[Swift-commit] r4613 - in trunk/tests/language-behaviour: . IO arithmetic arrays foreach mappers
achavez at ci.uchicago.edu achavez at ci.uchicago.edu
Tue Jun 14 09:02:16 CDT 2011
Author: achavez
Date: 2011-06-14 09:02:14 -0500 (Tue, 14 Jun 2011)
New Revision: 4613
Added:
   trunk/tests/language-behaviour/IO/
   trunk/tests/language-behaviour/IO/001-echo.out.expected
   trunk/tests/language-behaviour/IO/001-echo.swift
   trunk/tests/language-behaviour/IO/0011-echo-20110603-1140-rr21aum3.log
   trunk/tests/language-behaviour/IO/0011-echo.kml
   trunk/tests/language-behaviour/IO/0011-echo.out
   trunk/tests/language-behaviour/IO/0011-echo.out.expected
   trunk/tests/language-behaviour/IO/0011-echo.swift
   trunk/tests/language-behaviour/IO/0011-echo.xml
   trunk/tests/language-behaviour/IO/0012-echo-map-20110603-1140-n9omdlcb.log
   trunk/tests/language-behaviour/IO/0012-echo-map.kml
   trunk/tests/language-behaviour/IO/0012-echo-map.out.expected
   trunk/tests/language-behaviour/IO/0012-echo-map.swift
   trunk/tests/language-behaviour/IO/0012-echo-map.xml
   trunk/tests/language-behaviour/IO/readData.circle.in
   trunk/tests/language-behaviour/IO/readData.circle.out.expected
   trunk/tests/language-behaviour/IO/readData.circleArray.in
   trunk/tests/language-behaviour/IO/readData.circleArray.out.expected
   trunk/tests/language-behaviour/IO/readData.float.out.expected
   trunk/tests/language-behaviour/IO/readData.int.in
   trunk/tests/language-behaviour/IO/readData.int.out.expected
   trunk/tests/language-behaviour/IO/readData.intArray.in
   trunk/tests/language-behaviour/IO/readData.intArray.out.expected
   trunk/tests/language-behaviour/IO/readData.stringArray.in
   trunk/tests/language-behaviour/IO/readData.stringArray.out.expected
   trunk/tests/language-behaviour/IO/readData.swift
   trunk/tests/language-behaviour/IO/readData2.in
   trunk/tests/language-behaviour/IO/readData2.out.expected
   trunk/tests/language-behaviour/IO/readData2.swift
   trunk/tests/language-behaviour/IO/writeDataPrimitive.out.expected
   trunk/tests/language-behaviour/IO/writeDataPrimitive.swift
   trunk/tests/language-behaviour/IO/writeDataStringArray.swift
   trunk/tests/language-behaviour/IO/writeDataStringArray2.out.expected
   trunk/tests/language-behaviour/IO/writeDataStringArray2.swift
   trunk/tests/language-behaviour/IO/writeDataStruct.out.expected
   trunk/tests/language-behaviour/IO/writeDataStruct.swift
   trunk/tests/language-behaviour/IO/writeDataStructArray2.out.expected
   trunk/tests/language-behaviour/IO/writeDataStructArray2.swift
   trunk/tests/language-behaviour/arithmetic/
   trunk/tests/language-behaviour/arithmetic/006-add.out.expected
   trunk/tests/language-behaviour/arithmetic/006-add.swift
   trunk/tests/language-behaviour/arithmetic/007-add-in-proc-add.out.expected
   trunk/tests/language-behaviour/arithmetic/007-add-in-proc-add.swift
   trunk/tests/language-behaviour/arithmetic/008-add-multiply.out.expected
   trunk/tests/language-behaviour/arithmetic/008-add-multiply.swift
   trunk/tests/language-behaviour/arithmetic/009-multiply.out.expected
   trunk/tests/language-behaviour/arithmetic/009-multiply.swift
   trunk/tests/language-behaviour/arithmetic/010-divide.out.expected
   trunk/tests/language-behaviour/arithmetic/010-divide.swift
   trunk/tests/language-behaviour/arithmetic/011-divide-float.out.expected
   trunk/tests/language-behaviour/arithmetic/011-divide-float.swift
   trunk/tests/language-behaviour/arithmetic/013-mod.out.expected
   trunk/tests/language-behaviour/arithmetic/013-mod.swift
   trunk/tests/language-behaviour/arithmetic/014-subtract.out.expected
   trunk/tests/language-behaviour/arithmetic/014-subtract.swift
   trunk/tests/language-behaviour/arithmetic/0145-unary-subtact.out.expected
   trunk/tests/language-behaviour/arithmetic/0145-unary-subtact.swift
   trunk/tests/language-behaviour/arithmetic/015-lesseq.out.expected
   trunk/tests/language-behaviour/arithmetic/015-lesseq.swift
   trunk/tests/language-behaviour/arithmetic/016-greatereq.out.expected
   trunk/tests/language-behaviour/arithmetic/016-greatereq.swift
   trunk/tests/language-behaviour/arithmetic/017-greater.out.expected
   trunk/tests/language-behaviour/arithmetic/017-greater.swift
   trunk/tests/language-behaviour/arithmetic/018-less.out.expected
   trunk/tests/language-behaviour/arithmetic/018-less.swift
   trunk/tests/language-behaviour/arithmetic/019-equals.out.expected
   trunk/tests/language-behaviour/arithmetic/019-equals.swift
   trunk/tests/language-behaviour/arithmetic/0191-not-equals.out.expected
   trunk/tests/language-behaviour/arithmetic/0191-not-equals.swift
   trunk/tests/language-behaviour/arrays/
   trunk/tests/language-behaviour/arrays/020-array.out.expected
   trunk/tests/language-behaviour/arrays/020-array.swift
   trunk/tests/language-behaviour/arrays/021-array-in-proc-param.out.expected
   trunk/tests/language-behaviour/arrays/021-array-in-proc-param.swift
   trunk/tests/language-behaviour/arrays/022-array-with-exprs.out.expected
   trunk/tests/language-behaviour/arrays/022-array-with-exprs.swift
   trunk/tests/language-behaviour/arrays/025-array-passing.out.expected
   trunk/tests/language-behaviour/arrays/025-array-passing.swift
   trunk/tests/language-behaviour/arrays/027-array-assignment.out.expected
   trunk/tests/language-behaviour/arrays/027-array-assignment.swift
   trunk/tests/language-behaviour/arrays/028-array-assignment.swift
   trunk/tests/language-behaviour/arrays/029-array-assignment-sequence.swift
   trunk/tests/language-behaviour/arrays/083-array-assign.swift
   trunk/tests/language-behaviour/arrays/110-array-range-exprs.swift
   trunk/tests/language-behaviour/arrays/1101-array-range.swift
   trunk/tests/language-behaviour/arrays/1102-array-range-step.swift
   trunk/tests/language-behaviour/arrays/111-array-individual-assigns.out.expected
   trunk/tests/language-behaviour/arrays/111-array-individual-assigns.swift
   trunk/tests/language-behaviour/arrays/162-dot-on-array.out.expected
   trunk/tests/language-behaviour/arrays/162-dot-on-array.swift
   trunk/tests/language-behaviour/arrays/array_multidimensional-2.swift
   trunk/tests/language-behaviour/arrays/array_multidimensional_assign.swift
   trunk/tests/language-behaviour/arrays/array_multidimensional_index.out.expected
   trunk/tests/language-behaviour/arrays/array_multidimensional_index.swift
   trunk/tests/language-behaviour/foreach/
   trunk/tests/language-behaviour/foreach/0083-for.one.in
   trunk/tests/language-behaviour/foreach/0083-for.one.in.out.expected
   trunk/tests/language-behaviour/foreach/0083-for.swift
   trunk/tests/language-behaviour/foreach/0083-for.two.in
   trunk/tests/language-behaviour/foreach/0083-for.two.in.out.expected
   trunk/tests/language-behaviour/foreach/0084-for.swift
   trunk/tests/language-behaviour/foreach/050-foreach.blue.out.expected
   trunk/tests/language-behaviour/foreach/050-foreach.green.out.expected
   trunk/tests/language-behaviour/foreach/050-foreach.red.out.expected
   trunk/tests/language-behaviour/foreach/050-foreach.swift
   trunk/tests/language-behaviour/foreach/051-foreach.blue.out.expected
   trunk/tests/language-behaviour/foreach/051-foreach.green.out.expected
   trunk/tests/language-behaviour/foreach/051-foreach.red.out.expected
   trunk/tests/language-behaviour/foreach/051-foreach.swift
   trunk/tests/language-behaviour/foreach/052-foreach-index.blue.out.expected
   trunk/tests/language-behaviour/foreach/052-foreach-index.green.out.expected
   trunk/tests/language-behaviour/foreach/052-foreach-index.red.out.expected
   trunk/tests/language-behaviour/foreach/052-foreach-index.swift
   trunk/tests/language-behaviour/foreach/056-foreach-if.swift
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.check.sh
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.clean.sh
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0000.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0001.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0002.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0003.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0004.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0005.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0006.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0007.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0008.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0009.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0000.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0001.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0002.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0003.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0004.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0005.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0006.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0007.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0008.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0009.out.expected
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.setup.sh
   trunk/tests/language-behaviour/foreach/057-foreach-twice-range.swift
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.check.sh
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.clean.sh
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0000.out.expected
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0001.out.expected
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0002.out.expected
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0000.out.expected
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0001.out.expected
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0002.out.expected
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.setup.sh
   trunk/tests/language-behaviour/foreach/058-foreach-twice-string.swift
   trunk/tests/language-behaviour/mappers/
   trunk/tests/language-behaviour/mappers/0032-strcat-mapper-param.1.out.expected
   trunk/tests/language-behaviour/mappers/0032-strcat-mapper-param.swift
   trunk/tests/language-behaviour/mappers/070-singlefilemapper.out.expected
   trunk/tests/language-behaviour/mappers/070-singlefilemapper.swift
   trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.check.sh
   trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.clean.sh
   trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.in
   trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.out.expected
   trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.setup.sh
   trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.swift
   trunk/tests/language-behaviour/mappers/072-simplemapper.out.expected
   trunk/tests/language-behaviour/mappers/072-simplemapper.swift
   trunk/tests/language-behaviour/mappers/0721-simplemapper-array.0000.out.expected
   trunk/tests/language-behaviour/mappers/0721-simplemapper-array.0005.out.expected
   trunk/tests/language-behaviour/mappers/0721-simplemapper-array.swift
   trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000000000.out.expected
   trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000000005.out.expected
   trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000075943.out.expected
   trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.swift
   trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.0.out.expected
   trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.5.out.expected
   trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.75943.out.expected
   trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.swift
   trunk/tests/language-behaviour/mappers/073-simplemapper.out.expected
   trunk/tests/language-behaviour/mappers/073-simplemapper.swift
   trunk/tests/language-behaviour/mappers/075-array-mapper.first.out.expected
   trunk/tests/language-behaviour/mappers/075-array-mapper.second.out.expected
   trunk/tests/language-behaviour/mappers/075-array-mapper.swift
   trunk/tests/language-behaviour/mappers/075-array-mapper.third.out.expected
   trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.first.out.expected
   trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.second.out.expected
   trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.swift
   trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.third.out.expected
   trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh
   trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.clean.sh
   trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.setup.sh
   trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.swift
   trunk/tests/language-behaviour/mappers/07513-fixed-array-mapper-filename.real.out.expected
   trunk/tests/language-behaviour/mappers/07513-fixed-array-mapper-filename.swift
   trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.a.in
   trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.b.in
   trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.real.out.expected
   trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.swift
   trunk/tests/language-behaviour/mappers/0752-csv-mapper.csv
   trunk/tests/language-behaviour/mappers/0752-csv-mapper.left-two.out.expected
   trunk/tests/language-behaviour/mappers/0752-csv-mapper.left-zero.out.expected
   trunk/tests/language-behaviour/mappers/0752-csv-mapper.right-one.out.expected
   trunk/tests/language-behaviour/mappers/0752-csv-mapper.swift
   trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.a.out.expected
   trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.b.out.expected
   trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.blue.in
   trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.c.out.expected
   trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.green.in
   trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.red.in
   trunk/tests/language-behaviour/mappers/0754-csv-mapper-input.out.expected
   trunk/tests/language-behaviour/mappers/0754-csv-mapper-input.swift
   trunk/tests/language-behaviour/mappers/0754-csv-mapper.csv
   trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-one.in
   trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-two.in
   trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-zero.in
   trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-one.in
   trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-two.in
   trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-zero.in
   trunk/tests/language-behaviour/mappers/0755-ext-mapper.0.3.2.1.out.expected
   trunk/tests/language-behaviour/mappers/0755-ext-mapper.AAA.out.expected
   trunk/tests/language-behaviour/mappers/0755-ext-mapper.____.out.expected
   trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh
   trunk/tests/language-behaviour/mappers/0755-ext-mapper.swift
   trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.out.expected
   trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.sh
   trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.swift
   trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.inside.out.expected
   trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.mapper.out.expected
   trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.sh
   trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.swift
   trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.sh
   trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.swift
   trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.sh
   trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.swift
   trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.swift
   trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.sh
   trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.swift
   trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.sh
   trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.swift
   trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.sh
   trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.swift
   trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.sh
   trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.swift
   trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.sh
   trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.swift
   trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.sh
   trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.swift
   trunk/tests/language-behaviour/mappers/076-structured-regexp-mapper.b.out.expected
   trunk/tests/language-behaviour/mappers/076-structured-regexp-mapper.swift
   trunk/tests/language-behaviour/mappers/077-regexp-mapper.foo.out.expected
   trunk/tests/language-behaviour/mappers/077-regexp-mapper.swift
   trunk/tests/language-behaviour/mappers/078-singlefilemapper-name-expression.out.expected
   trunk/tests/language-behaviour/mappers/078-singlefilemapper-name-expression.swift
   trunk/tests/language-behaviour/mappers/0781-singlefilemapper-name-expression.out.expected
   trunk/tests/language-behaviour/mappers/0781-singlefilemapper-name-expression.swift
   trunk/tests/language-behaviour/mappers/079-regression-r970-simple-mapper-expr-prefix.out.expected
   trunk/tests/language-behaviour/mappers/079-regression-r970-simple-mapper-expr-prefix.swift
   trunk/tests/language-behaviour/mappers/0791-regression-r970-simple-mapper-expr-prefix.out.expected
   trunk/tests/language-behaviour/mappers/0791-regression-r970-simple-mapper-expr-prefix.swift
   trunk/tests/language-behaviour/mappers/150-filesys_mapper.swift
   trunk/tests/language-behaviour/mappers/760-csv-mapper.sh
   trunk/tests/language-behaviour/mappers/760-csv-mapper.swift
   trunk/tests/language-behaviour/mappers/T074-simplemapper.aleph.out.expected
   trunk/tests/language-behaviour/mappers/T074-simplemapper.beth.out.expected
   trunk/tests/language-behaviour/mappers/T074-simplemapper.gimel.out.expected
   trunk/tests/language-behaviour/mappers/T074-simplemapper.swift
   trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.aleph.out.expected
   trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.beth.out.expected
   trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.swift
   trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.aleph.out.expected
   trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.beth.out.expected
   trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.swift
   trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate.epsilon.out.expected
   trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate.sigma.out.expected
   trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate_moresubordinate.hamza.out.expected
   trunk/tests/language-behaviour/mappers/T078-simplemapper-nosuffix.swift
   trunk/tests/language-behaviour/mappers/T078-simplemapper-nosuffix_nodot.out.expected
   trunk/tests/language-behaviour/mappers/T079-simplemapper-nosuffix_exception.swift
Removed:
   trunk/tests/language-behaviour/006-add.out.expected
   trunk/tests/language-behaviour/006-add.swift
   trunk/tests/language-behaviour/007-add-in-proc-add.out.expected
   trunk/tests/language-behaviour/007-add-in-proc-add.swift
   trunk/tests/language-behaviour/008-add-multiply.out.expected
   trunk/tests/language-behaviour/008-add-multiply.swift
   trunk/tests/language-behaviour/009-multiply.out.expected
   trunk/tests/language-behaviour/009-multiply.swift
   trunk/tests/language-behaviour/010-divide.out.expected
   trunk/tests/language-behaviour/010-divide.swift
   trunk/tests/language-behaviour/011-divide-float.out.expected
   trunk/tests/language-behaviour/011-divide-float.swift
   trunk/tests/language-behaviour/013-mod.out.expected
   trunk/tests/language-behaviour/013-mod.swift
   trunk/tests/language-behaviour/014-subtract.out.expected
   trunk/tests/language-behaviour/014-subtract.swift
   trunk/tests/language-behaviour/0145-unary-subtact.out.expected
   trunk/tests/language-behaviour/0145-unary-subtact.swift
   trunk/tests/language-behaviour/015-lesseq.out.expected
   trunk/tests/language-behaviour/015-lesseq.swift
   trunk/tests/language-behaviour/016-greatereq.out.expected
   trunk/tests/language-behaviour/016-greatereq.swift
   trunk/tests/language-behaviour/017-greater.out.expected
   trunk/tests/language-behaviour/017-greater.swift
   trunk/tests/language-behaviour/018-less.out.expected
   trunk/tests/language-behaviour/018-less.swift
   trunk/tests/language-behaviour/019-equals.out.expected
   trunk/tests/language-behaviour/019-equals.swift
   trunk/tests/language-behaviour/0191-not-equals.out.expected
   trunk/tests/language-behaviour/0191-not-equals.swift
Log:
Use txt extension- will be an asciidoc file
Deleted: trunk/tests/language-behaviour/006-add.out.expected
--- trunk/tests/language-behaviour/006-add.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/006-add.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-135
Deleted: trunk/tests/language-behaviour/006-add.swift
--- trunk/tests/language-behaviour/006-add.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/006-add.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-type messagefile {}
-(messagefile t) greeting(int m) {
-    app {
-        echo m stdout=@filename(t);
-messagefile outfile <"006-add.out">;
-int i = 42+93;
-outfile = greeting(i);
Deleted: trunk/tests/language-behaviour/007-add-in-proc-add.out.expected
--- trunk/tests/language-behaviour/007-add-in-proc-add.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/007-add-in-proc-add.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-189
Deleted: trunk/tests/language-behaviour/007-add-in-proc-add.swift
--- trunk/tests/language-behaviour/007-add-in-proc-add.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/007-add-in-proc-add.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,12 +0,0 @@
-    app {
-messagefile outfile <"007-add-in-proc-add.out">;
-outfile = greeting(88+101);
Deleted: trunk/tests/language-behaviour/008-add-multiply.out.expected
--- trunk/tests/language-behaviour/008-add-multiply.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/008-add-multiply.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-8
Deleted: trunk/tests/language-behaviour/008-add-multiply.swift
--- trunk/tests/language-behaviour/008-add-multiply.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/008-add-multiply.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"008-add-multiply.out">;
-int i = 2+2*3;
Deleted: trunk/tests/language-behaviour/009-multiply.out.expected
--- trunk/tests/language-behaviour/009-multiply.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/009-multiply.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-42
Deleted: trunk/tests/language-behaviour/009-multiply.swift
--- trunk/tests/language-behaviour/009-multiply.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/009-multiply.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"009-multiply.out">;
-int i = 6*7;
Deleted: trunk/tests/language-behaviour/010-divide.out.expected
--- trunk/tests/language-behaviour/010-divide.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/010-divide.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-33
Deleted: trunk/tests/language-behaviour/010-divide.swift
--- trunk/tests/language-behaviour/010-divide.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/010-divide.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"010-divide.out">;
-int i = 99%/3;
Deleted: trunk/tests/language-behaviour/011-divide-float.out.expected
--- trunk/tests/language-behaviour/011-divide-float.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/011-divide-float.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-0.3333333333333333
Deleted: trunk/tests/language-behaviour/011-divide-float.swift
--- trunk/tests/language-behaviour/011-divide-float.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/011-divide-float.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-(messagefile t) greeting(float m) {
-    app {
-messagefile outfile <"011-divide-float.out">;
-float i = 1.0/3.0;
Deleted: trunk/tests/language-behaviour/013-mod.out.expected
--- trunk/tests/language-behaviour/013-mod.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/013-mod.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-19
Deleted: trunk/tests/language-behaviour/013-mod.swift
--- trunk/tests/language-behaviour/013-mod.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/013-mod.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"013-mod.out">;
-int i = 99 %% 20;
Deleted: trunk/tests/language-behaviour/014-subtract.out.expected
--- trunk/tests/language-behaviour/014-subtract.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/014-subtract.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
--37
Deleted: trunk/tests/language-behaviour/014-subtract.swift
--- trunk/tests/language-behaviour/014-subtract.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/014-subtract.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"014-subtract.out">;
-int i = 44-81;
Deleted: trunk/tests/language-behaviour/0145-unary-subtact.out.expected
--- trunk/tests/language-behaviour/0145-unary-subtact.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/0145-unary-subtact.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
--989929
Deleted: trunk/tests/language-behaviour/0145-unary-subtact.swift
--- trunk/tests/language-behaviour/0145-unary-subtact.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/0145-unary-subtact.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,15 +0,0 @@
-    app {
-messagefile outfile <"0145-unary-subtact.out">;
-int j = 989929;
-int i = -j;
Deleted: trunk/tests/language-behaviour/015-lesseq.out.expected
--- trunk/tests/language-behaviour/015-lesseq.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/015-lesseq.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-true
Deleted: trunk/tests/language-behaviour/015-lesseq.swift
--- trunk/tests/language-behaviour/015-lesseq.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/015-lesseq.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-(messagefile t) greeting(boolean m) {
-    app {
-messagefile outfile <"015-lesseq.out">;
-boolean i = 7<=9;
Deleted: trunk/tests/language-behaviour/016-greatereq.out.expected
--- trunk/tests/language-behaviour/016-greatereq.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/016-greatereq.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-false
Deleted: trunk/tests/language-behaviour/016-greatereq.swift
--- trunk/tests/language-behaviour/016-greatereq.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/016-greatereq.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"016-greatereq.out">;
-boolean i = 7>=9;
Deleted: trunk/tests/language-behaviour/017-greater.out.expected
--- trunk/tests/language-behaviour/017-greater.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/017-greater.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-false
Deleted: trunk/tests/language-behaviour/017-greater.swift
--- trunk/tests/language-behaviour/017-greater.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/017-greater.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"017-greater.out">;
-boolean i = 7>9;
Deleted: trunk/tests/language-behaviour/018-less.out.expected
--- trunk/tests/language-behaviour/018-less.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/018-less.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-true
Deleted: trunk/tests/language-behaviour/018-less.swift
--- trunk/tests/language-behaviour/018-less.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/018-less.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"018-less.out">;
-boolean i = 7<9;
Deleted: trunk/tests/language-behaviour/019-equals.out.expected
--- trunk/tests/language-behaviour/019-equals.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/019-equals.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-false
Deleted: trunk/tests/language-behaviour/019-equals.swift
--- trunk/tests/language-behaviour/019-equals.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/019-equals.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"019-equals.out">;
-boolean i = 7==9;
Deleted: trunk/tests/language-behaviour/0191-not-equals.out.expected
--- trunk/tests/language-behaviour/0191-not-equals.out.expected	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/0191-not-equals.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1 +0,0 @@
-true
Deleted: trunk/tests/language-behaviour/0191-not-equals.swift
--- trunk/tests/language-behaviour/0191-not-equals.swift	2011-06-14 02:17:30 UTC (rev 4612)
+++ trunk/tests/language-behaviour/0191-not-equals.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -1,14 +0,0 @@
-    app {
-messagefile outfile <"0191-not-equals.out">;
-boolean i = 7!=9;
Added: trunk/tests/language-behaviour/IO/001-echo.out.expected
--- trunk/tests/language-behaviour/IO/001-echo.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/001-echo.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+hello
Added: trunk/tests/language-behaviour/IO/001-echo.swift
--- trunk/tests/language-behaviour/IO/001-echo.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/001-echo.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,12 @@
+type messagefile;
+(messagefile t) greeting() {
+    app {
+        echo "hello" stdout=@filename(t);
+messagefile outfile <"001-echo.out">;
+outfile = greeting();
Added: trunk/tests/language-behaviour/IO/0011-echo-20110603-1140-rr21aum3.log
--- trunk/tests/language-behaviour/IO/0011-echo-20110603-1140-rr21aum3.log	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0011-echo-20110603-1140-rr21aum3.log	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,111 @@
+2011-06-03 11:40:08,649-0500 DEBUG Loader Max heap: 238616576
+2011-06-03 11:40:08,650-0500 DEBUG textfiles BEGIN SWIFTSCRIPT:
+type messagefile;
+app (messagefile t) greeting() {
+messagefile outfile <"0011-echo.out">;
+2011-06-03 11:40:08,650-0500 DEBUG textfiles END SWIFTSCRIPT:
+2011-06-03 11:40:08,650-0500 INFO  Loader 0011-echo.swift: source file is new. Recompiling.
+2011-06-03 11:40:09,279-0500 INFO  Karajan Validation of XML intermediate file was successful
+2011-06-03 11:40:09,475-0500 DEBUG Loader setting: tc.file to: ./tc.data
+2011-06-03 11:40:09,475-0500 DEBUG textfiles using default sites file
+2011-06-03 11:40:09,493-0500 INFO  VDL2ExecutionContext Stack dump:
+Level 1
+[iA = 0, iB = 0, bA = false, bB = false]
+	vdl:instanceconfig = Swift configuration []
+	vdl:operation = run
+	PATH_SEPARATOR = /
+	swift.home = /home/Alberto/Swift/cog/modules/swift/dist/swift-svn/bin/..
