[Swift-commit] r3454 - in branches/tests-01/src/org/griphyn/vdl: mapping type type/impl
Wed Jul 21 17:00:25 CDT 2010
Author: wozniak
Date: 2010-07-21 17:00:25 -0500 (Wed, 21 Jul 2010)
New Revision: 3454
Modified:
   branches/tests-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   branches/tests-01/src/org/griphyn/vdl/type/Type.java
   branches/tests-01/src/org/griphyn/vdl/type/impl/TypeImpl.java
Log:
Convert some data structures to Java 5
Modified: branches/tests-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- branches/tests-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2010-07-21 21:25:38 UTC (rev 3453)
+++ branches/tests-01/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2010-07-21 22:00:25 UTC (rev 3454)
@@ -25,579 +25,572 @@
 public abstract class AbstractDataNode implements DSHandle {
-	static final String DATASET_URI_PREFIX = "tag:benc at ci.uchicago.edu,2008:swift:dataset:";
+    static final String DATASET_URI_PREFIX = "tag:benc at ci.uchicago.edu,2008:swift:dataset:";
-	public static final Logger logger = Logger
-			.getLogger(AbstractDataNode.class);
+    public static final Logger logger = Logger
+    .getLogger(AbstractDataNode.class);
-	public static final MappingParam PARAM_PREFIX = new MappingParam("prefix",
-			null);
+    public static final MappingParam PARAM_PREFIX = new MappingParam("prefix",
+        null);
-	 * Datasets are identified within a run by this sequence number and the
-	 * partial ID field. The initial value is chosen to aid human recognition of
-	 * sequence numbers in the wild. There is no requirement that it start at
-	 * this (or any other) particular value. Note that this introduces a maximum
-	 * on the number of datasets which can be dealt with in any run to be about
-	 * 2^62.
-	private static long datasetIDCounter = 720000000000l;
+     * Datasets are identified within a run by this sequence number and the
+     * partial ID field. The initial value is chosen to aid human recognition of
+     * sequence numbers in the wild. There is no requirement that it start at
+     * this (or any other) particular value. Note that this introduces a maximum
+     * on the number of datasets which can be dealt with in any run to be about
+     * 2^62.
+    private static long datasetIDCounter = 720000000000l;
-	 * This is used to provide a (hopefully) globally unique identifier for each
-	 * time the datasetIDCounter is reset (whenever this class is loaded, which
-	 * will usually happen once per JVM). No meaning should be inferred from
-	 * this value - it exists purely for making unique URIs.
-	private static final String datasetIDPartialID = Loader.getUUID();
+     * This is used to provide a (hopefully) globally unique identifier for each
+     * time the datasetIDCounter is reset (whenever this class is loaded, which
+     * will usually happen once per JVM). No meaning should be inferred from
+     * this value - it exists purely for making unique URIs.
+    private static final String datasetIDPartialID = Loader.getUUID();
-	private Field field;
-	private Map handles;
-	private Object value;
-	private boolean closed;
-	private List listeners;
-	final String identifierURI = makeIdentifierURIString();
-	private Path pathFromRoot;
+    private Field field;
+    private Map<String,DSHandle> handles;
+    private Object value;
+    private boolean closed;
+    private List<DSHandleListener> listeners;
+    final String identifierURI = makeIdentifierURIString();
+    private Path pathFromRoot;
-	protected AbstractDataNode(Field field) {
-		this.field = field;
-		handles = new HashMap();
+    protected AbstractDataNode(Field field) {
+        this.field = field;
+        handles = new HashMap<String,DSHandle>();
-	public void init(Map params) {
+    public void init(Map params) {
-	public Type getType() {
-		return field.getType();
+    public Type getType() {
+        return field.getType();
-	public boolean isPrimitive() {
-		return field.getType().isPrimitive();
+    public boolean isPrimitive() {
+        return field.getType().isPrimitive();
-	public boolean isRestartable() {
-		return !isPrimitive();
+    public boolean isRestartable() {
+        return !isPrimitive();
-	protected Field getField() {
-		return field;
+    protected Field getField() {
+        return field;
-	 * create a String representation of this node. If the node has a value,
-	 * then uses the String representation of that value. Otherwise, generates a
-	 * text description.
