[Swift-commit] r4037 - in SwiftApps/SwiftR: . mxtests
noreply at svn.ci.uchicago.edu
Tue Jan 25 16:22:33 CST 2011
Author: tga
Date: 2011-01-25 16:22:33 -0600 (Tue, 25 Jan 2011)
New Revision: 4037
Added:
SwiftApps/SwiftR/mxtests/
SwiftApps/SwiftR/mxtests/BootstrapParallelBigger.R
Log:
Checking in initial version of larger bootstrap parallel script before modifying to work
with swiftR
Added: SwiftApps/SwiftR/mxtests/BootstrapParallelBigger.R
--- SwiftApps/SwiftR/mxtests/BootstrapParallelBigger.R (rev 0)
+++ SwiftApps/SwiftR/mxtests/BootstrapParallelBigger.R 2011-01-25 22:22:33 UTC (rev 4037)
@@ -0,0 +1,118 @@
+# Copyright 2007-2010 The OpenMx Project
+# Licensed under the Apache License, Version 2.0 (the "License");
+# you may not use this file except in compliance with the License.
+# You may obtain a copy of the License at
+# http://www.apache.org/licenses/LICENSE-2.0
+# Unless required by applicable law or agreed to in writing, software
+# distributed under the License is distributed on an "AS IS" BASIS,
+# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+# See the License for the specific language governing permissions and
+# limitations under the License.
+require(OpenMx)
+require(snowfall)
+hostfile <- Sys.getenv(c("PBS_NODEFILE"))
+hostnames <- read.table(hostfile, stringsAsFactors=FALSE)[[1]]
+ncpus <- length(hostnames)
+sfSetMaxCPUs(ncpus)
+sfInit(parallel=TRUE, cpus=ncpus, socketHosts=hostnames)
+sfLibrary(OpenMx)
+set.seed(10)
+# parameters for the simulation: lambda = factor loadings,
+# specifics = specific variances
+nVar <- 75
+nObs <- 10000
+nReps <- 1024
+goodStartValues <- TRUE
+if (!is.logical(goodStartValues)) {
+ stop("'goodStartValues' should be logical. Try again.")
+lambda <- matrix(1:nVar*2/nVar, nVar, 1)
+specifics <- diag(nVar)
+chl <- chol(lambda %*% t(lambda) + specifics)
+# indices for parameters and hessian estimate in results
+pStrt <- 3
+pEnd <- pStrt + 2*nVar - 1
+hStrt <- pEnd + 1
+hEnd <- hStrt + 2*nVar - 1
+# dimension names for OpenMx
+dn <- list()
+dn[[1]] <- paste("Var", 1:nVar, sep="")
+dn[[2]] <- dn[[1]]
+# function to get a covariance matrix
+randomCov <- function(nObs, nVar, chl, dn) {
+ x <- matrix(rnorm(nObs*nVar), nObs, nVar)
+ x <- x %*% chl
+ thisCov <- cov(x)
+ dimnames(thisCov) <- dn
+ return(thisCov)
+createNewModel <- function(index, prefix, model) {
+ modelname <- paste(prefix, index, sep='')
+ model at data@observed <- randomCov(nObs, nVar, chl, dn)
+ model at name <- modelname
+ return(model)
+getStats <- function(model) {
+ retval <- c(model at output$status[[1]],
+ max(abs(model at output$gradient)),
+ model at output$estimate,
+ sqrt(diag(solve(model at output$hessian))))
+ return(retval)
+# initialize obsCov for MxModel
+obsCov <- randomCov(nObs, nVar, chl, dn)
+# results matrix: get results for each simulation
+results <- matrix(0, nReps, hEnd)
+dnr <- c("inform", "maxAbsG", paste("lambda", 1:nVar, sep=""),
+ paste("specifics", 1:nVar, sep=""),
+ paste("hessLambda", 1:nVar, sep=""),
+ paste("hessSpecifics", 1:nVar, sep=""))
+dimnames(results)[[2]] <- dnr
+# instantiate MxModel
+template <- mxModel(name="stErrSim",
+ mxMatrix(name="lambda", type="Full", nrow=nVar, ncol=1,
+ free=TRUE, values=(1:nVar*2/nVar)*goodStartValues),
+ mxMatrix(name="specifics", type="Diag", nrow=nVar,
+ free=TRUE, values=rep(1, nVar)),
+ mxAlgebra(lambda %*% t(lambda) + specifics,
+ name="preCov", dimnames=dn),
+ mxData(observed=obsCov, type="cov", numObs=nObs),
+ mxMLObjective(covariance='preCov'),
+ independent = TRUE)
+topModel <- mxModel(name = 'container')
+sfExportAll()
+submodels <- lapply(1:nReps, createNewModel, 'stErrSim', template)
+names(submodels) <- omxExtractNames(submodels)
+topModel at submodels <- submodels
+modelResults <- mxRun(topModel, silent=TRUE, suppressWarnings=TRUE)
+print(ncpus)
+print(modelResults at output$wallTime)
+sfStop()
More information about the Swift-commit
