[Swift-commit] r3722 - in trunk/tests: apps language/working
noreply at svn.ci.uchicago.edu
Wed Nov 24 11:02:18 CST 2010
Author: wozniak
Date: 2010-11-24 11:02:17 -0600 (Wed, 24 Nov 2010)
New Revision: 3722
Added:
trunk/tests/apps/046-tibi.swift
trunk/tests/apps/047-LQCD.swift
trunk/tests/apps/0471-fmri.swift
Removed:
trunk/tests/language/working/046-tibi.swift
trunk/tests/language/working/047-LQCD.swift
trunk/tests/language/working/0471-fmri.swift
Log:
Move app tests to apps
Copied: trunk/tests/apps/046-tibi.swift (from rev 3708, trunk/tests/language/working/046-tibi.swift)
--- trunk/tests/apps/046-tibi.swift (rev 0)
+++ trunk/tests/apps/046-tibi.swift 2010-11-24 17:02:17 UTC (rev 3722)
@@ -0,0 +1,39 @@
+// this is from Tibi's message
+// on 8th feb 2007777777
+type file {}
+//define the wavelet procedure
+(file wavelets) waveletTransf (file waveletScript, int subjNo,
+string trialType, file dataFiles) {
+ app {
+ cwtsmall @filename(waveletScript) subjNo trialType;
+(file outputs[]) batchTrials ( string trialTypes[] ){
+ file waveletScript<single_file_mapper;
+file="scripts/runTrialSubjectWavelet.R">;
+ //file dataFiles[]<simple_mapper; prefix="101_", suffix="-epochs.Rdata">;
+ foreach s,i in trialTypes {
+ //file output<simple_mapper;prefix=s,suffix="101.tgz">;
+ file dataFiles<simple_mapper; prefix="101_", suffix=s>;
+ outputs[i] = waveletTransf(waveletScript,101,s,dataFiles);
+//string trialTypes[] = ["FB", "FC", "FI", "SB", "SC", "SI" ];
+string trialTypes[] = [ "FB" ];
+file allOutputs[];
+file namedOutputs[]<fixed_array_mapper;
+files="101-FBchannel10_cwt-results.Rdata, 101-FBchannel11_cwt-results.Rdata, 101-FBchannel12_cwt-results.Rdata, 101-FBchannel13_cwt-results.Rdata, 101-FBchannel14_cwt-results.Rdata, 101-FBchannel15_cwt-results.Rdata, 101-FBchannel16_cwt-results.Rdata, 101-FBchannel17_cwt-results.Rdata, 101-FBchannel18_cwt-results.Rdata, 101-FBchannel19_cwt-results.Rdata, 101-FBchannel1_cwt-results.Rdata, 101-FBchannel20_cwt-results.Rdata, 101-FBchannel21_cwt-results.Rdata, 101-FBchannel22_cwt-results.Rdata, 101-FBchannel23_cwt-results.Rdata, 101-FBchannel24_cwt-results.Rdata, 101-FBchannel25_cwt-results.Rdata, 101-FBchannel26_cwt-results.Rdata, 101-FBchannel27_cwt-results.Rdata, 101-FBchannel28_cwt-results.Rdata, 101-FBchannel2_cwt-results.Rdata, 101-FBchannel3_cwt-results.Rdata, 101-FBchannel4_cwt-results.Rdata, 101-FBchannel5_cwt-results.Rdata, 101-FBchannel6_cwt-results.Rdata, 101-FBchannel7_cwt-results.Rdata, 101-FBchannel8_cwt-results.Rdata, 101-FBchannel9_cwt-results.Rdata">;
+//the MAIN program
+//file waveletScript<single_file_mapper;
+string file="scripts/runTrialSubjectWavelet.R";
+//namedOutputs = waveletTransf(waveletScript, 101, "FB");
+namedOutputs = batchTrials(trialTypes);
Copied: trunk/tests/apps/047-LQCD.swift (from rev 3708, trunk/tests/language/working/047-LQCD.swift)
--- trunk/tests/apps/047-LQCD.swift (rev 0)
+++ trunk/tests/apps/047-LQCD.swift 2010-11-24 17:02:17 UTC (rev 3722)
