[Swift-commit] r4491 - trunk/tests
wozniak at ci.uchicago.edu
Wed May 18 15:23:04 CDT 2011
Author: wozniak
Date: 2011-05-18 15:23:04 -0500 (Wed, 18 May 2011)
New Revision: 4491
Modified:
trunk/tests/suite.sh
Log:
Greatly improve process termination logic and other minor improvements
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-05-18 20:20:33 UTC (rev 4490)
+++ trunk/tests/suite.sh 2011-05-18 20:23:04 UTC (rev 4491)
@@ -12,7 +12,7 @@
# Assuming your code is in /tmp/cog, where you
# have the conventional cog/modules/swift configuration,
# and you have done an ant dist, you can run
-# suite.sh -t -o /tmp tests/groups/group-all-local.sh
+# suite.sh -t -o /tmp $PWD/tests/groups/group-all-local.sh
# or cd into /tmp and run
# suite.sh -t cog/modules/swift/tests/groups/group-all-local.sh
# The -t option is "Tree mode"- as in, "test my existing source tree"
@@ -117,7 +117,7 @@
printf "\t -k <N> Skip first N tests \n"
printf "\t -n <N> Run N tests and quit \n"
printf "\t -p Do not build the package \n"
- printf "\t -s Do not do a svn checkout \n"
+ printf "\t -s Do not do a fresh svn checkout \n"
printf "\t -t Tree mode (alias: -a,-c,-g,-p,-s) \n"
printf "\t -x Do not continue after a failure \n"
printf "\t -v Verbose (set -x, HTML comments) \n"
@@ -175,6 +175,7 @@
GRID_TESTS=0
BUILD_PACKAGE=0
SKIP_CHECKOUT=1
+ shift;;
-x)
ALWAYS_EXITONFAILURE=1
shift;;
@@ -266,8 +267,7 @@
shutdown_trap() {
SHUTDOWN=1
- verbose "shutdown_trap... $PROCESS_PID\n\n"
- verbose "kill: process: $PROCESS_PID"
+ printf "\nshutdown_trap: kill: process: $PROCESS_PID\n"
kill $PROCESS_PID
@@ -559,18 +559,33 @@
fi
+# Note that killing Swift/Coasters may result in a delay as
+# Coasters shuts down: cf. CoasterService.addLocalHook()
+process_trap() {
+ PROCESS_INTERNAL_PID=$1
+ echo "process_trap: killing: $PROCESS_INTERNAL_PID"
+ # ps -H
+ kill -TERM $PROCESS_INTERNAL_PID
# Execute process in the background
process_exec() {
- printf "\nExecuting: $@\n" >>$LOG
+ printf "\nExecuting: $@\n" | tee -a $LOG
rm -f $OUTPUT
- "$@" > $OUTPUT 2>&1
+ "$@" > $OUTPUT 2>&1 &
+ PROCESS_INTERNAL_PID=$!
+ echo PROCESS_INTERNAL_PID=$PROCESS_INTERNAL_PID
+ trap "process_trap $PROCESS_INTERNAL_PID" SIGTERM
+ wait
EXITCODE=$?
if [ "$EXITCODE" == "127" ]; then
echo "Command not found: $@" > $OUTPUT
fi
if [ -f $OUTPUT ]; then
+ cat $OUTPUT
cat $OUTPUT >> $LOG
fi
(( $TEST_SHOULD_FAIL )) && EXITCODE=$(( ! $EXITCODE ))
@@ -958,6 +973,10 @@
checkvars GROUPARG
echo "GROUP ARGUMENT: $GROUPARG"
+if [[ $GROUPARG != /* ]]; then
+ # Adjust relative path
+ GROUPARG=$PWD/$GROUPARG
+fi
if [[ -f $GROUPARG ]]; then
GROUPLISTFILE=$GROUPARG
source $GROUPLISTFILE || exit 1
@@ -1043,6 +1062,8 @@
GROUPCOUNT=1
for G in ${GROUPLIST[@]}; do
export GROUP=$G
+ echo "GROUP: $GROUP"
+ [ -d $GROUP ] || crash "Could not find GROUP: $GROUP"
TITLE=$( group_title )
start_part "Part $GROUPCOUNT: $TITLE"
test_group
More information about the Swift-commit
