[Swift-commit] r4036 - in SwiftApps/SwiftR: . Swift/R Swift/exec Swift/man
Tue Jan 25 15:35:30 CST 2011
Author: tga
Date: 2011-01-25 15:35:30 -0600 (Tue, 25 Jan 2011)
New Revision: 4036
Modified:
   SwiftApps/SwiftR/JOINT-TODO
   SwiftApps/SwiftR/Swift/R/Swift.R
   SwiftApps/SwiftR/Swift/R/Workers.R
   SwiftApps/SwiftR/Swift/exec/start-swift
   SwiftApps/SwiftR/Swift/man/Swift-package.Rd
   SwiftApps/SwiftR/Swift/man/swiftInit.Rd
   SwiftApps/SwiftR/Swift/man/swiftapply.Rd
Log:
* SGE bugfix: correctly capture jobid
* Updated package help file
* All swiftApply and swiftInit options can now be set through options()
Modified: SwiftApps/SwiftR/JOINT-TODO
--- SwiftApps/SwiftR/JOINT-TODO	2011-01-25 19:23:13 UTC (rev 4035)
+++ SwiftApps/SwiftR/JOINT-TODO	2011-01-25 21:35:30 UTC (rev 4036)
@@ -6,7 +6,6 @@
     - Local multi-core
     - PBS
     - SSH
-* No hanging on FIFO reads/writes
 * Working on the following platforms for development use:
     - Cobalt
     - Slurm
Modified: SwiftApps/SwiftR/Swift/R/Swift.R
--- SwiftApps/SwiftR/Swift/R/Swift.R	2011-01-25 19:23:13 UTC (rev 4035)
+++ SwiftApps/SwiftR/Swift/R/Swift.R	2011-01-25 21:35:30 UTC (rev 4036)
@@ -48,8 +48,19 @@
     tmpdir <- getOption("swift.tmpdir")
   if(is.null(tmpdir))
     tmpdir <- Sys.getenv("SWIFTR_TMP");
-  if(tmpdir=="")
+  if(tmpdir=="") {
+    if(is.null(tmpdir))
+      tmpdir <- getOption("swift.tmpdir")
     tmpdir <- "/tmp";
+  if(is.null(quiet)) {
+    quiet <- getOption("swift.quiet")
+        quiet <- FALSE
   if (! quiet) {
       cat("\nSwift properties:\n")
       cat("  server =", server,"\n")
@@ -82,7 +93,7 @@
 #  basedir = paste("/tmp/",user,"/SwiftR/requests",sep="")
 #  reqdir <- system(paste("mktemp -d ", basedir, "/SwiftR.run.XXXX",sep=""),intern=TRUE)
   reqdir = sprintf("%s/R%.7d",requestdirbase,requestid)
-  dir.create(reqdir,showWarnings=FALSE)
+  dir.create(reqdir,recursive=TRUE,showWarnings=FALSE)
   #dir.create(reqdir,showWarnings=TRUE)
   if (! quiet) {
       cat("Swift request is in",reqdir,"\n")
Modified: SwiftApps/SwiftR/Swift/R/Workers.R
--- SwiftApps/SwiftR/Swift/R/Workers.R	2011-01-25 19:23:13 UTC (rev 4035)
+++ SwiftApps/SwiftR/Swift/R/Workers.R	2011-01-25 21:35:30 UTC (rev 4036)
@@ -8,7 +8,6 @@
                     rcmd=NULL, time=NULL,
                     workerLogging=NULL )
-    #TODO: document function
     # server: which server backend to use to acquire workers
     #           for example, local runs tasks on the local machine
     #           pbs, uses the PBS scheduler to obtain nodes on a cluster,
@@ -37,6 +36,8 @@
     # Presume UNIX path names - start-swift script
     cmdString <- file.path(.find.package("Swift"), "exec/start-swift-daemon")
+    if(is.null(cores))
+        cores <- getOption("swift.cores")
     if(! is.null(cores) )  {
         cmdString <- paste(cmdString, "-c", shQuote(cores))
@@ -46,30 +47,58 @@
     if(! is.null(server) )  {
         cmdString <- paste(cmdString, "-s", shQuote(server))
+    if(is.null(hosts))
+        hosts <- getOption("swift.hosts")
     if(! is.null(hosts) )  {