@@ -0,0 +1,100 @@
+type file {};
+(file gauge) stageIn (file input, int config) {
+ app {
+ stageIn "-v" "-i" @input "-c" config "-o" @gauge;
+(file output[]) stagSolve (file gauge, string mass, string source) {
+ app {
+ stagSolve "-v" "-g" @gauge "-m" mass "-s" source "-o" @output[*];
+(file output) cloverSolve ( float kappa, float cSW, file gauge, string source) {
+ app {
+ cloverSolve "-v" "-k" kappa "-c" cSW "-g" @gauge "-s" source "-o" @output;
+(file output) cvt12x12 (file input) {
+ app {
+ CVT12x12 "-v" "-i" @input "-o" @output;
+(file output) archive (file input) {
+ app {
+ Archive "-v" "-i" @input "-o" @output;
+(file output) archiveStag (string mass, file input[]) {
+ app {
+ ArchiveStag "-v" "-m" mass "-i" @input[*] "-o" @output;
+(file sdo) twoPtHH (file gauge, file antiQ, file Q0, file Q1, file Q2) {
+ app {
+ TwoPtHH "-v" "-g" @gauge "-a" @antiQ "-0" @Q0 "-1" @Q1 "-2" @Q2 stdout=@sdo;
+(file sdo) twoPtSH (file gauge, file stag, file antiQ, file Q0, file Q1, file Q2) {
+ app {
+ TwoPtSH "-v" "-g" @gauge "-s" @stag "-a" @antiQ "-0" @Q0 "-1" @Q1 "-2" @Q2 stdout=@sdo;
+string confList[]=["000102","000108","000114"];
+#string ensemble = "l4096f21b708m0031m031";
+float kappaQ = 0.127;
+float cSW = 1.75;
+string mass = "0.005,0.007,0.01,0.02,0.03";
+string fn[] = [ "m0.005_000102 m0.007_000102 m0.01_000102 m0.02_000102 m0.03_000102",
+ "m0.005_000108 m0.007_000108 m0.01_000108 m0.02_000108 m0.03_000108",
+ "m0.005_000114 m0.007_000114 m0.01_000114 m0.02_000114 m0.03_000114" ];
+int conflist[];
+foreach config,i in conflist {
+ string source = "local,0,0,0,0";
+ # gauge template name
+ file template<"foo">;
+ file gauge = stageIn (template, config);
+ # need config to be put into filenames too
+ #string fn = "m0.005 m0.007 m0.01 m0.02 m0.03";
+ file stags[]<fixed_array_mapper; files=fn[i]>;
+ stags = stagSolve(gauge, mass, source);
+ file stagTar<simple_mapper; suffix=".tar">;
+ stagTar = archiveStag(mass, stags);
+ file clover0 = cloverSolve(kappaQ, cSW, gauge, source);
+ file q0 = cvt12x12(clover0);
+ file cvtArch0 = archive(q0);
+ string source1 = "wavefunction,0,1S";
+ file clover1 = cloverSolve(kappaQ, cSW, gauge, source1);
+ file q1 = cvt12x12(clover1);
+ file cvtArch1 = archive(q1);
+ string source2 = "wavefunction,0,2S";
+ file clover2 = cloverSolve(kappaQ, cSW, gauge, source2);
+ file q2 = cvt12x12(clover2);
+ file cvtArch2 = archive(q2);
+ file antiQ = q0;
+ file pStdout = twoPtHH(gauge, antiQ, q0, q1, q2);
+ foreach stag in stags {
+ file sStdout = twoPtSH(gauge, stag, antiQ, q0, q1, q2);
Copied: trunk/tests/apps/0471-fmri.swift (from rev 3708, trunk/tests/language/working/0471-fmri.swift)
--- trunk/tests/apps/0471-fmri.swift (rev 0)
+++ trunk/tests/apps/0471-fmri.swift 2010-11-24 17:02:17 UTC (rev 3722)
@@ -0,0 +1,90 @@
+type voxelfile;
+type headerfile;
+type pgmfile;
+type imagefile;
+type warpfile;
+type volume {
+ voxelfile img;