+	#vdl:futureWrapperMap = org.griphyn.vdl.karajan.WrapperMap at 171f189
+2011-06-03 11:40:10,075-0500 INFO  unknown Using sites file: /home/Alberto/Swift/cog/modules/swift/dist/swift-svn/bin/../etc/sites.xml
+2011-06-03 11:40:10,112-0500 INFO  unknown Using tc.data: ./tc.data
+2011-06-03 11:40:10,212-0500 INFO  AbstractScheduler Setting resources to: {localhost=localhost}
+2011-06-03 11:40:10,702-0500 INFO  unknown Swift svn swift-r4543 cog-r3143
+2011-06-03 11:40:10,703-0500 INFO  unknown RUNID id=run:20110603-1140-rr21aum3
+2011-06-03 11:40:10,767-0500 DEBUG greeting PROCEDURE line=3 thread=0-1 name=greeting
+2011-06-03 11:40:10,774-0500 INFO  vdl:execute START thread=0-1 tr=echo
+2011-06-03 11:40:10,798-0500 INFO  WeightedHostScoreScheduler CONTACT_SELECTED host=localhost, score=1.000
+2011-06-03 11:40:10,802-0500 INFO  GlobalSubmitQueue No global submit throttle set. Using default (1024)
+2011-06-03 11:40:10,805-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:10,873-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:10,876-0500 INFO  vdl:initshareddir START host=localhost - Initializing shared directory
+2011-06-03 11:40:10,880-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:10,899-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:10,902-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:10,904-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:10,908-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:10,912-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:10,914-0500 INFO  vdl:initshareddir END host=localhost - Done initializing shared directory
+2011-06-03 11:40:10,917-0500 DEBUG vdl:execute2 THREAD_ASSOCIATION jobid=echo-1geu42bk thread=0-1-1 host=localhost replicationGroup=0geu42bk
+2011-06-03 11:40:10,925-0500 INFO  vdl:createdirset START jobid=echo-1geu42bk host=localhost - Initializing directory structure
+2011-06-03 11:40:10,926-0500 INFO  vdl:createdirset END jobid=echo-1geu42bk - Done initializing directory structure
+2011-06-03 11:40:10,926-0500 INFO  vdl:dostagein START jobid=echo-1geu42bk - Staging in files
+2011-06-03 11:40:10,932-0500 INFO  vdl:dostagein END jobid=echo-1geu42bk - Staging in finished
+2011-06-03 11:40:10,934-0500 DEBUG vdl:execute2 JOB_START jobid=echo-1geu42bk tr=echo arguments=[?:string = hello - Closed] tmpdir=0011-echo-20110603-1140-rr21aum3/jobs/1/echo-1geu42bk host=localhost
+2011-06-03 11:40:10,937-0500 DEBUG textfiles BEGIN TC:
+#This is the transformation catalog.
+#It comes pre-configured with a number of simple transformations with
+#paths that are likely to work on a linux box. However, on some systems,
+#the paths to these executables will be different (for example, sometimes
+#some of these programs are found in /usr/bin rather than in /bin)
+#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
+#there must be no trailing whitespace at the end of each line.
+# sitename  transformation  path   INSTALLED  platform  profiles
+localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
+localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
+localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
+localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
+localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
+localhost 	cp 		/bin/cp         INSTALLED	INTEL32::LINUX	null
+localhost	wc		/usr/bin/wc	INSTALLED	INTEL32::LINUX	null
+localhost	touch	/bin/touch	INSTALLED	INTEL32::LINUX	null
+localhost	sleep	/bin/sleep	INSTALLED	INTEL32::LINUX	null
+localhost	delayedcat	/home/Alberto/Swift/cog/modules/swift/tests/language-behaviour/delayedcat.sh	INSTALLED	INTEL32::LINUX	null
+2011-06-03 11:40:10,937-0500 DEBUG textfiles END TC:
+2011-06-03 11:40:10,946-0500 INFO  GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION, identity=urn:0-1-1-1307119210103) is /bin/bash shared/_swiftwrap echo-1geu42bk -jobdir 1 -scratch  -e /bin/echo -out 0011-echo.out -err stderr.txt -i -d  -if  -of 0011-echo.out -k  -cdmfile  -status files -a hello
+2011-06-03 11:40:10,952-0500 INFO  JobSubmissionTaskHandler Submit: in: /var/tmp/0011-echo-20110603-1140-rr21aum3 command: /bin/bash /var/tmp/0011-echo-20110603-1140-rr21aum3/shared/_swiftwrap echo-1geu42bk -jobdir 1 -scratch  -e /bin/echo -out 0011-echo.out -err stderr.txt -i -d  -if  -of 0011-echo.out -k  -cdmfile  -status files -a hello
+2011-06-03 11:40:11,045-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:11,048-0500 DEBUG vdl:checkjobstatus START jobid=echo-1geu42bk
+2011-06-03 11:40:11,051-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:11,052-0500 INFO  vdl:checkjobstatus SUCCESS jobid=echo-1geu42bk - Success file found
+2011-06-03 11:40:11,053-0500 DEBUG vdl:execute2 STAGING_OUT jobid=echo-1geu42bk
+2011-06-03 11:40:11,055-0500 INFO  vdl:dostageout START jobid=echo-1geu42bk - Staging out files
+2011-06-03 11:40:11,056-0500 DEBUG vdl:dostageout stageouts: [[$, outfile:messagefile = ? - Open]]
+2011-06-03 11:40:11,064-0500 DEBUG vdl:dostageout FILE_STAGE_OUT_START srcname=0011-echo.out srcdir=0011-echo-20110603-1140-rr21aum3/shared/ srchost=localhost destdir= desthost=localhost provider=file
+2011-06-03 11:40:11,065-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:11,077-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:11,078-0500 DEBUG vdl:dostageout FILE_STAGE_OUT_END srcname=0011-echo.out srcdir=0011-echo-20110603-1140-rr21aum3/shared/ srchost=localhost destdir= desthost=localhost provider=file
+2011-06-03 11:40:11,083-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:11,092-0500 INFO  vdl:dostageout END jobid=echo-1geu42bk - Staging out finished
+2011-06-03 11:40:11,097-0500 DEBUG vdl:execute2 JOB_END jobid=echo-1geu42bk
+2011-06-03 11:40:11,098-0500 INFO  vdl:execute END_SUCCESS thread=0-1 tr=echo
+2011-06-03 11:40:11,100-0500 DEBUG greeting PROCEDURE_END line=3
+2011-06-03 11:40:11,113-0500 DEBUG vdl:mains Starting cleanups
+2011-06-03 11:40:11,116-0500 INFO  vdl:cleanups START cleanups=[[0011-echo-20110603-1140-rr21aum3, localhost]]
+2011-06-03 11:40:11,118-0500 INFO  vdl:cleanup START dir=0011-echo-20110603-1140-rr21aum3 host=localhost
+2011-06-03 11:40:11,119-0500 DEBUG vdl:cleanup cdmfile
+2011-06-03 11:40:11,123-0500 INFO  GridExec TASK_DEFINITION: Task(type=JOB_SUBMISSION, identity=urn:0-1-1307119210114) is /bin/rm -rf 0011-echo-20110603-1140-rr21aum3
+2011-06-03 11:40:11,123-0500 INFO  JobSubmissionTaskHandler Submit: in: /var/tmp command: /bin/rm -rf 0011-echo-20110603-1140-rr21aum3
+2011-06-03 11:40:11,123-0500 INFO  LateBindingScheduler JobQueue: 0
+2011-06-03 11:40:11,130-0500 INFO  vdl:cleanup END dir=0011-echo-20110603-1140-rr21aum3 host=localhost
+2011-06-03 11:40:11,131-0500 INFO  vdl:cleanups END cleanups=[[0011-echo-20110603-1140-rr21aum3, localhost]]
+2011-06-03 11:40:11,132-0500 DEBUG vdl:mains Ending cleanups
+2011-06-03 11:40:11,158-0500 INFO  Loader Swift finished with no errors
Added: trunk/tests/language-behaviour/IO/0011-echo.kml
--- trunk/tests/language-behaviour/IO/0011-echo.kml	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0011-echo.kml	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,70 @@
+<project><!-- CACHE ID ee300c16-1a12-4e15-bc05-578b8e792831 -->
+  <import file="sys.xml"/>
+  <import file="scheduler.xml"/>
+  <import file="rlog.xml"/>
+  <import file="vdl.k"/>
+  <types>
+     <xs:schema targetNamespace="http://ci.uchicago.edu/swift/2009/02/swiftscript" xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xs="http://www.w3.org/2001/XMLSchema">
+      	   <xs:simpleType name="messagefile">
+      	   <xs:restriction base="string"/>
+      	   </xs:simpleType>
+     </xs:schema>
+  </types>
+  <global name="swift#string#17000">
+    <vdl:new type="string" value="hello" />
+  </global>
+  <element name="greeting" arguments="t">
+    <parameterlog>
+    <string>output</string>
+    <string>t</string>
+    <vdl:getdatasetprovenanceid var="{t}" />
+    <string>{#thread}</string>
+    </parameterlog>
+    <log level="debug" message="PROCEDURE line=3 thread={#thread} name=greeting"/>
+    <vdl:execute>
+      <vdl:tr>echo</vdl:tr>
+      <vdl:stageout var="{t}"/>
+      <vdl:arguments>
+        <variable>swift#string#17000</variable>
+      </vdl:arguments>
+      <vdl:stdout>
+        <swiftscript:filename>
+         <variable>t</variable>
+        </swiftscript:filename>
+      </vdl:stdout>
+    </vdl:execute>
+    <vdl:closedataset var="{t}"/>
+    <log level="debug" message="PROCEDURE_END line=3"/></element>
+  <set name="outfile">
+        <vdl:new type="messagefile" dbgname="outfile" waitfor="88000">
+          <vdl:mapping descriptor="single_file_mapper">
+            <vdl:parameter name="file" value="0011-echo.out"/>
+          </vdl:mapping>
+        </vdl:new>
+  </set>
+  <parameterlog>
+  <string>intermediate</string>
+  <string>outfile</string>
+  <vdl:getdatasetprovenanceid var="{outfile}" />
+  </parameterlog>
+  <restartLog>
+  	<vdl:mains>
+		<vdl:startprogressticker />
+		<vdl:mainp>
+		    <sequentialWithID>
+		        <sequential>
+		          <greeting>
+		            <parallel>
+		              <variable>outfile</variable>
+		            </parallel>
+		          </greeting>
+		            <partialCloseDataset var="{outfile}" closeID="88000" />
+		        </sequential>
+		    </sequentialWithID>
+		</vdl:mainp>
+		<vdl:stopprogressticker />
+	</vdl:mains>
+  </restartLog>
+</project>
Added: trunk/tests/language-behaviour/IO/0011-echo.out
--- trunk/tests/language-behaviour/IO/0011-echo.out	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0011-echo.out	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+hello
Added: trunk/tests/language-behaviour/IO/0011-echo.out.expected
--- trunk/tests/language-behaviour/IO/0011-echo.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0011-echo.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+hello
Added: trunk/tests/language-behaviour/IO/0011-echo.swift
--- trunk/tests/language-behaviour/IO/0011-echo.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0011-echo.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,10 @@
+type messagefile;
Added: trunk/tests/language-behaviour/IO/0011-echo.xml
--- trunk/tests/language-behaviour/IO/0011-echo.xml	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0011-echo.xml	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,29 @@
+<program xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript"
+         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+         xmlns:xs="http://www.w3.org/2001/XMLSchema">
+  <types>
+     	<type>
+     		<typename>messagefile</typename>
+     		<typealias>string</typealias>
+     		<typestructure></typestructure>
+     	</type>
+  </types>
+  <procedure name="greeting" src="line 3">
+      <output
+    name="t" type="messagefile"
+     xsi:nil="true" />
+    <binding>
+      <application src="line 3">
+        <executable>echo</executable>
+        <stdout><function name="filename">
+          <variableReference>t</variableReference></function></stdout><stringConstant>hello</stringConstant>  </application>
+    </binding>
+  </procedure>
+  <variable name="outfile" type="messagefile" isGlobal="false"><file name="0011-echo.out"/></variable>
+  <call proc="greeting" src="line 9">
+    <output><variableReference>outfile</variableReference></output>
+  </call>
+</program>
Added: trunk/tests/language-behaviour/IO/0012-echo-map-20110603-1140-n9omdlcb.log
--- trunk/tests/language-behaviour/IO/0012-echo-map-20110603-1140-n9omdlcb.log	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0012-echo-map-20110603-1140-n9omdlcb.log	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,33 @@
+2011-06-03 11:40:12,099-0500 DEBUG Loader Max heap: 238616576
+2011-06-03 11:40:12,100-0500 DEBUG textfiles BEGIN SWIFTSCRIPT:
+type messagefile;
+    app {
+messagefile outfile <"0012-echo-map.out"> = greeting();
+2011-06-03 11:40:12,100-0500 DEBUG textfiles END SWIFTSCRIPT:
+2011-06-03 11:40:12,101-0500 INFO  Loader 0012-echo-map.swift: source file is new. Recompiling.
