[Swift-commit] r4879 - trunk/tests/providers/local-pbs-coasters
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Fri Jul 29 16:49:34 CDT 2011
Author: wozniak
Date: 2011-07-29 16:49:34 -0500 (Fri, 29 Jul 2011)
New Revision: 4879
Added:
   trunk/tests/providers/local-pbs-coasters/001-catsn.check.sh
   trunk/tests/providers/local-pbs-coasters/001-catsn.setup.sh
   trunk/tests/providers/local-pbs-coasters/001-catsn.swift
   trunk/tests/providers/local-pbs-coasters/001-catsn.timeout
Removed:
   trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh
   trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh
   trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift
   trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout
Log:
Use shorter names
Deleted: trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh
--- trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh	2011-07-29 21:47:50 UTC (rev 4878)
+++ trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh	2011-07-29 21:49:34 UTC (rev 4879)
@@ -1,12 +0,0 @@
-#!/bin/bash
-set -x
-for count in `seq --format "%04.f" 1 1 10`
-do
-	[ -f catsn.$count.out ] || exit 1
-	CONTENTS1=$( cat catsn.$count.out.expected )
-	CONTENTS2=$( cat catsn.$count.out )
-	[[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
-done
-exit 0
Deleted: trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh
--- trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh	2011-07-29 21:47:50 UTC (rev 4878)
+++ trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh	2011-07-29 21:49:34 UTC (rev 4879)
@@ -1,4 +0,0 @@
-#!/bin/bash
-cp -v $GROUP/data.txt . || exit 1
-cp -v $GROUP/*expected . || exit 1
Deleted: trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift
--- trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift	2011-07-29 21:47:50 UTC (rev 4878)
+++ trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift	2011-07-29 21:49:34 UTC (rev 4879)
@@ -1,15 +0,0 @@
-type file;
-app (file o) cat (file i)
-  cat @i stdout=@o;
-string t = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
-string char[] = @strsplit(t, "");
-file out[]<simple_mapper; location=".", prefix="catsn.",suffix=".out">;
-foreach j in [1:@toint(@arg("n","10"))] {
-  file data<"data.txt">;
-  out[j] = cat(data);
Deleted: trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout
--- trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout	2011-07-29 21:47:50 UTC (rev 4878)
+++ trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout	2011-07-29 21:49:34 UTC (rev 4879)
@@ -1,2 +0,0 @@
-7200
Copied: trunk/tests/providers/local-pbs-coasters/001-catsn.check.sh (from rev 4875, trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh)
--- trunk/tests/providers/local-pbs-coasters/001-catsn.check.sh	                        (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/001-catsn.check.sh	2011-07-29 21:49:34 UTC (rev 4879)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+for count in `seq --format "%04.f" 1 1 10`
+do
+	[ -f catsn.$count.out ] || exit 1
+	CONTENTS1=$( cat catsn.$count.out.expected )
+	CONTENTS2=$( cat catsn.$count.out )
+	[[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
+done
+exit 0
Copied: trunk/tests/providers/local-pbs-coasters/001-catsn.setup.sh (from rev 4875, trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh)
--- trunk/tests/providers/local-pbs-coasters/001-catsn.setup.sh	                        (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/001-catsn.setup.sh	2011-07-29 21:49:34 UTC (rev 4879)
@@ -0,0 +1,4 @@
+#!/bin/bash
+cp -v $GROUP/data.txt . || exit 1
+cp -v $GROUP/*expected . || exit 1
Copied: trunk/tests/providers/local-pbs-coasters/001-catsn.swift (from rev 4875, trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift)
--- trunk/tests/providers/local-pbs-coasters/001-catsn.swift	                        (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/001-catsn.swift	2011-07-29 21:49:34 UTC (rev 4879)
@@ -0,0 +1,15 @@
+type file;
+app (file o) cat (file i)
+  cat @i stdout=@o;
+string t = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
+string char[] = @strsplit(t, "");
+file out[]<simple_mapper; location=".", prefix="catsn.",suffix=".out">;
+foreach j in [1:@toint(@arg("n","10"))] {
+  file data<"data.txt">;
+  out[j] = cat(data);
Copied: trunk/tests/providers/local-pbs-coasters/001-catsn.timeout (from rev 4875, trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout)
--- trunk/tests/providers/local-pbs-coasters/001-catsn.timeout	                        (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/001-catsn.timeout	2011-07-29 21:49:34 UTC (rev 4879)
@@ -0,0 +1,2 @@
+7200
