSAT.swift 2011-09-01 15:31:00 UTC (rev 5043)
@@ -0,0 +1,31 @@
+type file;
+app (file output) RunDSSAT (file input[])
+ RunDSSAT @output @input ;
+//This is unused at the moment since it was used to check bad cells (bad cell means that the cell doesn't have soil files)
+app (file output) gridCheck (string path)
+ gridCheck @output path;
+//gridList.txt contains the list of good grid cells
+//file gl <"gridList.txt">;
+//gridCheck app discards empty grid cells or those containing unusable files
+//gl = gridCheck(@arg("path","/gpfs/pads/projects/CI-SES000031/data/dssat/grid/"));
+string gridLists[] = readData("gridList.txt");
+foreach g,i in gridLists
+//file out<single_file_mapper;file=@strcat("output/",gridLists[i],"output.tar")>;
+file out<concurrent_mapper;prefix="output", suffix=".tar">;
+file in1[] <filesys_mapper;location=@strcat(@arg("path","/gpfs/pads/projects/CI-SES000031/data/dssat/grid/"), gridLists[i]), pattern="*">;
+out = RunDSSAT(in1);
Added: SwiftApps/DSSAT/RunSwift.sh
--- SwiftApps/DSSAT/RunSwift.sh (rev 0)
+++ SwiftApps/DSSAT/RunSwift.sh 2011-09-01 15:31:00 UTC (rev 5043)
@@ -0,0 +1,14 @@
+count=$(head -1 counter.txt);
+expr $count + 1 > counter.txt
+#echo $count
+mkdir run$count
+cp RunDSSAT.swift run$count/
+cp gridList.txt run$count/
+cp sites.xml run$count/
+cp beagle-coaster-trunk.xml run$count/
+cp tc run$count/
+cp cf run$count/
+cd run$count
+#time swift -tc.file tc -sites.file sites.xml -config cf RunDSSAT.swift >& swift.out
+SWIFT_HEAP_MAX=7000M time swift -tc.file tc -sites.file beagle-coaster-trunk.xml -config cf RunDSSAT.swift >& swift.out
Property changes on: SwiftApps/DSSAT/RunSwift.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/DSSAT/bin/RunDSSAT.sh
--- SwiftApps/DSSAT/bin/RunDSSAT.sh (rev 0)
+++ SwiftApps/DSSAT/bin/RunDSSAT.sh 2011-09-01 15:31:00 UTC (rev 5043)
@@ -0,0 +1,34 @@
+#!/bin/bash
+rm -rf run
+mkdir run
+cd run
+mkdir data
+out=$1
+#copy files of grid cell into data directory
+for i in $2
+do
+ cp ../$i data;
+done
+cp /gpfs/pads/projects/CI-SES000031/csm/sim/* data
+cp /gpfs/pads/projects/CI-SES000031/csm/*.CDE data
+cp /gpfs/pads/projects/CI-SES000031/csm/dssat.papia/bin/*.EXE .
+cd data
+../DSSAT040.EXE A H1234567.MZX > RESULT.OUT
+cd ..
+mkdir output
+mv data/*.OUT output
+mv data/RESULT.OUT output
+tar cf ../$out output
+exit
Property changes on: SwiftApps/DSSAT/bin/RunDSSAT.sh
Added: SwiftApps/DSSAT/bin/gridCheck.sh
--- SwiftApps/DSSAT/bin/gridCheck.sh (rev 0)
+++ SwiftApps/DSSAT/bin/gridCheck.sh 2011-09-01 15:31:00 UTC (rev 5043)
@@ -0,0 +1,12 @@
+#ls $2 -1 | head >> $1;
+n=$(ls $2 -1 | head -1000);
+for i in $n
+do
+ if [[ -f $2$i/SOIL.SOL && $(sed -n '6p' $2/$i/GENERIC1.WTH | grep 'NA'|wc -l) != 1 ]];
+ then
+ echo $i >> $1;
+ fi
+done
Property changes on: SwiftApps/DSSAT/bin/gridCheck.sh
Added: SwiftApps/DSSAT/counter.txt
--- SwiftApps/DSSAT/counter.txt (rev 0)
+++ SwiftApps/DSSAT/counter.txt 2011-09-01 15:31:00 UTC (rev 5043)
@@ -0,0 +1 @@
+26
Added: SwiftApps/DSSAT/tc
--- SwiftApps/DSSAT/tc (rev 0)
+++ SwiftApps/DSSAT/tc 2011-09-01 15:31:00 UTC (rev 5043)
@@ -0,0 +1,34 @@
+#This is the transformation catalog.
+#It comes pre-configured with a number of simple transformations with
+#paths that are likely to work on a linux box. However, on some systems,
+#the paths to these executables will be different (for example, sometimes
+#some of these programs are found in /usr/bin rather than in /bin)
+#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
+#there must be no trailing whitespace at the end of each line.
+# site transformation path obsolete fields for compatibility
+localhost echo /bin/echo null null null
+localhost cat /bin/cat null null null
+localhost ls /bin/ls null null null
+localhost grep /bin/grep null null null
+localhost sort /bin/sort null null null
+localhost paste /bin/paste null null null
+localhost pwd /bin/pwd null null null
+# For cluster usage
+pbs RunDSSAT /gpfs/pads/swift/ketan/DSSAT/bin/RunDSSAT.sh null null null
+pbs gridCheck /gpfs/pads/swift/ketan/DSSAT/bin/gridCheck.sh null null null
+# For localhost testing
+#localhost RunDSSAT /gpfs/pads/swift/ketan/DSSAT/bin/RunDSSAT.sh null null null
+#localhost gridCheck /gpfs/pads/swift/ketan/DSSAT/bin/gridCheck.sh null null null
More information about the Swift-commit