-	public String toString() {
-		if (this.value != null && !(this.value instanceof Exception)) {
-			// special handling for ints...
-			if (this.getType().equals(Types.INT)) {
-				try {
-					Number n = (Number) this.getValue();
-					return String.valueOf(n.intValue());
-				catch (ClassCastException e) {
-					throw new RuntimeException(
-							"Internal type error. Value is not a Number for "
-									+ getDisplayableName() + getPathFromRoot());
-			else {
-				return this.value.toString();
-		return getIdentifyingString();
+     * create a String representation of this node. If the node has a value,
+     * then uses the String representation of that value. Otherwise, generates a
+     * text description.
+    public String toString() {
+        if (this.value != null && !(this.value instanceof Exception)) {
+            // special handling for ints...
+            if (this.getType().equals(Types.INT)) {
+                try {
+                    Number n = (Number) this.getValue();
+                    return String.valueOf(n.intValue());
+                catch (ClassCastException e) {
+                    throw new RuntimeException(
+                        "Internal type error. Value is not a Number for "
+                        + getDisplayableName() + getPathFromRoot());
+            else {
+                return this.value.toString();
+        return getIdentifyingString();
-	public String getIdentifyingString() {
-		StringBuffer sb = new StringBuffer();
-		sb.append(this.getClass().getName());
+    public String getIdentifyingString() {
+        StringBuffer sb = new StringBuffer();
+        sb.append(this.getClass().getName());
-		sb.append(" identifier ");
-		sb.append(this.getIdentifier());
+        sb.append(" identifier ");
+        sb.append(this.getIdentifier());
-		sb.append(" type ");
-		sb.append(getType());
+        sb.append(" type ");
+        sb.append(getType());
-		if (value == null) {
-			sb.append(" with no value at dataset=");
-		else if (value instanceof Throwable) {
-			sb.append(" containing throwable ");
-			sb.append(value.getClass());
-			sb.append(" dataset=");
-		else {
-			sb.append(" value=");
-			sb.append(this.value.toString());
+        if (value == null) {
+            sb.append(" with no value at dataset=");
+        else if (value instanceof Throwable) {
+            sb.append(" containing throwable ");
+            sb.append(value.getClass());
+            sb.append(" dataset=");
+        else {
+            sb.append(" value=");
+            sb.append(this.value.toString());
-		sb.append(getDisplayableName());
+        sb.append(getDisplayableName());
-		if (!Path.EMPTY_PATH.equals(getPathFromRoot())) {
-			sb.append(" path=");
-			sb.append(getPathFromRoot().toString());
+        if (!Path.EMPTY_PATH.equals(getPathFromRoot())) {
+            sb.append(" path=");
+            sb.append(getPathFromRoot().toString());
-		if (closed) {
-			sb.append(" (closed)");
-		else {
-			sb.append(" (not closed)");
+        if (closed) {
+            sb.append(" (closed)");
+        else {
+            sb.append(" (not closed)");
-		return sb.toString();
+        return sb.toString();
-	public String getDisplayableName() {
-		String prefix = getRoot().getParam("dbgname");
-		if (prefix == null) {
-			prefix = getRoot().getParam("prefix");
-			prefix = "unnamed SwiftScript value";
-		return prefix;
+    public String getDisplayableName() {
+        String prefix = getRoot().getParam("dbgname");
+        if (prefix == null) {
+            prefix = getRoot().getParam("prefix");
+            prefix = "unnamed SwiftScript value";
+        return prefix;
-	public DSHandle getField(Path path) throws InvalidPathException {
-		if (path.isEmpty()) {
-			return this;
-		try {
-			DSHandle handle = getField(path.getFirst());
-			if (path.size() > 1) {
-				return handle.getField(path.butFirst());
-			else {
-				return handle;
-		catch (NoSuchFieldException e) {
-			throw new InvalidPathException(path, this);
+    public DSHandle getField(Path path) throws InvalidPathException {
+        if (path.isEmpty()) {
+            return this;
+        try {
+            DSHandle handle = getField(path.getFirst());
+            if (path.size() > 1) {
+                return handle.getField(path.butFirst());
