[Swift-commit] r4906 - in wwwdev: . main main/_notes
vytas at ci.uchicago.edu
Mon Aug 1 09:25:41 CDT 2011
Author: vytas
Date: 2011-08-01 09:25:39 -0500 (Mon, 01 Aug 2011)
New Revision: 4906
Added:
wwwdev/main/
wwwdev/main/_notes/
wwwdev/main/_notes/dwsync.xml
wwwdev/main/index.php
wwwdev/main/index2.php
wwwdev/main/rotator.php
wwwdev/main/template.php
Log:
new look & feel
Added: wwwdev/main/_notes/dwsync.xml
--- wwwdev/main/_notes/dwsync.xml (rev 0)
+++ wwwdev/main/_notes/dwsync.xml 2011-08-01 14:25:39 UTC (rev 4906)
@@ -0,0 +1,7 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<dwsync>
+<file name="template.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394630165" remote="16279532058" />
+<file name="index2.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394804378" remote="16279706419" />
+<file name="rotator.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394800047" remote="16279701950" />
+<file name="index.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394812432" remote="16279714328" />
+</dwsync>
\ No newline at end of file
Added: wwwdev/main/index.php
--- wwwdev/main/index.php (rev 0)
+++ wwwdev/main/index.php 2011-08-01 14:25:39 UTC (rev 4906)
@@ -0,0 +1,137 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
+<title>Swift - A system for rapid and reliable specification, execution, and management of large scale workflows</title>
+<link href="../css/960_12_col.css" rel="stylesheet" type="text/css" />
+<link href="../css/reset.css" rel="stylesheet" type="text/css" />
+<link href="../css/style3.css" rel="stylesheet" type="text/css" />
+<link href="../css/orbit-1.2.3.css" rel="stylesheet" type="text/css">
+<script type="text/javascript" src="../js/jquery-1.5.1.min.js"></script>
+<script type="text/javascript" src="../js/jquery.orbit-1.2.3.min.js"></script>
+<!--[if IE]>
+ <style type="text/css">
+ .timer { display: none !important; }
+ div.caption { background:transparent; filter:progid:DXImageTransform.Microsoft.gradient(startColorstr=#99000000,endColorstr=#99000000);zoom: 1; }
+ </style>
+ <![endif]-->
+<script type="text/javascript" src="http://use.typekit.com/dbf2lqy.js"></script>
+<script type="text/javascript">try{Typekit.load();}catch(e){}</script>
+<!-- Run the plugin -->
+ <script type="text/javascript">
+ $(window).load(function() {
+ $('#featured').orbit({
+ bullets: true,
+ </script>
+</head>
+<body>
+<div class="container_12">
+ <!-- header -->
+ <?php require('../inc/header2.php') ?>
+ <!-- end header -->
+ <div class="grid_12">
+ <h1 class="tagline">
+ A system for rapid and reliable specification, execution, and management of large scale workflows.
+ </h1>
+ </div>
+ <!-- end .grid_12 -->
+ <div class="clear"></div>
+ <div class="grid_9">
+ <div class="container">
+ <?php require('../inc/rotator.php') ?>
+ <img src="../images/rotator_shadow.png" width="674" height="10" />
+ </div>
+ </div>
+ <!-- end .grid_9 -->
+ <div class="grid_3">
+ <div id="box-prime"><div class="button_175"><a href="../packages/swift-0.92.1.tar.gz" onClick="javascript: pageTracker._trackPageview('/swift/packages/swift-0.92.1.tar.gz');">Download Now</a></div><b>0.92.1</b> current version<br />2011/04/13
+ <br /><a href="../downloads/index.php">view all downloads</a></div>
+ <div id="box-prime"><div class="button_175"><a href="../guides/quickstartguide.php">Get Started</a></div>Read our Quick Start Guide
+and start using Swift today!</div>
+ </div>
+ <!-- end .grid_3 -->
+ <div class="grid_6">
+ <p class="indented">
+ <b>Swift</b> is a system for the <b>rapid</b> and <b>reliable</b> specification, execution, and management of <b>large-scale</b> science and engineering <b>workflows</b>. It supports applications that execute many tasks coupled by disk-resident datasets—as is common, for example, when analyzing large quantities of data or performing parameter studies or ensemble simulations. </p>
+ <p class="highlight-A">A simple scripting language to enable the concise, high-level specifications of complex parallel computations, and mappers for accessing diverse data formats in a convenient manner.</p>
+ <p class="highlight-B">An execution engine that can manage the dispatch of many (10,000) tasks to many (100) processors, whether on parallel computers, campus grids, or multi-site grids.</p>
+ <p class="indented">Swift users have achieved multiple-order-of-magnitude savings in program development and execution time.</p>
+ </div>
+ <!-- end .grid_6 -->
+ <div id="feature">
+ <h3>
+ Who's Using Swift
+ </h3>
+ <ul class="swift-bullet">