+ headerfile hdr;
+(warpfile warp) align_warp(volume reference, volume subject, string model, string quick) {
+ app {
+ align_warp @reference.img @subject.img @warp "-m " model quick;
+(volume sliced) reslice(warpfile warp, volume subject)
+ app {
+ reslice @warp @sliced.img;
+(volume sliced) align_and_reslice(volume reference, volume subject, string model, string quick) {
+ warpfile warp;
+ warp = align_warp(reference, subject, model, quick);
+ sliced = reslice(warp, subject);
+(volume atlas) softmean(volume sliced[])
+ app {
+ softmean @atlas.img "y" "null" @filenames(sliced[*].img);
+(pgmfile outslice) slicer(volume input, string axis, string position)
+ app {
+ slicer @input.img axis position @outslice;
+(imagefile outimg) convert(pgmfile inpgm)
+ app {
+ convert @inpgm @outimg;
+(imagefile outimg) slice_to_jpeg(volume inp, string axis, string position)
+ pgmfile outslice;
+ outslice = slicer(inp, axis, position);
+ outimg = convert(outslice);
+(volume s[]) all_align_reslices(volume reference, volume subjects[]) {
+ foreach subject, i in subjects {
+ s[i] = align_and_reslice(reference, subjects[i], "12", "-q");
+volume references[] <csv_mapper;file="reference.csv">;
+volume reference=references[0];
+volume subjects[] <csv_mapper;file="subjects.csv">;
+volume slices[] <csv_mapper;file="slices.csv">;
+slices = all_align_reslices(reference, subjects);
+volume atlas <simple_mapper;prefix="atlas">;
+atlas = softmean(slices);
+string directions[] = [ "x", "y", "z"];
+foreach direction in directions {
+ imagefile o <single_file_mapper;file=@strcat("atlas-",direction,".jpeg")>;
+ string option = @strcat("-",direction);
+ o = slice_to_jpeg(atlas, option, ".5");
Deleted: trunk/tests/language/working/046-tibi.swift
--- trunk/tests/language/working/046-tibi.swift 2010-11-24 17:00:14 UTC (rev 3721)
+++ trunk/tests/language/working/046-tibi.swift 2010-11-24 17:02:17 UTC (rev 3722)
@@ -1,39 +0,0 @@
-// this is from Tibi's message
-// on 8th feb 2007777777
-type file {}
-//define the wavelet procedure
-(file wavelets) waveletTransf (file waveletScript, int subjNo,
-string trialType, file dataFiles) {
- app {
- cwtsmall @filename(waveletScript) subjNo trialType;
-(file outputs[]) batchTrials ( string trialTypes[] ){
- file waveletScript<single_file_mapper;
-file="scripts/runTrialSubjectWavelet.R">;
- //file dataFiles[]<simple_mapper; prefix="101_", suffix="-epochs.Rdata">;
- foreach s,i in trialTypes {
- //file output<simple_mapper;prefix=s,suffix="101.tgz">;
- file dataFiles<simple_mapper; prefix="101_", suffix=s>;
- outputs[i] = waveletTransf(waveletScript,101,s,dataFiles);
-//string trialTypes[] = ["FB", "FC", "FI", "SB", "SC", "SI" ];
-string trialTypes[] = [ "FB" ];
-file allOutputs[];
-file namedOutputs[]<fixed_array_mapper;
