[Swift-commit] r3721 - in trunk/tests: apps language/working
Wed Nov 24 11:00:14 CST 2010
Author: wozniak
Date: 2010-11-24 11:00:14 -0600 (Wed, 24 Nov 2010)
New Revision: 3721
Added:
   trunk/tests/apps/039-montage.swift
Removed:
   trunk/tests/language/working/039-montage.swift
Log:
Move 039-montage to apps
Copied: trunk/tests/apps/039-montage.swift (from rev 3708, trunk/tests/language/working/039-montage.swift)
--- trunk/tests/apps/039-montage.swift	                        (rev 0)
+++ trunk/tests/apps/039-montage.swift	2010-11-24 17:00:14 UTC (rev 3721)
@@ -0,0 +1,186 @@
+type Image {}
+type Header {}
+type Table {}
+type DiffStruct {
+	int cntr1;
+	int cntr2;
+	Image plus;
+	Image minus;
+	Image diff;
+type TxtFile {}
+type JPEG {};
+( Image projectedImage, Image projectedArea ) mProjectPP ( Image rawImage, Header template ) {
+	app {
+		mProjectPP "-X" @rawImage @projectedImage @template;
+( Image projectedImages[], Image projectedAreas[] ) mProjectPPBatch ( Image rawImages[], Header template ) {
+	foreach img, i in rawImages {
+		Image projImg<regexp_mapper;source=@img,match=".*\\/(.*)",transform="proj_\\1">;
+		Image areaImg<regexp_mapper;source=@projImg,match="(.*)\\.(.*)",transform="\\1_area.\\2">;
+		( projImg, areaImg ) = mProjectPP ( img, template );
+		projectedImages[i] = projImg;
+		projectedAreas[i] = areaImg;
+( Table diffsTbl ) mOverlaps ( Table imagesTbl ) {
+	app {
+		mOverlaps @imagesTbl @diffsTbl;
+( Image diffImage, TxtFile statusFile ) mDiffFit ( Image projectedImage1, Image projectedArea1, Image projectedImage2, Image projectedArea2, Header template) {
+	app {
+		mDiffFit "-s" @statusFile @projectedImage1 @projectedImage2 @diffImage @template;
+( Image diffImages[], TxtFile statusFiles[] ) mDiffFitBatch ( Table diffsTbl, Header template) {
+	//read overlap image pairs from diffsTbl
+	DiffStruct diffs[]<csv_mapper;file=@diffsTbl,skip=1,hdelim=" |">;
+	foreach d, i in diffs {
+		Image image1 = d.plus;
+		Image area1<regexp_mapper;source=@image1,match="(.*)\\.(.*)",transform="\\1_area.\\2">;
+		Image image2 = d.minus;
+		Image area2<regexp_mapper;source=@image2,match="(.*)\\.(.*)",transform="\\1_area.\\2">;
+		Image diffImg<fixed_mapper;file=@(d.diff)>;
+		TxtFile statusFile<regexp_mapper;source=@diffImg,match="diff(.*)fits",transform="fit\\1txt">;
+		( diffImg, statusFile ) = mDiffFit ( image1, area1, image2, area2, template );
+		diffImages[i] = diffImg;
+		statusFiles[i] = statusFile;
+( Table statusFilesTbl ) mStatTbl ( Table diffsTbl ) {
+	app {
+		mStatTbl @diffsTbl @statusFilesTbl;
+( Table fitsTbl ) mConcatFit ( Table statusFilesTbl, TxtFile statusFiles[], string statusDir ) {
+	app {
+		mConcatFit @statusFilesTbl @fitsTbl statusDir;
+( Table correctionsTbl ) mBgModel ( Table projectedImagesTbl, Table fitsTbl ) {
+	app {
+		mBgModel @projectedImagesTbl @fitsTbl @correctionsTbl;
+( Image correctedImage, Image correctedArea ) mBackground ( Image projectedImage, Image projectedArea, Table projectedImagesTbl, Table correctionsTbl ) {
+	app {
+		mBackground "-t" @projectedImage @correctedImage @projectedImagesTbl @correctionsTbl;
+( Image correctedImages[], Image correctedAreas[] ) mBackgroundBatch ( Image projectedImages[], Image projectedAreas[], Table projectedImagesTbl, Table correctionsTbl ) {
+	foreach projImg, i in projectedImages {
+		Image projArea = projectedAreas[i];
+		Image corrImg<regexp_mapper;source=@projImg,match="proj_(.*)",transform="corr_\\1">;
+		Image corrArea<regexp_mapper;source=@corrImg,match="(.*)\\.(.*)",transform="\\1_area.\\2">;
+		( corrImg, corrArea ) = mBackground ( projImg, projArea, projectedImagesTbl, correctionsTbl );
+		correctedImages[i] = corrImg;
+		correctedAreas[i] = corrArea;
+( Table imagesTbl ) mImgtbl ( string imageDir, Image images[] ) {
+	app {
+		mImgtbl imageDir @imagesTbl;
+( Table newImagesTbl ) mImgtbl_t ( string imageDir, Image images[], Table oldImagesTbl ) {