+            else {
+                return handle;
+        catch (NoSuchFieldException e) {
+            throw new InvalidPathException(path, this);
-	public Collection getFields(Path path) throws InvalidPathException,
-			HandleOpenException {
-		List fields = new ArrayList();
-		getFields(fields, path);
-		return fields;
+    public Collection<DSHandle> getFields(Path path)
+    throws InvalidPathException, HandleOpenException {
+        List<DSHandle> fields = new ArrayList<DSHandle>();
+        getFields(fields, path);
+        return fields;
-	private void getFields(List fields, Path path) throws InvalidPathException,
-			fields.add(this);
-		else {
-			Path rest = path.butFirst();
-			if (path.isWildcard(0)) {
-				if (isArray() && !closed) {
-					throw new HandleOpenException(this);
-				Iterator i = this.handles.entrySet().iterator();
-				while (i.hasNext()) {
-					Map.Entry e = (Map.Entry) i.next();
-					((AbstractDataNode) e.getValue()).getFields(fields, rest);
-			else {
-				try {
-					((AbstractDataNode) getField(path.getFirst())).getFields(
-							fields, rest);
+    private void getFields(List<DSHandle> fields, Path path)
+            fields.add(this);
+        else {
+            Path rest = path.butFirst();
+            if (path.isWildcard(0)) {
+                if (isArray() && !closed) {
+                    throw new HandleOpenException(this);
+                for (DSHandle handle : handles.values()) {
+                    ((AbstractDataNode) handle).getFields(fields, rest);
+            else {
+                try {
+                    ((AbstractDataNode) getField(path.getFirst())).getFields(
+                        fields, rest);
-	public void set(DSHandle handle) {
-		// TODO check type
-		if (closed) {
-			throw new IllegalArgumentException(this.getDisplayableName()
-					+ " is already assigned");
-		if (getParent() == null) {
-			 * AbstractDataNode node = (AbstractDataNode)handle; field =
-			 * node.getField(); handles = node.getHandles(); closed =
-			 * node.isClosed(); value = node.getValue();
-			throw new RuntimeException("Can't set root data node!");
-		else {
-			((AbstractDataNode) getParent()).setField(field.getName(), handle);
+    public void set(DSHandle handle) {
+        // TODO check type
+        if (closed) {
+            throw new IllegalArgumentException(this.getDisplayableName()
+                + " is already assigned");
+        if (getParent() == null) {
+             * AbstractDataNode node = (AbstractDataNode)handle; field =
+             * node.getField(); handles = node.getHandles(); closed =
+             * node.isClosed(); value = node.getValue();
+            throw new RuntimeException("Can't set root data node!");
+        else {
+            ((AbstractDataNode) getParent()).setField(field.getName(), handle);
-	protected void setField(String name, DSHandle handle) {
-		synchronized (handles) {
-			handles.put(name, handle);
+    protected void setField(String name, DSHandle handle) {
+        synchronized (handles) {
+            handles.put(name, handle);
-	protected synchronized DSHandle getField(String name)
-			throws NoSuchFieldException {
-		DSHandle handle = getHandle(name);
-		if (handle == null) {
-			if (closed) {
-				throw new NoSuchFieldException(name);
-			else {
-				handle = createDSHandle(name);
+    protected synchronized DSHandle getField(String name)
+    throws NoSuchFieldException {
+        DSHandle handle = getHandle(name);
+        if (handle == null) {
+            if (closed) {
+                throw new NoSuchFieldException(name);
+            else {
+                handle = createDSHandle(name);
-		return handle;
+        return handle;
-	protected DSHandle getHandle(String name) {
-			return (DSHandle) handles.get(name);
+    protected DSHandle getHandle(String name) {
+            return (DSHandle) handles.get(name);
-	protected boolean isHandlesEmpty() {
-			return handles.isEmpty();
+    protected boolean isHandlesEmpty() {
+            return handles.isEmpty();
-	public DSHandle createDSHandle(String fieldName)
-		if (closed) {
-			throw new RuntimeException("Cannot write to closed handle: " + this
-					+ " (" + fieldName + ")");
+    public DSHandle createDSHandle(String fieldName)
+        if (closed) {