         cmdString <- paste(cmdString, "-h", shQuote(hosts) )
+    if(is.null(parEnv))
+        parEnv <- getOption("swift.parenv")
     if(! is.null(parEnv) )  {
         cmdString <- paste(cmdString, "-e", shQuote(parEnv))
+    if(is.null(workmode))
+        workmode <- getOption("swift.workmode")
     if(! is.null(workmode) )  {
         cmdString <- paste(cmdString, "-m", shQuote(workmode))
+    if(is.null(nodes))
+        nodes <- getOption("swift.nodes")
     if(! is.null(nodes) )  {
         cmdString <- paste(cmdString, "-n", shQuote(nodes))
+    if(is.null(throttle))
+        throttle <- getOption("swift.throttle")
     if(! is.null(throttle) )  {
         cmdString <- paste(cmdString, "-p", shQuote(throttle))
+    if(is.null(queue))
+        queue <- getOption("swift.queue")
     if(! is.null(queue) )  {
         cmdString <- paste(cmdString, "-q", shQuote(queue))
+    if(is.null(rcmd))
+        rcmd <- getOption("swift.rcmd")
     if(! is.null(rcmd) )  {
         cmdString <- paste(cmdString, "-r", shQuote(rcmd))
+    if(is.null(time))
+        time <- getOption("swift.time")
     if(! is.null(time) )  {
         cmdString <- paste(cmdString, "-t", shQuote(time))
+    if(is.null(workerLogging))
+        workerLogging <- getOption("swift.workerLogging")
     if(! is.null(workerLogging) )  {
         cmdString <- paste(cmdString, "-w", shQuote(workerLogging))
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift	2011-01-25 19:23:13 UTC (rev 4035)
+++ SwiftApps/SwiftR/Swift/exec/start-swift	2011-01-25 21:35:30 UTC (rev 4036)
@@ -4,6 +4,15 @@
 export TRAPEVENTS="EXIT 1 2 3 15"  # Signals and conditions to trap
+# Standard clenuup actions
+function stdcleanup {
+    # don't accept any more requests: unlink fifo from filesystem
+    if [ -p requestpipe ]; then
+        rm requestpipe
+    fi
 # Define internal functions
 get-contact()
@@ -173,6 +182,10 @@
   if [ $parEnv != NONE ]; then
     parEnvDirective="#$ -pe $parEnv $(($nodes*$cores))"
   else
+    if [ $nodes -gt 1 ]; then
+        echo "Warning: requested $nodes nodes without parEnv directive"
+        echo "SGE provider is defaulting to a single node and $cores cores"
+    fi
     parEnvDirective=""
   fi
@@ -198,16 +211,28 @@
 # $ -A TG-DBS080004N
   cd /
+  HOST=$(echo $CONTACT | sed -e 's,^http://,,' -e 's/:.*//')
+  PORT=$(echo $CONTACT | sed -e 's,^.*:,,')
+  if [ "\$PE_HOSTFILE" = "" ] ; then
+    # Not a parallel environment, just run job on this host
+    # with the specified number of cores
+    echo '***' Single host \$(hostname) CONTACT:$CONTACT
+    # Mimic the first two pe_hostfile columns
+    HOSTS="\$(hostname) $cores"
+  else
+    echo '***' PE_HOSTFILE file: \$PE_HOSTFILE CONTACT:$CONTACT
+    cat \$PE_HOSTFILE
+    HOSTS=\$(cat \$PE_HOSTFILE)
+  fi
   if [ $workmode = slot ]; then
-    NODES=\`cat \$PE_HOSTFILE | awk '{ for(i=0;i<\$2;i++){print \$1} }'\`
+    NODES=\`echo "\$HOSTS" | awk '{ for(i=0;i<\$2;i++){print \$1} }'\`
   else
-    NODES=\`cat \$PE_HOSTFILE | awk '{print \$1}'\` # Better for Ranger, Eddie, ...
