[Swift-commit] r4905 - in wwwdev: . links links/_notes
vytas at ci.uchicago.edu vytas at ci.uchicago.edu
Mon Aug 1 09:25:32 CDT 2011
Author: vytas
Date: 2011-08-01 09:25:30 -0500 (Mon, 01 Aug 2011)
New Revision: 4905
Added:
   wwwdev/links/
   wwwdev/links/_notes/
   wwwdev/links/_notes/dwsync.xml
   wwwdev/links/index.php
Log:
new look & feel
Added: wwwdev/links/_notes/dwsync.xml
--- wwwdev/links/_notes/dwsync.xml	                        (rev 0)
+++ wwwdev/links/_notes/dwsync.xml	2011-08-01 14:25:30 UTC (rev 4905)
@@ -0,0 +1,4 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<dwsync>
+<file name="index.php" server="login.ci.uchicago.edu//home/vytas/public_html/projects/2011_07-Swift/" local="3394121884" remote="11984644062" />
+</dwsync>
\ No newline at end of file
Added: wwwdev/links/index.php
--- wwwdev/links/index.php	                        (rev 0)
+++ wwwdev/links/index.php	2011-08-01 14:25:30 UTC (rev 4905)
@@ -0,0 +1,83 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+	<head>
+		<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" />
+		<title>Swift: Links</title>
+		<link href="../css/style2.css" rel="stylesheet" type="text/css" />
+	</head>
+	<body id="about">
+		<!-- entire page container -->
+		<div id="container">
+			<!-- header -->
+			<div id="header">
+				<?php require('../inc/header.php') ?>
+			</div>
+			<!-- end header -->
+			<!-- nav -->
+			<div id="nav">
+				<?php require('../inc/nav.php') ?>
+			</div>
+			<!-- end nav -->
+			<!-- content container -->
+			<div id="content">
+				<!-- left side content -->
+				<div id="left">
+<h1>LINKS</h1>
+<p>
+	Swift incorporates several existing technologies to achieve its
+	results.
+</p>
+<h4>Globus Toolkit</h4>
+<p>
+	Swift uses the <a href="http://www.globus.org/">Globus Toolkit</a> as
+	middleware to talk to various resources.
+</p>
+<h4>Java CoG Kit</h4>
+<p>
+	The <a href="http://wiki.cogkit.org/index.php/Main_Page">CoG
+	Kit</a> provides a high level uniform interface to different versions of the
+	Globus Toolkit. It also contains the Karajan language and interpreter which
+	is used as an underlying execution engine for Swift.
+</p>
+<h4>TeraGrid</h4>
+<p>
+	"<a href="http://www.teragrid.org/">TeraGrid</a> is an open scientific
+	discovery infrastructure combining leadership class resources at nine
+	partner sites to create an integrated, persistent computational resource."
+</p>
+</div>
+				<!-- end left side content -->
+				<!-- right side content -->
+				<div id="right">
+					<?php require('../inc/links_sidebar.php') ?>
+				</div>
+				<!-- end right side content -->
+			</div>
+			<!-- end content container-->
+			<!-- footer -->
+			<div id="footer"><?php require('../inc/footer.php') ?></div>
+			<!-- end footer -->
+		</div>
+		<!-- end entire page container -->
+<script type="text/javascript">
+var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
+document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
+</script>
+try {
+var pageTracker = _gat._getTracker("UA-106257-5");
+pageTracker._trackPageview();
+} catch(err) {}</script>
+	</body>
+</html>
