[Swift-commit] r4327 - SwiftApps/SwiftR/Swift/R
tga at ci.uchicago.edu
Fri Apr 8 15:59:22 CDT 2011
Author: tga
Date: 2011-04-08 15:59:21 -0500 (Fri, 08 Apr 2011)
New Revision: 4327
Modified:
SwiftApps/SwiftR/Swift/R/Library.R
Log:
Fixed argument hadnling of swiftDetach.
Modified: SwiftApps/SwiftR/Swift/R/Library.R
--- SwiftApps/SwiftR/Swift/R/Library.R 2011-04-08 20:52:54 UTC (rev 4326)
+++ SwiftApps/SwiftR/Swift/R/Library.R 2011-04-08 20:59:21 UTC (rev 4327)
@@ -9,13 +9,14 @@
subpackname <- substitute(packname)
# Check to see if it is a string, if it is not a string
# then we will deparse it to get the expression text
- if (!is.character(subpackname) && is.name(subpackname)) {
- # Maybe library was provided unquoted
- packname <- deparse(subpackname)
+ if (!is.character(subpackname)) {
+ if (is.name(subpackname)) {
+ # Maybe library was provided unquoted
+ packname <- deparse(subpackname)
- if (!packname %in% installed.packages()) {
+ if (!(packname %in% installed.packages())) {
# Warn users in case they made a typo
warning(paste("Package", packname,
"was not a installed package in this instance of R,",
@@ -61,32 +62,42 @@
options(.swift.packages=plist)
-swiftDetach <- function (name) {
+sstartsWith <- function (str, prefix) {
+ substr(str, 1, nchar(prefix)) == prefix
+swiftDetach <- function (packname) {
# name is an string or identifier such as "package:OpenMx",
# following the same pattern as the built in R detach() function
# Detaches a library from workers and ensures that it will no longer be
- # imported. Note that the effect on dependent imports is a little
+ # imported.
+ # Caveat: the effect on dependent imports is a little
# messy and behaves differently on existing and new workers.
# If package A requires package B, and we import A on a worker,
# package B will also be imported on the worker. By detaching package A
# we don't also detach B. This contrasts to a fresh worker, where
# package B will not be imported.
- subname <- substitute(name)
+ subpackname <- substitute(packname)
- if (!is.character(subname) && is.name(subname)) {
- name <- deparse(subname)
+ # Check to see if symbol name has package: prefix
+ deparsed <- deparse(subpackname)
+ if (sstartsWith(deparsed, "package:")) {
+ packname <- deparsed
#TODO: remove from options(".swift.packages")
# Scan through list and remove any attach or detach of this name
# add a detach cmd to the end
- if (substr(name, 1, 8) != "package:")
+ if (!sstartsWith(packname, "package:"))
stop("Can only detach packages. Package must be specified as package:PackageName")
# Get bit after "package:"
- packname = substr(name, 9, nchar(name))
+ packname = substr(packname, 9, nchar(packname))
plist = getOption(".swift.packages")
if (is.null(plist)) {
plist = list()
More information about the Swift-commit