+    NODES=\`echo "\$HOSTS"  | awk '{print \$1}'\` # Better for Ranger, Eddie, ...
   fi
-  HOST=$(echo $CONTACT | sed -e 's,^http://,,' -e 's/:.*//')
-  PORT=$(echo $CONTACT | sed -e 's,^.*:,,')
-  echo '***' PE_HOSTFILE file: \$PE_HOSTFILE CONTACT:$CONTACT
-  cat \$PE_HOSTFILE
   for h in \$NODES; do
     workerCmd="echo Swift R startup running on host; hostname; cd /; WORKER_LOGGING_LEVEL=$workerLogging /usr/bin/perl $SWIFTBIN/worker.pl $CONTACT SwiftR-\$h $HOME/.globus/coasters $IDLETIMEOUT"
@@ -233,9 +258,31 @@
   # FIXME: set up for capturing batch job id: rm -rf remotepid.* # FIXME: should not be needed if we start in a new dir each time
   make-${server}-submit-file
-  qsub batch.sub >$jobidfile
+  #FIXME: doesn't work for SGE on IBI cluster as there is additional text
+  # returned by qsub
+  if [ "${server}" != "sge" ]
+  then
+    qsub batch.sub >$jobidfile
+    succ=$?
+  else
+    # Sun grid engine inconviently returns a bunch of text surrounding
+    # the job id.  There is no documented way to obtain the job number
+    # directly from qsub.  We will parse out the first number in this text
+    # and assume this is the job ID (this is true for versions of SGE
+    # this was tested on).
+    qsub batch.sub | sed 's/[^0-9 ]//g' | awk '{ print $1 }' > $jobidfile
+    succ=$?
+  fi
-  echo Started workers from batch job $(cat $jobidfile)
+  if [ $? -eq 0 ]
+  then
+    echo Started workers from batch job $(cat $jobidfile)
+  else
+    echo Batch queue submission failed, exiting.
+    stdcleanup
+    exit 1
+  fi
 verify-is-one-of()
@@ -385,12 +432,6 @@
 out=swift.stdouterr
 touch $out
-function stdcleanup {
-    # don't accept any more requests: unlink fifo from filesystem
-    if [ -p requestpipe ]; then
-        rm requestpipe
-    fi
 if [ $server = local ]; then
@@ -477,7 +518,7 @@
     jobid=$(cat $jobidfile)
     echo Terminating worker processes starter $starterpid and batch job $jobid
     if [ "_$starterpid" != _ ]; then
-      kill $starterpid
+      kill $starterpid &> /dev/null
     fi
     if [ "_$jobid" != _ ]; then
       qdel "$jobid"
Modified: SwiftApps/SwiftR/Swift/man/Swift-package.Rd
--- SwiftApps/SwiftR/Swift/man/Swift-package.Rd	2011-01-25 19:23:13 UTC (rev 4035)
+++ SwiftApps/SwiftR/Swift/man/Swift-package.Rd	2011-01-25 21:35:30 UTC (rev 4036)
@@ -72,7 +72,7 @@
 r = swiftLapply(seq(1,10),sqrt)
-Currenty swiftLapply is the only one implemented (i.e. swiftSapply etc are not yet provided but will be soon).
+Currently swiftLapply is the only one implemented (i.e. swiftSapply etc are not yet provided but will be soon).
 Arbitrary R objects can be passed. For example:
@@ -87,17 +87,21 @@
     res = swiftapply(sumstuff, arglist)
-As a preliminary interface, you can set R options() to control the
-operation of the functions in the Swift package:
+\code{swiftapply} and \code{swiftInit} take a range of arguments to
+control the setup of the cluster and how parallel apply calls are handled.
+You can set global default values of these settings through R options().
+Some key options are:
 options(swift.callsperbatch=n) # n = number of R calls to perform in
 each Swift job.
 options(swift.server="servername") # servername = "local" to run on
-the current host, "pbs" to submit to a local PBS cluster, "pbsf" to
-run on clusters such as Merlot which have firewalls that restrict
-outbound cnnectivity from the worker nodes to the Swift server running
-on the login node.
+the current host, "ssh" to run on remote machines via ssh, "pbs" to submit to a local PBS cluster and "sge" for a local Sun Grid Engine cluster. An additional
+setting, "pbsf" is provided for clusters such as Merlot which have
+firewalls that restrict outbound cnnectivity from the worker nodes
+to the Swift server running on the login node.
 options(swift.keepwork=TRUE) # Retain the temporary files that the
 Swift functions use to pass R data from client t remote R
@@ -157,42 +161,68 @@
 (b) One or more remote machines, possibly each a multicore, accessed via ssh
-(c) Clusters running PBS, SGE, or Condor schedulers
+(c) Clusters running PBS, or SGE schedulers.  More cluster schedulers will
+    be supported in the future.