+2011-06-03 11:40:12,683-0500 INFO  Karajan Validation of XML intermediate file was successful
+2011-06-03 11:40:12,882-0500 DEBUG Loader setting: tc.file to: ./tc.data
+2011-06-03 11:40:12,882-0500 DEBUG textfiles using default sites file
+2011-06-03 11:40:12,900-0500 INFO  VDL2ExecutionContext Stack dump:
+Level 1
+	#vdl:futureWrapperMap = org.griphyn.vdl.karajan.WrapperMap at d56b37
+2011-06-03 11:40:13,570-0500 INFO  unknown Using sites file: /home/Alberto/Swift/cog/modules/swift/dist/swift-svn/bin/../etc/sites.xml
+2011-06-03 11:40:13,609-0500 INFO  unknown Using tc.data: ./tc.data
+2011-06-03 11:40:13,715-0500 INFO  AbstractScheduler Setting resources to: {localhost=localhost}
Added: trunk/tests/language-behaviour/IO/0012-echo-map.kml
--- trunk/tests/language-behaviour/IO/0012-echo-map.kml	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0012-echo-map.kml	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,70 @@
+  <types>
+      	   </xs:simpleType>
+     </xs:schema>
+  </types>
+  </global>
+    <parameterlog>
+    </parameterlog>
+    <vdl:execute>
+      <vdl:arguments>
+      </vdl:arguments>
+      <vdl:stdout>
+      </vdl:stdout>
+    </vdl:execute>
+            <vdl:parameter name="file" value="0012-echo-map.out"/>
+          </vdl:mapping>
+        </vdl:new>
+  </set>
+  <parameterlog>
+  </parameterlog>
+  <restartLog>
+  	<vdl:mains>
+		<vdl:mainp>
+		        <sequential>
+		          <greeting>
+		            <parallel>
+		            </parallel>
+		          </greeting>
+		        </sequential>
+		</vdl:mainp>
+	</vdl:mains>
+  </restartLog>
+</project>
Added: trunk/tests/language-behaviour/IO/0012-echo-map.out.expected
--- trunk/tests/language-behaviour/IO/0012-echo-map.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0012-echo-map.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+hello
Added: trunk/tests/language-behaviour/IO/0012-echo-map.swift
--- trunk/tests/language-behaviour/IO/0012-echo-map.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0012-echo-map.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,11 @@
+type messagefile;
+    app {
Added: trunk/tests/language-behaviour/IO/0012-echo-map.xml
--- trunk/tests/language-behaviour/IO/0012-echo-map.xml	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/0012-echo-map.xml	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,29 @@
+  <types>
+     	<type>
+     	</type>
+  </types>
+      <output
+     xsi:nil="true" />
+    <binding>
+      <application src="line 4">
+    </binding>
+  </procedure>
+  <variable name="outfile" type="messagefile" isGlobal="false"><file name="0012-echo-map.out"/></variable>
+  </call>
+</program>
Added: trunk/tests/language-behaviour/IO/readData.circle.in
--- trunk/tests/language-behaviour/IO/readData.circle.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.circle.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,2 @@
+x		y 		r 		name
+10		10 		20.0	TheInnerCircle
\ No newline at end of file
Added: trunk/tests/language-behaviour/IO/readData.circle.out.expected
--- trunk/tests/language-behaviour/IO/readData.circle.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.circle.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+10 10 20 TheInnerCircle
Added: trunk/tests/language-behaviour/IO/readData.circleArray.in
--- trunk/tests/language-behaviour/IO/readData.circleArray.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.circleArray.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
+x		y		r		name
+1		1		5		CircleOne
+2		2		7		CircleTwo
Added: trunk/tests/language-behaviour/IO/readData.circleArray.out.expected
--- trunk/tests/language-behaviour/IO/readData.circleArray.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.circleArray.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+1 2 5 CircleTwo
Added: trunk/tests/language-behaviour/IO/readData.float.out.expected
--- trunk/tests/language-behaviour/IO/readData.float.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.float.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+3.1400001
Added: trunk/tests/language-behaviour/IO/readData.int.in
--- trunk/tests/language-behaviour/IO/readData.int.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.int.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+77777
Added: trunk/tests/language-behaviour/IO/readData.int.out.expected
--- trunk/tests/language-behaviour/IO/readData.int.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.int.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+77777
Added: trunk/tests/language-behaviour/IO/readData.intArray.in
--- trunk/tests/language-behaviour/IO/readData.intArray.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.intArray.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
+1
+5
+9
+0
Added: trunk/tests/language-behaviour/IO/readData.intArray.out.expected
--- trunk/tests/language-behaviour/IO/readData.intArray.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.intArray.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+1 5 9 0
Added: trunk/tests/language-behaviour/IO/readData.stringArray.in
--- trunk/tests/language-behaviour/IO/readData.stringArray.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.stringArray.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
+red
+green
+blue
+thermometer
Added: trunk/tests/language-behaviour/IO/readData.stringArray.out.expected
--- trunk/tests/language-behaviour/IO/readData.stringArray.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.stringArray.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+red green blue thermometer
Added: trunk/tests/language-behaviour/IO/readData.swift
--- trunk/tests/language-behaviour/IO/readData.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,80 @@
+type file;
+type circle {
+	int x;
+	int y;
+	float r;
+	string name;
+(file f) createInt() {
+	app{
+		echo "77777" stdout=@filename(f);
+(file f) createFloat() {
+	app{
+		echo "3.1400001" stdout=@filename(f);
+(file f) write(string data) {
+	app{
+		echo data stdout=@filename(f);
+int i;
+float fl;
+int ia[];
+string sa[];
+circle ca[];
+circle c;
+//will be generated
+file f <"readData.int.in">;
+//input file. assumed on disk
+file g <"readData.intArray.in">;
+// will be generated
+file h <"readData.float.in">;
+f = createInt();
+h = createFloat();
+i = readData(f);
+fl = readData(h);
+file o1 <"readData.int.out">;
+o1 = write(@strcat(i));
+ia = readData(g);
+file o2 <"readData.intArray.out">;
+o2 = write(@strcat(ia[0], " ", ia[1], " ", ia[2], " ", ia[3]));
+sa = readData("readData.stringArray.in");
+file o3 <"readData.stringArray.out">;
+o3 = write(@strcat(sa[0], " ", sa[1], " ", sa[2], " ", sa[3]));
+c = readData("readData.circle.in");
+file o4 <"readData.circle.out">;
+o4 = write(@strcat(c.x, " ", c.y, " ", c.r, " ", c.name));
+ca = readData("readData.circleArray.in");
+file o5 <"readData.circleArray.out">;
+o5 = write(@strcat(ca[0].x, " ", ca[1].y, " ", ca[0].r, " ", ca[1].name));
+file o6 <"readData.float.out">;
+o6 = write(@strcat(fl));
Added: trunk/tests/language-behaviour/IO/readData2.in
--- trunk/tests/language-behaviour/IO/readData2.in	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData2.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,6 @@
+rows[0].columns[0] = 0
+rows[0].columns[1] = 2
+rows[0].columns[2] = 4
+rows[1].columns[0] = 1
+rows[1].columns[1] = 3
+rows[1].columns[2] = 5
Added: trunk/tests/language-behaviour/IO/readData2.out.expected
--- trunk/tests/language-behaviour/IO/readData2.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData2.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+15
Added: trunk/tests/language-behaviour/IO/readData2.swift
--- trunk/tests/language-behaviour/IO/readData2.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/readData2.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,33 @@
+type vector {
+   int columns[];
+type matrix {
+   vector rows[];
+type file;
+(file o) echo(int s) {
+  app {
+    echo s stdout=@o;
+matrix m;
+m = readData2("readData2.in");
+int s;
+s = m.rows[0].columns[0] +
+        m.rows[0].columns[1] +
+        m.rows[0].columns[2] +
+        m.rows[1].columns[0] +
+        m.rows[1].columns[1] +
+        m.rows[1].columns[2] ;
+file out <"readData2.out">;
+out = echo(s);
Added: trunk/tests/language-behaviour/IO/writeDataPrimitive.out.expected
--- trunk/tests/language-behaviour/IO/writeDataPrimitive.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataPrimitive.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+foo
Added: trunk/tests/language-behaviour/IO/writeDataPrimitive.swift
--- trunk/tests/language-behaviour/IO/writeDataPrimitive.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataPrimitive.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,8 @@
+type file;
+string s = "foo";
+file f <"writeDataPrimitive.out">;
+f=writeData(s);
Added: trunk/tests/language-behaviour/IO/writeDataStringArray.swift
--- trunk/tests/language-behaviour/IO/writeDataStringArray.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataStringArray.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,8 @@
+type file;
+string s[] = ["foo", "bar"];
+file f <"writeDataStringArray.out">;
+f=writeData(s);
Added: trunk/tests/language-behaviour/IO/writeDataStringArray2.out.expected
--- trunk/tests/language-behaviour/IO/writeDataStringArray2.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataStringArray2.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,5 @@
+foo
+bar
+baz
+qux
+frrrr
Added: trunk/tests/language-behaviour/IO/writeDataStringArray2.swift
--- trunk/tests/language-behaviour/IO/writeDataStringArray2.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataStringArray2.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type file;
+string s[];
+file f <"writeDataStringArray2.out">;
+f=writeData(s);
+s[2] = "baz";
+s[3] = "qux";
+s[0] = "foo";
+s[1] = "bar";
+s[4] = "frrrr";
Added: trunk/tests/language-behaviour/IO/writeDataStruct.out.expected
--- trunk/tests/language-behaviour/IO/writeDataStruct.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataStruct.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,2 @@
+r c l
+Baz BAZ baz
Added: trunk/tests/language-behaviour/IO/writeDataStruct.swift
--- trunk/tests/language-behaviour/IO/writeDataStruct.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataStruct.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type file;
+type S { string l; string c; string r; }
+S s;
+file f <"writeDataStruct.out">;
+f=writeData(s);
+s.l = "baz";
+s.c = "BAZ";
+s.r = "Baz";
Added: trunk/tests/language-behaviour/IO/writeDataStructArray2.out.expected
--- trunk/tests/language-behaviour/IO/writeDataStructArray2.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataStructArray2.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,6 @@
+r c l
+Foo FOO foo
+Bar BAR bar
+Baz BAZ baz
+Qux QUX qux
+Frrrr FRRRR frrrr
Added: trunk/tests/language-behaviour/IO/writeDataStructArray2.swift
--- trunk/tests/language-behaviour/IO/writeDataStructArray2.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/IO/writeDataStructArray2.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,26 @@
+type file;
+S s[];
+file f <"writeDataStructArray2.out">;
+f=writeData(s);
+s[2].l = "baz";
+s[2].c = "BAZ";
+s[2].r = "Baz";
+s[3].l = "qux";
+s[3].c = "QUX";
+s[3].r = "Qux";
+s[0].l = "foo";
+s[0].c = "FOO";
+s[0].r = "Foo";
+s[1].l = "bar";
+s[1].c = "BAR";
+s[1].r = "Bar";
+s[4].l = "frrrr";
+s[4].c = "FRRRR";
+s[4].r = "Frrrr";
Copied: trunk/tests/language-behaviour/arithmetic/006-add.out.expected (from rev 4602, trunk/tests/language-behaviour/006-add.out.expected)
--- trunk/tests/language-behaviour/arithmetic/006-add.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/006-add.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+135
Copied: trunk/tests/language-behaviour/arithmetic/006-add.swift (from rev 4602, trunk/tests/language-behaviour/006-add.swift)
--- trunk/tests/language-behaviour/arithmetic/006-add.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/006-add.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type messagefile {}
+(messagefile t) greeting(int m) {
+    app {
+        echo m stdout=@filename(t);
+messagefile outfile <"006-add.out">;
+int i = 42+93;
+outfile = greeting(i);
Copied: trunk/tests/language-behaviour/arithmetic/007-add-in-proc-add.out.expected (from rev 4602, trunk/tests/language-behaviour/007-add-in-proc-add.out.expected)
--- trunk/tests/language-behaviour/arithmetic/007-add-in-proc-add.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/007-add-in-proc-add.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+189
Copied: trunk/tests/language-behaviour/arithmetic/007-add-in-proc-add.swift (from rev 4602, trunk/tests/language-behaviour/007-add-in-proc-add.swift)
--- trunk/tests/language-behaviour/arithmetic/007-add-in-proc-add.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/007-add-in-proc-add.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,12 @@
+    app {
+messagefile outfile <"007-add-in-proc-add.out">;
+outfile = greeting(88+101);
Copied: trunk/tests/language-behaviour/arithmetic/008-add-multiply.out.expected (from rev 4602, trunk/tests/language-behaviour/008-add-multiply.out.expected)
--- trunk/tests/language-behaviour/arithmetic/008-add-multiply.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/008-add-multiply.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+8
Copied: trunk/tests/language-behaviour/arithmetic/008-add-multiply.swift (from rev 4602, trunk/tests/language-behaviour/008-add-multiply.swift)
--- trunk/tests/language-behaviour/arithmetic/008-add-multiply.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/008-add-multiply.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"008-add-multiply.out">;
+int i = 2+2*3;
Copied: trunk/tests/language-behaviour/arithmetic/009-multiply.out.expected (from rev 4602, trunk/tests/language-behaviour/009-multiply.out.expected)
--- trunk/tests/language-behaviour/arithmetic/009-multiply.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/009-multiply.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+42
Copied: trunk/tests/language-behaviour/arithmetic/009-multiply.swift (from rev 4602, trunk/tests/language-behaviour/009-multiply.swift)
--- trunk/tests/language-behaviour/arithmetic/009-multiply.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/009-multiply.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"009-multiply.out">;
+int i = 6*7;
Copied: trunk/tests/language-behaviour/arithmetic/010-divide.out.expected (from rev 4602, trunk/tests/language-behaviour/010-divide.out.expected)
--- trunk/tests/language-behaviour/arithmetic/010-divide.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/010-divide.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+33
Copied: trunk/tests/language-behaviour/arithmetic/010-divide.swift (from rev 4602, trunk/tests/language-behaviour/010-divide.swift)
--- trunk/tests/language-behaviour/arithmetic/010-divide.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/010-divide.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"010-divide.out">;
+int i = 99%/3;
Copied: trunk/tests/language-behaviour/arithmetic/011-divide-float.out.expected (from rev 4602, trunk/tests/language-behaviour/011-divide-float.out.expected)
--- trunk/tests/language-behaviour/arithmetic/011-divide-float.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/011-divide-float.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0.3333333333333333
Copied: trunk/tests/language-behaviour/arithmetic/011-divide-float.swift (from rev 4602, trunk/tests/language-behaviour/011-divide-float.swift)
--- trunk/tests/language-behaviour/arithmetic/011-divide-float.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/011-divide-float.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+(messagefile t) greeting(float m) {
+    app {
+messagefile outfile <"011-divide-float.out">;
+float i = 1.0/3.0;
Copied: trunk/tests/language-behaviour/arithmetic/013-mod.out.expected (from rev 4602, trunk/tests/language-behaviour/013-mod.out.expected)
--- trunk/tests/language-behaviour/arithmetic/013-mod.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/013-mod.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+19
Copied: trunk/tests/language-behaviour/arithmetic/013-mod.swift (from rev 4602, trunk/tests/language-behaviour/013-mod.swift)
--- trunk/tests/language-behaviour/arithmetic/013-mod.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/013-mod.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"013-mod.out">;
+int i = 99 %% 20;
Copied: trunk/tests/language-behaviour/arithmetic/014-subtract.out.expected (from rev 4602, trunk/tests/language-behaviour/014-subtract.out.expected)
--- trunk/tests/language-behaviour/arithmetic/014-subtract.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/014-subtract.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+-37
Copied: trunk/tests/language-behaviour/arithmetic/014-subtract.swift (from rev 4602, trunk/tests/language-behaviour/014-subtract.swift)
--- trunk/tests/language-behaviour/arithmetic/014-subtract.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/014-subtract.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"014-subtract.out">;
+int i = 44-81;
Copied: trunk/tests/language-behaviour/arithmetic/0145-unary-subtact.out.expected (from rev 4602, trunk/tests/language-behaviour/0145-unary-subtact.out.expected)
--- trunk/tests/language-behaviour/arithmetic/0145-unary-subtact.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/0145-unary-subtact.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+-989929
Copied: trunk/tests/language-behaviour/arithmetic/0145-unary-subtact.swift (from rev 4602, trunk/tests/language-behaviour/0145-unary-subtact.swift)
--- trunk/tests/language-behaviour/arithmetic/0145-unary-subtact.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/0145-unary-subtact.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,15 @@
+    app {
+messagefile outfile <"0145-unary-subtact.out">;
+int j = 989929;
+int i = -j;
Copied: trunk/tests/language-behaviour/arithmetic/015-lesseq.out.expected (from rev 4602, trunk/tests/language-behaviour/015-lesseq.out.expected)
--- trunk/tests/language-behaviour/arithmetic/015-lesseq.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/015-lesseq.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+true
Copied: trunk/tests/language-behaviour/arithmetic/015-lesseq.swift (from rev 4602, trunk/tests/language-behaviour/015-lesseq.swift)
--- trunk/tests/language-behaviour/arithmetic/015-lesseq.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/015-lesseq.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+(messagefile t) greeting(boolean m) {
+    app {
+messagefile outfile <"015-lesseq.out">;
+boolean i = 7<=9;
Copied: trunk/tests/language-behaviour/arithmetic/016-greatereq.out.expected (from rev 4602, trunk/tests/language-behaviour/016-greatereq.out.expected)
--- trunk/tests/language-behaviour/arithmetic/016-greatereq.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/016-greatereq.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+false
Copied: trunk/tests/language-behaviour/arithmetic/016-greatereq.swift (from rev 4602, trunk/tests/language-behaviour/016-greatereq.swift)
--- trunk/tests/language-behaviour/arithmetic/016-greatereq.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/016-greatereq.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"016-greatereq.out">;
+boolean i = 7>=9;
Copied: trunk/tests/language-behaviour/arithmetic/017-greater.out.expected (from rev 4602, trunk/tests/language-behaviour/017-greater.out.expected)
