[Swift-commit] r4817 - SwiftApps/GOSwift/pykoa/tools
jonmon at ci.uchicago.edu
Mon Jul 11 19:10:41 CDT 2011
Author: jonmon
Date: 2011-07-11 19:10:40 -0500 (Mon, 11 Jul 2011)
New Revision: 4817
Modified:
SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
Log:
removed the lines to remove the tc, sites, config, and script files from the run directory. Need to keep these for debugging.
Modified: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-11 22:17:20 UTC (rev 4816)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py 2011-07-12 00:10:40 UTC (rev 4817)
@@ -307,13 +307,6 @@
ret = execute_swift(user_id, options, src_url, src_cred, src_subject, swift_dir, run_directory, home)
- # clean up
-# os.remove( swift_dir + "/" + run_directory + "/tc" )
-# os.remove( swift_dir + "/" + run_directory + "/sites.xml" )
-# os.remove( swift_dir + "/" + run_directory + "/cf" )
-# os.remove( swift_dir + "/" + run_directory + "/script.swift" )
return ret
def execute_swift(user_id, options, src_url, src_cred, src_subject, swift_dir, run_directory, home):
More information about the Swift-commit