-In configurations (b) and (c) Swift will launch its own workers, and
-then communicate using its own TCP protocol.
+You can select between options a), b) and c) using the "swift.server" option
+or by providing a "server" argument to \code{swiftInit} and \code{swiftapply}.
+Other arguments, documented on the \code{swiftInit} manual page, allow
+you to specify the parameters, such as number of cores.
-Swift workers must be able to connect back to the Swift server on TCP
+In cases b) and c), the Swift workers, running on remote machines or
+cluster nodes, must be able to connect back to the Swift server (running
+on the same machine as R) on TCP
 ports in the range of 30000 and higher.  (FIXME: determine specifics).
 If this is not available on a cluster (e.g., Merlot), then the pbsf
 server will tunnel the Swift port over the standard ssh port, assuming
-that is reachable.
+that is reachable.  If pbsf is in use, and
+your Swift server machine has multiple network
+interfaces, you may need to set the GLOBUS_HOSTNAME environment variable
+to specify the network address workers should connect to.
 \section{INSTALLATION}{
+Installation is through the standard R CMD INSTALL command.
+If you have access to install libraries directly in your R
+installation.
 \preformatted{
-mkdir ~/RPackages ~/RLibrary # if not already created
-cd ~/RPackages
-wget http://www.ci.uchicago.edu/~wilde/Swift_0.1.tar.gz
-R CMS INSTALL -l ~/RLibrary Swift_0.1.tar.gz
-export R_LIBS=~/RLibrary
+wget http://www.ci.uchicago.edu/~wilde/Swift_0.2.tar.gz
+R CMD INSTALL Swift_0.2.tar.gz
-export GLOBUS_HOSTNAME=10.0.0.200 # Eg for Merlot: internal address of the login node}
+If you keep your libraries in a separate location in your home directory,
+or you do not have access to modify the R installation.
+\preformatted{
+mkdir ~/RLibrary # if you have not already created a library folder
+R CMD INSTALL -l ~/RLibrary Swift_0.2.tar.gz
+# tell R where to find the library: add this to your .bashrc file or equivalent
+export R_LIBS=~/RLibrary:$R_LIBS
 \section{QUICK_START}{
+In a terminal window:
 \preformatted{
-In a shell (outside of R) start the local Swift server:
-$HOME/RLibrary/Swift/exec/swift-start local #
+$ export R_LIBS=$HOME/RLibrary
-export R_LIBS=$HOME/RLibrary
-R
+$ R
+Now in R:
+\preformatted{
 > require(Swift)
+> options(swift.server="local")
+> swiftInit(cores=4) # start up Swift on your local machine
 > basicSwiftTest()   # should take about 1 second
 > runAllSwiftTests() # should take < 60 seconds
@@ -219,40 +249,34 @@
 \section{START_SERVERS}{
-To run swiftapply() and any of the swiftXapply() functions, you first
+To run \code{swiftapply()} and any of the \code{swiftXapply()}
+functions, you first
 start one or more "Swift servers" on your local host (where you will
-run the R client workspace.
-Currently you must do this manually and in your login shell, outside
-of R - BEFORE trying to run R Swift functions. If you run swiftapply()
-without a Swift server running, your R session will hang and you will
-need to kill it. This issue will be resolved shortly.
-The start-swift command (and all related shell scripts) are located in the installed package "exec" directry, so its handy to set a shell variable to point there:
-SWIFT=<your package install dir>/Swift/
+run the R client workspace.  You can do this with the \code{swiftInit()}
+function in R.
 Examples of starting the Swift server follow.
