[Swift-commit] r4619 - trunk/tests
achavez at ci.uchicago.edu
Thu Jun 16 10:36:32 CDT 2011
Author: achavez
Date: 2011-06-16 10:36:31 -0500 (Thu, 16 Jun 2011)
New Revision: 4619
Modified:
trunk/tests/suite.sh
Log:
Test suite enhanced; Plain text report option added.
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-06-15 20:39:33 UTC (rev 4618)
+++ trunk/tests/suite.sh 2011-06-16 15:36:31 UTC (rev 4619)
@@ -1,157 +1,4 @@
#!/bin/bash
-# USAGE NOTES:
-# The script will (optionally) checkout Swift, run several tests in a
-# subdirectory called run-DATE, and generate useful HTML output and
-# tests.log . Tests are grouped into test GROUPs.
-# Usage: suite.sh <options>* <GROUPLISTFILE|GROUP>
-# PRIMARY USAGE MODE
-# Assuming your code is in /tmp/cog, where you
-# have the conventional cog/modules/swift configuration,
-# and you have done an ant dist, you can run
-# suite.sh -t -o /tmp $PWD/tests/groups/group-all-local.sh
-# or cd into /tmp and run
-# suite.sh -t cog/modules/swift/tests/groups/group-all-local.sh
-# The -t option is "Tree mode"- as in, "test my existing source tree"
-# Run suite.sh -h for quick help
-# When something goes wrong, find and check tests.log or use -v
-# SWIFT LOCATION
-# The TOPDIR (PWD by default) is set with the -o option.
-# Code is checked out into this directory or must already exist there.
-# The variables COG_VERSION and SWIFT_VERSION must be set for code checkout
-# e.g. COG_VERSION=branches/4.1.8, SWIFT_VERSION=branches/release-0.92
-# Swift is compiled and installed in its source tree
-# The run is executed in RUNDIR (TOPDIR/RUNDIRBASE)
-# The build test is started in TOPDIR
-# Everything for a Swift test is written in its RUNDIR
-# The temporary output always goes to OUTPUT (TOPDIR/exec.out)
-# HELPER SCRIPTS
-# Each *.swift test may be accompanied by a
-# *.setup.sh, *.check.sh, and/or *.clean.sh script
-# and a *.timeout specifier
-# The scripts may setup and inspect files in RUNDIR including exec.out,
-# which must be accessed in stdout.txt, because the currently running
-# tested process writes to exec.out, stdout.txt is a copy.
-# The GROUP scripts can read the GROUP variable
-# The timeout number in the *.timeout file overrides the default
-# timeout
-# TEST STRUCTURE
-# Tests are GROUPed into directories
-# Each GROUP directory has:
-# 1) a list of *.swift tests (plus *.sh scripts)
-# 2) optionally a sites.template.xml
-# 3) optionally a tc.template.data
-# 4) optionally a fs.template.data
-# 5) optionally a swift.properties
-# 6) optionally a title.txt
-# 7) preferably a README.txt
-# 7) optionally a *.timeout
-# template files are lightly processed by sed before use
-# Missing files will be pulled from swift/etc
-# WHAT TESTS ARE RUN
-# Each *.swift file is a test.
-# suite.sh launches all tests in each GROUP in the GROUPLIST.
-# The GROUPLIST is obtained from the GROUPARG.
-# 1) The GROUPARG can be an external script in the
-# groups/ subdirectory by the name of GROUPLISTFILE.
-# The GROUPLISTFILE:
-# 1) sets the array
-# 2) checks any variables needed by make_sites_sed()
-# 2) Or, the GROUPARG can just be a directory name that is
-# the name of the singleton GROUP
-# OUTPUT is the stdout of the current test
-# stdout.txt retains stdout from the previous test (for *.clean.sh)
-# output_*.txt is the HTML-linked permanent output from a test
-# All timeouts in this script are in seconds
-# PID TREE:
-# Background processes are used so that hung Swift jobs can be killed
-# These are the background processes (PIDs are tracked)
-# suite.sh
-# +-monitor()
-# +-sleep
-# +-process_exec()
-# +-bin/swift
-# +-java
-# PID management is now pretty good, but you may want to check ps
-# from time to time and keep xload running.
-# Note that Coasters may temporarily prevent Swift from exiting upon
-# receiving a signal (cf. CoasterService.addLocalHook()).
-# FAILURE CASES
-# Some cases are designed to cause Swift to crash. These
-# SwiftScripts contain the token THIS-SCRIPT-SHOULD-FAIL somewhere.
-# The response of suite.sh to the exit code of these Swift
-# executions is reversed.
