[Swift-commit] r4146 - branches/release-0.92/bin
noreply at svn.ci.uchicago.edu
Fri Feb 25 19:23:53 CST 2011
Author: davidk
Date: 2011-02-25 19:23:53 -0600 (Fri, 25 Feb 2011)
New Revision: 4146
Modified:
branches/release-0.92/bin/gensites
Log:
gensites: better error handling, fixed search path, list specific templates
Modified: branches/release-0.92/bin/gensites
--- branches/release-0.92/bin/gensites 2011-02-25 22:50:13 UTC (rev 4145)
+++ branches/release-0.92/bin/gensites 2011-02-26 01:23:53 UTC (rev 4146)
@@ -4,7 +4,7 @@
crash()
MSG=$1
- echo ${MSG}
+ echo ${MSG} >&2
exit 1
@@ -34,13 +34,14 @@
cat << END
- usage: gensites template [-p properties.file] [-L template_directory] [-h] [-T]
+ usage: gensites template [-p properties.file] [-L template_directory] [-h] [-T] [-l]
template Name of template to use
-p properties.file Specify a swift.properties to use
-L template_directory Specify a non-standard template directory
-T List all templates available
-h Help / usage information
+ -l List the contents of a specific template
Examples:
@@ -64,6 +65,7 @@
case "$1" in
-p) PROPERTIES_FILE=$2; verify_not_null properties_file $PROPERTIES_FILE; shift ;;
-L) TEMPLATE_DIRECTORY=$2; verify_not_null template_directory $TEMPLATE_DIRECTORY; shift ;;
+ -l) LIST_SPECIFIC_TEMPLATE=1 ;;
-T) LIST_TEMPLATES=1 ;;
-h|-help|-?) usage ;;
*) TEMPLATE=$1 ;;
@@ -85,8 +87,8 @@
fi
fi
-# List templates
-if [ ! -z "$LIST_TEMPLATES" ]; then
+# List all templates
+if [ ! -z $LIST_TEMPLATES ]; then
# Templates in etc/sites
for file in `ls -1 $SWIFT_HOME/* 2>/dev/null`
do
@@ -120,15 +122,24 @@
TEMPLATE_PATH=$HOME/.swift/sites/$TEMPLATE
fi
if [ ! -f "$TEMPLATE_PATH" ]; then
- crash "Cannot find template for $TEMPLATE"
+ crash "Cannot find template for $TEMPLATE"
fi
fi
+# List a specific template
+if [ ! -z $LIST_SPECIFIC_TEMPLATE ]; then
+ cat $TEMPLATE_PATH
+ exit 0
+fi
# Ensure a properties file exists
if [ ! -f "$PROPERTIES_FILE" ]; then
PROPERTIES_FILE="swift.properties"
- crash "Unable to find a valid properties file! Please specify a valid file with the -p option"
+ PROPERTIES_FILE="$HOME/.swift/swift.properties"
+ if [ ! -f "$PROPERTIES_FILE" ]; then
+ crash "Unable to find a valid properties file! Please specify a valid file with the -p option"
+ fi
fi
fi
@@ -166,14 +177,13 @@
# Verify that the variables by the template are defined
for TOKEN in PROJECT QUEUE N_GRAN N_MAX SLOTS
- do
- if grep _${TOKEN}_ ${TEMPLATE_PATH} > /dev/null
- then
- if ! declare -p ${TOKEN} > /dev/null
- then
- crash "Not specified: ${TOKEN}"
+do
+ # Need but can't find, due
+ if grep _${TOKEN}_ $TEMPLATE_PATH > /dev/null; then
+ if [ -z "${!TOKEN}" ]; then
+ crash "Not specified: ${TOKEN}"
+ fi
fi
- fi
done
# Replace values
@@ -192,5 +202,6 @@
echo "s at _SERVICE_PORT_@${SERVICE_PORT:-NO_PORT_GIVEN}@"
} > $SEDFILE
-sed -f $SEDFILE < ${TEMPLATE_PATH}
+sed -f $SEDFILE < $TEMPLATE_PATH
rm $SEDFILE
More information about the Swift-commit