+            throw new RuntimeException("Cannot write to closed handle: " + this
+                + " (" + fieldName + ")");
-		AbstractDataNode child;
-		Field childField = getChildField(fieldName);
-		if (childField.getType().isArray()) {
-			child = new ArrayDataNode(getChildField(fieldName), getRoot(), this);
-		else {
-			child = new DataNode(getChildField(fieldName), getRoot(), this);
+        AbstractDataNode child;
+        Field childField = getChildField(fieldName);
+        if (childField.getType().isArray()) {
+            child = new ArrayDataNode(getChildField(fieldName), getRoot(), this);
+        else {
+            child = new DataNode(getChildField(fieldName), getRoot(), this);
-			Object o = handles.put(fieldName, child);
-			if (o != null) {
-						"Trying to create a handle that already exists ("
-								+ fieldName + ") in " + this);
-		return child;
+            Object o = handles.put(fieldName, child);
+            if (o != null) {
+                    "Trying to create a handle that already exists ("
+                    + fieldName + ") in " + this);
+        return child;
-	protected Field getChildField(String fieldName) throws NoSuchFieldException {
-		return Field.Factory.createField(fieldName, field.getType().getField(
-				fieldName).getType());
+    protected Field getChildField(String fieldName) throws NoSuchFieldException {
+        return Field.Factory.createField(fieldName, field.getType().getField(
+            fieldName).getType());
-	protected void checkDataException() {
-		if (value instanceof DependentException) {
-			throw (DependentException) value;
+    protected void checkDataException() {
+        if (value instanceof DependentException) {
+            throw (DependentException) value;
-	protected void checkMappingException() {
-		if (value instanceof MappingDependentException) {
-			throw (MappingDependentException) value;
+    protected void checkMappingException() {
+        if (value instanceof MappingDependentException) {
+            throw (MappingDependentException) value;
-	public Object getValue() {
-		checkDataException();
-		if (field.getType().isArray()) {
-			return handles;
-		else {
-			return value;
+    public Object getValue() {
+        checkDataException();
+        if (field.getType().isArray()) {
+            return handles;
+        else {
+            return value;
-	public Map getArrayValue() {
-		if (!field.getType().isArray()) {
-			throw new RuntimeException("getArrayValue called on a struct: "
-					+ this);
-		return handles;
+    public Map<String,DSHandle> getArrayValue() {
+        if (!field.getType().isArray()) {
+            ("getArrayValue called on a struct: " + this);
+        return handles;
-	public boolean isArray() {
-		return false;
+    public boolean isArray() {
+        return false;
-	public void setValue(Object value) {
-		if (this.closed) {
-					+ " is closed with a value of " + this.value);
-		if (this.value != null) {
-					+ " is already assigned with a value of " + this.value);
-		this.value = value;
-		closeShallow();
+    public void setValue(Object value) {
+        if (this.closed) {
+                + " is closed with a value of " + this.value);
+        if (this.value != null) {
+                + " is already assigned with a value of " + this.value);
+        this.value = value;
+        closeShallow();
-	public Collection getFringePaths() throws HandleOpenException {
-		ArrayList list = new ArrayList();
-		getFringePaths(list, Path.EMPTY_PATH);
-		return list;
+    public Collection<Path> getFringePaths() throws HandleOpenException {
+        List<Path> list = new ArrayList<Path>();
+        getFringePaths(list, Path.EMPTY_PATH);
+        return list;
-	public void getFringePaths(List list, Path parentPath)
-			throws HandleOpenException {
-		checkMappingException();
-		if (getField().getType().getBaseType() != null) {
-			list.add(Path.EMPTY_PATH);
-		else {
-			Iterator i = getField().getType().getFields().iterator();
-				Field field = (Field) i.next();
-				AbstractDataNode mapper;
-				try {
-					mapper = (AbstractDataNode) this.getField(field.getName());
-							"Inconsistency between type declaration and handle for field '"
-									+ field.getName() + "'");
-				// [m] Hmm. Should there be a difference between field and
-				// mapper.getField()?