-# SCHEDULERS
-# Environment must contain PROJECT, QUEUE, and WORK
-# These variables will be incorporated into the sites.xml
-# via make_sites_sed() -> group_sites_xml()
-# Note that some schedulers restrict your choice of RUNDIR
-# NAMING
-# Site-specific test groups are in providers/ .
-# These are named:
-# providers/<provider description>/
-# or:
-# providers/<provider description>/<site>
-# E.g., providers/local-pbs/PADS
-# ADDING TESTS TO EXISTING GROUPS
-# Simply add a *.swift file to a GROUP directory.
-# That script will be launched when the GROUP is tested.
-# Optionally, you may add helper scripts (see above) to setup,
-# check, and clean up after tests.
-# The helper scripts are launched from the RUNDIR and have access
-# to files in RUNDIR and environment variables from suite.sh
-# such as $GROUP. Thus, you can:
-# bring in input files: cp $GROUP/input-file.txt .
-# check output: grep TEXT1 stdout.txt
-# grep TEXT2 output-file.txt
-# clean up (optional): rm output-file.txt
-# The results are added to the HTML output, etc., automatically.
-# The prefix number on each test is simply for sorting
-# (e.g., ls *.swift)
-# ADDING TEST GROUPS
-# If no existing group has the sites, tc, etc. that you need to test,
-# you will need to add a test group. Simply create a new directory.
-# Add files from TEST STRUCTURE if necessary; missing files will be
-# filled in with defaults.
-# IMPROVING THIS TEST SUITE
-# This is a work in progress. Here are some things you can do:
-# * Run it! Report problems to swift-devel
-# * Fix broken tests
-# * Break down test GROUPs into smaller, meaningful GROUPs.
-# It would be good to limit GROUP sizes to 20 or so tests.
-# * Current work has focused on the HTML and stdout output,
-# which is intended to be high-level and clean. Using -v
-# results in extremely verbose output.
-# Some happy medium could be achieved by improving the use of
-# the LOG (tests.log).
-# PROBLEMS
-# If you have a problem:
-# * Use -v to get the set -x output.
-# * Use ps -H to get the PID tree.
-# WARNINGS
-# suite.sh uses shopt
shopt -s nullglob
printhelp() {
@@ -160,6 +7,7 @@
echo "usage:"
printf "\t -a Do not run ant dist \n"
printf "\t -c Do not remove dist (clean) \n"
+ printf "\t -f Generate plain text output file \n"
printf "\t -h This message \n"
printf "\t -k <N> Skip first N tests \n"
printf "\t -n <N> Run N tests and quit \n"
@@ -173,6 +21,7 @@
# Defaults:
+TEXTREPORT=0
DEFAULT_TIMEOUT=30 # seconds
RUN_ANT=1
CLEAN=1
@@ -193,6 +42,9 @@
-c)
CLEAN=0
shift;;
+ -f)
+ TEXTREPORT=1
+ shift;;
-h)
printhelp
exit 0;;
@@ -249,6 +101,11 @@
LOG=$TOPDIR/$LOGBASE
OUTPUT=$RUNDIR/exec.out
+#Specifying the Path for the plain Text File.
+REPORT_PATH=$RUNDIRBASE/tests-$DATE.txt
+REPORT=$TOPDIR/$REPORT_PATH
+#Specifying the path for the HTML output file
HTMLPATH=$RUNDIRBASE/tests-$DATE.html
HTML=$TOPDIR/$HTMLPATH
@@ -256,9 +113,11 @@
#BRANCH="branches/tests-01"
SCRIPTDIR=$( cd $( dirname $0 ) ; /bin/pwd )
+touch /home/Alberto/$SCRIPTDIR
TESTCOUNT=0
+TESTSFAILED=0
+TESTSPASSED=0
MASTER_PID=$$
# PIDs to kill if suite.sh is killed:
@@ -269,7 +128,7 @@
SHUTDOWN=0
echo "RUNNING_IN: $RUNDIR"
-echo "HTML_OUTPUT: $HTML"
+echo "HTML_OUTPUT: $REPORT"
TESTDIR=$TOPDIR/cog/modules/swift/tests
@@ -314,14 +173,21 @@
header() {
- CURRENT=$SCRIPTDIR/html/current.html
- sed "s at _HTMLBASE_@$HTMLPATH@" < $CURRENT > $TOPDIR/current.html
- HEADER=$SCRIPTDIR/html/header.html
- HOST=$( hostname )
- SEDCMD="s/_DATE_/$DATE/;s/_TIME_/$TIME/;s/_HOST_/$HOST"/