+	app {
+		mImgtbl imageDir "-t" @oldImagesTbl @newImagesTbl;
+( Image mosaic, Image mosaicArea ) mAdd ( Table imagesTbl, Header template, Image images[], Image imageAreas[] ) {
+	app {
+		mAdd "-e" @imagesTbl @template @mosaic;
+( Image shrunkImage ) mShrink ( Image image, float factor ) {
+	app {
+		mShrink @image @shrunkImage factor;
+( JPEG jpeg ) mJPEG ( Image image ) {
+	app {
+		mJPEG "-ct" 1
+		      "-gray" @image
+		      "-1.5s" "60s" "gaussian"
+		      "-out" @jpeg;
+// get raw images
+Image rawImages[]<dir_mapper;location="rawdir", suffix=".fits">;
+// template header file
+Header template<"template.hdr">;
+// fast project raw images
+Image projectedImages[], projectedAreas[];
+( projectedImages, projectedAreas ) = mProjectPPBatch ( rawImages, template );
+// table of projected images
+Table projImgTbl<"projImg.tbl">;
+projImgTbl = mImgtbl ( ".", projectedImages );
+// table of overlapping images
+Table diffsTbl<"diffs.tbl">;
+diffsTbl = mOverlaps ( projImgTbl );
+Image diffImgs[];
+TxtFile statusFiles[];
+( diffImgs, statusFiles ) = mDiffFitBatch ( diffsTbl, template );
+Table statusFilesTbl<"statfile.tbl">;
+statusFilesTbl = mStatTbl ( diffsTbl );
+// fit to plane
+Table fitsTbl<"fits.tbl">;
+fitsTbl = mConcatFit ( statusFilesTbl, statusFiles, "." );
+// corrections
+Table correctionsTbl<"corrections.tbl">;
+correctionsTbl = mBgModel ( projImgTbl, fitsTbl );
+// background adjustment
+Image correctedImages[], correctedAreas[];
+( correctedImages, correctedAreas ) = mBackgroundBatch ( projectedImages, projectedAreas, projImgTbl, correctionsTbl );
+// table of corrected images
+Table corrImgTbl<"corrImg.tbl">;
+corrImgTbl = mImgtbl ( ".", correctedImages );
+// generate mosaic
+Image mosaic<"mosaic.fits">;
+Image mosaicArea<"mosaic_area.fits">;
+( mosaic, mosaicArea ) = mAdd ( corrImgTbl, template, correctedImages, correctedAreas );
+// shrink the image
+Image smallMosaic<"smallMosaic.fits">;
+smallMosaic = mShrink ( mosaic, 3.0 );
+// convert to jpeg
+JPEG jpeg<"mosaic.jpg">;
+jpeg = mJPEG( smallMosaic );
Deleted: trunk/tests/language/working/039-montage.swift
--- trunk/tests/language/working/039-montage.swift	2010-11-24 16:59:23 UTC (rev 3720)
+++ trunk/tests/language/working/039-montage.swift	2010-11-24 17:00:14 UTC (rev 3721)
@@ -1,186 +0,0 @@
-type Image {}
-type Header {}
-type Table {}
-type DiffStruct {
-	int cntr1;
-	int cntr2;
-	Image plus;
-	Image minus;
-	Image diff;
-type TxtFile {}
-type JPEG {};
-( Image projectedImage, Image projectedArea ) mProjectPP ( Image rawImage, Header template ) {
-	app {
-		mProjectPP "-X" @rawImage @projectedImage @template;
-( Image projectedImages[], Image projectedAreas[] ) mProjectPPBatch ( Image rawImages[], Header template ) {
-	foreach img, i in rawImages {
-		Image projImg<regexp_mapper;source=@img,match=".*\\/(.*)",transform="proj_\\1">;
-		Image areaImg<regexp_mapper;source=@projImg,match="(.*)\\.(.*)",transform="\\1_area.\\2">;
-		( projImg, areaImg ) = mProjectPP ( img, template );
-		projectedImages[i] = projImg;
-		projectedAreas[i] = areaImg;
-( Table diffsTbl ) mOverlaps ( Table imagesTbl ) {
-	app {
-		mOverlaps @imagesTbl @diffsTbl;
-( Image diffImage, TxtFile statusFile ) mDiffFit ( Image projectedImage1, Image projectedArea1, Image projectedImage2, Image projectedArea2, Header template) {
-	app {
-		mDiffFit "-s" @statusFile @projectedImage1 @projectedImage2 @diffImage @template;
-( Image diffImages[], TxtFile statusFiles[] ) mDiffFitBatch ( Table diffsTbl, Header template) {
-	//read overlap image pairs from diffsTbl
-	DiffStruct diffs[]<csv_mapper;file=@diffsTbl,skip=1,hdelim=" |">;
-	foreach d, i in diffs {
-		Image image1 = d.plus;
-		Image area1<regexp_mapper;source=@image1,match="(.*)\\.(.*)",transform="\\1_area.\\2">;
-		Image image2 = d.minus;
