[Swift-commit] r4316 - SwiftApps/SwiftR/Swift/tests
    tga at ci.uchicago.edu
    Fri Apr  8 13:57:45 CDT 2011
Author: tga
Date: 2011-04-08 13:57:45 -0500 (Fri, 08 Apr 2011)
New Revision: 4316
Added:
   SwiftApps/SwiftR/Swift/tests/serialisation_overhead.R
Log:
Checking in work from a little while ago: a test to quantify the impact of
different factors on writing data to disk.
Added: SwiftApps/SwiftR/Swift/tests/serialisation_overhead.R
--- SwiftApps/SwiftR/Swift/tests/serialisation_overhead.R	                        (rev 0)
+++ SwiftApps/SwiftR/Swift/tests/serialisation_overhead.R	2011-04-08 18:57:45 UTC (rev 4316)
@@ -0,0 +1,70 @@
+require(Swift)
+source("Swift/tests/perf_tests.R")
+source("Swift/tests/OpenMx/BootstrapParallelBigger.R")
+args = 128
+res = list(n=c(), create=c(), prepro=c(), write=c(), writesep=c(), writesepsplit=c())
+i = 1
+for (n in c(1,2,4,8,16,32,48, 64, 96, 128, 192, 256, 384, 512)) {
+    cat("\n", n, "\n\n")
+    res$n[[i]] = n
+    startTime = proc.time()[["elapsed"]]
+    model <- buildModels(75, 100, n)
+    endTime = proc.time()[["elapsed"]]
+    res$create[[i]] = endTime - startTime
+    cat(paste("Took", endTime - startTime, "s to build models\n"))
+    dataList <- generateDataList(model)
+    dshare <- shareData(model)
+    independents <- getAllIndependents(dshare)
+    res$prepro[[i]] = endTime - startTime
+    cat(paste("Took", endTime - startTime, "s to process model\n"))
+    x = list(mxRun, independents)
+    wStartTime = proc.time()[["elapsed"]]
+    save(x, file="blah.Rdata")
+    wEndTime = proc.time()[["elapsed"]]
+    cat(paste("Took", wEndTime - wStartTime, "s to write to disk models\n"))
+    res$write[[i]] = wEndTime - wStartTime
+    for (j in 1:n) {
+        x = list(mxRun, independents[[j]])
+        save(x, file=paste("blah", j, ".Rdata", sep=""))
+    cat(paste("Took", wEndTime - wStartTime, "s to write to disk models individually\n"))
+    res$writesep[[i]] = wEndTime - wStartTime
+    y = list(mxRun)
+    save(y, file=paste("mxRun.Rdata", sep=""))
+    for (j in 1:n) {
+        x = independents[[j]]
+    cat(paste("Took", wEndTime - wStartTime, "s to write to disk models individually split\n"))
+    res$writesepsplit[[i]] = wEndTime - wStartTime
+    i <- i + 1
+plot(res$n, res$writesep, col="green", type="l", xlab="No. replicas", ylab="Time (s)")
+points(res$n, res$write, col="red", type="l")
+points(res$n, res$writesepsplit, col="blue", type="l")
+points(res$n, res$create, col="black", type="l")
+points(res$n, res$prepro, col="brown", type="l")
+legend("topleft",
+    legend=c("write separately", "write single file",
+            "write function\nand args separately", "time to create omx models",
+            "time to identify independent models"),
+        fill=c("green", "red", 'blue', 'black', 'brown'))
More information about the Swift-commit