- sed $SEDCMD < $HEADER > $HTML
- FIRSTTEST=1
+ if [ $TEXTREPORT == 1 ]; then
+ HEADER=$SCRIPTDIR/html/header.txt
+ HOST=$( hostname )
+ SEDCMD="s/_DATE_/$DATE/;s/_TIME_/$TIME/;s/_HOST_/$HOST"/
+ sed $SEDCMD < $HEADER > $REPORT
+ FIRSTTEST=1
+ else
+ CURRENT=$SCRIPTDIR/html/current.html
+ sed "s at _HTMLBASE_@$HTMLPATH@" < $CURRENT > $TOPDIR/current.html
+ HEADER=$SCRIPTDIR/html/header.html
+ sed $SEDCMD < $HEADER > $HTML
+ FIRSTTEST=1
+ fi
html() {
@@ -451,42 +317,14 @@
shift
done
outecho() {
TYPE=$1
shift
echo "<$TYPE>$1|$2|$3|$4|$5|$6|$7|$8|$9|"
-# Create HTML output
-output_html() {
- TYPE=$1
- if [ "$TYPE" == "test" ]; then
- LABEL="$2" # Text on link to output
- CMD=$3 # Command issued (td title)
- RESULT=$4 # Passed or Failed
- # WIDTH=$( width "$LABEL" )
- if [ "$RESULT" == "Passed" ]; then
- html_td class "success" width 25 title "$CMD"
- html_a_href $TEST_LOG "$LABEL"
- else
- echo "FAILED"
- cat $RUNDIR/$TEST_LOG < /dev/null
- html_td class "failure" width 25 title "$CMD"
- html_a_href $TEST_LOG $LABEL
- fi
- html_~td
- elif [ "$TYPE" == "package" ]; then
- BINPACKAGE=$2
- else
- html $@
- fi
+#Create the table, and the links for the test results HTML output
start_test_results() {
html_h1 "Test results"
html_a_name "tests"
@@ -494,57 +332,118 @@
html_table border 0 cellpadding 1
+# Create either HTML or plain text report.
+# $TEXTREPORT monitor whether the report will be plain text or HTML
+output_report() {
+ TYPE=$1
+ if [ "$TYPE" == "test" ]; then
+ LABEL="$2" # Text on link to output
+ CMD=$3 # Command issued (td title)
+ RESULT=$4 # Passed or Failed
+ if [ "$RESULT" == "Passed" ]; then
+ printf %-10.10s "success">>$REPORT
+ else
+ echo "FAILED"
+ cat $RUNDIR/$TEST_LOG < /dev/null
+ printf %-10.10s "failure">>$REPORT
+ fi
+ elif [ "$TYPE" == "package" ]; then
+ BINPACKAGE=$2
+ else
+ printf $@>>$REPORT
+ fi
+ else
+ # WIDTH=$( width "$LABEL" )
+ html_td class "success" width 25 title "$CMD"
+ html_a_href $TEST_LOG "$LABEL"
+ else
+ echo "FAILED"
+ html_td class "failure" width 25 title "$CMD"
+ html_a_href $TEST_LOG $LABEL
+ fi
+ html_~td
+ BINPACKAGE=$2
+ else
+ html $@
+ fi
+ fi
start_group() {
G=$1
echo
echo $G
echo
- html_tr group
- html_th 3
- html "$G"
- html_~th
- html_~tr
+ stars
+ printf "$G\n">>$REPORT
+ printf %-5.5s "#">>$REPORT
+ printf %-60.60s "Filename">>$REPORT
+ printf %-10.10s "Test">>$REPORT
+ printf %-10.10s "Setup.sh" "Check.sh" "Clean.sh">>$REPORT
+ printf "\n">>$REPORT
+ else
+ html_tr group
+ html_th 3
+ html "$G"
+ html_~th
+ html_~tr
+ fi
start_row() {
- html_tr testline
- html_td align right width 50
- html "<b>$TESTCOUNT</b>"
- html " "
- html_~td
- html " "
- if [[ -n $TESTLINK ]]; then
- html_a_href $TESTLINK $TESTNAME
- else
- html $TESTNAME
- fi
- html " "
- html_~td
- html_td
- html_table
- html_tr
- SEQ=1
+ printf %-5.5s "$TESTCOUNT">>$REPORT
+ printf %-60.60s "$TESTNAME">>$REPORT
+ else
+ html_tr testline
+ html_td align right width 50
+ html "<b>$TESTCOUNT</b>"
+ html " "
+ html_~td
+ html " "
+ if [[ -n $TESTLINK ]]; then
+ html_a_href $TESTLINK $TESTNAME
+ else
+ html $TESTNAME
+ fi
+ html " "
+ html_~td
+ html_td
+ html_table
+ html_tr
+ fi
+ SEQ=1
end_row() {
- html_~tr
- html_~table
- html_~td
- html_~tr
+ else
+ html_~tr
+ html_~table
+ html_~td
+ html_~tr
+ fi
-# HTML width of label (for alignment)
-width() {
- LABEL="$1"
- if [ ${#LABEL} -gt 2 ]; then
- WIDTH=""
- else
- WIDTH="width=\"20\""
- fi
- echo $WIDTH
+# Create test output_*.txt file and copy to stdout.txt
+# Rename to copy_output?