-				// Path fullPath =
-				// parentPath.addLast(mapper.getField().getName());
-				Path fullPath = parentPath.addLast(field.getName());
-				if (!mapper.field.getType().isPrimitive() && !mapper.isArray() && mapper.field.getType().getFields().size() == 0) {
-					list.add(fullPath);
-				else {
-					mapper.getFringePaths(list, fullPath);
+    public void getFringePaths(List<Path> list, Path parentPath)
+    throws HandleOpenException {
+        checkMappingException();
+        if (getField().getType().getBaseType() != null) {
+            list.add(Path.EMPTY_PATH);
+        else {
+            for (Field field : getField().getType().getFields()) {
+                AbstractDataNode mapper;
+                String name = field.getName();
+                try {
+                    mapper = (AbstractDataNode) this.getField(name);
+                    ("Inconsistency between type declaration and " +
+                        "handle for field '" + name + "'");
+                // [m] Hmm. Should there be a difference between field and
+                // mapper.getField()?
+                // Path fullPath =
+                // parentPath.addLast(mapper.getField().getName());
+                Path fullPath = parentPath.addLast(field.getName());
+                Type type = mapper.field.getType();
+                if (!type.isPrimitive() &&
+                        !mapper.isArray() &&
+                        type.getFields().size() == 0) {
+                    list.add(fullPath);
+                else {
+                    mapper.getFringePaths(list, fullPath);
-	public synchronized void closeShallow() {
-			return;
-		this.closed = true;
-		notifyListeners();
-		if (logger.isInfoEnabled()) {
-			logger.debug("closed " + this.getIdentifyingString());
-		// so because its closed, we can dump the contents
+    public synchronized void closeShallow() {
+            return;
+        this.closed = true;
+        notifyListeners();
+        if (logger.isInfoEnabled()) {
+            logger.debug("closed " + this.getIdentifyingString());
+        // so because its closed, we can dump the contents
-		try {
-			if(VDL2Config.getConfig().getProvenanceLog()) {
-				logContent();
-		catch (Exception e) {
-			logger.warn("Exception whilst logging dataset content for " + this,
-				e);
-		// TODO record retrospective provenance information for this dataset
-		// here
-		// we should do it at closing time because that's the point at which we
-		// know the dataset has its values (all the way down the tree) assigned.
+        try {
+            if(VDL2Config.getConfig().getProvenanceLog()) {
+                logContent();
+        catch (Exception e) {
+            logger.warn("Exception whilst logging dataset content for " + this,
+                e);
+        // TODO record retrospective provenance information for this dataset
+        // here
+        // we should do it at closing time because that's the point at which we
+        // know the dataset has its values (all the way down the tree) assigned.
-		// provenance-id for this dataset should have been assigned at creation
-		// time,
-		// though, so that we can refer to this dataset elsewhere before it is
-		// closed.
+        // provenance-id for this dataset should have been assigned at creation
+        // time,
+        // though, so that we can refer to this dataset elsewhere before it is
+        // closed.
-		// is this method the only one called to set this.closed? or do
-		// subclasses
-		// or other methods ever change it?
+        // is this method the only one called to set this.closed? or do
+        // subclasses
+        // or other methods ever change it?
-	public synchronized void logContent() {
-		String identifier = this.getIdentifier();
-		Path pathFromRoot = this.getPathFromRoot();
-		if (this.getPathFromRoot() != null) {
-				logger.info("ROOTPATH dataset=" + identifier + " path="
-						+ pathFromRoot);
-				if (this.getType().isPrimitive()) {
-					logger.info("VALUE dataset=" + identifier + " VALUE="
-							+ this.toString());
+    public synchronized void logContent() {
+        String identifier = this.getIdentifier();
+        Path pathFromRoot = this.getPathFromRoot();
+        if (this.getPathFromRoot() != null) {
+                logger.info("ROOTPATH dataset=" + identifier + " path="
+                    + pathFromRoot);
+                if (this.getType().isPrimitive()) {
+                    logger.info("VALUE dataset=" + identifier + " VALUE="
+                        + this.toString());
-			Mapper m;
+            Mapper m;
-			try {
-				m = this.getMapper();
-			catch (VDL2FutureException fe) {
-				m = null; // no mapping info if mapper isn't initialised yet
-			if (m != null) {
-				// TODO proper type here
-				// Not sure catching exception here is really the right thing to
-				// do here
-				// anyway - should perhaps only be trying to map leafnodes?
