[Swift-commit] r4878 - trunk/tests/providers/local-pbs-coasters/fusion
wozniak at ci.uchicago.edu
Fri Jul 29 16:47:51 CDT 2011
Author: wozniak
Date: 2011-07-29 16:47:50 -0500 (Fri, 29 Jul 2011)
New Revision: 4878
Added:
trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.check.sh
trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.setup.sh
trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.swift
trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.timeout
trunk/tests/providers/local-pbs-coasters/fusion/data.txt
trunk/tests/providers/local-pbs-coasters/fusion/sites.template.xml
trunk/tests/providers/local-pbs-coasters/fusion/tc.template.data
Log:
Copy in local-pbs-coasters settings for fusion
Copied: trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.check.sh (from rev 4875, trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.check.sh)
--- trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.check.sh (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.check.sh 2011-07-29 21:47:50 UTC (rev 4878)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+for count in `seq --format "%04.f" 1 1 10`
+do
+ [ -f catsn.$count.out ] || exit 1
+ CONTENTS1=$( cat catsn.$count.out.expected )
+ CONTENTS2=$( cat catsn.$count.out )
+ [[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
+done
+exit 0
Copied: trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.setup.sh (from rev 4875, trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.setup.sh)
--- trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.setup.sh (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.setup.sh 2011-07-29 21:47:50 UTC (rev 4878)
@@ -0,0 +1,4 @@
+#!/bin/bash
+cp -v $GROUP/data.txt . || exit 1
+cp -v $GROUP/*expected . || exit 1
Copied: trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.swift (from rev 4875, trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.swift)
--- trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.swift (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.swift 2011-07-29 21:47:50 UTC (rev 4878)
@@ -0,0 +1,15 @@
+type file;
+app (file o) cat (file i)
+ cat @i stdout=@o;
+string t = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
+string char[] = @strsplit(t, "");
+file out[]<simple_mapper; location=".", prefix="catsn.",suffix=".out">;
+foreach j in [1:@toint(@arg("n","10"))] {
+ file data<"data.txt">;
+ out[j] = cat(data);
Copied: trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.timeout (from rev 4875, trunk/tests/providers/local-pbs-coasters/001-catsn-pads-local-pbs-coasters.timeout)
--- trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.timeout (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/fusion/001-catsn-pads-local-pbs-coasters.timeout 2011-07-29 21:47:50 UTC (rev 4878)
@@ -0,0 +1,2 @@
+7200
Copied: trunk/tests/providers/local-pbs-coasters/fusion/data.txt (from rev 4875, trunk/tests/providers/local-pbs-coasters/data.txt)
--- trunk/tests/providers/local-pbs-coasters/fusion/data.txt (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/fusion/data.txt 2011-07-29 21:47:50 UTC (rev 4878)
@@ -0,0 +1 @@
+Hello world
Copied: trunk/tests/providers/local-pbs-coasters/fusion/sites.template.xml (from rev 4875, trunk/tests/providers/local-pbs-coasters/sites.template.xml)
--- trunk/tests/providers/local-pbs-coasters/fusion/sites.template.xml (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/fusion/sites.template.xml 2011-07-29 21:47:50 UTC (rev 4878)
@@ -0,0 +1,17 @@
+<config>
+<pool handle="local-pbs-coasters">
+ <execution jobmanager="local:pbs" provider="coaster" url="none"/>
+ <filesystem provider="local" url="none" />
+ <profile namespace="globus" key="maxWallTime">1</profile>
+ <profile namespace="globus" key="maxTime">7200</profile>
+ <profile key="jobsPerNode" namespace="globus">1</profile>
+ <profile key="slots" namespace="globus">1</profile>
+ <profile key="nodeGranularity" namespace="globus">1</profile>
+ <profile key="maxNodes" namespace="globus">1</profile>
+ <profile key="queue" namespace="globus">_QUEUE_</profile>
+ <profile key="jobThrottle" namespace="karajan">5.99</profile>
+ <profile key="initialScore" namespace="karajan">10000</profile>
+ <profile namespace="globus" key="project">_PROJECT_</profile>
+ <workdirectory>_WORK_</workdirectory>
+</pool>
+</config>
Copied: trunk/tests/providers/local-pbs-coasters/fusion/tc.template.data (from rev 4875, trunk/tests/providers/local-pbs-coasters/tc.template.data)
--- trunk/tests/providers/local-pbs-coasters/fusion/tc.template.data (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/fusion/tc.template.data 2011-07-29 21:47:50 UTC (rev 4878)
@@ -0,0 +1,8 @@
+local-pbs-coasters echo /bin/echo INSTALLED INTEL32::LINUX null
+local-pbs-coasters cat /bin/cat INSTALLED INTEL32::LINUX null
+local-pbs-coasters ls /bin/ls INSTALLED INTEL32::LINUX null
+local-pbs-coasters grep /bin/grep INSTALLED INTEL32::LINUX null
+local-pbs-coasters sort /bin/sort INSTALLED INTEL32::LINUX null
+local-pbs-coasters paste /bin/paste INSTALLED INTEL32::LINUX null
+local-pbs-coasters wc /usr/bin/wc INSTALLED INTEL32::LINUX null
More information about the Swift-commit
