[Swift-commit] r4620 - trunk/tests
    achavez at ci.uchicago.edu
    Thu Jun 16 10:41:52 CDT 2011
Author: achavez
Date: 2011-06-16 10:41:51 -0500 (Thu, 16 Jun 2011)
New Revision: 4620
Added:
   trunk/tests/README
Removed:
   trunk/tests/README
Log:
The content of README were moved to USAGENOTES, README now provides instructions on how to properly build USAGENOTES with asciidoc.
Deleted: trunk/tests/README
--- trunk/tests/README	2011-06-16 15:36:31 UTC (rev 4619)
+++ trunk/tests/README	2011-06-16 15:41:51 UTC (rev 4620)
@@ -1,15 +0,0 @@
-suite.sh:
-	See suite.sh for usage
-run-suite.sh:
-	wrapper for suite.sh
-	env variables set may be customized by user
-meta.sh:
-	wrapper for run-suite.sh
-	used to execute run-suite/suite.sh from a remote site using ssh
-	example usage:
-		 meta.sh login.pads.ci.uchicago.edu /home/skenny/swift_runs/tests sites/pads-pbs-coasters.sh
Added: trunk/tests/README
--- trunk/tests/README	                        (rev 0)
@@ -0,0 +1,7 @@
+USAGENOTES contains instructions on how to operate the test suite.
+It is an asciidoc document, in order to properly build it run the following command:
+$ asciidoc -a toc USAGENOTES
+It will generate an HTML file called USAGENOTES.
+Warning:
+asciidoc must be installed.
More information about the Swift-commit