-				// Mapping
-				// non-leaf stuff is giving wierd paths anyway
+            try {
+                m = this.getMapper();
+            catch (VDL2FutureException fe) {
+                m = null; // no mapping info if mapper isn't initialised yet
+            if (m != null) {
+                // TODO proper type here
+                // Not sure catching exception here is really the right thing to
+                // do here
+                // anyway - should perhaps only be trying to map leafnodes?
+                // Mapping
+                // non-leaf stuff is giving wierd paths anyway
-// TODO this is perhaps an unpleasant way of finding if this is a file-backed
-// leaf node or not
-				boolean filemapped = true;
-				Type type = this.getType();
-				if(type.getName().equals("external")) {
-					filemapped = false;
-				if(type.isPrimitive()) {
-				if(type.isArray()) {
-				if(handles.size()>0) {
+                // TODO this is perhaps an unpleasant way of finding if this is a file-backed
+                // leaf node or not
+                boolean filemapped = true;
+                Type type = this.getType();
+                if(type.getName().equals("external")) {
+                    filemapped = false;
+                if(type.isPrimitive()) {
+                if(type.isArray()) {
+                if(handles.size()>0) {
-				try {
-					if(filemapped) {
-						Object path = m.map(pathFromRoot);
-							logger.info("FILENAME dataset=" + identifier + " filename="
-								+ path);
-						logger.info("NOFILENAME dataset=" + identifier);
+                try {
+                    if(filemapped) {
+                        Object path = m.map(pathFromRoot);
+                            logger.info("FILENAME dataset=" + identifier + " filename="
+                                + path);
+                        logger.info("NOFILENAME dataset=" + identifier);
-			Iterator i = handles.entrySet().iterator();
-				AbstractDataNode node = (AbstractDataNode) e.getValue();
-					logger.info("CONTAINMENT parent=" + identifier + " child="
-							+ node.getIdentifier());
-				node.logContent();
+            //Iterator i = handles.entrySet().iterator();
+            //while (i.hasNext()) {
+            //    Map.Entry e = (Map.Entry) i.next();
+                AbstractDataNode node = (AbstractDataNode) handle;
+                    logger.info("CONTAINMENT parent=" + identifier +
+                        " child=" + node.getIdentifier());
+                node.logContent();
+    public boolean isClosed() {
+        return closed;
-	public boolean isClosed() {
-		return closed;
+    public void closeDeep() {
+        if (!this.closed) {
+            closeShallow();
+                AbstractDataNode mapper = (AbstractDataNode) handle;
+                mapper.closeDeep();
-	public void closeDeep() {
-		if (!this.closed) {
-			closeShallow();
-				AbstractDataNode mapper = (AbstractDataNode) e.getValue();
-				mapper.closeDeep();
-	/** Recursively closes arrays through a tree of arrays and complex
+    /** Recursively closes arrays through a tree of arrays and complex
  	    types. */
-	public void closeDeepStructure() {
-		if (!this.closed && this.getType().isArray()) {
-			closeShallow();
-				AbstractDataNode child = (AbstractDataNode) e.getValue();
-				if(child.getType().isArray()  ||
-				   child.getType().getFields().size() > 0 ) {
-					child.closeDeepStructure();
+    public void closeDeepStructure() {
+        if (!this.closed && this.getType().isArray()) {
+            closeShallow();
+                AbstractDataNode child = (AbstractDataNode) handle;
+                if(child.getType().isArray()  ||
+                        child.getType().getFields().size() > 0 ) {
+                    child.closeDeepStructure();
+    public synchronized Path getPathFromRoot() {
+        if (pathFromRoot == null) {