--- trunk/tests/language-behaviour/arithmetic/017-greater.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/017-greater.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+false
Copied: trunk/tests/language-behaviour/arithmetic/017-greater.swift (from rev 4602, trunk/tests/language-behaviour/017-greater.swift)
--- trunk/tests/language-behaviour/arithmetic/017-greater.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/017-greater.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"017-greater.out">;
+boolean i = 7>9;
Copied: trunk/tests/language-behaviour/arithmetic/018-less.out.expected (from rev 4602, trunk/tests/language-behaviour/018-less.out.expected)
--- trunk/tests/language-behaviour/arithmetic/018-less.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/018-less.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+true
Copied: trunk/tests/language-behaviour/arithmetic/018-less.swift (from rev 4602, trunk/tests/language-behaviour/018-less.swift)
--- trunk/tests/language-behaviour/arithmetic/018-less.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/018-less.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"018-less.out">;
+boolean i = 7<9;
Copied: trunk/tests/language-behaviour/arithmetic/019-equals.out.expected (from rev 4602, trunk/tests/language-behaviour/019-equals.out.expected)
--- trunk/tests/language-behaviour/arithmetic/019-equals.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/019-equals.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+false
Copied: trunk/tests/language-behaviour/arithmetic/019-equals.swift (from rev 4602, trunk/tests/language-behaviour/019-equals.swift)
--- trunk/tests/language-behaviour/arithmetic/019-equals.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/019-equals.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"019-equals.out">;
+boolean i = 7==9;
Copied: trunk/tests/language-behaviour/arithmetic/0191-not-equals.out.expected (from rev 4602, trunk/tests/language-behaviour/0191-not-equals.out.expected)
--- trunk/tests/language-behaviour/arithmetic/0191-not-equals.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/0191-not-equals.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+true
Copied: trunk/tests/language-behaviour/arithmetic/0191-not-equals.swift (from rev 4602, trunk/tests/language-behaviour/0191-not-equals.swift)
--- trunk/tests/language-behaviour/arithmetic/0191-not-equals.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arithmetic/0191-not-equals.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"0191-not-equals.out">;
+boolean i = 7!=9;
Added: trunk/tests/language-behaviour/arrays/020-array.out.expected
--- trunk/tests/language-behaviour/arrays/020-array.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/020-array.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+4
Added: trunk/tests/language-behaviour/arrays/020-array.swift
--- trunk/tests/language-behaviour/arrays/020-array.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/020-array.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,16 @@
+    app {
+messagefile outfile <"020-array.out">;
+int i[] = [ 3, 1, 4, 1, 5];
+int j = i[2];
+outfile = greeting(j);
Added: trunk/tests/language-behaviour/arrays/021-array-in-proc-param.out.expected
--- trunk/tests/language-behaviour/arrays/021-array-in-proc-param.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/021-array-in-proc-param.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+1
Added: trunk/tests/language-behaviour/arrays/021-array-in-proc-param.swift
--- trunk/tests/language-behaviour/arrays/021-array-in-proc-param.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/021-array-in-proc-param.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+    app {
+messagefile outfile <"021-array-in-proc-param.out">;
+outfile = greeting(i[3]);
Added: trunk/tests/language-behaviour/arrays/022-array-with-exprs.out.expected
--- trunk/tests/language-behaviour/arrays/022-array-with-exprs.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/022-array-with-exprs.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+22
Added: trunk/tests/language-behaviour/arrays/022-array-with-exprs.swift
--- trunk/tests/language-behaviour/arrays/022-array-with-exprs.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/022-array-with-exprs.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,16 @@
+    app {
+messagefile outfile <"022-array-with-exprs.out">;
+int i[] = [ 1+91, 3+3, 16+3*2 , 1, 5];
+int j = i[2];
Added: trunk/tests/language-behaviour/arrays/025-array-passing.out.expected
--- trunk/tests/language-behaviour/arrays/025-array-passing.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/025-array-passing.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+two
Added: trunk/tests/language-behaviour/arrays/025-array-passing.swift
--- trunk/tests/language-behaviour/arrays/025-array-passing.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/025-array-passing.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+(messagefile t) greeting(string m[]) {
+    app {
+        echo m[1] stdout=@filename(t);
+messagefile outfile <"025-array-passing.out">;
+string msg[] = [ "one", "two" ];
+outfile = greeting(msg);
Added: trunk/tests/language-behaviour/arrays/027-array-assignment.out.expected
--- trunk/tests/language-behaviour/arrays/027-array-assignment.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/027-array-assignment.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+two
Added: trunk/tests/language-behaviour/arrays/027-array-assignment.swift
--- trunk/tests/language-behaviour/arrays/027-array-assignment.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/027-array-assignment.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,15 @@
+    app {
+messagefile outfile <"027-array-assignment.out">;
+string msg[];
+msg = [ "one", "two" ];
Added: trunk/tests/language-behaviour/arrays/028-array-assignment.swift
--- trunk/tests/language-behaviour/arrays/028-array-assignment.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/028-array-assignment.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,18 @@
+    app {
+string msg[];
+string baz[];
+baz = msg;
+outfile = greeting(baz);
Added: trunk/tests/language-behaviour/arrays/029-array-assignment-sequence.swift
--- trunk/tests/language-behaviour/arrays/029-array-assignment-sequence.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/029-array-assignment-sequence.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,10 @@
+int a,b,c,d,e,f,g;
+trace(g);
+a=8645;
+b=a;
+c=b;
+d=c;
+e=d;
+f=e;
+g=f;
Added: trunk/tests/language-behaviour/arrays/083-array-assign.swift
--- trunk/tests/language-behaviour/arrays/083-array-assign.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/083-array-assign.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,13 @@
+type messagefile;
+(messagefile t) greeting(string m) {
+    app {
+messagefile outfile[];
+outfile[0] = greeting("hi");
+outfile[1] = greeting("bye");
Added: trunk/tests/language-behaviour/arrays/110-array-range-exprs.swift
--- trunk/tests/language-behaviour/arrays/110-array-range-exprs.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/110-array-range-exprs.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,2 @@
+int i[] = [ 1+1 : 5+5 : 1*3 ];
Added: trunk/tests/language-behaviour/arrays/1101-array-range.swift
--- trunk/tests/language-behaviour/arrays/1101-array-range.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/1101-array-range.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,8 @@
+int i[] = [0:9];
+int j[] = [0:9];
+foreach ix in i {
+  trace(j[ix]);
Added: trunk/tests/language-behaviour/arrays/1102-array-range-step.swift
--- trunk/tests/language-behaviour/arrays/1102-array-range-step.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/1102-array-range-step.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,8 @@
+int i[] = [0:9];
+int j[] = [0:19:2];
+foreach ix in i {
+  trace(j[ix]);
Added: trunk/tests/language-behaviour/arrays/111-array-individual-assigns.out.expected
--- trunk/tests/language-behaviour/arrays/111-array-individual-assigns.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/111-array-individual-assigns.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+100
Added: trunk/tests/language-behaviour/arrays/111-array-individual-assigns.swift
--- trunk/tests/language-behaviour/arrays/111-array-individual-assigns.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/111-array-individual-assigns.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,18 @@
+int i[];
+i[0]=1;
+i[1]=100;
+i[2]=10000;
+type messagefile;
+(messagefile t) p(int inp[]) {
+    app {
+        echo inp[1] stdout=@filename(t);
+messagefile outfile <"111-array-individual-assigns.out">;
+outfile = p(i);
Added: trunk/tests/language-behaviour/arrays/162-dot-on-array.out.expected
--- trunk/tests/language-behaviour/arrays/162-dot-on-array.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/162-dot-on-array.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+two-C
Added: trunk/tests/language-behaviour/arrays/162-dot-on-array.swift
--- trunk/tests/language-behaviour/arrays/162-dot-on-array.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/162-dot-on-array.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,36 @@
+type messagefile;
+(messagefile t) greeting(string s) {
+    app {
+        echo s stdout=@filename(t);
+messagefile outfile <"162-dot-on-array.out">;
+type astruct {
+  string a;
+  string b;
+  string c;
+astruct foo[];
+foo[0].a = "zero-A";
+foo[0].b = "zero-B";
+foo[0].c = "zero-C";
+foo[1].a = "one-A";
+foo[1].b = "one-B";
+foo[1].c = "one-C";
+foo[2].a = "two-A";
+foo[2].b = "two-B";
+foo[2].c = "two-C";
+string s[] = foo.c;
+string u = s[2];
+outfile = greeting(u);
Added: trunk/tests/language-behaviour/arrays/array_multidimensional-2.swift
--- trunk/tests/language-behaviour/arrays/array_multidimensional-2.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/array_multidimensional-2.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,19 @@
+type file;
+(file t) echo_array (string s[][]) {
+    app {
+        echo s[0][0] s[1][0] s[1][1] stdout=@filename(t);
+string greetings[][];
+greetings[0][0] = "left";
+greetings[0][1] = "right";
+greetings[1][0] = "up";
+greetings[1][1] = "down";
+file hw <"array_multidimensional_index.out">;
+hw = echo_array(greetings);
Added: trunk/tests/language-behaviour/arrays/array_multidimensional_assign.swift
--- trunk/tests/language-behaviour/arrays/array_multidimensional_assign.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/array_multidimensional_assign.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,16 @@
+type file {}
+    app {
+greetings = [ [ "left", "right" ], ["up", "down"]];
+file hw <"array_multidimensional_assign.out">;
Added: trunk/tests/language-behaviour/arrays/array_multidimensional_index.out.expected
--- trunk/tests/language-behaviour/arrays/array_multidimensional_index.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/array_multidimensional_index.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+left up down
Added: trunk/tests/language-behaviour/arrays/array_multidimensional_index.swift
--- trunk/tests/language-behaviour/arrays/array_multidimensional_index.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/arrays/array_multidimensional_index.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type file {}
+    app {
+string greetings[][] = [ [ "left", "right" ], ["up", "down"]];
Added: trunk/tests/language-behaviour/foreach/0083-for.one.in
--- trunk/tests/language-behaviour/foreach/0083-for.one.in	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/0083-for.one.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+LLLL
Added: trunk/tests/language-behaviour/foreach/0083-for.one.in.out.expected
--- trunk/tests/language-behaviour/foreach/0083-for.one.in.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/0083-for.one.in.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+./0083-for.one.in
Added: trunk/tests/language-behaviour/foreach/0083-for.swift
--- trunk/tests/language-behaviour/foreach/0083-for.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/0083-for.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+type file;
+(file t) echo(string m) {
+    app {
+file f1[] <filesys_mapper;pattern="0083-for*.in",location=".">;
+foreach i1 in f1 {
+  string fn = @filename(i1);
+  file o <single_file_mapper;file=@strcat(fn,".out")>;
+  o = echo(fn);
Added: trunk/tests/language-behaviour/foreach/0083-for.two.in
--- trunk/tests/language-behaviour/foreach/0083-for.two.in	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/0083-for.two.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+RRRR
Added: trunk/tests/language-behaviour/foreach/0083-for.two.in.out.expected
--- trunk/tests/language-behaviour/foreach/0083-for.two.in.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/0083-for.two.in.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+./0083-for.two.in
Added: trunk/tests/language-behaviour/foreach/0084-for.swift
--- trunk/tests/language-behaviour/foreach/0084-for.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/0084-for.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type file;
+    app {
+foreach i1 in f1 {
Added: trunk/tests/language-behaviour/foreach/050-foreach.blue.out.expected
--- trunk/tests/language-behaviour/foreach/050-foreach.blue.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/050-foreach.blue.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test
Added: trunk/tests/language-behaviour/foreach/050-foreach.green.out.expected
--- trunk/tests/language-behaviour/foreach/050-foreach.green.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/050-foreach.green.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test
Added: trunk/tests/language-behaviour/foreach/050-foreach.red.out.expected
--- trunk/tests/language-behaviour/foreach/050-foreach.red.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/050-foreach.red.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test
Added: trunk/tests/language-behaviour/foreach/050-foreach.swift
--- trunk/tests/language-behaviour/foreach/050-foreach.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/050-foreach.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,15 @@
+    app {
+        echo "test" stdout=@filename(t);
+string array[] = ["red", "green", "blue"];
+foreach s in array {
+  messagefile outfile <single_file_mapper;file=@strcat("050-foreach.",s,".out")>;
+  outfile = greeting();
Added: trunk/tests/language-behaviour/foreach/051-foreach.blue.out.expected
--- trunk/tests/language-behaviour/foreach/051-foreach.blue.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/051-foreach.blue.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+The filename is: 051-foreach.blue.out and the loop var is: blue
Added: trunk/tests/language-behaviour/foreach/051-foreach.green.out.expected
--- trunk/tests/language-behaviour/foreach/051-foreach.green.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/051-foreach.green.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+The filename is: 051-foreach.green.out and the loop var is: green
Added: trunk/tests/language-behaviour/foreach/051-foreach.red.out.expected
--- trunk/tests/language-behaviour/foreach/051-foreach.red.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/051-foreach.red.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+The filename is: 051-foreach.red.out and the loop var is: red
Added: trunk/tests/language-behaviour/foreach/051-foreach.swift
--- trunk/tests/language-behaviour/foreach/051-foreach.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/051-foreach.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,20 @@
+(messagefile t) greeting(string l) {
+    app {
+        echo @strcat("The filename is: ", @filename(t),
+                     " and the loop var is: ", l)
+             stdout=@filename(t);
+      single_file_mapper;
+      file=@strcat("051-foreach.",s,".out")
+  outfile = greeting(s);
Added: trunk/tests/language-behaviour/foreach/052-foreach-index.blue.out.expected
--- trunk/tests/language-behaviour/foreach/052-foreach-index.blue.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/052-foreach-index.blue.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+The filename is: 052-foreach-index.blue.out, the loop var is: blueand the index is: 2
Added: trunk/tests/language-behaviour/foreach/052-foreach-index.green.out.expected
--- trunk/tests/language-behaviour/foreach/052-foreach-index.green.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/052-foreach-index.green.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+The filename is: 052-foreach-index.green.out, the loop var is: greenand the index is: 1
Added: trunk/tests/language-behaviour/foreach/052-foreach-index.red.out.expected
--- trunk/tests/language-behaviour/foreach/052-foreach-index.red.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/052-foreach-index.red.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+The filename is: 052-foreach-index.red.out, the loop var is: redand the index is: 0
Added: trunk/tests/language-behaviour/foreach/052-foreach-index.swift
--- trunk/tests/language-behaviour/foreach/052-foreach-index.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/052-foreach-index.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,26 @@
+(messagefile t) greeting(int ix, string l) {
+    app {
+                     ", the loop var is: ", l,
+                     "and the index is: ", ix)
+// this highlights a bug, at least after all commits
+// that 'index' is being treated as a string, not as
+// an integer...
+// try this test earlier on, though
+foreach s, index in array {
+      file=@strcat("052-foreach-index.",s,".out")
+  outfile = greeting(index, s);
Added: trunk/tests/language-behaviour/foreach/056-foreach-if.swift
--- trunk/tests/language-behaviour/foreach/056-foreach-if.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/056-foreach-if.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,26 @@
+    app {
+// an integer...
+messagefile outfiles[];
+  if( index %% 2 == 1) {
+     outfiles[index] = greeting(index, s);
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.check.sh
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.check.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.check.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+#!/bin/bash
+set -x
+for count in `seq --format "%04.f" 0 1 9`
+do
+	[ -f "057-foreach-twice-range.first.$count.out" ] || exit 1
+	CONTENTS1=$( cat 057-foreach-twice-range.first.$count.out.expected )
+	CONTENTS2=$( cat 057-foreach-twice-range.first.$count.out )
+	[[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
+	[ -f "057-foreach-twice-range.second.$count.out" ] || exit 1
+	CONTENTS3=$( cat 057-foreach-twice-range.second.$count.out.expected )
+	CONTENTS4=$( cat 057-foreach-twice-range.second.$count.out )
+	[[ $CONTENTS3 == $CONTENTS4 ]] || exit 1
+done
+exit 0
Property changes on: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.check.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.clean.sh
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.clean.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+rm -v 057-foreach-twice-range.*.out || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.clean.sh
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0000.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0000.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0000.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-0