# TEST_LOG = test log
test_log() {
TEST_LOG="output_$LOGCOUNT.txt"
@@ -557,10 +456,11 @@
stars() {
- for i in {1..90}
+ for i in {1..120}
do
- printf "*"
+ printf "*">>$REPORT
done
echo
@@ -661,7 +561,7 @@
RESULT=$( result )
test_log
- output_html test $SEQ "$LASTCMD" $RESULT $TEST_LOG
+ output_report test $SEQ "$LASTCMD" $RESULT $TEST_LOG
check_bailout
@@ -746,9 +646,21 @@
echo "TOOK (seconds): $(( STOP-START ))"
RESULT=$( result )
+ NOPASO="Failed"
+#Verifies the value of $RESULT, if the test was successful
+#increases $TESTSPASSED by 1, if the test Failed
+#increases $TESTSFAILED by 1.
+ if [ "$RESULT" != "Passed" ]; then
+ let TESTSFAILED=$TESTSFAILED+1
+ else
+ let TESTSPASSED=$TESTSPASSED+1
+ fi
test_log
LASTCMD="$@"
check_bailout
@@ -764,7 +676,7 @@
RESULT=$( result )
test_log
- output_html test "$SYMBOL" "$LASTCMD" $RESULT
+ output_report test "$SYMBOL" "$LASTCMD" $RESULT
check_bailout
@@ -882,7 +794,7 @@
test_exec rm -f castor*.jar *gt2ft*.jar ant.jar
test_exec cd $TOPDIR
test_exec tar -pczf $RUNDIR/swift-$DATE.tar.gz $SWIFT_HOME
- output_html package "swift-$DATE.tar.gz"
+ output_report package "swift-$DATE.tar.gz"
# Generate the sites.sed file
@@ -965,6 +877,32 @@
fi
+# Print the number of tests run, failed and passed.
+# Revision:001
+group_statistics(){
+ printf "\n $TESTCOUNT Tests run\t$TESTSFAILED Tests failed\t$TESTSPASSED Tests succeeded. \n\n">>$REPORT
+ else
+# html_tr group
+# html_td neutral
+# html "$TESTCOUNT Tests run"
+# html_~td
+# html_td success
+# html "$TESTSPASSED Tests succeeded"
+# html_~td
+# html_td failure
+# html "$TESTSFAILED Tests failed"
+# html_~td
+# html_~tr
+ printf "<tr class=\"group\">">>$HTML
+ printf "<td class=\"neutral\"> $TESTCOUNT Tests run. </td>">>$HTML
+ printf "<td class=\"success\"> $TESTSPASSED Tests succeeded. </td>">>$HTML
+ printf "<td class=\"failure\"> $TESTSFAILED Tests failed. </td>">>$HTML
+ printf "</tr>">>$HTML
+ # printf "\n $TESTCOUNT Tests run\t$TESTSFAILED Tests failed\t$TESTSPASSED Tests succeeded. \n\n">>$HTML
+ fi
# Execute all tests in current GROUP
test_group() {
@@ -985,15 +923,19 @@
echo -e "\nTest case: $TESTNAME"
cp -v $GROUP/$TESTNAME .
TESTLINK=$TESTNAME
start_row
for (( i=0; $i<$ITERS_LOCAL; i=$i+1 )); do
swift_test_case $TESTNAME
(( $TESTCOUNT >= $NUMBER_OF_TESTS )) && return
(( $SHUTDOWN )) && return
done
- end_row
+ end_row
done
+ group_statistics
+ TESTCOUNT=0
+ TESTSPASSED=0
+ TESTSFAILED=0
SCRIPTS=$( echo $GROUP/*.test.sh )
checkfail "Could not list: $GROUP"
@@ -1013,8 +955,10 @@
done
end_row
done
if [[ $WORK == "" ]]
then
WORK=$TOPDIR/work
@@ -1046,12 +990,16 @@
make_sites_sed
+# Here the report starts.
+# Call to function header()
header
-start_test_results
+if [ $TEXTREPORT == 1 ]; then
+ printf "Test Results\n\n">>$REPORT
+else
+ start_test_results
+fi
cd $TOPDIR
start_group "Build"
TESTLINK=
EXITONFAILURE=true
if [ "$SKIP_CHECKOUT" != "1" ]; then
@@ -1121,8 +1069,6 @@
(( $SHUTDOWN )) && break
done
-footer
exit 0
# Local Variables:
More information about the Swift-commit