+ <li>physical sciences</li>
+ <li>biological sciences</li>
+ <li>social sciences</li>
+ <li>humanities</li>
+ <li>computer science</li>
+ <li>education</li>
+ </ul>
+ <a href="../papers/index.php" class="trailingLink">read the papers</a>
+ </div>
+ <!-- end feature -->
+ <h3>
+ Supported Platforms
+ </h3>
+ <p class="indented-half">Cillum brisket ad veniam exercitation andouille. Cillum turkey ut jowl in tail. Reprehenderit nisi pig ex culpa qui, ea meatball ball tip tenderloin pancetta pork. </p>
+ <a href="../downloads/index.php" class="trailingLink">explore downloads</a>
+ </div>
+ </div>
+ <h3>
+ What Users Are Saying
+ </h3>
+ <p class="quote">A few lines of SwiftScript described how our analysis procedures should be applied to thousands of fMRI images. Our computation was performed quickly and reliably. Life is good.</p>
+ <p class="quote-speaker">Dr. Marielle Goodwin<br />
+Director of Brain Trauma Research<br />
+University of Chicago Hospitals</p>
+<a href="../case_studies/index.php" class="trailingLink">more case studies</a>
+ </div>
+ <h3>What's New</h3>
+ <h5>Paper Published</h5>
+ <p>Swift: A Language for Distributed Parallel Scripting</p>
+ <a href="../papers/SwiftLanguageForDistributedParallelScripting.pdf" class="trailingLinkPDF">read the paper</a>
+ </div>
+ </div>
+ <p> </p>
+ </div>
+ </div>
+</div>
+<!-- end .container_12 -->
+<!-- footer -->
+<?php require('../inc/footer2.php') ?>
+<!-- end footer -->
+var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
+document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
+</script>
+try {
+var pageTracker = _gat._getTracker("UA-106257-5");
+pageTracker._trackPageview();
+} catch(err) {}</script>
+</body>
+</html>
Added: wwwdev/main/index2.php
--- wwwdev/main/index2.php (rev 0)
+++ wwwdev/main/index2.php 2011-08-01 14:25:39 UTC (rev 4906)
@@ -0,0 +1,137 @@
+<head>
+<!--[if IE]>
+ </style>
+ <![endif]-->
+ bullets: true,
+ </script>
+</head>
+<body>
+ <!-- header -->
+ </h1>
+ </div>
+ </div>
+ </div>
+ </div>
+ </div>
+ <h3>
+ Who's Using Swift
+ </h3>
+ </ul>
+ </div>
+ <h3>
+ </h3>
+ </div>
+ </div>
+ <h3>
+ </h3>
+ </div>
+ </div>
+ </div>
+ <p> </p>
+ </div>
+ </div>
+</div>
+<!-- footer -->
+</script>
+try {
+</body>
+</html>
Added: wwwdev/main/rotator.php
--- wwwdev/main/rotator.php (rev 0)
+++ wwwdev/main/rotator.php 2011-08-01 14:25:39 UTC (rev 4906)
@@ -0,0 +1,85 @@
+<head>
+<title>Swift - Move Me</title>
+<!--[if IE]>
+ </style>
+ <![endif]-->
+ bullets: true,
+ </script>
+</head>
+<body>
+ <!-- header -->
+<div class="grid_12 page-header">
+ <h1>Rotator Set-Up</h1>
+</div>
+<div class="clear"></div>
+<!-- end .grid_12 -->
+THE ACTUAL ORBIT SLIDER CONTENT
+ <div id="featured">
+ <a href="#">
+ <img src="../images/rotator/2011_08_neuroscience.jpg" />
+ </a>
+ <img src="../images/rotator/bg_rotator2.jpg" data-caption="#htmlCaption" />
+ <img src="../images/rotator/bg_rotator3.jpg" />
+ </div>
+ <div class="content" style="">
+ <h1>Orbit does content now.</h1>
+ <h3>Highlight me...I'm text.</h3>
+ </div>
+ <!-- Captions for Orbit -->
+ <span class="orbit-caption" id="htmlCaption"><strong>I'm A Caption:</strong> I can have <a href="#">links</a>, <em>style</em> or anything that is valid markup :)</span>
+ </div>
+ </div>
+ <h3>Right Header</h3>
+ <p>Right column content.</p>
+ <p> </p>
+ </div>
+ </div>
+<!-- footer -->
+</body>
+</html>
Added: wwwdev/main/template.php
--- wwwdev/main/template.php (rev 0)
+++ wwwdev/main/template.php 2011-08-01 14:25:39 UTC (rev 4906)
@@ -0,0 +1,84 @@
+<head>
+</head>
+<body>
+ <a href="../main/index.php"><img src="../images/logo_swift.png" width="328" height="92" alt="Swift" align="left" border="0" /></a>
+ <ul id="nav">
+ <li><a href="../downloads/index.php">downloads</a></li>
+ <li><a href="../documentation/index.php">documentation</a></li>
+ <li><a href="../case_studies/index.php">case studies</a></li>
+ <li><a href="../papers/index.php">papers</a></li>
+ <li class="last"><a href="../support/index.php">support</a></li>
+ </ul>
+ </h1>
+ </div>
+ <p>
+ 700
+ </p>
+ </div>
+ <p>
+ 220
+ </p>
+ </div>
+ <p>
+ 460
+ </p>
+ </div>
+ <p>
+ 220
+ </p>
+ </div>
+ <p>
+ 220
+ </p>
+ </div>
+ <p> </p>
+ </div>
+ </div>
+</div>
+<div id="footer">
+ <ul>
+ </ul>
+ <div class="footer-blurb">The Swift project is supported by the National Science Foundation with additional support from NIH, Argonne National Laboratory and the University of Chicago Computation Institute.</div>
+ </div>
+</body>
+</html>
More information about the Swift-commit
