[Swift-commit] r4490 - trunk/src/org/griphyn/vdl/mapping/file
skenny at ci.uchicago.edu skenny at ci.uchicago.edu
Wed May 18 15:20:33 CDT 2011
Author: skenny
Date: 2011-05-18 15:20:33 -0500 (Wed, 18 May 2011)
New Revision: 4490
Modified:
   trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
Log:
no-longer trying to convert filenames to integers for indexing arrays, addresses bug 116
Modified: trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java	2011-05-18 19:35:02 UTC (rev 4489)
+++ trunk/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java	2011-05-18 20:20:33 UTC (rev 4490)
@@ -4,19 +4,71 @@
 package org.griphyn.vdl.mapping.file;
 import java.util.Map;
+import java.util.HashMap;
+import org.griphyn.vdl.mapping.Path;
+import org.griphyn.vdl.mapping.PhysicalFormat;
+import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.MappingParam;
 public class SimpleFileMapper extends AbstractFileMapper {
 	public static final MappingParam PARAM_PADDING = new MappingParam("padding", new Integer(4));
+	private Map filenames = new HashMap();
+	private int count = 0;
+        private String isinput;
 	public SimpleFileMapper() {
 		super();
 	public void setParams(Map params) {
 		super.setParams(params);
 		int precision = PARAM_PADDING.getIntValue(this);
 		setElementMapper(new DefaultFileNameElementMapper(precision));
+		this.isinput = (String)params.get("input");
+	public Path rmap(String name) {
+	    if(this.isinput == null){
+		return super.rmap(name);
+		if (name == null || name.equals("")) {
+			return null;
+		String index = String.valueOf(count);
+		filenames.put(index, name);
+		Path p = Path.EMPTY_PATH;
+		p = p.addFirst(index, true);
+		++count;
+		return p;
+	public PhysicalFormat map(Path path) {
+		return super.map(path);
+		if (path.size()!=1) {
+			return null;
+		if (!path.isArrayIndex(0)) {
+			return null;
+		String location = PARAM_LOCATION.getStringValue(this);
+		String index = path.getFirst();
+		String filename = (String)filenames.get(index);
+		if (filename == null) {
+			return null;
+		if (location != null) {
+			if (!location.endsWith("/")) {
+				filename = location + '/' + filename;
+			} else {
+				filename = location + filename;
+		return new AbsFile(filename);
