[Swift-commit] r4145 - in SwiftApps/SwiftR/Swift: R exec
noreply at svn.ci.uchicago.edu
Fri Feb 25 16:50:13 CST 2011
Author: tga
Date: 2011-02-25 16:50:13 -0600 (Fri, 25 Feb 2011)
New Revision: 4145
Modified:
SwiftApps/SwiftR/Swift/R/Apply.R
SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
SwiftApps/SwiftR/Swift/exec/start-swift
Log:
Finished adding in detection of when R worker process fails to start up.
Modified: SwiftApps/SwiftR/Swift/R/Apply.R
--- SwiftApps/SwiftR/Swift/R/Apply.R 2011-02-25 15:45:03 UTC (rev 4144)
+++ SwiftApps/SwiftR/Swift/R/Apply.R 2011-02-25 22:50:13 UTC (rev 4145)
@@ -91,7 +91,12 @@
res <- getServiceResponse(resultPipeName, timeout)
# Check that the message was correct
- if (res[[1]] != "done") {
+ if (substring(res[[1]], 1, 6) == "error:") {
+ stop(paste("Received error message from Swift '", res,
+ "'. The swift server has shut down, rerun swiftInit to"
+ ," restart", sep=""))
+ else if (res[[1]] != "done") {
stop(paste("Got unexpected message '",
paste(res, collapse="\n"),"' on fifo ",
"aborting job", sep=""))
Modified: SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
--- SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh 2011-02-25 15:45:03 UTC (rev 4144)
+++ SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh 2011-02-25 22:50:13 UTC (rev 4145)
@@ -3,7 +3,6 @@
# Arguments: inputBatchSaveFile outputBatchSaveFile
# bash @shellscript @RServerScript @rcall @result stdout=@stout stderr=@sterr;
-set -x
# Set restrictive umask for duration of script
# This value prevents any other users from reading
@@ -89,12 +88,9 @@
function start_timeout {
ppid=$$
- echo start_timeout
trap "timeout_handler" SIGHUP
- echo timeout_handler for $ppid sleeping
sleep ${TIMEOUT}s
- echo timeout_handler work up
kill -1 $ppid &> /dev/null #SIGHUP
if [ "$1" != "" ]; then
kill -1 $1 &> /dev/null #SIGHUP
@@ -104,7 +100,6 @@
function stop_timeout {
#DEBUG
- echo stop_timeout
trap "" SIGHUP
@@ -129,10 +124,10 @@
mkfifo $SLOTDIR/fromR.fifo
chmod +x $RServerScript
echo "$0: INFO: Launching $RServerScript $SLOTDIR"
- PATH=.:$PATH
#echo PATH: $PATH > $SLOTDIR/R.log
#which Rscript >> $SLOTDIR/R.log
- echo $PATH
+ echo LD_LIBRARYPATH= $LD_LIBRARY_PATH
$RServerScript $SLOTDIR >> $SLOTDIR/R.log 2>&1 & # launch R server
# idletimer $SLOTDIR </dev/null >/dev/null 2>&1 & # R saves pid in R.pid for idletimer to kill it
echo "$0: INFO: Launched $RServerScript $SLOTDIR Rscript"
@@ -162,7 +157,6 @@
echo run $(pwd)/$callFile $(pwd)/$resultFile > $SLOTDIR/toR.fifo &
echopid=$!
-echo echopid $echopid
start_timeout $echopid
if wait $echopid
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift 2011-02-25 15:45:03 UTC (rev 4144)
+++ SwiftApps/SwiftR/Swift/exec/start-swift 2011-02-25 22:50:13 UTC (rev 4145)
@@ -558,14 +558,15 @@
# Find and terminate R workers: they should register their PiD
# in a standard location based on the pid of this start-swift
# script
- if [ "$keepdir" = "FALSE" ]
- then
- for rwork in `(shopt -s nullglob; echo ../Rworkers/worker.$$/*/)`
- do
+ for rwork in `(shopt -s nullglob; echo ../Rworkers/worker.$$/*/)`
+ do
+ if [ -f "$rwork/R.pid" ]; then
kill `cat $rwork/R.pid` &> /dev/null
+ fi
+ if [ "$keepdir" = "FALSE" ]; then
rm -rf $rwork
- done
- fi
+ fi
+ done
stdcleanup_end
exit 0
@@ -659,5 +660,12 @@
fi
$SWIFTRBIN/../swift/bin/swift $swiftLoggingFlag -config cf -tc.file tc -sites.file sites.xml $script -pipedir=$(pwd) >& $out </dev/null
+exitcode=$?
+# Do any cleanup if swift exits in this manner
+if [ "$exitcode" != 0 ]; then
+ echo "error: Swift exited unexpectedly with $exitcode" > resultpipe &
+ echopid=$!
+ sleep 5
+ kill $echopid &> /dev/null
+fi
-# Do any cleanup if swift exits in this manner
More information about the Swift-commit