-files="101-FBchannel10_cwt-results.Rdata, 101-FBchannel11_cwt-results.Rdata, 101-FBchannel12_cwt-results.Rdata, 101-FBchannel13_cwt-results.Rdata, 101-FBchannel14_cwt-results.Rdata, 101-FBchannel15_cwt-results.Rdata, 101-FBchannel16_cwt-results.Rdata, 101-FBchannel17_cwt-results.Rdata, 101-FBchannel18_cwt-results.Rdata, 101-FBchannel19_cwt-results.Rdata, 101-FBchannel1_cwt-results.Rdata, 101-FBchannel20_cwt-results.Rdata, 101-FBchannel21_cwt-results.Rdata, 101-FBchannel22_cwt-results.Rdata, 101-FBchannel23_cwt-results.Rdata, 101-FBchannel24_cwt-results.Rdata, 101-FBchannel25_cwt-results.Rdata, 101-FBchannel26_cwt-results.Rdata, 101-FBchannel27_cwt-results.Rdata, 101-FBchannel28_cwt-results.Rdata, 101-FBchannel2_cwt-results.Rdata, 101-FBchannel3_cwt-results.Rdata, 101-FBchannel4_cwt-results.Rdata, 101-FBchannel5_cwt-results.Rdata, 101-FBchannel6_cwt-results.Rdata, 101-FBchannel7_cwt-results.Rdata, 101-FBchannel8_cwt-results.Rdata, 101-FBchannel9_cwt-results.Rdata">;
-//the MAIN program
-//file waveletScript<single_file_mapper;
-string file="scripts/runTrialSubjectWavelet.R";
-//namedOutputs = waveletTransf(waveletScript, 101, "FB");
-namedOutputs = batchTrials(trialTypes);
Deleted: trunk/tests/language/working/047-LQCD.swift
--- trunk/tests/language/working/047-LQCD.swift 2010-11-24 17:00:14 UTC (rev 3721)
+++ trunk/tests/language/working/047-LQCD.swift 2010-11-24 17:02:17 UTC (rev 3722)
@@ -1,100 +0,0 @@
-type file {};
-(file gauge) stageIn (file input, int config) {
- app {
- stageIn "-v" "-i" @input "-c" config "-o" @gauge;
-(file output[]) stagSolve (file gauge, string mass, string source) {
- app {
- stagSolve "-v" "-g" @gauge "-m" mass "-s" source "-o" @output[*];
-(file output) cloverSolve ( float kappa, float cSW, file gauge, string source) {
- app {
- cloverSolve "-v" "-k" kappa "-c" cSW "-g" @gauge "-s" source "-o" @output;
-(file output) cvt12x12 (file input) {
- app {
- CVT12x12 "-v" "-i" @input "-o" @output;
-(file output) archive (file input) {
- app {
- Archive "-v" "-i" @input "-o" @output;
-(file output) archiveStag (string mass, file input[]) {
- app {
- ArchiveStag "-v" "-m" mass "-i" @input[*] "-o" @output;
-(file sdo) twoPtHH (file gauge, file antiQ, file Q0, file Q1, file Q2) {
- app {
- TwoPtHH "-v" "-g" @gauge "-a" @antiQ "-0" @Q0 "-1" @Q1 "-2" @Q2 stdout=@sdo;
-(file sdo) twoPtSH (file gauge, file stag, file antiQ, file Q0, file Q1, file Q2) {
- app {
- TwoPtSH "-v" "-g" @gauge "-s" @stag "-a" @antiQ "-0" @Q0 "-1" @Q1 "-2" @Q2 stdout=@sdo;
-string confList[]=["000102","000108","000114"];
-#string ensemble = "l4096f21b708m0031m031";
-float kappaQ = 0.127;
-float cSW = 1.75;
-string mass = "0.005,0.007,0.01,0.02,0.03";
-string fn[] = [ "m0.005_000102 m0.007_000102 m0.01_000102 m0.02_000102 m0.03_000102",
- "m0.005_000108 m0.007_000108 m0.01_000108 m0.02_000108 m0.03_000108",
- "m0.005_000114 m0.007_000114 m0.01_000114 m0.02_000114 m0.03_000114" ];
-int conflist[];
-foreach config,i in conflist {
- string source = "local,0,0,0,0";
- # gauge template name
- file template<"foo">;
- file gauge = stageIn (template, config);