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0001.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0001.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0001.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-1
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0002.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0002.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0002.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-2
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0003.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0003.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0003.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-3
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0004.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0004.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0004.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-4
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0005.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0005.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0005.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-5
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0006.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0006.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0006.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-6
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0007.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0007.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0007.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-7
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0008.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0008.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0008.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-8
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0009.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0009.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.first.0009.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test1-9
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0000.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0000.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0000.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-0
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0001.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0001.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0001.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-1
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0002.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0002.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0002.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-2
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0003.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0003.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0003.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-3
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0004.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0004.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0004.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-4
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0005.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0005.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0005.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-5
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0006.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0006.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0006.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-6
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0007.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0007.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0007.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-7
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0008.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0008.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0008.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-8
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0009.out.expected
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0009.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.second.0009.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+test2-9
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.setup.sh
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.setup.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,3 @@
+#!/bin/bash
+cp -v $GROUP/057*expected . || exit 1
Property changes on: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.setup.sh
Added: trunk/tests/language-behaviour/foreach/057-foreach-twice-range.swift
--- trunk/tests/language-behaviour/foreach/057-foreach-twice-range.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/057-foreach-twice-range.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,20 @@
+type file;
+app (file o) echo (string msg)
+  echo msg stdout=@o;
+file out[]<simple_mapper; location=".", prefix="057-foreach-twice-range.first.",suffix=".out">;
+file out2[]<simple_mapper; location=".", prefix="057-foreach-twice-range.second.",suffix=".out">;
+foreach a,i in [0:9] {
+  string s = @strcat("test1-", i);
+  out[i] = echo(s);
+  string s = @strcat("test2-", i);
+  out2[i] = echo(s);
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.check.sh
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.check.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.check.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+#!/bin/bash
+set -x
+for count in `seq --format "%04.f" 0 1 2`
+do
+	[ -f "058-foreach-twice-string.first.$count.out" ] || exit 1
+	CONTENTS1=$( cat 058-foreach-twice-string.first.$count.out.expected )
+	CONTENTS2=$( cat 058-foreach-twice-string.first.$count.out )
+	[ -f "058-foreach-twice-string.second.$count.out" ] || exit 1
+	CONTENTS3=$( cat 058-foreach-twice-string.second.$count.out.expected )
+	CONTENTS4=$( cat 058-foreach-twice-string.second.$count.out )
+done
+exit 0
Property changes on: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.check.sh
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.clean.sh
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.clean.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,6 @@
+#!/bin/bash
+set -x
+rm -v 058-foreach-twice-string.*.out || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.clean.sh
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0000.out.expected
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0000.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0000.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+zero
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0001.out.expected
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0001.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0001.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+one
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0002.out.expected
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0002.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.first.0002.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+two
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0000.out.expected
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0000.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0000.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+zero
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0001.out.expected
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0001.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0001.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+one
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0002.out.expected
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0002.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.second.0002.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+two
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.setup.sh
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.setup.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,3 @@
+#!/bin/bash
+cp -v $GROUP/058*expected . || exit 1
Property changes on: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.setup.sh
Added: trunk/tests/language-behaviour/foreach/058-foreach-twice-string.swift
--- trunk/tests/language-behaviour/foreach/058-foreach-twice-string.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/foreach/058-foreach-twice-string.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,19 @@
+type file;
+app (file o) echo (string f)
+  echo @f stdout=@o;
+file out[]<simple_mapper; location=".", prefix="058-foreach-twice-string.first.",suffix=".out">;
+file out2[]<simple_mapper; location=".", prefix="058-foreach-twice-string.second.",suffix=".out">;
+string words[] = ["zero", "one", "two"];
+foreach w,i in words {
+  out[i] = echo(w);
+  out2[i] = echo(w);
Added: trunk/tests/language-behaviour/mappers/0032-strcat-mapper-param.1.out.expected
--- trunk/tests/language-behaviour/mappers/0032-strcat-mapper-param.1.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0032-strcat-mapper-param.1.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0032-strcat-mapper-param.1
Added: trunk/tests/language-behaviour/mappers/0032-strcat-mapper-param.swift
--- trunk/tests/language-behaviour/mappers/0032-strcat-mapper-param.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0032-strcat-mapper-param.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,18 @@
+type file;
+    app {
+// file f1[] <filesys_mapper;pattern="0083-for*.in",location=".">;
+file f1 <"0032-strcat-mapper-param.1">;
+  string fn = @filename(f1);
+  o = echo(fn);
Added: trunk/tests/language-behaviour/mappers/070-singlefilemapper.out.expected
--- trunk/tests/language-behaviour/mappers/070-singlefilemapper.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/070-singlefilemapper.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+070-singlefilemapper.out
Added: trunk/tests/language-behaviour/mappers/070-singlefilemapper.swift
--- trunk/tests/language-behaviour/mappers/070-singlefilemapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/070-singlefilemapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,12 @@
+type messagefile;
+(messagefile t) write() {
+    app {
+        echo @filename(t) stdout=@filename(t);
+messagefile outfile <"070-singlefilemapper.out">;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.check.sh
--- trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.check.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.check.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,8 @@
+#!/bin/bash
+set -x
+[ -f 071-singlefilemapper-input.in ] || exit 1
+grep 071-singlefilemapper-input.in 071-singlefilemapper-input.out || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.check.sh
Added: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.clean.sh
--- trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.clean.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,8 @@
+#!/bin/bash
+set -x
+rm -v 071-singlefilemapper-input.in \
+      071-singlefilemapper-input.out || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.clean.sh
Added: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.in
--- trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+foo
Added: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.out.expected
--- trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+071-singlefilemapper-input.in
Added: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.setup.sh
--- trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.setup.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+cp -v $GROUP/071-singlefilemapper-input.in . || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.setup.sh
Added: trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.swift
--- trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/071-singlefilemapper-input.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,11 @@
+type messagefile;
+app (messagefile o) write(messagefile i) {
+  echo @filename(i) stdout=@filename(o);
+messagefile infile <"071-singlefilemapper-input.in">;
+messagefile outfile <"071-singlefilemapper-input.out">;
+outfile = write(infile);
Added: trunk/tests/language-behaviour/mappers/072-simplemapper.out.expected
--- trunk/tests/language-behaviour/mappers/072-simplemapper.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/072-simplemapper.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+072-simplemapper.out
Added: trunk/tests/language-behaviour/mappers/072-simplemapper.swift
--- trunk/tests/language-behaviour/mappers/072-simplemapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/072-simplemapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type messagefile;
+    app {
+messagefile outfile <simple_mapper;
+                     prefix="072-simplemapper",
+                     suffix=".out">;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/0721-simplemapper-array.0000.out.expected
--- trunk/tests/language-behaviour/mappers/0721-simplemapper-array.0000.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0721-simplemapper-array.0000.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0721-simplemapper-array.0000.out
Added: trunk/tests/language-behaviour/mappers/0721-simplemapper-array.0005.out.expected
--- trunk/tests/language-behaviour/mappers/0721-simplemapper-array.0005.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0721-simplemapper-array.0005.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0721-simplemapper-array.0005.out
Added: trunk/tests/language-behaviour/mappers/0721-simplemapper-array.swift
--- trunk/tests/language-behaviour/mappers/0721-simplemapper-array.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0721-simplemapper-array.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,15 @@
+type messagefile;
+    app {
+messagefile outfile[] <simple_mapper;
+                     prefix="0721-simplemapper-array.",
+                     suffix=".out">;
+outfile[0] = write();
+outfile[5] = write();
Added: trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000000000.out.expected
--- trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000000000.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000000000.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0722-simplemapper-padding.000000000.out
Added: trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000000005.out.expected
--- trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000000005.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000000005.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0722-simplemapper-padding.000000005.out
Added: trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000075943.out.expected
--- trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000075943.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.000075943.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0722-simplemapper-padding.000075943.out
Added: trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.swift
--- trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0722-simplemapper-padding.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+type messagefile;
+    app {
+                     prefix="0722-simplemapper-padding.",
+                     suffix=".out",
+                     padding="9">;
+outfile[75943] = write();
Added: trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.0.out.expected
--- trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.0.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.0.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0723-simplemapper-nopadding.0.out
Added: trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.5.out.expected
--- trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.5.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.5.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0723-simplemapper-nopadding.5.out
Added: trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.75943.out.expected
--- trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.75943.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.75943.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0723-simplemapper-nopadding.75943.out
Added: trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.swift
--- trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0723-simplemapper-nopadding.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+type messagefile;
+    app {
+                     prefix="0723-simplemapper-nopadding.",
+                     suffix=".out",
+                     padding="0">;
Added: trunk/tests/language-behaviour/mappers/073-simplemapper.out.expected
--- trunk/tests/language-behaviour/mappers/073-simplemapper.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/073-simplemapper.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+073-simplemapper.out
Added: trunk/tests/language-behaviour/mappers/073-simplemapper.swift
--- trunk/tests/language-behaviour/mappers/073-simplemapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/073-simplemapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+// this one is like test 072-simplemapper, but checks that
+// a dot is added to the front of the suffix if its missing
+type messagefile;
+    app {
+                     prefix="073-simplemapper",
+                     suffix="out">;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/075-array-mapper.first.out.expected
--- trunk/tests/language-behaviour/mappers/075-array-mapper.first.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/075-array-mapper.first.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+075-array-mapper.first.out
Added: trunk/tests/language-behaviour/mappers/075-array-mapper.second.out.expected
--- trunk/tests/language-behaviour/mappers/075-array-mapper.second.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/075-array-mapper.second.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+075-array-mapper.second.out
Added: trunk/tests/language-behaviour/mappers/075-array-mapper.swift
--- trunk/tests/language-behaviour/mappers/075-array-mapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/075-array-mapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,18 @@
+type messagefile;
+    app {
+string fns[]=["075-array-mapper.first.out",
+              "075-array-mapper.second.out",
+              "075-array-mapper.third.out"];
+messagefile outfile[] <array_mapper; files=fns>;
+outfile[1] = write();
+outfile[2] = write();
Added: trunk/tests/language-behaviour/mappers/075-array-mapper.third.out.expected
--- trunk/tests/language-behaviour/mappers/075-array-mapper.third.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/075-array-mapper.third.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+075-array-mapper.third.out
Added: trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.first.out.expected
--- trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.first.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.first.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 0
Added: trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.second.out.expected
--- trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.second.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.second.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 1
Added: trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.swift
--- trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,16 @@
+type messagefile;
+(messagefile t) write(string s) {
+    app {
+string fns="0751-fixed-array-mapper.first.out 0751-fixed-array-mapper.second.out 0751-fixed-array-mapper.third.out";