+            AbstractDataNode parent = (AbstractDataNode) this.getParent();
+            Path myPath;
+            if (parent != null) {
+                myPath = parent.getPathFromRoot();
+                pathFromRoot = myPath.addLast(getField().getName(), parent
+                    .getField().getType().isArray());
+            else {
+                pathFromRoot = Path.EMPTY_PATH;
+        return pathFromRoot;
-	public synchronized Path getPathFromRoot() {
-		if (pathFromRoot == null) {
-			AbstractDataNode parent = (AbstractDataNode) this.getParent();
-			Path myPath;
-			if (parent != null) {
-				myPath = parent.getPathFromRoot();
-				pathFromRoot = myPath.addLast(getField().getName(), parent
-						.getField().getType().isArray());
-			else {
-				pathFromRoot = Path.EMPTY_PATH;
-		return pathFromRoot;
+    public Mapper getMapper() {
+        return ((AbstractDataNode) getRoot()).getMapper();
-	public Mapper getMapper() {
-		return ((AbstractDataNode) getRoot()).getMapper();
+    protected Map<String,DSHandle> getHandles() {
+        return handles;
-	protected Map getHandles() {
-		return handles;
+    public synchronized void addListener(DSHandleListener listener) {
+        if (logger.isDebugEnabled()) {
+            logger.debug("Adding handle listener \"" + listener +
+                "\" to \"" + getIdentifyingString() + "\"");
+        if (listeners == null) {
+            listeners = new ArrayList<DSHandleListener>();
+        listeners.add(listener);
+        if (closed) {
-	public synchronized void addListener(DSHandleListener listener) {
-		if (logger.isDebugEnabled()) {
-			logger.debug("Adding handle listener \"" + listener + "\" to \""
-					+ getIdentifyingString() + "\"");
-		if (listeners == null) {
-			listeners = new LinkedList();
-		listeners.add(listener);
-		if (closed) {
+    protected synchronized void notifyListeners() {
+        if (listeners != null) {
+            for (DSHandleListener listener : listeners) {
+                    logger.debug("Notifying listener \"" + listener
+                        + "\" about \"" + getIdentifyingString() + "\"");
+                listener.handleClosed(this);
+            listeners = null;
-	protected synchronized void notifyListeners() {
-		if (listeners != null) {
-			Iterator i = listeners.iterator();
-				DSHandleListener listener = (DSHandleListener) i.next();
-				i.remove();
-					logger.debug("Notifying listener \"" + listener
-                                                     + "\" about \"" + getIdentifyingString() + "\"");
-				listener.handleClosed(this);
-			listeners = null;
+    public String getIdentifier() {
+        return identifierURI;
-	public String getIdentifier() {
-		return identifierURI;
-	String makeIdentifierURIString() {
-		datasetIDCounter++;
-		return DATASET_URI_PREFIX + datasetIDPartialID + ":" + datasetIDCounter;
+    String makeIdentifierURIString() {
+        datasetIDCounter++;
+        return DATASET_URI_PREFIX + datasetIDPartialID + ":" + datasetIDCounter;
Modified: branches/tests-01/src/org/griphyn/vdl/type/Type.java
--- branches/tests-01/src/org/griphyn/vdl/type/Type.java	2010-07-21 21:25:38 UTC (rev 3453)
+++ branches/tests-01/src/org/griphyn/vdl/type/Type.java	2010-07-21 22:00:25 UTC (rev 3454)
@@ -108,7 +108,7 @@
 	 * @return a list of Fields
-	public List getFields();
+	public List<Field> getFields();
 	 * get the base type of this type as a type can be derived from another type
Modified: branches/tests-01/src/org/griphyn/vdl/type/impl/TypeImpl.java
--- branches/tests-01/src/org/griphyn/vdl/type/impl/TypeImpl.java	2010-07-21 21:25:38 UTC (rev 3453)
+++ branches/tests-01/src/org/griphyn/vdl/type/impl/TypeImpl.java	2010-07-21 22:00:25 UTC (rev 3454)
@@ -80,8 +80,8 @@
 		return list;
-	public List getFields() {
-		return new ArrayList(fields.values());
+	public List<Field> getFields() {
+		return new ArrayList<Field>(fields.values());
 	public Type getBaseType() {