-To run N parallel R servers on the local host, one for each core:
+To run 4 parallel R servers on the local host:
-\verb{$SWIFT/exec/start-swift}
+\verb{options(swift.server="local")}
+\verb{swiftInit(cores=4)}
-To run 4 R servers:
-\verb{$SWIFT/exec/start-swift -c 4}
 To run 4 R servers on each of two hosts that can be reach by ssh:
-\verb{$SIFT/exec/start-swift -s ssh -c 4 -h "hostname1 hostname2"}
+\verb{options(swift.server="ssh")}
+\verb{swiftInit(cores="4", hosts="hostname1 hostname2")}
 To run 8 R servers for 30 minutes on each of 3 nodes of the Merlot cluster, run this on the login host "merlot", using its "serial" queue:
-\verb{$SWIFT/exec/start-swift -s pbsf -c 8 -n 3 -t 00:30:00 -q serial}
+\verb{options(swift.server="pbsf")}
+\verb{swiftInit(cores=8, nodes=3, time="00:30:00",
+        queue="serial")}
-These Swift servers can be started and left running, across R runs
+These Swift servers can be started and left running for multiple
+\code{swiftapply()}
+calls, and will be shut down when you close your R session, when the Swift
+package is unloaded or when \code{swiftShutdown()} is called.
-options(swift.server="local") #  or "pbsman" or "ssh"
 \section{TESTS}{
@@ -263,6 +287,7 @@
 # Start swift local server as above
 require(Swift)
+initSwift()
 basicSwiftTest()
@@ -270,6 +295,7 @@
 \preformatted{
 require(Swift)
+initSwift()
 runAllSwiftTests()
@@ -281,60 +307,6 @@
-\section{STOPPING_SWIFT_SERVERS}{
-The following ps command is useful for displaying the many background
-swift processes. I keep this aliased as "mp" (my processes):
-  alias mp='ps -fjH -u $USER'
-Local (swift-start local):
-$ jobs
-$ kill %1
-Remote (swift-start ssh):
-$ jobs
-$ kill %1  # This tries to track down the remote processes and kill them
-Cluster (swift-start pbs):
-$ jobs
-$ kill %1 # Swift should terminate its queued and/or running cluster jobs
-Occaasionally a killall R and/or killall java is required
-\section{USAGE}{
-Swift returns Error object when remote side fails.
-swiftapply( )
-options:
-  swift.server: matched server name on start-swift
-  swift.callsperbatch
-  initialize:
-less likely to touch:
-  remove temp reqs (sp???) FIXME
-  mode (service, manual, ???)
-Other Swift functions (compatible with Snow/Snowfall packages):
-swiftLapply
-To be developed: swiftSapply, ...
 \section{OPENMX_EXAMPLES}{
 This section is specific to users of the OpenMX R package for
@@ -342,54 +314,42 @@
-\section{USING_OTHER_PARALLEL_ENVIRONMENTS}{
+\section{SSH-specific issues}{
-3) ssh confiured for password-free login (to run on remote worker nodes)
+For the "ssh" server to work correctly within SwiftR, it is best that
+you have ssh configured for password-free login to the remote worker nodes
+you will be using.
-Ability to ssh to server machines (without password: agents, master
-control channel, etc) (FIXME: Are these limitations necessary?)
-Passwords or ssh key passphrases OK for some scenarios.
-ssh from Mac
-ssh -A when jumping to a new host (to forward the ssh agent)
+%Ability to ssh to server machines (without password: agents, master
+%control channel, etc) (FIXME: Are these limitations necessary?)
+%Passwords or ssh key passphrases OK for some scenarios.
-(or set up ssh agents manually)
+%ssh from Mac
-(document ssh tricks here for pw-less access)
+%ssh -A when jumping to a new host (to forward the ssh agent)
+%(or set up ssh agents manually)
-\section{DIRECTORY STRUCTURE USED FOR SWIFT RUNTIME}{
-tbd
+%(document ssh tricks here for pw-less access)
-\section{PROCEESS STRUCTURE OF SWIFT RUNTIME}{
+\section{Swift Runtime Directory Structure}{
+SwiftR stores various files in the file system in the course of its operation.
+These are, by default, stored under the directory "$TMP/$USER/SwiftR".
-\preformatted{
+The Swift server services will store logs and other information under
+directories
+with names beginning with "swift.".
+One of these directories is created per \code{swiftInit} call.