- # need config to be put into filenames too
- #string fn = "m0.005 m0.007 m0.01 m0.02 m0.03";
- file stags[]<fixed_array_mapper; files=fn[i]>;
- stags = stagSolve(gauge, mass, source);
- file stagTar<simple_mapper; suffix=".tar">;
- stagTar = archiveStag(mass, stags);
- file clover0 = cloverSolve(kappaQ, cSW, gauge, source);
- file q0 = cvt12x12(clover0);
- file cvtArch0 = archive(q0);
- string source1 = "wavefunction,0,1S";
- file clover1 = cloverSolve(kappaQ, cSW, gauge, source1);
- file q1 = cvt12x12(clover1);
- file cvtArch1 = archive(q1);
- string source2 = "wavefunction,0,2S";
- file clover2 = cloverSolve(kappaQ, cSW, gauge, source2);
- file q2 = cvt12x12(clover2);
- file cvtArch2 = archive(q2);
- file antiQ = q0;
- file pStdout = twoPtHH(gauge, antiQ, q0, q1, q2);
- foreach stag in stags {
- file sStdout = twoPtSH(gauge, stag, antiQ, q0, q1, q2);
Deleted: trunk/tests/language/working/0471-fmri.swift
--- trunk/tests/language/working/0471-fmri.swift 2010-11-24 17:00:14 UTC (rev 3721)
+++ trunk/tests/language/working/0471-fmri.swift 2010-11-24 17:02:17 UTC (rev 3722)
@@ -1,90 +0,0 @@
-type voxelfile;
-type headerfile;
-type pgmfile;
-type imagefile;
-type warpfile;
-type volume {
- voxelfile img;
- headerfile hdr;
-(warpfile warp) align_warp(volume reference, volume subject, string model, string quick) {
- app {
- align_warp @reference.img @subject.img @warp "-m " model quick;
-(volume sliced) reslice(warpfile warp, volume subject)
- app {
- reslice @warp @sliced.img;
-(volume sliced) align_and_reslice(volume reference, volume subject, string model, string quick) {
- warpfile warp;
- warp = align_warp(reference, subject, model, quick);
- sliced = reslice(warp, subject);
-(volume atlas) softmean(volume sliced[])
- app {
- softmean @atlas.img "y" "null" @filenames(sliced[*].img);
-(pgmfile outslice) slicer(volume input, string axis, string position)
- app {
- slicer @input.img axis position @outslice;
-(imagefile outimg) convert(pgmfile inpgm)
- app {
- convert @inpgm @outimg;
-(imagefile outimg) slice_to_jpeg(volume inp, string axis, string position)
- pgmfile outslice;
- outslice = slicer(inp, axis, position);
- outimg = convert(outslice);
-(volume s[]) all_align_reslices(volume reference, volume subjects[]) {
- foreach subject, i in subjects {
- s[i] = align_and_reslice(reference, subjects[i], "12", "-q");
-volume references[] <csv_mapper;file="reference.csv">;
-volume reference=references[0];
-volume subjects[] <csv_mapper;file="subjects.csv">;
-volume slices[] <csv_mapper;file="slices.csv">;
-slices = all_align_reslices(reference, subjects);
-volume atlas <simple_mapper;prefix="atlas">;
-atlas = softmean(slices);
-string directions[] = [ "x", "y", "z"];
-foreach direction in directions {
- imagefile o <single_file_mapper;file=@strcat("atlas-",direction,".jpeg")>;
- string option = @strcat("-",direction);
- o = slice_to_jpeg(atlas, option, ".5");
More information about the Swift-commit
