[Swift-commit] r4296 - trunk/libexec/log-processing
wozniak at ci.uchicago.edu
Wed Apr 6 15:50:53 CDT 2011
Author: wozniak
Date: 2011-04-06 15:50:53 -0500 (Wed, 06 Apr 2011)
New Revision: 4296
Modified:
trunk/libexec/log-processing/README.txt
Log:
Add some asciidoc syntax
Modified: trunk/libexec/log-processing/README.txt
--- trunk/libexec/log-processing/README.txt 2011-04-06 20:41:46 UTC (rev 4295)
+++ trunk/libexec/log-processing/README.txt 2011-04-06 20:50:53 UTC (rev 4296)
@@ -1,4 +1,7 @@
+Log Processing
To properly generate log plots, you must enable VDL/Karajan logging.
Make sure log4.properties contains:
@@ -8,16 +11,32 @@
To make a basic load plot:
-* Generate the LOG (may set log4j.logger.swift=INFO for this one)
- (assuming the log is titled swift-run.log)
+* Generate the log (may set log4j.logger.swift=INFO for this one)
+(assuming the log is titled swift-run.log)
* Make the execute transitions file:
- make LOG=swift-run.log execute.transitions
- These transitions are relative to the Unix epoch
+make LOG=swift-run.log execute.transitions
+These transitions are relative to the Unix epoch
* Make the start time file (this contains the earliest timestamp)
- make LOG=swift-run.log start-time.tmp
+make LOG=swift-run.log start-time.tmp
* Normalize the transition times
- ./normalise-event-start-time < execute.transitions > execute.norm
+./normalise-event-start-time < execute.transitions > execute.norm
* Build up a load data file:
- ./accumulate-load.pl < execute.norm > load.data
-* Plot with the JFreeChart-based plotter:
- lines.zsh load.cfg load.eps load.data
+./accumulate-load.pl < execute.norm > load.data
+* Plot with the JFreeChart-based plotter in usertools/plotter:
+lines.zsh load.cfg load.eps load.data
More information about the Swift-commit