-vanquish$ mp
-UID        PID  PPID  PGID   SID  C STIME TTY          TIME CMD
-wilde     3621  3553  3553  3553  0 19:17 ?        00:00:00 sshd: wilde at pts/1
-wilde     3622  3621  3622  3622  0 19:17 pts/1    00:00:00   -bash
-wilde     3726  3622  3726  3622  0 19:20 pts/1    00:00:00     /bin/bash ./start-swift local
-wilde     3775  3726  3726  3622  0 19:20 pts/1    00:00:00       /bin/sh /homes/wilde/RLibrary/Swift/exec/../swift/bin/swift -config
-wilde     3835  3775  3726  3622  0 19:20 pts/1    00:00:11         java -Xmx256M -Djava.endorsed.dirs=/homes/wilde/RLibrary/Swift/exe
-wilde     8664  3622  8664  3622  0 20:47 pts/1    00:00:00     ps -fjH -u wilde
-wilde     3441  3366  3366  3366  0 19:16 ?        00:00:00 sshd: wilde at pts/0
-wilde     3442  3441  3442  3442  0 19:16 pts/0    00:00:00   -bash
-wilde     4114  3442  4114  3442  0 19:35 pts/0    00:00:05     /usr/lib64/R/bin/exec/R
-wilde     4667     1  3726  3622  0 19:38 pts/1    00:00:00 /usr/lib64/R/bin/exec/R --slave --no-restore --file=./SwiftRServer.sh --ar
-wilde     4611     1  3726  3622  0 19:38 pts/1    00:00:00 /usr/lib64/R/bin/exec/R --slave --no-restore --file=./SwiftRServer.sh --ar
-wilde     4569     1  3726  3622  0 19:38 pts/1    00:00:00 /usr/lib64/R/bin/exec/R --slave --no-restore --file=./SwiftRServer.sh --ar
-wilde     4562     1  3726  3622  0 19:38 pts/1    00:00:00 /usr/lib64/R/bin/exec/R --slave --no-restore --file=./SwiftRServer.sh --ar
-wilde     4522     1  3726  3622  0 19:38 pts/1    00:00:00 /usr/lib64/R/bin/exec/R --slave --no-restore --file=./SwiftRServer.sh --ar
-wilde     4455     1  3726  3622  0 19:38 pts/1    00:00:00 /usr/lib64/R/bin/exec/R --slave --no-restore --file=./SwiftRServer.sh --ar
-wilde     4270     1  3726  3622  0 19:38 pts/1    00:00:00 /usr/lib64/R/bin/exec/R --slave --no-restore --file=./SwiftRServer.sh --ar
-wilde     4160     1  3726  3622  0 19:36 pts/1    00:00:00 /usr/lib64/R/bin/exec/R --slave --no-restore --file=./SwiftRServer.sh --ar
-vanquish$ }
+Swift workers store data files and logs under "$TMP/$USER/SwiftR" on
+whichever machine they are currently running on.
 \section{DEBUGGING AND TROUBLESHOOTING}{
 * manual mode
@@ -415,8 +375,10 @@
 You should see periodic status update lines such as the following:
-\preformatted{
-tbd}
+\preformatted{Progress:  Selecting site:6  Active:2  Finished successfully:84
+Progress:  uninitialized:1  Finished successfully:92
+Progress:  Stage in:1  Finished successfully:101
 * reporting bugs: what to send  (FIXME: need swiftsnapshot script)
@@ -439,7 +401,8 @@
 wget http://www.ci.uchicago.edu/~wilde/swift.rNNNN.cog.rNNNN.tar.gz
 cd ~/SwiftR
-./install.sh # generates a .gz package in ~/public_html/*.gz}
+make install
@@ -476,15 +439,9 @@
 The following caveats are high priority on the FIXME list:
-You MUST start the Swift server before running a swiftapply() call
-from R. Otherwise R hangs and must be killed and restarted.
-When the FIFOs (named pipes) which are used to communicate from R to
-Swift get hung, you need to use kill or Quit to break out of R.
 There is no automatic restart yet if swift dies in its server loop. In
 particular, parsing errors, eg on the Swift initialexpr text, can
-cause the R and hence the Swift server to exit.  The
+cause the R and hence the Swift server to exit
 Only lapply is implemented (also SwiftApply) - need to see if we can
 cut down arg passing overhead for many of the apply() cases.
Modified: SwiftApps/SwiftR/Swift/man/swiftInit.Rd
--- SwiftApps/SwiftR/Swift/man/swiftInit.Rd	2011-01-25 19:23:13 UTC (rev 4035)
+++ SwiftApps/SwiftR/Swift/man/swiftInit.Rd	2011-01-25 21:35:30 UTC (rev 4036)
@@ -11,6 +11,17 @@
 %- maybe also 'usage' for other objects documented here.
