[Swift-commit] r4315 - SwiftApps/SwiftR/Swift/R
tga at ci.uchicago.edu
Fri Apr 8 13:51:56 CDT 2011
Author: tga
Date: 2011-04-08 13:51:56 -0500 (Fri, 08 Apr 2011)
New Revision: 4315
Modified:
SwiftApps/SwiftR/Swift/R/Library.R
SwiftApps/SwiftR/Swift/R/Tests.R
Log:
Added in tests to check swiftLibrary/swiftDetach.
Fixed the logic of swiftLibrary/swiftDetach to correctly handle
complex expressions that evaluate to strings.
Modified: SwiftApps/SwiftR/Swift/R/Library.R
--- SwiftApps/SwiftR/Swift/R/Library.R 2011-04-08 18:51:13 UTC (rev 4314)
+++ SwiftApps/SwiftR/Swift/R/Library.R 2011-04-08 18:51:56 UTC (rev 4315)
@@ -6,13 +6,16 @@
# If reset is true, then previously added libraries won't be
# reimported on new workers.
+ subpackname <- substitute(packname)
# Check to see if it is a string, if it is not a string
# then we will deparse it to get the expression text
- if (!is.character(substitute(packname))) {
+ if (!is.character(subpackname) && is.name(subpackname)) {
# Maybe library was provided unquoted
- packname <- deparse(substitute(packname))
+ packname <- deparse(subpackname)
- if (! packname %in% installed.packages()) {
+ if (!packname %in% installed.packages()) {
# Warn users in case they made a typo
warning(paste("Package", packname,
"was not a installed package in this instance of R,",
@@ -68,9 +71,13 @@
# package B will also be imported on the worker. By detaching package A
# we don't also detach B. This contrasts to a fresh worker, where
# package B will not be imported.
- if (!is.character(substitute(name))) {
- # Maybe package was provided unquoted
- name <- deparse(substitute(name))
+ subname <- substitute(name)
+ # Check to see if it is a string, if it is not a string
+ # then we will deparse it to get the expression text
+ if (!is.character(subname) && is.name(subname)) {
+ # Maybe library was provided unquoted
+ name <- deparse(subname)
#TODO: remove from options(".swift.packages")
Modified: SwiftApps/SwiftR/Swift/R/Tests.R
--- SwiftApps/SwiftR/Swift/R/Tests.R 2011-04-08 18:51:13 UTC (rev 4314)
+++ SwiftApps/SwiftR/Swift/R/Tests.R 2011-04-08 18:51:56 UTC (rev 4315)
@@ -649,6 +649,113 @@
return (TRUE)
+pkgexists <- function(pkgname) {
+ paste("package:", pkgname, sep='') %in% search()
+swiftTest_7.1 <- function () {
+ # test swiftLIbrary passing symbolic arg
+ try(detach(package:cluster),silent=T)
+ # Test swiftLibrary default
+ # cluster is pkg in R std lib
+ swiftLibrary(cluster)
+ # test
+ loadedok <- swiftLapply(list("cluster"), pkgexists)[[1]]
+ if (!loadedok) {
+ cat("cluster should be loaded on remote host\n")
+ cat("\n!!!==> test 7.1 failed")
+ return (FALSE)
+ if (pkgexists("cluster")) {
+ cat("cluster should not be loaded in this session\n")
+ return (FALSE)
+ swiftDetach(package:cluster)
+ if (loadedok) {
+ cat("cluster should be detached on remote host\n")
+ return (FALSE)
+ cat("\n!!!==> test 7.1 passed.\n")
+ return (TRUE)
+swiftTest_7.2 <- function () {
+ # Test swiftLibrary string
+ try(detach(package:cluster), silent=T)
+ swiftLibrary("cluster")
+ # test
+ if (!loadedok) {
+ cat("\n!!!==> test 7.2 failed")
+ return (FALSE)
+ return (FALSE)
+ swiftDetach("package:cluster")
+ if (loadedok) {
+ return (FALSE)
+ cat("\n!!!==> test 7.2 passed.\n")
+ return (TRUE)
+swiftTest_7.3 <- function () {
+ # Test swiftLibrary constructed string to make
+ swiftLibrary(paste("clus", "ter", sep=""))
+ # test
+ if (!loadedok) {
+ cat("\n!!!==> test 7.3 failed")
+ return (FALSE)
+ return (FALSE)
+ swiftDetach(paste("package:","clus", "ter", sep=""))
+ if (loadedok) {
+ return (FALSE)
+ cat("\n!!!==> test 7.3 passed.\n")
+ return (TRUE)
runAllSwiftTests <- function(...) {
startTime = proc.time()[["elapsed"]]
@@ -715,6 +822,13 @@
mkTest(swiftTest_6.2),
mkTest(swiftTest_6.3)))
+testGroup7 <- makeTestGroup(
+ name="7 - library imports",
+ tests = list(mkTest(swiftTest_7.1),
+ mkTest(swiftTest_7.2),
+ mkTest(swiftTest_7.3)))
makeFullTestSuite <- function (...) {
initArgs <- list(...)
initArgs[['keepwork']] <- TRUE
@@ -723,6 +837,6 @@
options(swift.initialexpr="initVar1 <- 19; initVar2 <- sqrt(400)+3")
do.call(swiftInit, initArgs) }, # swiftInit controlled via options
groups=list(testGroup1.1, testGroup2, testGroup1.2, testGroup1.3, testGroup3, testGroup4,
- testGroup5, testGroup6),
+ testGroup5, testGroup6, testGroup7),
teardown=function () { swiftShutdown() })
More information about the Swift-commit