-		Image area2<regexp_mapper;source=@image2,match="(.*)\\.(.*)",transform="\\1_area.\\2">;
-		Image diffImg<fixed_mapper;file=@(d.diff)>;
-		TxtFile statusFile<regexp_mapper;source=@diffImg,match="diff(.*)fits",transform="fit\\1txt">;
-		( diffImg, statusFile ) = mDiffFit ( image1, area1, image2, area2, template );
-		diffImages[i] = diffImg;
-		statusFiles[i] = statusFile;
-( Table statusFilesTbl ) mStatTbl ( Table diffsTbl ) {
-	app {
-		mStatTbl @diffsTbl @statusFilesTbl;
-( Table fitsTbl ) mConcatFit ( Table statusFilesTbl, TxtFile statusFiles[], string statusDir ) {
-	app {
-		mConcatFit @statusFilesTbl @fitsTbl statusDir;
-( Table correctionsTbl ) mBgModel ( Table projectedImagesTbl, Table fitsTbl ) {
-	app {
-		mBgModel @projectedImagesTbl @fitsTbl @correctionsTbl;
-( Image correctedImage, Image correctedArea ) mBackground ( Image projectedImage, Image projectedArea, Table projectedImagesTbl, Table correctionsTbl ) {
-	app {
-		mBackground "-t" @projectedImage @correctedImage @projectedImagesTbl @correctionsTbl;
-( Image correctedImages[], Image correctedAreas[] ) mBackgroundBatch ( Image projectedImages[], Image projectedAreas[], Table projectedImagesTbl, Table correctionsTbl ) {
-	foreach projImg, i in projectedImages {
-		Image projArea = projectedAreas[i];
-		Image corrImg<regexp_mapper;source=@projImg,match="proj_(.*)",transform="corr_\\1">;
-		Image corrArea<regexp_mapper;source=@corrImg,match="(.*)\\.(.*)",transform="\\1_area.\\2">;
-		( corrImg, corrArea ) = mBackground ( projImg, projArea, projectedImagesTbl, correctionsTbl );
-		correctedImages[i] = corrImg;
-		correctedAreas[i] = corrArea;
-( Table imagesTbl ) mImgtbl ( string imageDir, Image images[] ) {
-	app {
-		mImgtbl imageDir @imagesTbl;
-( Table newImagesTbl ) mImgtbl_t ( string imageDir, Image images[], Table oldImagesTbl ) {
-	app {
-		mImgtbl imageDir "-t" @oldImagesTbl @newImagesTbl;
-( Image mosaic, Image mosaicArea ) mAdd ( Table imagesTbl, Header template, Image images[], Image imageAreas[] ) {
-	app {
-		mAdd "-e" @imagesTbl @template @mosaic;
-( Image shrunkImage ) mShrink ( Image image, float factor ) {
-	app {
-		mShrink @image @shrunkImage factor;
-( JPEG jpeg ) mJPEG ( Image image ) {
-	app {
-		mJPEG "-ct" 1
-		      "-gray" @image
-		      "-1.5s" "60s" "gaussian"
-		      "-out" @jpeg;
-// get raw images
-Image rawImages[]<dir_mapper;location="rawdir", suffix=".fits">;
-// template header file
-Header template<"template.hdr">;
-// fast project raw images
-Image projectedImages[], projectedAreas[];
-( projectedImages, projectedAreas ) = mProjectPPBatch ( rawImages, template );
-// table of projected images
-Table projImgTbl<"projImg.tbl">;
-projImgTbl = mImgtbl ( ".", projectedImages );
-// table of overlapping images
-Table diffsTbl<"diffs.tbl">;
-diffsTbl = mOverlaps ( projImgTbl );
-Image diffImgs[];
-TxtFile statusFiles[];
-( diffImgs, statusFiles ) = mDiffFitBatch ( diffsTbl, template );
-Table statusFilesTbl<"statfile.tbl">;
-statusFilesTbl = mStatTbl ( diffsTbl );
-// fit to plane
-Table fitsTbl<"fits.tbl">;
-fitsTbl = mConcatFit ( statusFilesTbl, statusFiles, "." );
-// corrections
-Table correctionsTbl<"corrections.tbl">;
-correctionsTbl = mBgModel ( projImgTbl, fitsTbl );
-// background adjustment
-Image correctedImages[], correctedAreas[];
-( correctedImages, correctedAreas ) = mBackgroundBatch ( projectedImages, projectedAreas, projImgTbl, correctionsTbl );
-// table of corrected images
-Table corrImgTbl<"corrImg.tbl">;
-corrImgTbl = mImgtbl ( ".", correctedImages );
-// generate mosaic
-Image mosaic<"mosaic.fits">;
-Image mosaicArea<"mosaic_area.fits">;
-( mosaic, mosaicArea ) = mAdd ( corrImgTbl, template, correctedImages, correctedAreas );
-// shrink the image
-Image smallMosaic<"smallMosaic.fits">;
-smallMosaic = mShrink ( mosaic, 3.0 );
-// convert to jpeg
-JPEG jpeg<"mosaic.jpg">;
-jpeg = mJPEG( smallMosaic );