 \arguments{
+  All arguments to swiftInit() are optional.
+  If any of the arguments are not provided to swiftInit, this function
+  tries to obtain a value from Swift's options mechanism.  The option
+  names correspond to the argument names prefixed with "swift.", for example
+  "swift.cores" or "swift.server".
+  This function does not necessarily require any arguments to be set directly
+  or indirectly through options, however depending on your server setting
+  and local configuration you may need to provide some argument.
   \item{cores}{
     The number of cores per host.  The default values vary from 2 to 8 depending on the server type.
@@ -35,23 +46,29 @@
   The project name passed to the PBS or SGE batch scheduler.  Site-specific.
   \item{parEnv}{
-  SGE only.
+  SGE only.  This is the parallel environment setting passed to the
+    Sun Grid Engine scheduler, and is required in order to run
+    multi-node jobs with SwiftR on Sun Grid Engine sites.  The "mpi"
+    environment is often a suitable choice.
   \item{workmode}{
   Can be "node" or "slot".
-  node: start one worker for all slots on a node.  slot: start one worker
-  per slot (multiple workers per node).
+  If "node", one worker is started for all slots on a node.
+  If "slot", one worker is started per slot (multiple workers per node).
   \item{throttle}{
-%%     ~~Describe \code{throttle} here~~
+  The throttle setting to be used by Swift: controls the rate of sending jobs
+  to workers.
   \item{queue}{
     The scheduler queue to put jobs in.  This is only relevant for PBS
     and SGE.
   \item{rcmd}{
-    Specific to SGE: the remote shell command.  The default value is
-    typically fine, but if you have issues it may need to be changed.
+    Specific to SGE clusters: this is the remote shell command that is
+    used, for example \code{ssh} or \code{qrsh}.
+    For most clusters, the default setting "ssh" works
+    , but if you have problems it may need to be changed.
   \item{time}{
     The duration to request nodes for from the PBS or SGE scheduler.
@@ -61,7 +78,7 @@
   \item{workerLogging}{
-    For testing purposes: the swift worker loggin level.
+    For testing purposes: the swift worker logging level.
Modified: SwiftApps/SwiftR/Swift/man/swiftapply.Rd
--- SwiftApps/SwiftR/Swift/man/swiftapply.Rd	2011-01-25 19:23:13 UTC (rev 4035)
+++ SwiftApps/SwiftR/Swift/man/swiftapply.Rd	2011-01-25 21:35:30 UTC (rev 4036)
@@ -3,18 +3,37 @@
 \alias{swiftapply}
 %- Also NEED an '\alias' for EACH other topic documented here.
 \title{
-    swiftapply: Applying a Function to a List of Arguments
+    Applying a Function to a List of Arguments
 \description{
-    swiftapply takes a function, and list of argument lists,
+    Several variations of a parallel apply call are provided.
+    All variations take a function, and list of argument lists,
     and applies the function to each of the argument lists.
     This is done in parallel using the Swift engine.
+    swiftLapply behaves in the same way as the serial \code{lapply}
+    function.
+    swiftapply
 \usage{
 swiftapply(func, arglists, server = NULL, callsperbatch = NULL, runmode = NULL, initialexpr = NULL, workerhosts = NULL, keepwork = NULL, tmpdir = NULL, timeout = NULL, quiet = FALSE)
+swiftLapply(tlist, func, ...)
 \arguments{
+  The first two arguments are required for all variations of the
+  apply.
+  All other arguments are optional.
+  swiftapply takes the full range of options specified below directly
+  as arguments.    If they are not provided as arguments, settings specified
+  through R's options mechanism will be used, for example
+  \verb{options(swift.server="local"}.
+  swiftLapply and other variations also respect arguments
+  set through the R options mechanism.
   \item{func}{
     The function to apply.
@@ -24,6 +43,8 @@
   \item{server}{
     The swift server type to use to run.  The possible values are
     "local", "ssh", "pbs", "sge" and "pbsf", the same as swiftInit.
+    The most recently started server of the specified type will be used
+    to execute the apply call.  The default value is "local".
   \item{callsperbatch}{
     The number of function calls to group together into a single batch.
