[Swift-commit] r4818 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Tue Jul 12 12:00:08 CDT 2011
Author: jonmon
Date: 2011-07-12 12:00:08 -0500 (Tue, 12 Jul 2011)
New Revision: 4818
Modified:
   SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
changed the way files are written. added information to contact the proxy servers correctly.
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-07-12 00:10:40 UTC (rev 4817)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-07-12 17:00:08 UTC (rev 4818)
@@ -19,7 +19,6 @@
 from pykoa.tools.koa_ep_activate import check_explicit_activate
 from pykoa.consumers import guc_util
 from pykoa.constants import get_scheme
-from pykoa.lib.mlsd import MLSDEntry
 from pykoa.data import endpoint_dao
 from pykoa.data import creds_dao
 from pykoa.koaexception import ToolsException, cli_exception_handler
@@ -52,8 +51,12 @@
                       default=False, action="store_true",
                       help="Use gsi-ssh delegated credential")
+    myproxy.add_myproxy_options(parser)
     (options, args) = pykoa.tools.parse_args(parser, argv)
+    if options.gsi_activation and not os.getenv("X509_USER_PROXY"):
+        raise ToolsException("ENO_GSI_SSH")
     return (parser, options, args)
 def parse_stdin():
@@ -70,8 +73,7 @@
     sites_file = extract_sites( lines )
     config     = extract_config( lines )
     script     = extract_script( lines )
     return ( tc, sites_file, config, script )
 def extract_tc( lines ):
@@ -206,33 +208,30 @@
     # Set up for the acutal execution
     os.mkdir( swift_dir+'/'+run_directory )
-    tc_file = open( swift_dir+'/'+run_directory+'/tc', 'w' )
-    sites_file = open( swift_dir+'/'+run_directory+'/sites.xml', 'w' )
-    config_file = open( swift_dir+'/'+run_directory+'/cf', 'w' )
-    script_file = open( swift_dir+'/'+run_directory+'/script.swift', 'w' )
+    with open( swift_dir+'/'+run_directory+'/tc', 'w' ) as tc_file:
+        tc_file.write( tc )
-    tc_file.write( tc )
-    sites_file.write( sites )
-    config_file.write( config )
-    script_file.write( script )
+    with open( swift_dir+'/'+run_directory+'/sites.xml', 'w' ) as sites_file:
+        sites_file.write( sites )
-    tc_file.close()
-    sites_file.close()
-    config_file.close()
-    script_file.close()
+    with open( swift_dir+'/'+run_directory+'/cf', 'w' ) as config_file:
+        config_file.write( config )
-    # A logical endpoint (no dots) can be a scp like path, if it has a :
-    if re.match("^[^.]+:", args[0]):
-        url = url_parse.SCPUrl(args[0], allow_empty_path=True)
-        url.update_relative_path()
-    else:
-        url = url_parse.TransferURL(args[0])
+    with open( swift_dir+'/'+run_directory+'/script.swift', 'w' ) as script_file:
+        script_file.write( script )
+    # A logical endpoint (no dots) can be a scp like path, if it has a :
+    for arg in args:
+        if re.match("^[^.]+:", arg):
+            url = url_parse.SCPUrl(arg, allow_empty_path=True)
+            url.update_relative_path()
+        else:
+            url = url_parse.TransferURL(arg)
     src_url = None
     src_cred = None
     default_myproxy = None
     ep = None
-    myproxy_host = None
     if not url.scheme:
         # See if it's a logical endpoint
@@ -280,13 +279,13 @@
         cred_file = os.environ["X509_USER_PROXY"]
         src_cred = open(cred_file).read()
-    elif myproxy_host or ((not src_cred) and default_myproxy):
-        if not myproxy_host:
-            myproxy_host = default_myproxy
+    elif options.myproxy_host or ((not src_cred) and default_myproxy):
+        if not options.myproxy_host:
+            options.myproxy_host = default_myproxy
 	if ep:
-	    check_explicit_activate([ep], myproxy_host)
+	    check_explicit_activate([ep], options.myproxy_host)
-        cred_file = myproxy.contact_myproxy_server(myproxy_host,
+        cred_file = myproxy.contact_myproxy_server(options.myproxy_host,
                 options.myproxy_user, options.myproxy_dn,
                 lifetime=options.myproxy_lifetime)
@@ -295,12 +294,12 @@
         try:
             if ep:
-                # Save cred to DB, re-entering passphrases is annoying
+                # Save to the database
                 ep_cache = {'foo': ep.id}
                 koa_transfer.do_activate(conn, cred_file, ep_cache, user_id,
-                        quiet=True)
+                                         quiet=True)
         finally:
-            os.unlink(cred_file)
+            os.remove(cred_file)
     if not src_cred:
         raise ToolsException("A credential is needed.  Try -g or -m.")
