[Swift-commit] r4326 - trunk/libexec/log-processing
wozniak at ci.uchicago.edu
Fri Apr 8 15:52:54 CDT 2011
Author: wozniak
Date: 2011-04-08 15:52:54 -0500 (Fri, 08 Apr 2011)
New Revision: 4326
Added:
trunk/libexec/log-processing/block-level.pl
trunk/libexec/log-processing/blocks.cfg
Log:
New Coasters block allocation plot
Added: trunk/libexec/log-processing/block-level.pl
--- trunk/libexec/log-processing/block-level.pl (rev 0)
+++ trunk/libexec/log-processing/block-level.pl 2011-04-08 20:52:54 UTC (rev 4326)
@@ -0,0 +1,34 @@
+#!/usr/bin/perl
+# Accumulate the load level at each point in time
+# INPUT: A Swift log file with Coasters messages:
+# timestamp ... Block Starting block: workers=24 ...
+# timestamp ... Block Shutting down ... (24x ...
+# where timestamp is a number
+# OUTPUT: lines formatted as "timestamp level"
+# where timestamp and load are numbers,
+# level being the number of Coasters Cpus available
+$level = 0;
+sub report() {
+ @tokens = split;
+ printf("$tokens[0] $level\n");
+while (<STDIN>) {
+ if (/Block/) {
+ if (/Block Starting block:/) {
+ /workers=(\d*)/;
+ report;
+ $level += $1;
+ report;
+ if (/Block Shutting down block/) {
+ /\((\d*)x/;
+ report;
+ $level -= $1;
+ report;
Property changes on: trunk/libexec/log-processing/block-level.pl
___________________________________________________________________
Added: trunk/libexec/log-processing/blocks.cfg
--- trunk/libexec/log-processing/blocks.cfg (rev 0)
+++ trunk/libexec/log-processing/blocks.cfg 2011-04-08 20:52:54 UTC (rev 4326)
@@ -0,0 +1,6 @@
+xlabel = time
+ylabel = allocation size
+# shape.blocks.data = none
+label.blocks.data = cores
More information about the Swift-commit