+messagefile outfile[] <fixed_array_mapper; files=fns>;
+outfile[0] = write("slot 0");
+outfile[1] = write("slot 1");
+outfile[2] = write("slot 2");
Added: trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.third.out.expected
--- trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.third.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0751-fixed-array-mapper.third.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 2
Added: trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh
--- trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+cat stdout.txt
+X=$( grep -c "file: 07511" stdout.txt )
+[ $? == 0 ] || exit 1
+echo $X
+(( $X == 3 )) || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh
Added: trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.clean.sh
--- trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.clean.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.clean.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+rm -v $GROUP/07511-fixed-array-mapper-input.*.in || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.clean.sh
Added: trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.setup.sh
--- trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.setup.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.setup.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+cp -v $GROUP/07511-fixed-array-mapper-input.*.in . || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.setup.sh
Added: trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.swift
--- trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,19 @@
+type messagefile;
+app p(messagefile t) {
+  echo "foo" stdin=@filename(t);
+string fns="07511-fixed-array-mapper-input.first.in 07511-fixed-array-mapper-input.second.in 07511-fixed-array-mapper-input.third.in";
+messagefile infile[] <fixed_array_mapper; files=fns>;
+p(infile[0]);
+p(infile[1]);
+p(infile[2]);
+tracef("file: %s\n", @filename(infile[0]));
+tracef("file: %s\n", @filename(infile[1]));
+tracef("file: %s\n", @filename(infile[2]));
Added: trunk/tests/language-behaviour/mappers/07513-fixed-array-mapper-filename.real.out.expected
--- trunk/tests/language-behaviour/mappers/07513-fixed-array-mapper-filename.real.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07513-fixed-array-mapper-filename.real.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+q r s t
Added: trunk/tests/language-behaviour/mappers/07513-fixed-array-mapper-filename.swift
--- trunk/tests/language-behaviour/mappers/07513-fixed-array-mapper-filename.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07513-fixed-array-mapper-filename.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,19 @@
+type messagefile;
+    app {
+string fns="q r s t";
+messagefile realoutput <"07513-fixed-array-mapper-filename.real.out">;
+string fn;
+fn = @filename(outfile);
+realoutput = write(fn);
Added: trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.a.in
--- trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.a.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.a.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+foo
Added: trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.b.in
--- trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.b.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.b.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+foo
Added: trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.real.out.expected
--- trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.real.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.real.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+07514-fixed-array-mapper-filenames.a.in 07514-fixed-array-mapper-filenames.b.in
Added: trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.swift
--- trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07514-fixed-array-mapper-filenames.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+type messagefile;
+(messagefile t) write(messagefile s[]) {
+    app {
+        echo @filenames(s) stdout=@filename(t);
+string fns="07514-fixed-array-mapper-filenames.a.in 07514-fixed-array-mapper-filenames.b.in";
+messagefile realoutput <"07514-fixed-array-mapper-filenames.real.out">;
+string fn;
+realoutput = write(outfile);
Added: trunk/tests/language-behaviour/mappers/0752-csv-mapper.csv
--- trunk/tests/language-behaviour/mappers/0752-csv-mapper.csv	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0752-csv-mapper.csv	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
+l,r
+0752-csv-mapper.left-zero.out,0752-csv-mapper.right-zero.out
+0752-csv-mapper.left-one.out,0752-csv-mapper.right-one.out
+0752-csv-mapper.left-two.out,0752-csv-mapper.right-two.out
Added: trunk/tests/language-behaviour/mappers/0752-csv-mapper.left-two.out.expected
--- trunk/tests/language-behaviour/mappers/0752-csv-mapper.left-two.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0752-csv-mapper.left-two.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 2
Added: trunk/tests/language-behaviour/mappers/0752-csv-mapper.left-zero.out.expected
--- trunk/tests/language-behaviour/mappers/0752-csv-mapper.left-zero.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0752-csv-mapper.left-zero.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 0
Added: trunk/tests/language-behaviour/mappers/0752-csv-mapper.right-one.out.expected
--- trunk/tests/language-behaviour/mappers/0752-csv-mapper.right-one.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0752-csv-mapper.right-one.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 1
Added: trunk/tests/language-behaviour/mappers/0752-csv-mapper.swift
--- trunk/tests/language-behaviour/mappers/0752-csv-mapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0752-csv-mapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,19 @@
+type messagefile;
+type cols {
+  messagefile l;
+  messagefile r;
+    app {
+cols outfile[] <csv_mapper; file="0752-csv-mapper.csv">;
+outfile[0].l = write("slot 0");
+outfile[1].r = write("slot 1");
+outfile[2].l = write("slot 2");
Added: trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.a.out.expected
--- trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.a.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.a.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0753-filesystem-mapper.blue.in
Added: trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.b.out.expected
--- trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.b.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.b.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0753-filesystem-mapper.green.in
Added: trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.blue.in
Added: trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.c.out.expected
--- trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.c.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.c.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0753-filesystem-mapper.red.in
Added: trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.green.in
Added: trunk/tests/language-behaviour/mappers/0753-filesystem-mapper.red.in
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper-input.out.expected
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper-input.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper-input.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+10319
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper-input.swift
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper-input.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper-input.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,19 @@
+type messagefile;
+type cols {
+  messagefile l;
+  messagefile r;
+(messagefile t) write(messagefile s) {
+    app {
+        cat stdin=@filename(s) stdout=@filename(t);
+cols infiles[] <csv_mapper; file="0754-csv-mapper.csv">;
+messagefile outfile <"0754-csv-mapper-input.out">;
+outfile = write(infiles[1].r);
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper.csv
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper.csv	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper.csv	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
+l,r
+0754-csv-mapper.left-zero.in,0754-csv-mapper.right-zero.in
+0754-csv-mapper.left-one.in,0754-csv-mapper.right-one.in
+0754-csv-mapper.left-two.in,0754-csv-mapper.right-two.in
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-one.in
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-one.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-one.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+14708
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-two.in
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-two.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-two.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+102
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-zero.in
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-zero.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper.left-zero.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+9807
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-one.in
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-one.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-one.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+10319
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-two.in
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-two.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-two.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+8709
Added: trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-zero.in
--- trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-zero.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0754-csv-mapper.right-zero.in	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+2544
Added: trunk/tests/language-behaviour/mappers/0755-ext-mapper.0.3.2.1.out.expected
--- trunk/tests/language-behaviour/mappers/0755-ext-mapper.0.3.2.1.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0755-ext-mapper.0.3.2.1.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 1
Added: trunk/tests/language-behaviour/mappers/0755-ext-mapper.AAA.out.expected
--- trunk/tests/language-behaviour/mappers/0755-ext-mapper.AAA.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0755-ext-mapper.AAA.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 0
Added: trunk/tests/language-behaviour/mappers/0755-ext-mapper.____.out.expected
--- trunk/tests/language-behaviour/mappers/0755-ext-mapper.____.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0755-ext-mapper.____.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 2
Added: trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh
--- trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
+echo "[0].l 0755-ext-mapper.AAA.out"
+echo "[1].r 0755-ext-mapper.0.3.2.1.out"
+echo "[2].l 0755-ext-mapper.____.out"
Property changes on: trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh
Added: trunk/tests/language-behaviour/mappers/0755-ext-mapper.swift
--- trunk/tests/language-behaviour/mappers/0755-ext-mapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0755-ext-mapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,19 @@
+type messagefile;
+type cols {
+  messagefile l;
+  messagefile r;
+    app {
+cols outfile[] <ext; exec="./0755-ext-mapper.sh">;
Added: trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.out.expected
--- trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+slot 0
Added: trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.sh
--- trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,2 @@
+#!/bin/bash
+echo "$ 07551-ext-mapper-single.out"
Property changes on: trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.sh
Added: trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.swift
--- trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07551-ext-mapper-single.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,12 @@
+type messagefile;
+    app {
+messagefile outfile <ext; exec="./07551-ext-mapper-single.sh">;
+outfile = write("slot 0");
Added: trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.inside.out.expected
--- trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.inside.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.inside.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+5000
Added: trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.mapper.out.expected
--- trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.mapper.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.mapper.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+-ssss 5000
Added: trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.sh
--- trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,6 @@
+#!/bin/bash
+echo $@ > 07552-ext-mapper-numeric.mapper.out
+echo "$ 07552-ext-mapper-numeric.inside.out"
Property changes on: trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.sh
Added: trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.swift
--- trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07552-ext-mapper-numeric.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,13 @@
+type messagefile;
+(messagefile t) greeting(int n) {
+    app {
+        echo n stdout=@filename(t);
+int n = 5000;
+messagefile outfile <ext; exec="07552-ext-mapper-numeric.sh", ssss=n>;
+outfile = greeting(n);
Added: trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.sh
--- trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,3 @@
+#!/bin/bash
+echo "eerste 07554-ext-mapper-struct.a.out"
+echo "twede 07554-ext-mapper-struct.b.out"
Property changes on: trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.sh
Added: trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.swift
--- trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07554-ext-mapper-struct.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,18 @@
+type messagefile;
+type struct {
+messagefile eerste;
+messagefile twede;
+    app {
+struct outfiles <ext; exec="./07554-ext-mapper-struct.sh">;
+outfiles.eerste = write("1st");
+outfiles.twede = write("2nd");
Added: trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.sh
--- trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,5 @@
+#!/bin/bash
+echo "eerste 07555-ext-mapper-twostruct.a.out"
+echo "twede 07555-ext-mapper-twostruct.b.out"
+echo "derde.links 07555-ext-mapper-twostruct.cl.out"
+echo "derde.rechts 07555-ext-mapper-twostruct.cr.out"
Property changes on: trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.sh
Added: trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.swift
--- trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07555-ext-mapper-twostruct.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,26 @@
+type file;
+type structInner {
+    file links;
+    file rechts;
+type struct {
+    file eerste;
+    file twede;
+    structInner derde;
+(file t) write(string s) {
+    app {
+struct outfiles <ext; exec="./07555-ext-mapper-twostruct.sh">;
+outfiles.derde.links = write("3l");
+outfiles.derde.rechts = write("3r");
Added: trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.swift
--- trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,23 @@
+type file;
+type structInner {
+    file links;
+    file rechts;
+type struct {
+    file eerste;
+    file twede;
+(struct t) singlewrite() {
+    app {
+        touch @filenames(t);
+outfiles = singlewrite();
Added: trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.sh
--- trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,8 @@
+#!/bin/bash
+sleep 10s
+echo "[0].l 0756-ext-mapper.AAA.out"
+sleep 10s
+echo "[1].r 0756-ext-mapper.0.3.2.1.out"
+sleep 10s
+echo "[2].l 0756-ext-mapper.____.out"
+sleep 10s
Property changes on: trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.sh
Added: trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.swift
--- trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0756-ext-mapper-slow.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,19 @@
+type messagefile;
+type cols {
+  messagefile l;
+  messagefile r;
+    app {
+cols outfile[] <ext; exec="./0756-ext-mapper-slow.sh">;
Added: trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.sh
--- trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
+echo "[0] 0757-ext-mapper-array.AAA.out"
+echo "[1] 0757-ext-mapper-array.0.3.2.1.out"
+echo "[2] 0757-ext-mapper-array.____.out"
Property changes on: trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.sh
Added: trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.swift
--- trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0757-ext-mapper-array.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type messagefile;
+    app {
+messagefile outfile[] <ext; exec="./0757-ext-mapper-array.sh">;
Added: trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.sh
--- trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
Property changes on: trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.sh
Added: trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.swift
--- trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0758-ext-mapper-array.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,13 @@
+type messagefile;
+    app {
+messagefile outfile[] <ext; exec="./0758-ext-mapper-array.sh">;
+foreach f,i in [0:2] {
+ outfile[i] = write("slot X");
Added: trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.sh
--- trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,3 @@
+#!/bin/bash
+echo [0] 0759-ext-mapper-array.a.out
+echo [1] 0759-ext-mapper-array.q.out
Property changes on: trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.sh
Added: trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.swift
--- trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0759-ext-mapper-array.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,12 @@
+type file;
+(file t[]) write() {
+    app {
+        touch "0759-ext-mapper-array.a.out" "0759-ext-mapper-array.q.out";
+file outfile[] <ext; exec="./0759-ext-mapper-array.sh">;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.sh
--- trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,5 @@
+#!/bin/bash
+echo [0][0].a out.n/1foo/0/00/00/ST.TU.pdt
+echo [0][0].b out.n/1foo/0/00/00/ST.TU.rmsd
Property changes on: trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.sh
Added: trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.swift
--- trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07591-ext-mapper-multidimensional-array.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+type F;
+type S {
+ F a;
+ F b;
+app (S output[][]) touch() {
+touch @filenames(output);
+S o[][] <ext; exec="07591-ext-mapper-multidimensional-array.sh">;
+o = touch();
Added: trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.sh
--- trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,6 @@
+#!/bin/bash
+echo [0][0].c[0] out.n/1foo/0/00/00/ST.TU.rmsd2
Property changes on: trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.sh
Added: trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.swift
--- trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/07592-ext-mapper-multidimensional-array-structs.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,18 @@
+type F;
+type S {
+ F a;
+ F b;
+ F c[];
+S o[][] <ext; exec="07592-ext-mapper-multidimensional-array-structs.sh">;
+o = touch();
Added: trunk/tests/language-behaviour/mappers/076-structured-regexp-mapper.b.out.expected
--- trunk/tests/language-behaviour/mappers/076-structured-regexp-mapper.b.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/076-structured-regexp-mapper.b.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+Hello, world!
