[Swift-commit] r4612 - in trunk: libexec	src/org/griphyn/vdl/karajan/lib
    hategan at ci.uchicago.edu
    Mon Jun 13 21:17:30 CDT 2011
Author: hategan
Date: 2011-06-13 21:17:30 -0500 (Mon, 13 Jun 2011)
New Revision: 4612
Modified:
   trunk/libexec/vdl-int.k
   trunk/src/org/griphyn/vdl/karajan/lib/UnwrapClosedList.java
Log:
fixed arguments when wrapper arguments are passed through files
Modified: trunk/libexec/vdl-int.k
--- trunk/libexec/vdl-int.k	2011-06-14 02:16:03 UTC (rev 4611)
+++ trunk/libexec/vdl-int.k	2011-06-14 02:17:30 UTC (rev 4612)
@@ -444,9 +444,7 @@
 							"-k ", kickstart, nl(),
 							"-cdmfile ", cdm:file(), nl(),
 							"-status ", statusMode, nl(),
-							"-a ", each(unwrapClosedList(arguments)), nl())
-						for(a, unwrapClosedList(arguments)
-							sys:file:write(wrapfile, append = true, a, nl())
+							for(a, unwrapClosedList(arguments), "-a ", a, nl())
Modified: trunk/src/org/griphyn/vdl/karajan/lib/UnwrapClosedList.java
--- trunk/src/org/griphyn/vdl/karajan/lib/UnwrapClosedList.java	2011-06-14 02:16:03 UTC (rev 4611)
+++ trunk/src/org/griphyn/vdl/karajan/lib/UnwrapClosedList.java	2011-06-14 02:17:30 UTC (rev 4612)
@@ -3,17 +3,14 @@
 package org.griphyn.vdl.karajan.lib;
+import java.util.ArrayList;
 import java.util.List;
 import org.apache.log4j.Logger;
 import org.globus.cog.karajan.arguments.Arg;
 import org.globus.cog.karajan.stack.VariableStack;
 import org.globus.cog.karajan.workflow.ExecutionException;
-import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
 import org.griphyn.vdl.mapping.DSHandle;
-import org.griphyn.vdl.mapping.HandleOpenException;
-import org.griphyn.vdl.mapping.InvalidPathException;
-import org.griphyn.vdl.mapping.Path;
 public class UnwrapClosedList extends VDLFunction {
 	public static final Logger logger = Logger.getLogger(UnwrapClosedList.class);
@@ -24,18 +21,14 @@
 		setArguments(UnwrapClosedList.class, new Arg[] { PA_LIST });
-	 * Takes a supplied variable and path, and returns the unique value at that
-	 * path. Path can contain wildcards, in which case an array is returned.
 	public Object function(VariableStack stack) throws ExecutionException {
 		@SuppressWarnings("unchecked")
         List<DSHandle> l = (List<DSHandle>) PA_LIST.getValue(stack);
-		Object[] r = new Object[l.size()];
+		List<Object> r = new ArrayList<Object>(l.size());
-		for (int i = 0; i < r.length; i++) {
-		    r[i] = l.get(i).getValue();
+		for (DSHandle h : l) {
+		    r.add(h.getValue());
 		return r;
More information about the Swift-commit