Added: trunk/tests/language-behaviour/mappers/076-structured-regexp-mapper.swift
--- trunk/tests/language-behaviour/mappers/076-structured-regexp-mapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/076-structured-regexp-mapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,25 @@
+type messagefile {}
+(messagefile t) greeting() {
+    app {
+        echo "Hello, world!" stdout=@filename(t);
+(messagefile t) greeting2(messagefile ignored) {
+    app {
+messagefile outfile <"076-structured-regexp-mapper.a.out">;
+messagefile outfile2 <structured_regexp_mapper;
+    source=outfile,
+    match="(.*)per.a(.*)",
+    transform="\\1per.b\\2"
+outfile = greeting();
+outfile2 = greeting2(outfile);
Added: trunk/tests/language-behaviour/mappers/077-regexp-mapper.foo.out.expected
--- trunk/tests/language-behaviour/mappers/077-regexp-mapper.foo.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/077-regexp-mapper.foo.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+hello
Added: trunk/tests/language-behaviour/mappers/077-regexp-mapper.swift
--- trunk/tests/language-behaviour/mappers/077-regexp-mapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/077-regexp-mapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,15 @@
+type messagefile;
+    app {
+        echo "hello" stdout=@filename(t);
+messagefile outfile <regexp_mapper;
+       source="outfoo",
+       match="(...)(.*)",
+       transform="077-regexp-mapper.\\2.\\1">;
Added: trunk/tests/language-behaviour/mappers/078-singlefilemapper-name-expression.out.expected
--- trunk/tests/language-behaviour/mappers/078-singlefilemapper-name-expression.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/078-singlefilemapper-name-expression.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+078-singlefilemapper-name-expression.out
Added: trunk/tests/language-behaviour/mappers/078-singlefilemapper-name-expression.swift
--- trunk/tests/language-behaviour/mappers/078-singlefilemapper-name-expression.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/078-singlefilemapper-name-expression.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type messagefile;
+    app {
+string fn = "078-singlefilemapper-name-expression.out";
+messagefile outfile <single_file_mapper;file=fn>;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/0781-singlefilemapper-name-expression.out.expected
--- trunk/tests/language-behaviour/mappers/0781-singlefilemapper-name-expression.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0781-singlefilemapper-name-expression.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0781-singlefilemapper-name-expression.out
Added: trunk/tests/language-behaviour/mappers/0781-singlefilemapper-name-expression.swift
--- trunk/tests/language-behaviour/mappers/0781-singlefilemapper-name-expression.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0781-singlefilemapper-name-expression.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type messagefile;
+    app {
+string fn = "0781-singlefilemapper-name-expression";
+messagefile outfile <single_file_mapper;file=@strcat(fn,".","out")>;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/079-regression-r970-simple-mapper-expr-prefix.out.expected
--- trunk/tests/language-behaviour/mappers/079-regression-r970-simple-mapper-expr-prefix.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/079-regression-r970-simple-mapper-expr-prefix.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+079-regression-r970-simple-mapper-expr-prefix.out
Added: trunk/tests/language-behaviour/mappers/079-regression-r970-simple-mapper-expr-prefix.swift
--- trunk/tests/language-behaviour/mappers/079-regression-r970-simple-mapper-expr-prefix.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/079-regression-r970-simple-mapper-expr-prefix.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,14 @@
+type messagefile;
+    app {
+string fn = "079-regression-r970-simple-mapper-expr-prefix";
+messagefile outfile <simple_mapper;prefix=fn,suffix=".out">;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/0791-regression-r970-simple-mapper-expr-prefix.out.expected
--- trunk/tests/language-behaviour/mappers/0791-regression-r970-simple-mapper-expr-prefix.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0791-regression-r970-simple-mapper-expr-prefix.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+0791-regression-r970-simple-mapper-expr-prefix.out
Added: trunk/tests/language-behaviour/mappers/0791-regression-r970-simple-mapper-expr-prefix.swift
--- trunk/tests/language-behaviour/mappers/0791-regression-r970-simple-mapper-expr-prefix.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0791-regression-r970-simple-mapper-expr-prefix.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,16 @@
+type messagefile;
+    app {
+string a = "0791-regression-r970";
+string b = "-simple-mapper-";
+string c = "expr-prefix";
+messagefile outfile <simple_mapper;prefix=@strcat(a,b,c),suffix=".out">;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/150-filesys_mapper.swift
--- trunk/tests/language-behaviour/mappers/150-filesys_mapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/150-filesys_mapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,4 @@
+type file;
+file f[] <filesys_mapper; prefix="pc", suffix=".pcap">;
Added: trunk/tests/language-behaviour/mappers/760-csv-mapper.sh
--- trunk/tests/language-behaviour/mappers/760-csv-mapper.sh	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/760-csv-mapper.sh	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,10 @@
+#!/bin/sh
+NAME=$1
+CSV_OUT=$2
+    echo "m"
+    touch $NAME
+    echo $NAME
+} > $CSV_OUT
Property changes on: trunk/tests/language-behaviour/mappers/760-csv-mapper.sh
Added: trunk/tests/language-behaviour/mappers/760-csv-mapper.swift
--- trunk/tests/language-behaviour/mappers/760-csv-mapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/760-csv-mapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,28 @@
+type file;
+type s
+    file m;
+app (file out) create ()
+    echo_sh "file1" @filename(out);
+(file result) list (file inf)
+    s diffs[] <csv_mapper; file=inf>;
+    foreach f, i in diffs
+        tracef("%s\n", @f.m);
+file o<"tmp.csv">;
+file i;
+file p;
+o = create();
+p = list(o);
Added: trunk/tests/language-behaviour/mappers/T074-simplemapper.aleph.out.expected
--- trunk/tests/language-behaviour/mappers/T074-simplemapper.aleph.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T074-simplemapper.aleph.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+foo
Added: trunk/tests/language-behaviour/mappers/T074-simplemapper.beth.out.expected
--- trunk/tests/language-behaviour/mappers/T074-simplemapper.beth.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T074-simplemapper.beth.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+bar
Added: trunk/tests/language-behaviour/mappers/T074-simplemapper.gimel.out.expected
--- trunk/tests/language-behaviour/mappers/T074-simplemapper.gimel.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T074-simplemapper.gimel.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+baz
Added: trunk/tests/language-behaviour/mappers/T074-simplemapper.swift
--- trunk/tests/language-behaviour/mappers/T074-simplemapper.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T074-simplemapper.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,28 @@
+// The basename of this test must begin with a letter rather than a
+// number because the mapper uses the first character to determine
+// whether the prefix should be interpreted as a number or as
+// a string - see bug 80
+type messagefile;
+type messagestruct {
+    messagefile aleph;
+    messagefile beth;
+    messagefile gimel;
+(messagefile t) stringToFile(string m) {
+    app {
+        echo m stdout=@filename(t);
+messagestruct outstruct <simple_mapper;
+                         prefix="T074-simplemapper.",
+                         suffix=".out">;
+outstruct.aleph = stringToFile("foo");
+outstruct.beth = stringToFile("bar");
+outstruct.gimel = stringToFile("baz");
Added: trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.aleph.out.expected
--- trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.aleph.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.aleph.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+foo
Added: trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.beth.out.expected
--- trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.beth.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.beth.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+bar
Added: trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.swift
--- trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T076-simplemapper-bug80.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,34 @@
+type messagefile;
+type secondstruct {
+    messagefile epsilon;
+    messagefile sigma;
+    messagefile beth;
+    secondstruct subordinate;
+    app {
+                         prefix="T076-simplemapper-bug80.",
+                         suffix=".out">;
+outstruct.subordinate.epsilon = stringToFile("E");
+outstruct.subordinate.sigma = stringToFile("S");
Added: trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.aleph.out.expected
--- trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.aleph.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.aleph.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+foo
Added: trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.beth.out.expected
--- trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.beth.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.beth.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+bar
Added: trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.swift
--- trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,39 @@
+type messagefile;
+type tertiarystruct {
+	messagefile hamza;
+    tertiarystruct moresubordinate;
+    messagefile beth;
+    app {
+                         prefix="T077-simplemapper-bug80.",
+                         suffix=".out">;
+outstruct.subordinate.moresubordinate.hamza = stringToFile("misr");
Added: trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate.epsilon.out.expected
--- trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate.epsilon.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate.epsilon.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+E
Added: trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate.sigma.out.expected
--- trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate.sigma.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate.sigma.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+S
Added: trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate_moresubordinate.hamza.out.expected
--- trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate_moresubordinate.hamza.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T077-simplemapper-bug80_subordinate_moresubordinate.hamza.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+misr
Added: trunk/tests/language-behaviour/mappers/T078-simplemapper-nosuffix.swift
--- trunk/tests/language-behaviour/mappers/T078-simplemapper-nosuffix.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T078-simplemapper-nosuffix.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,17 @@
+// this one is like test 073-simplemapper, but doesn't
+// add the missing dot in front of the suffix
+type messagefile;
+    app {
+                     prefix="T078-simplemapper-nosuffix", noauto="true",
+                     suffix="_nodot.out">;
+outfile = write();
Added: trunk/tests/language-behaviour/mappers/T078-simplemapper-nosuffix_nodot.out.expected
--- trunk/tests/language-behaviour/mappers/T078-simplemapper-nosuffix_nodot.out.expected	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T078-simplemapper-nosuffix_nodot.out.expected	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1 @@
+T078-simplemapper-nosuffix_nodot.out
Added: trunk/tests/language-behaviour/mappers/T079-simplemapper-nosuffix_exception.swift
--- trunk/tests/language-behaviour/mappers/T079-simplemapper-nosuffix_exception.swift	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/T079-simplemapper-nosuffix_exception.swift	2011-06-14 14:02:14 UTC (rev 4613)
@@ -0,0 +1,16 @@
+// this one is like test T078-simplemapper-nosuffix, but demonstrates the
+// mapping exception on invalid values
+type messagefile;
+    app {
+                     prefix="T078-simplemapper-nosuffix", noauto="exception",
+outfile = write();
